[MOAB-dev] r1691 - MOAB/trunk/tools/iMesh/SIDL
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Mar 25 11:58:17 CDT 2008
Author: kraftche
Date: 2008-03-25 11:58:17 -0500 (Tue, 25 Mar 2008)
New Revision: 1691
Modified:
   MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp
Log:
Fix broken test:
 - Test expects non-forced tag deletion to fail
 - Non-forced tag deletion fails if the tag is set on any entity
 - Test does not verify that the tag is set on any entities
 - Explicitly set tag on one entity to ensure that tag deletion fails as expected
Modified: MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp
--- MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp	2008-03-25 16:39:22 UTC (rev 1690)
+++ MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp	2008-03-25 16:58:17 UTC (rev 1691)
@@ -2114,7 +2114,19 @@
     // try deleting another unforced - should not get error
     if (all_tags_size > 1) {
       bool delete_err = false;
-      try {mesh_stag.destroyTag(all_tags.get(1), false);}
+      try {
+        int num_ent;
+      	sidl::array<void*> all_ents;
+        sidl::array<char> data = sidl::array<char>::create1d(100);
+        mesh.getEntities( 0, iBase::EntityType_ALL_TYPES, iMesh::EntityTopology_ALL_TOPOLOGIES, all_ents, num_ent );
+        if (num_ent > 0) {
+          mesh_stag.setEntSetData( all_ents.get(0), all_tags.get(1), data, 100 );
+      	  mesh_stag.destroyTag(all_tags.get(1), false);
+        else {
+          delete_err = true;
       catch (iBase::Error) {
         delete_err = true;
