[MOAB-dev] r2204 - MOAB/trunk/parallel
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Nov 3 16:05:57 CST 2008
Author: kraftche
Date: 2008-11-03 16:05:56 -0600 (Mon, 03 Nov 2008)
New Revision: 2204
Modified:
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/MBParallelComm.hpp
Log:
o Remove declaration of function with no implementation
o Add part-based utility methods for use by iMeshP
NOTE: All new code in MBParallelComm assumes one part per processor for now.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2008-11-03 22:04:42 UTC (rev 2203)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2008-11-03 22:05:56 UTC (rev 2204)
@@ -138,7 +138,7 @@
 MBParallelComm::MBParallelComm(MBInterface *impl, MPI_Comm comm, int* id )
     : mbImpl(impl), procConfig(comm), sharedpTag(0), sharedpsTag(0),
       sharedhTag(0), sharedhsTag(0), pstatusTag(0), ifaceSetsTag(0),
-      partitionTag(0)
+      partitionTag(0), globalPartCount(-1), partitioningSet(0)
   myBuffer.resize(INITIAL_BUFF_SIZE);
@@ -166,7 +166,7 @@
                                int* id)
-      partitionTag(0)
   myBuffer.swap(tmp_buff);
   int flag = 1;
@@ -3713,6 +3713,7 @@
     result = new MBParallelComm( impl, *comm, &pcomm_id );
     if (!result)
       return 0;
+    result->set_partitioning( prtn );
     rval = impl->tag_set_data( prtn_tag, &prtn, 1, &pcomm_id );
     if (MB_SUCCESS != rval) {
@@ -3720,7 +3721,7 @@
       result = 0;
   return result;
@@ -3780,6 +3781,218 @@
   return MB_FAILURE;
+MBErrorCode MBParallelComm::get_global_part_count( int& count_out ) const
+  count_out = globalPartCount;
+  return count_out < 0 ? MB_FAILURE : MB_SUCCESS;
+MBErrorCode MBParallelComm::get_part_owner( int part_id, int& owner ) const
+  // FIXME: assumes only 1 local part
+  owner = part_id;
+  return MB_SUCCESS;
+MBErrorCode MBParallelComm::get_part_id( MBEntityHandle /*part*/, int& id_out ) const
+  id_out = proc_config().proc_rank();
+MBErrorCode MBParallelComm::create_part( MBEntityHandle& set_out )
+    // mark as invalid so we know that it needs to be updated
+  globalPartCount = -1;
+    // create set representing part
+  MBErrorCode rval = mbImpl->create_meshset( MESHSET_SET, set_out );
+  if (MB_SUCCESS != rval)
+    return rval;
+    // set tag on set
+    // FIXME: need to assign valid global id
+  int val = 0;
+  rval = mbImpl->tag_set_data( part_tag(), &set_out, 1, &val );
+  if (MB_SUCCESS != rval) {
+    mbImpl->delete_entities( &set_out, 1 );
+    return rval;
+  if (get_partitioning()) {
+    rval = mbImpl->add_entities( get_partitioning(), &set_out, 1 );
+      return rval;
+MBErrorCode MBParallelComm::destroy_part( MBEntityHandle part_id )
+  MBErrorCode rval;
+    rval = mbImpl->remove_entities( get_partitioning(), &part_id, 1 );
+      return rval;
+  return mbImpl->delete_entities( &part_id, 1 );
+MBErrorCode MBParallelComm::collective_sync_partition()
+  int count = partition_sets().size();
+  int err = MPI_Allreduce( &count, &globalPartCount, 1, MPI_INT, MPI_SUM,
+                           proc_config().proc_comm() );
+  return err ? MB_FAILURE : MB_SUCCESS;
+MBErrorCode MBParallelComm::get_part_neighbor_ids( MBEntityHandle part,
+                                                   int neighbors_out[MAX_SHARING_PROCS],
+                                                   int num_neighbors_out )
+  MBErrorCode rval;
+  MBRange iface;
+  rval = get_interface_sets( part, iface );
+  if (MB_SUCCESS != rval);
+    return rval;
+  num_neighbors_out = 0;
+  int n, j = 0;
+  int tmp[MAX_SHARING_PROCS], curr[MAX_SHARING_PROCS];
+  int *parts[2] = { neighbors_out, tmp };
+  for (MBRange::iterator i = iface.begin(); i != iface.end(); ++i) {
+    rval = get_sharing_parts( *i, curr, n );
+      return rval;
+    std::sort( parts, parts+n );
+    int* k = std::set_union( parts[j], parts[j]+num_neighbors_out,
+                             curr, curr + n, parts[1-j] );
+    j = 1-j;
+    num_neighbors_out = k - parts[j];
+  if (parts[j] != neighbors_out)
+    std::copy( parts[j], parts[j]+num_neighbors_out, neighbors_out );
+MBErrorCode MBParallelComm::get_interface_sets( MBEntityHandle ,
+                                                MBRange& iface_sets_out,
+                                                int* adj_part_id )
+    // FIXME : assumes one part per processor.
+    // Need to store part iface sets as children to implement
+    // this correctly.
+  iface_sets_out = interface_sets();
+  if (adj_part_id) {
+    int part_ids[MAX_SHARING_PROCS], num_parts;
+    MBRange::iterator i = iface_sets_out.begin();
+    while (i != iface_sets_out.end()) {
+      MBErrorCode rval = get_sharing_parts( *i, part_ids, num_parts );
+        return rval;
+      if (std::find(part_ids, part_ids+num_parts, *adj_part_id) - part_ids != num_parts)
+        ++i;
+      else
+        i = iface_sets_out.erase( i );
+MBErrorCode MBParallelComm::get_owning_part( MBEntityHandle handle,
+                                             int& owning_part_id,
+                                             MBEntityHandle* owning_handle )
+  // assume get_sharing_parts returns owner first in list.
