[MOAB-dev] r2266 - MOAB/trunk
tautges at mcs.anl.gov
Mon Nov 17 11:53:20 CST 2008
Author: tautges
Date: 2008-11-17 11:53:20 -0600 (Mon, 17 Nov 2008)
New Revision: 2266
Added:
MOAB/trunk/ReadSms.cpp
MOAB/trunk/ReadSms.hpp
Modified:
MOAB/trunk/FileTokenizer.cpp
MOAB/trunk/MBReadUtil.cpp
MOAB/trunk/MBReadUtil.hpp
MOAB/trunk/MBReadUtilIface.hpp
MOAB/trunk/MBReaderWriterSet.cpp
MOAB/trunk/Makefile.am
Log:
Adding reader for RPI Sms files.
Modified: MOAB/trunk/FileTokenizer.cpp
--- MOAB/trunk/FileTokenizer.cpp 2008-11-17 17:36:51 UTC (rev 2265)
+++ MOAB/trunk/FileTokenizer.cpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -468,7 +468,7 @@
if (nextToken != bufferEnd) {
// if requested size is less than buffer contents,
// just pass back part of the buffer
- if (bufferEnd - nextToken <= size) {
+ if (bufferEnd - nextToken <= (int)size) {
memcpy( mem, nextToken, size );
nextToken += size;
return true;
Modified: MOAB/trunk/MBReadUtil.cpp
--- MOAB/trunk/MBReadUtil.cpp 2008-11-17 17:36:51 UTC (rev 2265)
+++ MOAB/trunk/MBReadUtil.cpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -268,3 +268,53 @@
return MB_SUCCESS;
+MBErrorCode MBReadUtil::get_ordered_vertices(MBEntityHandle *bound_ents,
+ int *sense,
+ int bound_size,
+ int dim,
+ MBEntityHandle *bound_verts,
+ MBEntityType &etype)
+ // get dimension of bounding entities
+ int bound_dim = MBCN::Dimension(TYPE_FROM_HANDLE(bound_ents[0]));
+ int indices[MB_MAX_SUB_ENTITY_VERTICES];
+ const MBEntityHandle *connect;
+ std::vector<MBEntityHandle> tmp_connect;
+ // find the right entity type based on # bounding ents
+ int numv = 0, num_connect;
+ MBErrorCode result;
+ for (MBEntityType t = MBEDGE; t < MBENTITYSET; t++) {
+ int nindex = MBCN::NumSubEntities(t, bound_dim);
+ if (MBCN::Dimension(t) != dim || nindex != bound_size)
+ continue;
+ // fill in vertices from bounding entity vertices
+ int nverts = MBCN::VerticesPerEntity(t);
+ std::fill(bound_verts, bound_verts+nverts, 0);
+ for (int index = 0; index < nindex; index++) {
+ result = mMB->get_connectivity(bound_ents[index], connect, num_connect,
+ false, &tmp_connect);
+ if (MB_SUCCESS != result) return result;
+ MBCN::SubEntityVertexIndices(t, bound_dim, index, indices);
+ for (int c = 0; c < num_connect; c++) {
+ if (!bound_verts[indices[c]]) {
+ bound_verts[indices[c]] = (sense[index] > 0) ?
+ connect[c] : connect[num_connect - c - 1];
+ numv++;
+ if (numv == nverts) {
+ etype = t;
+ return MB_SUCCESS;
+ // if we get here, we didn't get full connectivity
+ etype = MBMAXTYPE;
+ return MB_FAILURE;
Modified: MOAB/trunk/MBReadUtil.hpp
--- MOAB/trunk/MBReadUtil.hpp 2008-11-17 17:36:51 UTC (rev 2265)
+++ MOAB/trunk/MBReadUtil.hpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -95,6 +95,15 @@
__attribute__((format(printf,2,3)))
#endif
+ //! given an ordered list of bounding entities and the sense of
+ //! those entities, return an ordered list of vertices
+ MBErrorCode get_ordered_vertices(MBEntityHandle *bound_ents,
+ int *sense,
+ int num_bound,
+ int dim,
+ MBEntityType &etype);
#endif
Modified: MOAB/trunk/MBReadUtilIface.hpp
--- MOAB/trunk/MBReadUtilIface.hpp 2008-11-17 17:36:51 UTC (rev 2265)
+++ MOAB/trunk/MBReadUtilIface.hpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -120,6 +120,15 @@
#endif
= 0;
+ virtual MBErrorCode get_ordered_vertices(MBEntityHandle *bound_ents,
+ int *sense,
+ int num_bound,
+ int dim,
+ MBEntityType &etype) = 0;
#endif
Modified: MOAB/trunk/MBReaderWriterSet.cpp
--- MOAB/trunk/MBReaderWriterSet.cpp 2008-11-17 17:36:51 UTC (rev 2265)
