[MOAB-dev] r2233 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Wed Nov 12 21:48:56 CST 2008
Author: kraftche
Date: 2008-11-12 21:48:56 -0600 (Wed, 12 Nov 2008)
New Revision: 2233
Modified:
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
Log:
o Fix bug in iMeshP_createPartitionAll
o Implement iMeshP_getPartHandleFromPartId
o Implement iMeshP_getPartHandlesFromPartsIdsArr
o Fix bug in iMeshP_getPartitionComm
o Re-implement broken iMeshP_getNumPartitions
o Re-implement broken iMeshP_getPartitions
o Fix typo in function name: iMeshP_getNumGlobalParts
o Re-implement broken iMeshP_getNumOfTypeAll
o Re-implement broken iMeshP_getNumOfTopoAll
o Re-implement broken iMeshP_isEntOwnerArr
o Partial implementation of iMeshP_syncMeshAll
o Untested implementation of iMeshP_pushTags
o Untested implementation of iMeshP_pushTagsEnt
o Untested partial implementation of iMeshP_createGhostEnts
o Pass necessary options to iMesh_load from iMeshP_load
o Fix bug connecting existing partition instance to newly read file
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-11-13 03:42:02 UTC (rev 2232)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-11-13 03:48:56 UTC (rev 2233)
@@ -13,6 +13,7 @@
#undef IS_BUILDING_MB
#include <assert.h>
+#include <sstream>
#ifdef USE_MPI
#include "mpi.h"
@@ -116,6 +117,15 @@
//DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntitySetHandle )
DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntityHandle )
+template <> inline
+MBTag itaps_cast<MBTag,iBase_TagHandle>( iBase_TagHandle h )
+ { return reinterpret_cast<MBTag>(h); }
+template <> inline
+iBase_TagHandle itaps_cast<iBase_TagHandle,MBTag>( MBTag h )
+ { return reinterpret_cast<iBase_TagHandle>(h); }
#endif
#define PCOMM MBParallelComm::get_pcomm( MBI, itaps_cast<MBEntityHandle>(partition_handle) )
@@ -181,6 +191,45 @@
return iface->get_entities_by_handle( set, entities );
+static inline MBErrorCode remove_not_owned( MBParallelComm* pcomm, MBRange& ents )
+ MBErrorCode rval;
+ std::vector<unsigned char> pstatus(ents.size());
+ rval = pcomm->get_moab()->tag_get_data(pcomm->pstatus_tag(), ents, &pstatus[0]);
+ if (MB_SUCCESS != rval)
+ return rval;
+ MBRange::iterator i = ents.begin();
+ std::vector<unsigned char>::const_iterator j;
+ for (j = pstatus.begin(); j != pstatus.end(); ++j) {
+ if (*j & PSTATUS_NOT_OWNED)
+ i = ents.erase( i );
+ else
+ ++i;
+ return MB_SUCCESS;
+static inline MBErrorCode count_owned( MBParallelComm* pcomm, const MBRange& ents, int& n )
+ MBErrorCode rval;
+ n = 0;
+ return rval;
+ if (!(*j & PSTATUS_NOT_OWNED))
+ ++n;
static void set_intersection_query( iMesh_Instance instance,
iMeshP_PartHandle set1,
iBase_EntitySetHandle set2,
@@ -224,7 +273,7 @@
/*out*/ iMeshP_PartitionHandle *partition_handle,
int *err )
- partition_handle = 0;
+ *partition_handle = 0;
MBTag prtn_tag;
MBErrorCode rval = MBI->tag_create( PARALLEL_PARITIONING_TAG_NAME,
@@ -259,6 +308,72 @@
RETURN (iBase_SUCCESS);
+void iMeshP_getPartIdFromPartHandle( iMesh_Instance instance,
+ const iMeshP_PartitionHandle partition_handle,
+ const iMeshP_PartHandle part_handle,
+ iMeshP_Part *part_id,
+ int *err )
+ int junk1 = 1, junk2;
+ iMeshP_getPartIdsFromPartHandlesArr( instance, partition_handle, &part_handle, 1,
+ &part_id, &junk1, &junk2, err );
+void iMeshP_getPartHandleFromPartId( iMesh_Instance instance,
+ iMeshP_Part part_id,
+ iMeshP_PartHandle *part_handle,
+ int *err )
+ iMeshP_getPartHandlesFromPartsIdsArr( instance, partition_handle, &part_id, 1,
