[MOAB-dev] r2190 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Fri Oct 31 12:28:54 CDT 2008
Author: kraftche
Date: 2008-10-31 12:28:54 -0500 (Fri, 31 Oct 2008)
New Revision: 2190
Modified:
MOAB/trunk/parallel/parallel_unit_tests.cpp
Log:
fix tests: for ghosting more than one layer of elements, the behavior expected by the tests was not the desired behavior
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-31 17:27:13 UTC (rev 2189)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-31 17:28:54 UTC (rev 2190)
@@ -428,6 +428,86 @@
return MB_SUCCESS;
+MBErrorCode get_expected_ghosts( MBInterface& moab,
+ const std::vector<int> partition_geom_ids[4],
+ std::vector<int>& ghost_entity_ids,
+ int ghost_dimension,
+ int bridge_dimension,
+ int num_layers )
+ MBErrorCode rval;
+ MBTag tags[2];
+ rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, tags[0] ); CHKERR(rval);
+ rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, tags[1] ); CHKERR(rval);
+ // get all interface sets
+ MBRange iface_sets;
+ for (int d = 0; d < 3; ++d) {
+ for (size_t i = 0; i < partition_geom_ids[d].size(); ++i) {
+ // get the entity set
+ const void* tag_vals[2] = { &d, &(partition_geom_ids[d][i]) };
+ MBRange ents;
+ rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET,
+ tags, tag_vals, 2,
+ ents ); CHKERR(rval);
+ iface_sets.merge( ents );
+ // for each interface set
+ MBRange ghosts;
+ for (MBRange::iterator i = iface_sets.begin(); i != iface_sets.end(); ++i) {
+ if (num_layers < 1)
+ break;
+ // get iface dim
+ int gdim = -1;
+ rval = moab.tag_get_data( tags[0], &*i, 1, &gdim );
+ CHKERR(rval);
+ // get partitions adjacent to interface set
+ MBRange parents; parents.insert(*i);
+ for (int step = gdim; step < 3; ++step) {
+ MBRange old_parents;
+ old_parents.swap(parents);
+ for (MBRange::iterator p = old_parents.begin(); p != old_parents.end(); ++p) {
+ rval = moab.get_parent_meshsets( *p, parents ); CHKERR(rval);
+ // get entities in adjacent partitions not owned by this proc.
+ MBRange adj_proc_ents;
+ for (MBRange::iterator p = parents.begin(); p != parents.end(); ++p) {
+ int id;
+ rval = moab.tag_get_data( tags[1], &*p, 1, &id ); CHKERR(rval);
+ if (std::find(partition_geom_ids[3].begin(), partition_geom_ids[3].end(), id)
+ != partition_geom_ids[3].end())
+ continue;
+ rval = moab.get_entities_by_dimension( *p, ghost_dimension, adj_proc_ents );
+ CHKERR(rval);
+ // get adjacent entities
+ MBRange iface_ghosts, iface_ents;
+ rval = moab.get_entities_by_dimension( *i, bridge_dimension, iface_ents ); CHKERR(rval);
+ for (int n = 0; n < num_layers; ++n) {
+ iface_ghosts.clear();
+ rval = moab.get_adjacencies( iface_ents, ghost_dimension, false, iface_ghosts, MBInterface::UNION ); CHKERR(rval);
+ iface_ents.clear();
+ rval = moab.get_adjacencies( iface_ghosts, bridge_dimension, false, iface_ents, MBInterface::UNION ); CHKERR(rval);
+ // intersect with entities in adjacent partitions
+ ghosts.merge( iface_ghosts.intersect( adj_proc_ents ) );
+ // get ids
+ ghost_entity_ids.resize( ghosts.size() );
+ rval = moab.tag_get_data( tags[1], ghosts, &ghost_entity_ids[0] );
+ CHKERR(rval);
+ return MB_SUCCESS;
MBErrorCode test_ghost_elements( const char* filename,
@@ -556,7 +636,7 @@
// get the global IDs of teh entities we expect to be ghosted
std::vector<int> expected_ghost_ent_ids;
- rval = get_ghost_entities( moab2, partn_geom_ids, expected_ghost_ent_ids,
+ rval = get_expected_ghosts( moab2, partn_geom_ids, expected_ghost_ent_ids,
ghost_dimension, bridge_dimension, num_layers );
PCHECK(MB_SUCCESS == rval);
