[MOAB-dev] r1797 - MOAB/trunk
bckiedro at mcs.anl.gov bckiedro at mcs.anl.gov
Tue May 6 15:54:34 CDT 2008
Author: bckiedro
Date: 2008-05-06 15:54:34 -0500 (Tue, 06 May 2008)
New Revision: 1797
Added:
   MOAB/trunk/MBElemUtil.cpp
   MOAB/trunk/MBElemUtil.hpp
   MOAB/trunk/ReadIDEAS.cpp
   MOAB/trunk/ReadIDEAS.hpp
Modified:
   MOAB/trunk/MBGeomUtil.cpp
   MOAB/trunk/MBGeomUtil.hpp
   MOAB/trunk/MBReaderWriterSet.cpp
   MOAB/trunk/Makefile.am
Log:
05/06/2008 -- BCK
Added the following capabilities:
* The kd-tree can now handle MBHEX elements
* Support for reading IDEAS .unv file format
MBGeomUtil.cpp : in box_elem_overlap, added a case for MBHEX
                 added box_hex_overlap routine
                 added point_in_trilinear_hex routine (two versions, one with and without acceleration)
MBElemUtil.cpp : created this new file for code relating to element utilities
                 currently contains nat_coords_trilinear_hex that gets natural coordinates of a MBHEX
ReadIDEAS.cpp  : created this new file as part of reader suite to read in IDEAS (.unv) files
MBReaderWriterSet.cpp : added register_factory for IDEAS format
The following header files have been added or modifed
MBGeomUtil.hpp
MBElemUtil.hpp
ReadIDEAS.hpp
Added: MOAB/trunk/MBElemUtil.cpp
--- MOAB/trunk/MBElemUtil.cpp	                        (rev 0)
+++ MOAB/trunk/MBElemUtil.cpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -0,0 +1,133 @@
+#include <iostream>
+#include <assert.h>
+#include "MBElemUtil.hpp"
+// nat_coords_trilinear_hex
+// Given an MBEntityHandle defining a MBHEX element defined by a
+// trilinear basis and a set of xyz points in space, it finds the
+// cooresponding natural coordinates and returns them to the pointer
+// nat.  The method uses an iterative technique, guessing initial
+// coordinates {0, 0, 0} and calculating new coordinates based on the
+// ones just calculated.
+void MBElemUtil::nat_coords_trilinear_hex(MBCartVect hex[8],
+                                          MBCartVect xyz,
+                                          MBCartVect &ncoords,
+                                          double etol)
+      MBCartVect nat(0.);
+      double A[8]; double B[8]; double C[8]; double D[8];
+      double Ax, By, Cz;
+      double err = 1.e37;
+      double xt, yt, zt;
+      double nxi, neta, nmu;
+      double pxi, peta, pmu;
+      double tmp;
+      // Iterative estimate of natural coordinates
+      while ( err > etol ) {
+            // Estimate the xi-coordinate
+            A[0] = (1 - nat[1]) * (1 - nat[2]);
+            A[1] = A[0];
+            A[2] = (1 + nat[1]) * (1 - nat[2]);
+            A[3] = A[2];
+            A[4] = (1 - nat[1]) * (1 + nat[2]);
+            A[5] = A[4];
+            A[6] = (1 + nat[1]) * (1 + nat[2]);
+            A[7] = A[6];
+            Ax = 0;
+            for (unsigned int i = 0; i < 8; i++) {
+                  Ax = Ax + A[i]*hex[i][0];
+            nat[0] = (8*xyz[0] - Ax ) /
+                     (-A[0]*hex[0][0] + A[1]*hex[1][0] + A[2]*hex[2][0] - A[3]*hex[3][0]
+                      -A[4]*hex[4][0] + A[5]*hex[5][0] + A[6]*hex[6][0] - A[7]*hex[7][0]);
+            // Estimate the eta-coordinate
+            B[0] = (1 - nat[0]) * (1 - nat[2]);
+            B[1] = (1 + nat[0]) * (1 - nat[2]);
+            B[2] = B[1];
+            B[3] = B[0];
+            B[4] = (1 - nat[0]) * (1 + nat[2]);
+            B[5] = (1 + nat[0]) * (1 + nat[2]);
+            B[6] = B[5];
+            B[7] = B[4];
+            By = 0;
+                  By = By + B[i]*hex[i][1];
+            nat[1] = (8*xyz[1] - By ) /