+  MBErrorCode result;
+  int n, parts[MAX_SHARING_PROCS];
+  if (owning_handle) {
+    MBEntityHandle handles[MAX_SHARING_PROCS];
+    result = get_sharing_parts( handle, parts, n, handles );
+    *owning_handle = handles[0];
+  else {
+    result = get_sharing_parts( handle, parts, n );
+  owning_part_id = parts[0];
+  return result;
+MBErrorCode MBParallelComm::get_sharing_parts( MBEntityHandle entity,
+                                 int part_ids_out[MAX_SHARING_PROCS],
+                                 int& num_part_ids_out,
+                                 MBEntityHandle remote_handles[MAX_SHARING_PROCS] )
+  // FIXME : assumes one part per proc, and therefore part_id == rank
+    // If entity is not shared, then we're the owner.
+  unsigned char pstat;
+  MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &entity, 1,
+                                            &pstat);
+  if (!(pstat & PSTATUS_SHARED)) {
+    part_ids_out[0] = proc_config().proc_rank();
+    num_part_ids_out = 1;
+    if (remote_handles)
+      remote_handles[0] = entity;
+    // If entity is shared with one other proc, then
+    // sharedp_tag will contain a positive value.
+  int other_proc;
+  result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, &other_proc );
+  if (MB_SUCCESS != result)
+    return result;
+  if (-1 != other_proc) {
+      // make sure we return owner first, as other functions
+      // (e.g. get_owning_part) assume that behavior
+    const int my_idx = !(pstat & PSTATUS_NOT_OWNED);
+    const int other_idx = 1 - my_idx;
+      // return this processor and the other one
+    num_part_ids_out = 2;
+    part_ids_out[my_idx] = proc_config().proc_rank();
+    part_ids_out[other_idx] = other_proc;
+      // done?
+    if (!remote_handles)
+      // get handles on remote processors (and this one)
+    remote_handles[my_idx] = entity;
+    return mbImpl->tag_get_data( sharedh_tag(), &entity, 1, remote_handles + other_idx );
+    // If here, then the entity is shared with at least two other processors.
+    // Get the list from the sharedps_tag
+  result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, part_ids_out );
+    return result;
+    // Count number of valid (positive) entries in sharedps_tag
+  for (num_part_ids_out = 0; num_part_ids_out < MAX_SHARING_PROCS &&
+       part_ids_out[num_part_ids_out] >= 0; ++num_part_ids_out);
+    // done?
+    // get remote handles
+  return mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, remote_handles );
 #ifdef TEST_PARALLELCOMM
 #include <iostream>
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp	2008-11-03 22:04:42 UTC (rev 2203)
+++ MOAB/trunk/parallel/MBParallelComm.hpp	2008-11-03 22:05:56 UTC (rev 2204)
@@ -263,13 +263,13 @@
   MBErrorCode get_iface_entities(int other_proc,
                                  int dim,
                                  MBRange &iface_ents);
     //! return partition sets; if tag_name is input, gets sets with
     //! that tag name, otherwise uses PARALLEL_PARTITION tag
   MBErrorCode get_partition_sets(MBEntityHandle this_set,
                                  MBRange &part_sets,
                                  const char *tag_name = NULL);
     //! get processors with which this processor shares an interface
   MBErrorCode get_interface_procs(std::set<unsigned int> &iface_procs);
@@ -333,6 +333,7 @@
     //! return partitions set tag
   MBTag partition_tag();
+  MBTag part_tag() { return partition_tag(); }
     //! return all the entities in parts owned locally
   MBErrorCode get_part_entities(MBRange &ents, int dim = -1);
@@ -360,6 +361,27 @@
                                   bool owned_test = true,
                                   bool shared_test = false );
+  MBEntityHandle get_partitioning() const { return partitioningSet; }
+  void set_partitioning( MBEntityHandle h ) { partitioningSet = h; }
+  MBErrorCode get_global_part_count( int& count_out ) const;
+  MBErrorCode get_part_owner( int part_id, int& owner_out ) const;
+  MBErrorCode get_part_id( MBEntityHandle part, int& id_out ) const;
+  MBErrorCode create_part( MBEntityHandle& part_out );
+  MBErrorCode destroy_part( MBEntityHandle part ) ;
+  MBErrorCode collective_sync_partition();
+  MBErrorCode get_part_neighbor_ids( MBEntityHandle part,
+                                     int num_neighbors_out );
+  MBErrorCode get_interface_sets( MBEntityHandle part,
+                                  int* adj_part_id = 0 );
+  MBErrorCode get_owning_part( MBEntityHandle entity,
+                               int& owning_part_id_out,
+                               MBEntityHandle* owning_handle = 0 );
+  MBErrorCode get_sharing_parts( MBEntityHandle entity,
+                                 MBEntityHandle remote_handles[MAX_SHARING_PROCS] = 0 );
 private:
   int num_subranges(const MBRange &this_range);
@@ -700,6 +722,10 @@
     //! tags used to save sharing procs and handles
   MBTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag,
     ifaceSetsTag, partitionTag;
+  int globalPartCount; //!< Cache of global part count
+  MBEntityHandle partitioningSet; //!< entity set containing all parts
 inline MBErrorCode MBParallelComm::get_shared_proc_tags(MBTag &sharedp,
