[MOAB-dev] r1826 - MOAB/trunk/tools/dagmc
kraftche at mcs.anl.gov
Mon May 19 17:04:19 CDT 2008
Author: kraftche
Date: 2008-05-19 17:04:18 -0500 (Mon, 19 May 2008)
New Revision: 1826
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
Fix bug in DagMC::point_in_volume where when the following two
conditions are met:
1) input point is closest to the geometric curve joining two surfaces
(or the geometric vertex joining 3 or more surfaces)
2) the surfaces are used with different senses within the volume
the result may be incorrect.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2008-05-19 20:21:01 UTC (rev 1825)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2008-05-19 22:04:18 UTC (rev 1826)
@@ -596,7 +596,7 @@
rval = moab_instance()->get_coords( conn, len, coords[0].array() );
if (MB_SUCCESS != rval) return rval;
- rval = surface_sense( volume, surfs.front(), sense );
+ rval = surface_sense( volume, surfs[i], sense );
// get triangle normal
