[MOAB-dev] r1861 - MOAB/trunk
    kraftche at mcs.anl.gov
    Thu May 29 11:11:59 CDT 2008
Author: kraftche
Date: 2008-05-29 11:11:59 -0500 (Thu, 29 May 2008)
New Revision: 1861
Modified:
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/SequenceManager.hpp
   MOAB/trunk/TypeSequenceManager.hpp
Log:
Optimize MBCore::get_coords( handle_array, ... ) for case where
handles in array are roughly grouped by entity sequence (the
common case being that they're all in the same sequence.)
This only decreases kD-tree build time by about 5%, but it's still
a good optimization.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2008-05-29 14:40:47 UTC (rev 1860)
+++ MOAB/trunk/MBCore.cpp	2008-05-29 16:11:59 UTC (rev 1861)
@@ -668,22 +668,30 @@
                                   const int num_entities,
                                   double *coords) const
-  MBErrorCode status;
   const EntitySequence* seq;
+  const VertexSequence* vseq;
   const MBEntityHandle* const end = entities + num_entities;
-  for(const MBEntityHandle* iter = entities; iter != end; ++iter)
-    if(TYPE_FROM_HANDLE(*iter) != MBVERTEX)
-      return MB_TYPE_OUT_OF_RANGE;
-    status = sequence_manager()->find(*iter, seq);
-    if(status != MB_SUCCESS )
-      return MB_ENTITY_NOT_FOUND;
+  const MBEntityHandle* iter = entities;
+  seq = sequence_manager()->get_last_accessed_sequence( MBVERTEX );
+  if (!seq) // no vertices
+    return num_entities ? MB_ENTITY_NOT_FOUND : MB_SUCCESS;
+  vseq = static_cast<const VertexSequence*>(seq);
+  while (iter != end) {
+    if (vseq->start_handle() > *iter || vseq->end_handle() < *iter) {
+      if (TYPE_FROM_HANDLE(*iter) != MBVERTEX)
+        return MB_TYPE_OUT_OF_RANGE;
+      if (MB_SUCCESS != sequence_manager()->find(*iter, seq))
+        return MB_ENTITY_NOT_FOUND;
-    static_cast<const VertexSequence*>(seq)->get_coordinates(*iter, coords);
+    vseq->get_coordinates( *iter, coords );
     coords += 3;
+    ++iter;
   return MB_SUCCESS;
Modified: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp	2008-05-29 14:40:47 UTC (rev 1860)
+++ MOAB/trunk/SequenceManager.hpp	2008-05-29 16:11:59 UTC (rev 1861)
@@ -44,6 +44,10 @@
       /** Count entities of a given MBEntityType */
     MBEntityID get_number_entities( MBEntityType type ) const
       { return typeData[type].get_number_entities(); }
+      /** Get most recently accessed sequence for a given type */
+    const EntitySequence* get_last_accessed_sequence( MBEntityType type ) const
+      { return typeData[type].get_last_accessed(); }
       /**\brief Replace subset of existing sequence with new
        *        sequence (splits existing sequence)
Modified: MOAB/trunk/TypeSequenceManager.hpp
--- MOAB/trunk/TypeSequenceManager.hpp	2008-05-29 14:40:47 UTC (rev 1860)
+++ MOAB/trunk/TypeSequenceManager.hpp	2008-05-29 16:11:59 UTC (rev 1861)
@@ -176,6 +176,7 @@
   inline EntitySequence* find( MBEntityHandle h );
   inline MBErrorCode find( MBEntityHandle h, EntitySequence*& );
   inline MBErrorCode find( MBEntityHandle h, const EntitySequence*& ) const;
+  inline const EntitySequence* get_last_accessed() const;
     /**\brief Get handles for all entities in all sequences. */
   inline void get_entities( MBRange& entities_out ) const;
@@ -409,7 +410,10 @@
+inline const EntitySequence* TypeSequenceManager::get_last_accessed() const
+  { return lastReferenced; /* only NULL if TypeSequenceManager is empty */ }
 inline void TypeSequenceManager::get_entities( MBRange& entities_out ) const
   MBRange::iterator in = entities_out.begin();
