[MOAB-dev] r2270 - MOAB/trunk/tools/iMesh
    kraftche at mcs.anl.gov
    Tue Nov 18 13:33:06 CST 2008
Author: kraftche
Date: 2008-11-18 13:33:06 -0600 (Tue, 18 Nov 2008)
New Revision: 2270
Modified:
   MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
Log:
o Re-create parallel mesh for each unit test:
  a) prevents tests from interfering with each other
  b) testing correctness, not performance
o Add new test for pushing tag data for ghosted entities
  (previous test was only for interface entities.)
Modified: MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp	2008-11-18 19:30:05 UTC (rev 2269)
+++ MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp	2008-11-18 19:33:06 UTC (rev 2270)
@@ -207,7 +207,8 @@
  * - iMeshP_pushTags
  * - iMeshP_pushTagsEnt
-int test_push_tag_data( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
+int test_push_tag_data_iface( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
+int test_push_tag_data_ghost( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
@@ -391,32 +392,64 @@
                               Main Method
-#define RUN_TEST(A) run_test( &A, #A, imesh, prtn, map )
+#define RUN_TEST(A) run_test( &A, #A )
 int run_test( int (*func)(iMesh_Instance, iMeshP_PartitionHandle, const PartMap&),
-              const char* func_name,
-              iMesh_Instance data,
-              iMeshP_PartitionHandle prtn,
-              const PartMap& map )
+              const char* func_name )
-  int result = (*func)(data,prtn,map);
-  int is_err = is_any_proc_error( result );
-  int rank;
+  int rank, size, ierr;
   MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+  MPI_Comm_size( MPI_COMM_WORLD, &size );
   if (rank == 0) {
+    ierr = create_mesh( FILENAME, size );
+  MPI_Bcast( &ierr, 1, MPI_INT, 0, MPI_COMM_WORLD );
+  if (ierr) {
+    if (rank == 0) {
+      std::cerr << "Failed to create input test file on root processor.  Aborting."
+                << std::endl;
+    abort();
+  iMesh_Instance imesh;
+  iMesh_newMesh( 0, &imesh, &ierr, 0 );
+  PCHECK;
+  iMeshP_PartitionHandle prtn;
+  iMeshP_createPartitionAll( imesh, MPI_COMM_WORLD, &prtn, &ierr );
+  PCHECK;
+  PartMap map;
+  ierr = test_load( imesh, prtn, map, size );
+  if (ierr) {
+    if (rank == 0) {
+      std::cerr << "Failed to load input mesh." << std::endl
+                << "Cannot run further tests." << std::endl
+                << "ABORTING" << std::endl;
+    abort();
+  int result = (*func)(imesh,prtn,map);
+  int is_err = is_any_proc_error( result );
+  if (rank == 0) {
     if (is_err)
       std::cout << func_name << " : FAILED!!" << std::endl;
     else
       std::cout << func_name << " : success" << std::endl;
+  iMesh_dtor( imesh, &ierr );
+  CHKERR;
   return is_err;
 int main( int argc, char* argv[] )
   MPI_Init(&argc, &argv);
-  int size, rank, ierr = 1;
+  int size, rank;
@@ -435,37 +468,7 @@
     MPI_Barrier(MPI_COMM_WORLD);
-  if (rank == 0) {
-    ierr = create_mesh( FILENAME, size );
-  MPI_Bcast( &ierr, 1, MPI_INT, 0, MPI_COMM_WORLD );
-  if (ierr) {
-    if (rank == 0) {
-      std::cerr << "Failed to create input test file on root processor.  Aborting."