+ &part_handle, &junk1, &junk2, err );
+void iMeshP_getPartIdsFromPartHandlesArr(
+ iMesh_Instance instance,
+ const iMeshP_PartHandle *part_handles,
+ const int part_handles_size,
+ iMeshP_Part **part_ids,
+ int *part_ids_allocated,
+ int *part_ids_size,
+ int *err)
+ MBErrorCode rval;
+ MBParallelComm* pcomm = PCOMM;
+ ALLOCATE_ARRAY( part_ids, part_handles_size );
+ for (int i = 0; i < part_handles_size; ++i) {
+ int id;
+ rval = pcomm->get_part_id( itaps_cast<MBEntityHandle>(part_handles[i]), id );
+ (*part_ids)[i] = id;
+ CHKERR(rval);
+ RETURN(iBase_SUCCESS);
+void iMeshP_getPartHandlesFromPartsIdsArr(
+ const iMeshP_Part *part_ids,
+ const int part_ids_size,
+ iMeshP_PartHandle **part_handles,
+ int *part_handles_allocated,
+ int *part_handles_size,
+ int *err)
+ MBErrorCode rval;
+ ALLOCATE_ARRAY( part_handles, part_ids_size );
+ for (int i = 0; i < part_ids_size; ++i) {
+ MBEntityHandle handle;
+ rval = pcomm->get_part_handle( part_ids[i], handle );
+ CHKERR(rval);
+ (*part_handles)[i] = itaps_cast<iMeshP_PartHandle>(handle);
void iMeshP_getPartitionComm( iMesh_Instance instance,
MPI_Comm* communicator_out,
@@ -267,7 +382,7 @@
if (!pcomm)
RETURN (iBase_FAILURE);
- *communicator_out = pcomm->proc_config().proc_rank();
+ *communicator_out = pcomm->proc_config().proc_comm();
@@ -285,18 +400,17 @@
int* num_partitions_out,
int* err )
- MBTag prtn_tag;
- MBErrorCode rval = MBI->tag_get_handle( PARALLEL_PARITIONING_TAG_NAME, prtn_tag );
- if (MB_TAG_NOT_FOUND == rval) {
- *num_partitions_out = 0;
- RETURN (iBase_SUCCESS);
+ std::vector<MBParallelComm*> pcomms;
+ MBErrorCode rval = MBParallelComm::get_all_pcomm( MBI, pcomms );
CHKERR(rval);
+ std::vector<MBParallelComm*>::iterator i;
+ *num_partitions_out = 0;
+ for (i = pcomms.begin(); i != pcomms.end(); ++i)
+ if ((*i)->get_partitioning())
+ (*num_partitions_out)++;
- rval = MBI->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &prtn_tag, 0, 1,
- *num_partitions_out );
- CHKERR(rval);
+ RETURN (iBase_SUCCESS );
void iMeshP_getPartitions( iMesh_Instance instance,
@@ -305,24 +419,30 @@
int *partition_handle_size,
int *err )
- MBRange range;
- MBTag prtn_tag;
- if (MB_SUCCESS == rval)
- rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &prtn_tag, 0, 1,
- range );
- else if (MB_TAG_NOT_FOUND == rval)
- rval = MB_SUCCESS;
+ CHKERR(rval);
- CHKERR(rval);
- MBRANGE_TO_ITAPS_ARRAY( range, partition_handle );
+ int count = 0;
+ ++count;
+ ALLOCATE_ARRAY( partition_handle, count );
+ *partition_handle_size = 0;
+ (*partition_handle)[(*partition_handle_size)++]
+ = itaps_cast<iMeshP_PartitionHandle>((*i)->get_partitioning());
-void iMeshP_getNumGobalParts( iMesh_Instance instance,
- const iMeshP_PartitionHandle partition_handle,
- int *num_global_part,
- int *err )
+void iMeshP_getNumGlobalParts( iMesh_Instance instance,
+ int *num_global_part,
+ int *err )
if (!pcomm)
@@ -398,14 +518,21 @@
int *num_type,
int *err )
- FIXME; // need to prune out entities that are remote
if (!pcomm)
- iMesh_getNumOfType( instance, entity_set_handle, entity_type, num_type, err );
- int vals[2] = { *num_type, *err }, sums[2];
+ MBRange entities;
+ MBErrorCode rval = get_entities( MBI,
+ itaps_cast<MBEntityHandle>(entity_set_handle),
+ entity_type,
+ iMesh_ALL_TOPOLOGIES,
+ entities );
+ int count = 0;
+ if (MB_SUCCESS == rval)
+ rval = count_owned( pcomm, entities, count );
+ int vals[2] = { count, rval }, sums[2];
int ierr = MPI_Allreduce( vals, sums, 2, MPI_INT, MPI_SUM, pcomm->proc_config().proc_comm() );
