[MOAB-dev] r2278 - in MOAB/trunk: . tools/dagmc
kraftche at mcs.anl.gov
Mon Nov 24 10:03:10 CST 2008
Author: kraftche
Date: 2008-11-24 10:03:10 -0600 (Mon, 24 Nov 2008)
New Revision: 2278
Modified:
MOAB/trunk/configure.in
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/Makefile.am
Log:
fix building of DagMC against Cubit CGM
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2008-11-21 17:08:50 UTC (rev 2277)
+++ MOAB/trunk/configure.in 2008-11-24 16:03:10 UTC (rev 2278)
@@ -803,21 +803,53 @@
AC_MSG_WARN([$CGM_DIR : not a directory.])
fi
CGM_MISSING=no
+ CGM_MAKE=
AC_CHECK_FILE([${CGM_DIR}/lib/cgm.make],
- [CGM_CONFIG_OPTIONS="include ${CGM_DIR}/lib/cgm.make";
+ [CGM_MAKE="${CGM_DIR}/lib/cgm.make";
DEFINES="$DEFINES -DCGM"],
[AC_CHECK_FILE([${CGM_DIR}/cgm.make],
- [CGM_CONFIG_OPTIONS="include ${CGM_DIR}/cgm.make";
+ [CGM_MAKE="${CGM_DIR}/cgm.make";
[AC_MSG_WARN([$CGM_DIR : not a configured CGM]);
CGM_MISSING=yes])
esac
+ if test "x$CGM_MISSING" = "xno"; then
+ CGM_CONFIG_OPTIONS="include $CGM_MAKE"
+ AC_MSG_CHECKING([Checking for GeometryQueryTool::ray_fire(RefFace*,...)])
+ old_CPPFLAGS="$CPPFLAGS"
+ old_LDFLAGS="$LDFLAGS"
+ old_LIBS="$LIBS"
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_DEFINES], [CPPFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_INCLUDES],[CPPFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LTFLAGS], [LDFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LDFLAGS], [LDFLAGS="$CPPFLAGS $make_val"])
+ SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LIBS], [LIBS="$make_val $libs"])
+ AC_LANG_PUSH([C++])
+ AC_LINK_IFELSE(
+ [AC_LANG_PROGRAM([#include "GeometryQueryTool.hpp"
+ #include "CubitVector.hpp"],
+ [CubitVector a,b;
+ DLIList<double> c;
+ GeometryQueryTool::instance()->fire_ray((RefFace*)0, a, b, c );
+ [MOAB_CGM_DEFINES="-DHAVE_CGM_FIRE_RAY"; AC_MSG_RESULT(yes)],
+ [AC_MSG_RESULT(no)])
+ CPPFLAGS="$old_CPPFLAGS"
+ LDFLAGS="$old_LDFLAGS"
+ LIBS="$old_LIBS"
+ AC_LANG_POP([C++])
+ fi
+ AC_SUBST(MOAB_CGM_DEFINES)
AC_SUBST(CGM_DIR)
AC_SUBST(CGM_CONFIG_OPTIONS)
DAGMC_CONFIG_OPTIONS="include \${MOAB_LIBDIR}/dagmc.make"
AC_SUBST(DAGMC_CONFIG_OPTIONS)
fi
AM_CONDITIONAL( HAVE_CGM, [test "x$CGM_MISSING" = "xno"] )
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2008-11-21 17:08:50 UTC (rev 2277)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2008-11-24 16:03:10 UTC (rev 2278)
@@ -123,10 +123,11 @@
#ifdef CGM
if (useCAD) {
-#ifdef CUBIT_CGM
- std::cout << "use_cad = 1 not supported with this build of CGM/DagMC;"
- << std:: endl
- << "need an ACIS-based install of CGM." << std::endl;
+#ifndef HAVE_CGM_FIRE_RAY
+ std::cout << "use_cad = 1 not supported with this build of CGM/DagMC."
+ << std::endl
+ << "Required ray-fire query not available. (Cubit-based CGM?)"
+ << std::endl;
return MB_NOT_IMPLEMENTED;
#else
rval = CAD_ray_intersect(point, dir, huge_val,
@@ -218,11 +219,12 @@
moabMCNPUseDistLimit = !!atoi( options[2].value.c_str() );
useCAD = !!atoi( options[3].value.c_str() );
-#ifdef CUBIT_CGM
if (useCAD) {
std::cout << "Warning: use_cad = 1 not supported with this build of "
<< "CGM/DagMC;" << std:: endl
+ << std::endl;
#endif
@@ -266,11 +268,12 @@
useCAD = !!(use_cad);
std::cout << "Turned " << (useCAD?"ON":"OFF") << " ray firing on full CAD model." << std::endl;
-#ifdef CUBIT_CGM
if (useCAD) {
+ << std::endl;
#endif
@@ -1447,7 +1450,7 @@
double &len)
#ifdef CGM
-#ifdef CUBIT_CGM
#else
std::vector<double>::iterator dit = distances.begin();
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am 2008-11-21 17:08:50 UTC (rev 2277)
+++ MOAB/trunk/tools/dagmc/Makefile.am 2008-11-24 16:03:10 UTC (rev 2278)
@@ -12,7 +12,7 @@
if HAVE_CGM
INCLUDES += $(CGM_INCLUDES)
-CPPFLAGS += $(CGM_CPPFLAGS) -DCGM
+CPPFLAGS += $(CGM_CPPFLAGS) -DCGM $(MOAB_CGM_DEFINES)
CXXFLAGS += $(CGM_CXXFLAGS)
libdagmc_la_SOURCES += cgm2moab.cc