+++ MOAB/trunk/MBReaderWriterSet.cpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -24,6 +24,7 @@
#include "ReadSTL.hpp"
#include "ReadGmsh.hpp"
#include "ReadIDEAS.hpp"
+#include "ReadSms.hpp"
#include "Tqdcfr.hpp"
#include "WriteAns.hpp"
@@ -72,6 +73,8 @@
register_factory( ReadVtk::factory, WriteVtk::factory, "Kitware VTK", "vtk", "VTK" );
+ register_factory( ReadSms::factory, NULL, "RPI SMS", "sms", "SMS" );
register_factory( Tqdcfr::factory, NULL, "Cubit", "cub", "CUBIT" );
#ifdef NETCDF_FILE
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2008-11-17 17:36:51 UTC (rev 2265)
+++ MOAB/trunk/Makefile.am 2008-11-17 17:53:20 UTC (rev 2266)
@@ -152,6 +152,8 @@
RangeMap.hpp \
ReadGmsh.cpp \
ReadGmsh.hpp \
+ ReadSms.hpp \
+ ReadSms.cpp \
ReadSTL.cpp \
ReadSTL.hpp \
ReadVtk.cpp \
Added: MOAB/trunk/ReadSms.cpp
--- MOAB/trunk/ReadSms.cpp (rev 0)
+++ MOAB/trunk/ReadSms.cpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -0,0 +1,398 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+ * \class ReadSms
+ * \brief Sms (http://www.geuz.org/sms) file reader
+ * \author Jason Kraftcheck
+#include "FileTokenizer.hpp" // for file tokenizer
+#include "MBInternals.hpp"
+#include "MBInterface.hpp"
+#include "MBReadUtilIface.hpp"
+#include "MBRange.hpp"
+#include "MBTagConventions.hpp"
+#include "MBParallelConventions.h"
+#include "MBCN.hpp"
+#include <errno.h>
+#include <string.h>
+#include <map>
+#include <set>
+#include <iostream>
+#define CHECK(a) if (MB_SUCCESS != result) { \
+ std::cerr << a << std::endl; \
+ return result; \
+MBReaderIface* ReadSms::factory( MBInterface* iface )
+ { return new ReadSms(iface); }
+ReadSms::ReadSms(MBInterface* impl)
+ : mdbImpl(impl)
+ void* ptr = 0;
+ mdbImpl->query_interface("MBReadUtilIface", &ptr);
+ readMeshIface = reinterpret_cast<MBReadUtilIface*>(ptr);
+ReadSms::~ReadSms()
+ if (readMeshIface) {
+ mdbImpl->release_interface("MBReadUtilIface", readMeshIface);
+ readMeshIface = 0;
+MBErrorCode ReadSms::load_file( const char* filename,
+ MBEntityHandle& file_set,
+ const FileOptions& ,
+ const int* blocks,
+ const int num_blocks )
+ mCurrentMeshHandle = 0;
+ const MBErrorCode result = load_file_impl( filename, blocks, num_blocks );
+ // If file read has failed, destroy anything that was
+ // created during the read.
+ if (MB_SUCCESS != result && mCurrentMeshHandle)
+ MBRange entities;
+ mdbImpl->get_entities_by_handle( mCurrentMeshHandle, entities );
+ entities.insert( mCurrentMeshHandle );
+ mdbImpl->delete_entities( entities );
+ file_set = mCurrentMeshHandle;
+ return result;
+MBErrorCode ReadSms::load_file_impl( const char* filename,
+ const int* material_set_list,
+ const int num_material_sets )
+ bool warned = false;
+ MBErrorCode result = mdbImpl->tag_get_handle( GLOBAL_ID_TAG_NAME, globalId );
+ if (MB_TAG_NOT_FOUND == result)
+ result = mdbImpl->tag_create( GLOBAL_ID_TAG_NAME,
+ sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, globalId, 0 );
+ CHECK("Failed to create gid tag.");
+ result = mdbImpl->tag_get_handle("PARAMETER_COORDS", paramCoords );
+ double dum_params[] = {0.0, 0.0, 0.0};
+ if (MB_TAG_NOT_FOUND == result) {
+ result = mdbImpl->tag_create("PARAMETER_COORDS",
+ 3*sizeof(double), MB_TAG_DENSE,
+ MB_TYPE_DOUBLE, paramCoords, 0 );
+ CHECK("Failed to create param coords tag.");
+ return result;
+ result = mdbImpl->tag_get_handle(GEOM_DIMENSION_TAG_NAME, geomDimension);
+ int dum_dim = -1;
+ result = mdbImpl->tag_create(GEOM_DIMENSION_TAG_NAME,
+ MB_TYPE_INTEGER, geomDimension, &dum_dim);
