[MOAB-dev] r1867 - MOAB/trunk
dcthomp at mcs.anl.gov
Fri May 30 18:45:17 CDT 2008
Author: dcthomp
Date: 2008-05-30 18:45:17 -0500 (Fri, 30 May 2008)
New Revision: 1867
Modified:
MOAB/trunk/CMakeLists.txt
Log:
COMP: Keep up to date with autoconf build
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2008-05-30 20:13:37 UTC (rev 1866)
+++ MOAB/trunk/CMakeLists.txt 2008-05-30 23:45:17 UTC (rev 1867)
@@ -123,6 +123,7 @@
MBAlloc.cpp
MBAxisBox.cpp
MBBits.cpp
+ MBBSPTree.cpp
MBCN.cpp
MBCartVect.cpp
MBElemUtil.cpp
@@ -355,4 +356,10 @@
target_link_libraries( test_mesh_refiner MOAB )
add_test( TestMeshRefiner ${EXECUTABLE_OUTPUT_PATH}/test_mesh_refiner )
+ add_executable( bsp_tree_test bsp_tree_test.cpp )
+ set_source_files_properties( bsp_tree_test.cpp
+ COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
+ target_link_libraries( bsp_tree_test MOAB )
+ add_test( TestBSPTree ${EXECUTABLE_OUTPUT_PATH}/bsp_tree_test )