assert(iBase_SUCCESS == 0);
if (ierr || sums[1])
@@ -422,14 +549,21 @@
int *num_topo,
int *err )
if (!pcomm)
- iMesh_getNumOfTopo( instance, entity_set_handle, entity_topology, num_topo, err );
- int vals[2] = { *num_topo, *err }, sums[2];
+ MBRange entities;
+ iBase_ALL_TYPES,
+ entity_topology,
+ entities );
+ int count = 0;
@@ -466,47 +600,6 @@
MBRTN( pcomm->destroy_part( itaps_cast<MBEntityHandle>(part_handle) ) );
-void iMeshP_getPartIdFromPartHandle( iMesh_Instance instance,
- const iMeshP_PartHandle part_handle,
- iMeshP_Part *part_id,
- int *err )
- int junk1 = 1, junk2 = 1;
- iMeshP_getPartIdsFromPartHandlesArr( instance,
- partition_handle,
- &part_handle,
- 1,
- &part_id,
- &junk1,
- &junk2,
- err );
-void iMeshP_getPartIdsFromPartHandlesArr( iMesh_Instance instance,
- const iMeshP_PartHandle *part_handles,
- const int part_handles_size,
- iMeshP_Part **part_ids,
- int *part_ids_allocated,
- int *part_ids_size,
- int *err )
- MBParallelComm* pcomm = PCOMM;
- if (!pcomm)
- RETURN (iBase_FAILURE);
- ALLOCATE_ARRAY( part_ids, part_handles_size );
- MBErrorCode rval;
- int id;
- for (int i = 0; i < part_handles_size && MB_SUCCESS == rval; ++i) {
- rval = pcomm->get_part_id( itaps_cast<MBEntityHandle>(part_handles[i]), id );
- (*part_ids)[i] = id;
- MBRTN(rval);
void iMeshP_getNumPartNbors( iMesh_Instance instance,
@@ -607,7 +700,7 @@
int adj_part_id,
MBRange& entities_out)
- int* adj_part_id_ptr = adj_part_id == iMeshP_ALL_PARTS ? 0 : &adj_part_id;
+ int* adj_part_id_ptr = ((unsigned)adj_part_id == iMeshP_ALL_PARTS) ? 0 : &adj_part_id;
MBRange iface_sets;
MBErrorCode rval = pcomm->get_interface_sets(
@@ -1071,10 +1164,26 @@
int* is_owner_size,
int *err )
- iMesh_isEntArrContained( instance, part_handle,
- entity_handles, entity_handles_size,
- is_owner, is_owner_allocated, is_owner_size,
- err );
+ MBErrorCode rval;
+ if (!pcomm)
+ RETURN(iBase_FAILURE);
+ int id;
+ rval = pcomm->get_part_id( itaps_cast<MBEntityHandle>(part_handle), id );
+ CHKERR(rval);
+ ALLOCATE_ARRAY( is_owner, entity_handles_size );
+ *is_owner_size = entity_handles_size;
+ int owner;
+ for (int i = 0; i < entity_handles_size; ++i) {
+ rval = pcomm->get_owner( itaps_cast<MBEntityHandle>(entity_handles[i]), owner );
+ CHKERR(rval);
+ (*is_owner)[i] = (owner == id);
void iMeshP_getEntStatus(iMesh_Instance instance,
@@ -1342,7 +1451,15 @@
void iMeshP_syncMeshAll( iMesh_Instance instance,
int *err )
-{ FIXME; RETURN(iBase_NOT_SUPPORTED); }
+ FIXME; // for now we only sync vertex coordinates
+ // need to update MBParallelComm::update_shared_mesh to fix this
+ MBErrorCode rval = pcomm->update_shared_mesh();
+ CHKERR(rval);
+ RETURN (iBase_SUCCESS);
void iMeshP_pushTags( iMesh_Instance instance,
@@ -1350,7 +1467,31 @@
int entity_type,
int entity_topo,
int *err )
+ MBDimensionPair types;
+ if (entity_topo != iMesh_ALL_TOPOLOGIES)
+ types.first = types.second = mb_topology_table[entity_topo];
+ else if (entity_type != iBase_ALL_TYPES)
+ types = MBCN::TypeDimensionMap[entity_type];
+ else {
+ types.first = MBVERTEX;
+ types.second = MBENTITYSET;
+ --types.second;
+ MBTag tag_handle = itaps_cast<MBTag>(tag);
+ MBErrorCode rval;
+ MBRange entities;
+ for (MBEntityType t = types.first; t <= types.second; ++t) {
+ rval = MBI->get_entities_by_type_and_tag( 0, t, &tag_handle, 0, 1, entities, MBInterface::UNION );
+ CHKERR(rval);
+ rval = pcomm->exchange_tags( itaps_cast<MBTag>(tag), entities );
+ CHKERR(rval);
void iMeshP_pushTagsEnt( iMesh_Instance instance,
@@ -1358,7 +1499,16 @@