+                     (-B[0]*hex[0][1] - B[1]*hex[1][1] + B[2]*hex[2][1] + B[3]*hex[3][1]
+                      -B[4]*hex[4][1] - B[5]*hex[5][1] + B[6]*hex[6][1] + B[7]*hex[7][1]);
+            // Estimate the mu-coordinate
+            C[0] = (1 - nat[0]) * (1 - nat[1]);
+            C[1] = (1 + nat[0]) * (1 - nat[1]);
+            C[2] = (1 + nat[0]) * (1 + nat[1]);
+            C[3] = (1 - nat[0]) * (1 + nat[1]);
+            C[4] = C[0];
+            C[5] = C[1];
+            C[6] = C[2];
+            C[7] = C[3];
+            Cz = 0;
+                  Cz = Cz + C[i]*hex[i][2];
+            nat[2] = (8*xyz[2] - Cz ) /
+                     (-C[0]*hex[0][2] - C[1]*hex[1][2] - C[2]*hex[2][2] - C[3]*hex[3][2]
+                      +C[4]*hex[4][2] + C[5]*hex[5][2] + C[6]*hex[6][2] + C[7]*hex[7][2]);
+            // Shortcut variables...
+            nxi  = 1 - nat[0];
+            neta = 1 - nat[1];
+            nmu  = 1 - nat[2];
+            pxi  = 1 + nat[0];
+            peta = 1 + nat[1];
+            pmu  = 1 + nat[2];
+	    D[0] = nxi * neta * nmu;
+	    D[1] = pxi * neta * nmu;
+	    D[2] = pxi * peta * nmu;
+	    D[3] = nxi * peta * nmu;
+	    D[4] = nxi * neta * pmu;
+	    D[5] = pxi * neta * pmu;
+	    D[6] = pxi * peta * pmu;
+	    D[7] = nxi * peta * pmu;
+            // Compute corresponding estimates for x, y, and z to check
+            xt = 0.125 * ( D[0] * hex[0][0] + D[1] * hex[1][0] +
+                           D[2] * hex[2][0] + D[3] * hex[3][0] +
+                           D[4] * hex[4][0] + D[5] * hex[5][0] +
+                           D[6] * hex[6][0] + D[7] * hex[7][0] );
+            yt = 0.125 * ( D[0] * hex[0][1] + D[1] * hex[1][1] +
+                           D[2] * hex[2][1] + D[3] * hex[3][1] +
+                           D[4] * hex[4][1] + D[5] * hex[5][1] +
+                           D[6] * hex[6][1] + D[7] * hex[7][1] );
+            zt = 0.125 * ( D[0] * hex[0][2] + D[1] * hex[1][2] +
+                           D[2] * hex[2][2] + D[3] * hex[3][2] +
+                           D[4] * hex[4][2] + D[5] * hex[5][2] +
+                           D[6] * hex[6][2] + D[7] * hex[7][2] );
+            // Compute error
+            err = fabs(xt - xyz[0]);
+            tmp = fabs(yt - xyz[1]);
+            if (tmp > err) err = tmp;
+            tmp = fabs(zt - xyz[2]);
+      ncoords = nat;
+      return;
Added: MOAB/trunk/MBElemUtil.hpp
--- MOAB/trunk/MBElemUtil.hpp	                        (rev 0)
+++ MOAB/trunk/MBElemUtil.hpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -0,0 +1,12 @@
+#include "MBCore.hpp"
+#include "MBCartVect.hpp"
+class MBElemUtil {
+  public:
+  static void nat_coords_trilinear_hex(MBCartVect[8],
+                                       MBCartVect,
+                                       MBCartVect&,
+                                       double);
Modified: MOAB/trunk/MBGeomUtil.cpp
--- MOAB/trunk/MBGeomUtil.cpp	2008-05-06 19:05:58 UTC (rev 1796)
+++ MOAB/trunk/MBGeomUtil.cpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -21,9 +21,11 @@
 #include "MBCN.hpp"
 #include "MBGeomUtil.hpp"
 #include <cmath>
 #include <algorithm>
 #include <assert.h>
 #ifdef _MSC_VER
 #  include <float.h>
@@ -269,9 +271,12 @@
                        const MBCartVect& center,
                        const MBCartVect& dims )
   switch (elem_type) {
     case MBTRI:
       return box_tri_overlap( elem_corners, center, dims );
+    case MBHEX:
+      return box_hex_overlap( elem_corners, center, dims );
     case MBPOLYGON:
     case MBPOLYHEDRON:
       assert(false);
@@ -654,4 +659,195 @@
   return closest % closest < tolerance * tolerance;