-                << std::endl;
-    abort();
-  iMesh_Instance imesh;
-  iMesh_newMesh( 0, &imesh, &ierr, 0 );
-  PCHECK;
-  iMeshP_PartitionHandle prtn;
-  iMeshP_createPartitionAll( imesh, MPI_COMM_WORLD, &prtn, &ierr );
-  PCHECK;
-  PartMap map;
-  int num_errors =  test_load( imesh, prtn, map, size );
-  if (num_errors) {
-    if (rank == 0) {
-      std::cerr << "Failed to load input mesh." << std::endl
-                << "Cannot run further tests." << std::endl
-                << "ABORTING" << std::endl;
-    abort();
+  int num_errors = 0;
   num_errors += RUN_TEST( test_get_partitions );
   num_errors += RUN_TEST( test_get_parts );
   num_errors += RUN_TEST( test_get_by_type );
@@ -481,7 +484,8 @@
   num_errors += RUN_TEST( test_entity_status );
   num_errors += RUN_TEST( test_entity_copy_parts );
   num_errors += RUN_TEST( test_entity_copies );
-  num_errors += RUN_TEST( test_push_tag_data );
+  num_errors += RUN_TEST( test_push_tag_data_iface );
+  num_errors += RUN_TEST( test_push_tag_data_ghost );
   num_errors += RUN_TEST( test_create_ghost_ents );
     // wait until all procs are done before writing summary data
@@ -2543,13 +2547,20 @@
  * - iMeshP_pushTags
-int test_push_tag_data( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& )
+int test_push_tag_data_common( iMesh_Instance imesh,
+                               iMeshP_PartitionHandle prtn,
+                               int num_ghost_layers )
   const char* src_name = "test_src";
   const char* dst_name = "test_dst";
   int ierr, rank;
+  if (num_ghost_layers) {
+    iMeshP_createGhostEntsAll( imesh, prtn, iBase_FACE, iBase_VERTEX, num_ghost_layers, 0, &ierr );
+    PCHECK;
   iBase_TagHandle src_tag, dst_tag;
   iMesh_createTag( imesh, src_name, 1, iBase_INTEGER, &src_tag, &ierr, strlen(src_name) );
   CHKERR;
@@ -2576,26 +2587,43 @@
   tag_vals.clear();
   tag_vals.resize( verts.size(), -1 );
-  int *junk1 = &tag_vals[0], junk2 = tag_vals.size(), junk3;
-  iMesh_getIntArrData( imesh, &verts[0], verts.size(), dst_tag, &junk1, &junk2, &junk3, &ierr );
-  CHKERR;
-  assert( junk1 == &tag_vals[0] );
-  assert( junk2 == (int)tag_vals.size() );
-  assert( junk3 == (int)verts.size() );
+iBase_TagHandle id_tag;
+iMesh_getTagHandle( imesh, "GLOBAL_ID", &id_tag, &ierr, strlen("GLOBAL_ID") );
+std::vector<int> ids(verts.size());
+int* junk1 = &ids[0], junk2 = ids.size(), junk3;
+iMesh_getIntArrData( imesh, &verts[0], verts.size(), id_tag, &junk1, &junk2, &junk3, &ierr );
+PCHECK;
+int errcount = 0;
+for (size_t i = 0; i < verts.size(); ++i) {
+  iMesh_getIntData( imesh, verts[i], dst_tag, &tag_vals[i], &ierr );
+  if (ierr != iBase_SUCCESS) {
+    std::cerr << "Rank " << rank << " : getIntData failed for vertex " << ids[i] << std::endl;
+    std::cerr.flush();
+    ++errcount;
+ASSERT(0 == errcount);
+//  int *junk1 = &tag_vals[0], junk2 = tag_vals.size(), junk3;
+//  iMesh_getIntArrData( imesh, &verts[0], verts.size(), dst_tag, &junk1, &junk2, &junk3, &ierr );
+//  PCHECK;
+//  assert( junk1 == &tag_vals[0] );
+//  assert( junk2 == (int)tag_vals.size() );
+//  assert( junk3 == (int)verts.size() );
   std::vector<int> expected( verts.size() );
   std::vector<iMeshP_Part> parts( verts.size() );
   iMeshP_Part* junk4 = &parts[0];
   junk2 = parts.size();
   iMeshP_getEntOwnerPartArr( imesh, prtn, &verts[0], verts.size(), &junk4, &junk2, &junk3, &ierr );
-  CHKERR;
+  PCHECK;
   assert(junk4 == &parts[0]);
   assert(junk2 == (int)parts.size());
   assert(junk3 == (int)verts.size());
   junk1 = &expected[0];
   junk2 = expected.size();
   iMeshP_getRankOfPartArr( imesh, prtn, &parts[0], parts.size(), &junk1, &junk2, &junk3, &ierr );
-  CHKERR;
+  PCHECK;
   assert(junk1 == &expected[0]);
   assert(junk2 == (int)expected.size());
   assert(junk3 == (int)parts.size());
@@ -2612,10 +2640,10 @@
   tag_vals.clear();
   iMesh_setIntArrData( imesh, &verts[0], verts.size(), src_tag, &tag_vals[0], tag_vals.size(), &ierr );
-  CHKERR;
+  PCHECK;
   iMesh_setIntArrData( imesh, &verts[0], verts.size(), dst_tag, &tag_vals[0], tag_vals.size(), &ierr );
-  CHKERR;
+  PCHECK;
   std::vector<iBase_EntityHandle> some;
@@ -2632,7 +2660,7 @@
   tag_vals.clear();
   tag_vals.resize( some.size(), rank );
   iMesh_setIntArrData( imesh, &some[0], some.size(), src_tag, &tag_vals[0], tag_vals.size(), &ierr );
-  CHKERR;
+  PCHECK;
   iMeshP_pushTagsEnt( imesh, prtn, src_tag, dst_tag, &some[0], some.size(), &ierr );
   PCHECK;
@@ -2651,7 +2679,29 @@
   return iBase_SUCCESS;
+/**\brief Test commuinication of tag data
+ * Test:
+ * - iMeshP_pushTags
+ * - iMeshP_pushTagsEnt
+int test_push_tag_data_iface( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& )
+  return test_push_tag_data_common( imesh, prtn, 0 );
+ * Test:
+int test_push_tag_data_ghost( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& )
+  return test_push_tag_data_common( imesh, prtn, 1 );
                           PartMap class