+ CHECK("Failed to create geom dim tag.");
+ return result;
+ // Create set for more convienient check for material set ids
+ std::set<int> blocks;
+ for (const int* mat_set_end = material_set_list + num_material_sets;
+ material_set_list != mat_set_end; ++material_set_list)
+ blocks.insert( *material_set_list );
+ // Open file
+ FILE* file_ptr = fopen( filename, "r" );
+ if (!file_ptr)
+ readMeshIface->report_error( "%s: %s\n", filename, strerror(errno) );
+ return MB_FILE_DOES_NOT_EXIST;
+ char line[256];
+ int dummy;
+ fscanf(file_ptr, "%s %d", line, &dummy);
+ int nregions, nfaces, nedges, nvertices, npoints;
+ fscanf(file_ptr, "%d %d %d %d %d", &nregions, &nfaces, &nedges,
+ &nvertices, &npoints);
+ // create the vertices
+ std::vector<double*> coord_arrays;
+ MBEntityHandle vstart = 0;
+ result = readMeshIface->get_node_arrays( 3, nvertices, MB_START_ID,
+ vstart, coord_arrays );
+ CHECK("Failed to get node arrays.");
+ return result;
+ MBEntityHandle this_gent, new_handle;
+ std::vector<MBEntityHandle> gentities[4];
+ int gent_id, dum_int;
+ int gent_type, num_connections;
+ for(int i = 0; i < nvertices; i++)
+ fscanf(file_ptr, "%d", &gent_id);
+ if (!gent_id) continue;
+ fscanf(file_ptr,"%d %d %lf %lf %lf", &gent_type, &num_connections,
+ coord_arrays[0]+i, coord_arrays[1]+i, coord_arrays[2]+i);
+ result = get_gentity(gentities, gent_type, gent_id, this_gent);
+ new_handle = vstart + i;
+ result = mdbImpl->add_entities(this_gent, &new_handle, 1);
+ CHECK("Adding vertex to geom set failed.");
+ switch(gent_type)
+ case 1:
+ fscanf(file_ptr, "%le", dum_params);
+ result = mdbImpl->tag_set_data(paramCoords, &new_handle, 1, dum_params);
+ CHECK("Failed to set param coords tag for vertex.");
+ break;
+ case 2:
+ fscanf(file_ptr, "%le %le %d", dum_params, dum_params+1, &dum_int);
+ dum_params[2] = dum_int;
+ break;
+ default: break;
+ } // end of reading vertices
+// Read Edges
+ int vert1, vert2, num_pts;
+ std::vector<MBEntityHandle> everts(2);
+ MBEntityHandle estart, *connect;
+ result = readMeshIface->get_element_array(nedges, 2, MBEDGE, 1, estart, connect);
+ CHECK("Failed to create array of edges.");
+ for(int i = 0; i < nedges; i++)
+ fscanf(file_ptr,"%d",&gent_id);
+ fscanf(file_ptr, "%d %d %d %d %d", &gent_type, &vert1, &vert2,
+ &num_connections, &num_pts);
+ connect[0] = vstart + vert1 - 1;
+ connect[1] = vstart + vert2 - 1;
+ if (num_pts > 1 && !warned) {
+ std::cout << "Warning: num_points > 1 not supported; choosing last one." << std::endl;
+ warned = true;
+ CHECK("Problem getting geom set for edge.");
+ new_handle = estart + i;
+ CHECK("Failed to add edge to geom set.");
+ connect += 2;
+ for(int j = 0; j < num_pts; j++) {
+ switch(gent_type) {
+ case 1:
+ CHECK("Failed to set param coords tag for edge.");
+ break;
+ case 2:
+ break;
+ default:
+ break;
+ } // end of reading edges
+// Read Faces
+ std::vector<MBEntityHandle> bound_ents, bound_verts, new_faces;
+ int bound_id;
+ MBRange shverts;
+ new_faces.resize(nfaces);
+ int num_bounding;
+ for(int i = 0; i < nfaces; i++)
+ if(!gent_id) continue;
+ fscanf(file_ptr,"%d %d", &gent_type, &num_bounding);
+ CHECK("Problem getting geom set for face.");
+ bound_ents.resize(num_bounding+1);
+ bound_verts.resize(num_bounding);
+ for(int j = 0; j < num_bounding; j++) {
+ fscanf(file_ptr, "%d ", &bound_id);
+ if (0 > bound_id) bound_id = abs(bound_id);
+ assert(0 < bound_id && bound_id <= nedges);
+ bound_ents[j] = estart + abs(bound_id) - 1;
+ // convert edge-based model to vertex-based one