+bool box_hex_overlap( const MBCartVect hex_vertices[8],
+                      const MBCartVect& box_center,
+                      const MBCartVect& box_dims)
+      // Mapping of vertices to each face on MBHEX
+      const unsigned int facids[] = {0, 1, 5, 4,   1, 2, 6, 5,   2, 3, 7, 6,
+                                     3, 0, 4, 7,   3, 2, 1, 0,   4, 5, 6, 7};
+      // Mapping of vertices to each edge on MBHEX
+      const unsigned int edgids[] = {0, 1,   1, 2,   2, 3,   3, 0,
+                                     0, 4,   1, 5,   2, 6,   3, 7,
+                                     4, 5,   5, 6,   6, 7,   7, 4};
+      const double eps = 1.e-10;
+      // Center the hex such that origin located at the box
+      MBCartVect hexv[8];
+      for (unsigned int i=0; i < 8; i++) {
+            hexv[i] = hex_vertices[i] - box_center;
+      // Check hex against box normals...
+      // Need to check both positive and negative faces
+      double       t;
+      unsigned int positive = 0, negative = 0;
+      unsigned int out_plus = 0, out_minus = 0, inside = 0;
+      bool         test;
+      // Negative face, loop over all vertices in hex
+      for (unsigned int i=0; i < 3; i++) {
+            // vxyz = box_center[i] + box_dims[i];
+            out_plus = 0; out_minus = 0; inside = 0;
+            // Test each vertex on hex...
+            for (unsigned int j=0; j < 8; j++) {
+                  const double bxd = box_dims[i] + eps;
+                  if (hexv[j][i] > bxd )  out_plus++;
+                  else if (hexv[j][i] < -bxd )  out_minus++;
+                  else inside++;
+                  test = ((inside) || ( out_plus && out_minus ));
+                  if (test) break;
+            if (!test) return false;
+      // Construct the vertices of the box...
+      MBCartVect boxv[8];
+      boxv[0][0] = -box_dims[0]; boxv[0][1] = -box_dims[1]; boxv[0][2] = -box_dims[2];
+      boxv[1][0] =  box_dims[0]; boxv[1][1] = -box_dims[1]; boxv[1][2] = -box_dims[2];
+      boxv[2][0] =  box_dims[0]; boxv[2][1] =  box_dims[1]; boxv[2][2] = -box_dims[2];
+      boxv[3][0] = -box_dims[0]; boxv[3][1] =  box_dims[1]; boxv[3][2] = -box_dims[2];
+      boxv[4][0] = -box_dims[0]; boxv[4][1] = -box_dims[1]; boxv[4][2] =  box_dims[2];
+      boxv[5][0] =  box_dims[0]; boxv[5][1] = -box_dims[1]; boxv[5][2] =  box_dims[2];
+      boxv[6][0] =  box_dims[0]; boxv[6][1] =  box_dims[1]; boxv[6][2] =  box_dims[2];
+      boxv[7][0] = -box_dims[0]; boxv[7][1] =  box_dims[1]; boxv[7][2] =  box_dims[2];
+      // Check box against hex normals ...
+      // Loop over each face of hex
+      for (unsigned int i = 0; i < 6; i++ ) {
+            // Compute the normal
+        const MBCartVect midpt1 = 0.5 * (( hexv[(facids[4*i+2])] + hexv[(facids[4*i+3])] )
+                                    - ( hexv[(facids[4*i])]   + hexv[(facids[4*i+1])] ));
+        const MBCartVect midpt2 = 0.5 * (( hexv[(facids[4*i+3])] + hexv[(facids[4*i])]   )
+                                    - ( hexv[(facids[4*i+1])] + hexv[(facids[4*i+2])] ));
+        const MBCartVect normal = midpt1 * midpt2;
+        // Loop over each vertex in the box
+        positive = 0; negative = 0;
+          // Take dot product of the vector and normal
+          t = ( boxv[j] - hexv[(facids[4*i])] ) % normal;
+          // Do the comparison
+          if (t > eps )  positive++;
+          else           negative++;
+          if (positive && negative) break;
+        // std::cout << positive << "  " << negative << std::endl;
+        test = ( (positive && !negative) ? false : true );
+      // Edge check ...