const iBase_EntityHandle *entities,
int entities_size,
int *err )
+ MBRange range;
+ const MBEntityHandle* ents = itaps_cast<const MBEntityHandle*>(entities);
+ std::copy( ents, ents+entities_size, mb_range_inserter(range) );
+ MBErrorCode rval = pcomm->exchange_tags( itaps_cast<MBTag>(tag), range );
+ CHKERR(rval);
void iMeshP_iPushTags( iMesh_Instance instance,
@@ -1385,7 +1535,17 @@
int num_layers,
int include_copies,
int *err )
+ if (include_copies) {
+ FIXME; RETURN(iBase_NOT_SUPPORTED);
+ MBErrorCode rval;
+ rval = pcomm->exchange_ghost_cells( ghost_dim, bridge_dim, num_layers, true );
+ CHKERR(rval);
void iMeshP_deleteGhostEnts( iMesh_Instance instance,
@@ -1403,19 +1563,15 @@
int *err )
-static std::string append_option( const char* options,
- int options_len,
- const char* option,
- const char* default_value = 0 )
+static void append_option( std::string& opt,
+ const char* option,
+ const char* default_value = 0 )
std::string::size_type i;
// construct a std::string containing at least the leading
// separator.
- std::string opt( options, options_len );
- if (opt.empty())
- opt = ";";
- char sep = opt[0];
+ char sep = opt.empty() ? ';' : opt[0];
// make sure that the separator is ok (not contained in the option)
const char separators[] = ";:,.!@$#%&*^|/\"'\\~%";
@@ -1427,8 +1583,10 @@
!strchr(option,separators[c]) &&
(!default_value || !strchr(default_value,separators[c])))
break;
- if (c == e)
- return std::string();
+ if (c == e) {
+ opt.clear();
+ return;
i = 0;
while (std::string::npos != (i = opt.find(sep,i)))
@@ -1456,8 +1614,6 @@
opt += default_value;
- return opt;
void iMeshP_load( iMesh_Instance instance,
@@ -1471,36 +1627,38 @@
MBErrorCode rval;
- // make sure 'options' string contains 'PARALLEL'
- std::string opt = append_option( options, options_len, "PARALLEL" );
- if (opt.empty())
- RETURN(iBase_FAILURE);
+ // create partition set if user didn't give us one.
+ MBEntityHandle partitioning;
+ if (partition) {
+ partitioning = itaps_cast<MBEntityHandle>(partition);
+ else {
+ rval = MBI->create_meshset( MESHSET_SET, partitioning );
+ CHKERR(rval);
- // load the file
- iMesh_load( instance, entity_set_handle, name, opt.c_str(), err, name_len, opt.length() );
- if (*err) return;
- // look for most recent pcomm instance
- MBParallelComm* pcomm = 0;
- for (int i = 0; i < MAX_SHARING_PROCS; ++i) {
- MBParallelComm* tmp_pcomm = MBParallelComm::get_pcomm( MBI, i );
- if (tmp_pcomm)
- pcomm = tmp_pcomm;
+ // get MBParallelComm for partition
+ MPI_Comm default_comm = MPI_COMM_WORLD;
+ MBParallelComm* pcomm = MBParallelComm::get_pcomm( MBI, partitioning, &default_comm );
if (!pcomm) {
+ // add necessary values to options string
+ std::string opt( options, options_len );
+ append_option( opt, "PARALLEL" );
+ append_option( opt, "PARTITION_DISTRIBUTE" );
+ append_option( opt, "PARALLEL_RESOLVE_SHARED_ENTS" );
+ std::ostringstream id;
+ id << pcomm->get_id();
+ append_option( opt, "PCOMM", id.str().c_str() );
- // if user-specified partition set, use it instead
- if (partition) {
- MBEntityHandle old_partition = pcomm->get_partitioning();
- if (old_partition)
- MBI->delete_entities( &old_partition, 1 );
- rval = pcomm->set_partitioning( itaps_cast<MBEntityHandle>(partition) );
- CHKERR(rval);
+ // load the file
+ iMesh_load( instance, entity_set_handle, name, opt.c_str(), err, name_len, opt.length() );
+ if (*err) return;
+ rval = pcomm->collective_sync_partition();
+ MBRTN(rval);
void iMeshP_save( iMesh_Instance instance,