+ for (int j = 0; j < num_bounding; j++) {
+ if (j == num_bounding-1) bound_ents[j+1] = bound_ents[0];
+ result = mdbImpl->get_adjacencies(&bound_ents[j], 2, 0, false, shverts);
+ CHECK("Failed to get vertices bounding edge.");
+ assert(shverts.size() == 1);
+ bound_verts[j] = *shverts.begin();
+ shverts.clear();
+ result = mdbImpl->create_element((MBEntityType)(MBTRI+num_bounding-3),
+ &bound_verts[0], bound_verts.size(),
+ new_faces[i]);
+ CHECK("Failed to create edge.");
+ result = mdbImpl->add_entities(this_gent, &new_faces[i], 1);
+ fscanf(file_ptr, "%d", &num_pts);
+ if(!num_pts) continue;
+ case 1:
+ result = mdbImpl->tag_set_data(paramCoords, &new_faces[i], 1, dum_params);
+ CHECK("Failed to set param coords tag for face.");
+ break;
+ case 2:
+ break;
+ default:
+ break;
+ } // end of reading faces
+// Read Regions
+ int sense[MB_MAX_SUB_ENTITIES];
+ bound_verts.resize(MB_MAX_SUB_ENTITIES);
+ for(int i = 0; i < nregions; i++)
+ result = get_gentity(gentities, 3, gent_id, this_gent);
+ CHECK("Couldn't get geom set for region.");
+ fscanf(file_ptr, "%d", &num_bounding);
+ bound_ents.resize(num_bounding);
+ assert(abs(bound_id) < (int)new_faces.size()+1 && bound_id);
+ sense[j] = (bound_id < 0) ? -1 : 1;
+ bound_ents[j] = new_faces[abs(bound_id)-1];
+ MBEntityType etype;
+ result = readMeshIface->get_ordered_vertices(&bound_ents[0], sense,
+ num_bounding,
+ 3, &bound_verts[0], etype);
+ CHECK("Failed in get_ordered_vertices.");
+ // make the element
+ result = mdbImpl->create_element(etype, &bound_verts[0],
+ MBCN::VerticesPerEntity(etype), new_handle);
+ CHECK("Failed to create region.");
+ CHECK("Failed to add region to geom set.");
+ fscanf(file_ptr, "%d ", &dum_int);
+ } // end of reading regions
+MBErrorCode ReadSms::get_gentity(std::vector<MBEntityHandle> *gentities,
+ int gent_type, int gent_id,
+ MBEntityHandle &this_gent)
+ MBErrorCode result = MB_SUCCESS;
+ if ((int)gentities[gent_type].size() <= gent_id ||
+ !gentities[gent_type][gent_id]) {
+ if ((int)gentities[gent_type].size() <= gent_id)
+ gentities[gent_type].resize(gent_id+1, 0);
+ if (!gentities[gent_type][gent_id]) {
+ result = mdbImpl->create_meshset(MESHSET_SET,
+ gentities[gent_type][gent_id]);
+ result = mdbImpl->tag_set_data(globalId,
+ &gentities[gent_type][gent_id], 1,
+ &gent_id);
+ result = mdbImpl->tag_set_data(geomDimension,
+ &gent_type);
+ this_gent = gentities[gent_type][gent_id];
+ return result;
Added: MOAB/trunk/ReadSms.hpp
--- MOAB/trunk/ReadSms.hpp (rev 0)
+++ MOAB/trunk/ReadSms.hpp 2008-11-17 17:53:20 UTC (rev 2266)
@@ -0,0 +1,54 @@
+#ifndef READ_SMS_HPP
+#define READ_SMS_HPP
+#include "MBForward.hpp"
+#include "MBReaderIface.hpp"
+#include <vector>
+class MBReadUtilIface;
+// Base class for binary and ASCII readers
+class ReadSms : public MBReaderIface
+public:
+ //! factory method
+ static MBReaderIface* factory( MBInterface* );
+ MBErrorCode load_file(const char *file_name,
+ const FileOptions& opts,
+ int num_material_sets );
+ //! Constructor
+ ReadSms(MBInterface* impl = NULL);
+ //! Destructor
+ virtual ~ReadSms();
+private:
+ MBErrorCode load_file_impl( const char *file_name,
+ const int num_material_sets );
+ MBErrorCode get_gentity(std::vector<MBEntityHandle> *gentities,
+ MBEntityHandle &this_gent);
+ MBReadUtilIface* readMeshIface;
+ //! interface instance
+ MBInterface* mdbImpl;
+ //! Meshset Handle for the mesh that is currently being read
+ MBEntityHandle mCurrentMeshHandle;
+ MBTag globalId, paramCoords, geomDimension;
+#endif