+      // For box, only need to check three edges due to orthogonality
+      int side1, side2;
+      MBCartVect edge_cross;
+      for (unsigned int d = 0; d < 3; d++ ) {
+        // const unsigned int d0 = d % 3;
+        const unsigned int d1 = (d + 1) % 3;
+        const unsigned int d2 = (d + 2) % 3;
+        for (unsigned int i = 0; i < 12; i++) {
+          // edge_cross[d0] = 0.;
+          edge_cross[d1] = hexv[(edgids[2*i])][d2] - hexv[(edgids[2*i+1])][d2];
+          edge_cross[d2] = hexv[(edgids[2*i+1])][d1] - hexv[(edgids[2*i])][d1];
+          if ((edge_cross[d1]*edge_cross[d1] + edge_cross[d2]*edge_cross[d2]) < eps) continue;
+          side1 = side2 = 0;
+          // Hex edge and box vertex tests
+          positive = 0; negative = 0; test = false;
+          for (unsigned int j = 0; j < 8; j++) {
+            // t = edge_cross % ( boxv[j] - hexv[(edgids[2*i])] );
+            t =  edge_cross[d1] * ( boxv[j][d1] - hexv[(edgids[2*i])][d1] )
+               + edge_cross[d2] * ( boxv[j][d2] - hexv[(edgids[2*i])][d2] );
+            if (t > eps) positive++;
+            else if (t < -eps) negative++;
+            if (positive && negative) {
+              test = true;
+              break;
+          if (!test) side1 = ( (positive && !negative) ? +1 : -1 );
+          if (side1 == 0) continue;
+          // Hex edge and hex vertex tests
+            // t = edge_cross % ( hexv[j] - hexv[(edgids[2*i])] );
+              test = true;
+              break;
+          if (!test) side2 = ( (positive && !negative) ? +1 : -1 );
+          if (side2 == 0) continue;
+          // Test if on opposite sides
+          if (side1 * side2 < 0 ) return false;
+      // All possibilities exhausted, must overlap ...
+      return true;
+bool point_in_trilinear_hex(MBCartVect hex[8],
+                            MBCartVect xyz,
+                            double etol)
+      const double one = 1.000001;
+      MBElemUtil::nat_coords_trilinear_hex(hex, xyz, nat, etol);
+      for (unsigned int i = 0; i < 3; i++) {
+            if ((nat[i] > one) || (nat[i] < -one)) return false;
+      return true;
+                            MBCartVect xyz,
+                            MBCartVect box_min, MBCartVect box_max,
+                            double etol)
+      if ((xyz[0] < box_min[0]) || (xyz[0] > box_max[0])) return false;
+      if ((xyz[1] < box_min[1]) || (xyz[1] > box_max[1])) return false;
+      if ((xyz[2] < box_min[2]) || (xyz[2] > box_max[2])) return false;
+      return true;
 } // namespace MBGeoemtry
Modified: MOAB/trunk/MBGeomUtil.hpp
--- MOAB/trunk/MBGeomUtil.hpp	2008-05-06 19:05:58 UTC (rev 1796)
+++ MOAB/trunk/MBGeomUtil.hpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -226,6 +226,36 @@
                               MBCartVect& closest_out,
                               int& closest_topo );
+// Finds whether or not a box defined by the center and the half
+// width intersects a trilinear hex defined by its eight vertices.
+bool box_hex_overlap( const MBCartVect hexv[8],
+                      const MBCartVect& box_dims);
+// point_in_trilinear_hex
+// Tests if a point in xyz space is within a hex element defined with
+// its eight vertex points forming a trilinear basis function.  Computes
+// the natural coordinates with respect to the hex of the xyz point
+// and checks if each are between +/-1.  If anyone is outside the range
+// the function returns false, otherwise it returns true.
+                            MBCartVect xyz,
+                            double etol);
+// its eight vertex points forming a trilinear basis function.  Like the
+// test above except that it gets a bounding box as arguments to filter
+// the test for acceleration.
+                            MBCartVect xyz,
+                            double etol);
 #endif
Modified: MOAB/trunk/MBReaderWriterSet.cpp
--- MOAB/trunk/MBReaderWriterSet.cpp	2008-05-06 19:05:58 UTC (rev 1796)
+++ MOAB/trunk/MBReaderWriterSet.cpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -23,6 +23,7 @@
 #include "ReadVtk.hpp"
 #include "ReadSTL.hpp"
 #include "ReadGmsh.hpp"
+#include "ReadIDEAS.hpp"
 #include "Tqdcfr.hpp"
 #include "WriteAns.hpp"
@@ -66,6 +67,8 @@
   const char* exo_sufxs[] = { "exo", "exoII", "exo2", "g", "gen", NULL };
   register_factory( ReadNCDF::factory, WriteNCDF::factory, "Exodus II", exo_sufxs, "EXODUS" );
 #endif
+  register_factory( ReadIDEAS::factory, NULL, "IDEAS format", "unv", "UNV" );
   register_factory( ReadVtk::factory, WriteVtk::factory, "Kitware VTK", "vtk", "VTK" );
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2008-05-06 19:05:58 UTC (rev 1796)
+++ MOAB/trunk/Makefile.am	2008-05-06 20:54:34 UTC (rev 1797)
@@ -122,6 +122,7 @@
   MBCN.cpp \
   MBCNArrays.hpp \
   MBCartVect.cpp \
+  MBElemUtil.cpp \
   MBHandleUtils.cpp \
   MBMatrix3.cpp \
   MBMatrix3.hpp \
@@ -158,6 +159,8 @@
   ReadSTL.hpp \
   ReadVtk.cpp \
   ReadVtk.hpp \
+  ReadIDEAS.cpp \
+  ReadIDEAS.hpp \
   ScdElementData.cpp \
   ScdElementData.hpp \
   ScdVertexData.cpp \
@@ -216,6 +219,7 @@
   MBCN_protos.h \
   MBCartVect.hpp \
   MBCore.hpp \
+  MBElemUtil.hpp \
   MBEntityType.h \
   MBEntityHandle.h \
   MBError.hpp \
Added: MOAB/trunk/ReadIDEAS.cpp
--- MOAB/trunk/ReadIDEAS.cpp	                        (rev 0)
+++ MOAB/trunk/ReadIDEAS.cpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -0,0 +1,195 @@
+#include <fstream>
+#include <vector>
+#include "assert.h"
+#include "MBInterface.hpp"
+#include "MBInternals.hpp"
+#include "MBReadUtilIface.hpp"
+#include "FileTokenizer.hpp"
+#include "MBRange.hpp"
+MBReaderIface* ReadIDEAS::factory( MBInterface* iface )
+  { return new ReadIDEAS( iface ); }
+ReadIDEAS::ReadIDEAS(MBInterface* impl)
+    : MBI(impl)
+  impl->query_interface("MBReadUtilIface", reinterpret_cast<void**>(&readMeshIface));
+MBErrorCode ReadIDEAS::load_file(const char* fname,
+                                 MBEntityHandle& meshset,
+                                 const FileOptions& options,
+                                 const int* material_set_list,
+                                 int num_material_sets ) {
+  file.open( fname );
+  MBErrorCode rval;
+  rval = MBI->create_meshset(MESHSET_SET, mesh_handle);
+  if (MB_SUCCESS != rval) return rval;
+  char line[10000];
+  file.getline(line, 10000);
+  std::string s = line;
+  if (s.find("-1") > s.length()) return MB_FAILURE;
+  while (! file.eof() ) {
+    s = line;
+    unsigned int header_id = (unsigned int) strtol(line, NULL, 10);
+    switch (header_id) {
+      case VERTEX_LIST :
+        create_vertices();
+      break;
+      case MAKE_TETRAHEDRA :
+        create_tetrahedral_elements();
+      break;
+      default:
+        skip_header();
+      break;
+  meshset = mesh_handle;
+  file.close();
+  return MB_SUCCESS;
+void ReadIDEAS::skip_header() {
+  // Go until finding a pair of -1 lines
+  char *ctmp;
+  char line[10000];
+  std::string s;
+  int end_of_block = 0;
+  long int il;
+    il = std::strtol(line, &ctmp, 10);
+    if (il == -1) {
+      s = ctmp+1;
+      if (s.empty()) end_of_block++;
+    else end_of_block = 0;
+    if (end_of_block >= 2) break;
+void ReadIDEAS::create_vertices() {
+  // Read two lines: first has some data, second has coordinates
+  double *coords;
+  char line1[10000], line2[10000];
+  int il1, il2;
+  char *ctmp1, *ctmp2;
+  std::string s1, s2;
+  MBErrorCode rval;
+  int top_of_block = file.tellg();
+  unsigned int num_verts = 0;
+    file.getline(line1, 10000);
+    file.getline(line2, 10000);
+    // Check if we are at the end of the block
+    il1 = std::strtol(line1, &ctmp1, 10);
+    il2 = std::strtol(line2, &ctmp2, 10);
+    if ((il1 == -1) && (il2 == -1)) {
+      s1 = ctmp1+1;
+      s2 = ctmp2+1;
+      if ((s1.empty()) && (s2.empty())) break;
+    num_verts++;
+  file.seekg( top_of_block );
+  coords = new double [ 3*num_verts ];
+  for (unsigned int i = 0; i < num_verts; i++) {
+    // Get the doubles out of the 2nd line
+    coords[3*i  ] = std::strtod(line2, &ctmp2);
+    coords[3*i+1] = std::strtod(ctmp2+1, &ctmp2);
+    coords[3*i+2] = std::strtod(ctmp2+1, NULL);
+  MBRange verts;
+  rval = MBI->create_vertices(coords, num_verts, verts);
+  assert( MB_SUCCESS == rval );
+  rval = MBI->add_entities( mesh_handle, verts );
+void ReadIDEAS::create_tetrahedral_elements() {
+  MBEntityHandle connect[4];
+  int il1, il2;
+  MBErrorCode rval;
+  MBEntityHandle handle;
+  MBRange verts;
+  rval = MBI->get_entities_by_type( mesh_handle, MBVERTEX, verts, true);
+  MBEntityHandle vstart = *(verts.begin());
+      s1 = ctmp1+1;
+      s2 = ctmp2+1;
+    // Get the connectivity out of the 2nd line
+    connect[0] = vstart + strtol( line2, &ctmp2, 10) - 1;
+    connect[1] = vstart + strtol( ctmp2+1, &ctmp2, 10) - 1;
+    connect[2] = vstart + strtol( ctmp2+1, &ctmp2, 10) - 1;
+    connect[3] = vstart + strtol( ctmp2+1, &ctmp2, 10) - 1;
+    // Make the element
+    rval = MBI->create_element(MBTET, connect, 4, handle);
+    rval = MBI->add_entities( mesh_handle, &handle, 1);
Added: MOAB/trunk/ReadIDEAS.hpp
--- MOAB/trunk/ReadIDEAS.hpp	                        (rev 0)
+++ MOAB/trunk/ReadIDEAS.hpp	2008-05-06 20:54:34 UTC (rev 1797)
@@ -0,0 +1,51 @@
+#include <fstream>
+#include <vector>
+#include "MBReaderIface.hpp"
+#define VERTEX_LIST       2411
+#define MAKE_TETRAHEDRA   2412
+class MBReadUtilIface;
+class ReadIDEAS : public MBReaderIface
+public:
+  static MBReaderIface* factory( MBInterface* );
+MBErrorCode load_file(const char* fname,
+                      const FileOptions&,
+                      int num_material_sets );
+  //! Constructor
+  ReadIDEAS(MBInterface* impl = NULL);
+  //! Destructor
+  virtual ~ReadIDEAS() {}
+protected:
+  void skip_header();
+  void create_vertices();
+  void create_tetrahedral_elements();
+private:
+  std::ifstream file;
+  // Read mesh interface
+  MBReadUtilIface* readMeshIface;
+  // MOAB Interface
+  MBInterface* MBI;
+  // Handle for the mesh
+  MBEntityHandle mesh_handle;
