[MOAB-dev] r1684 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Mar 24 15:59:38 CDT 2008
Author: kraftche
Date: 2008-03-24 15:59:38 -0500 (Mon, 24 Mar 2008)
New Revision: 1684
Modified:
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
Log:
fix build errors: apparently I somehow lost some changes before my last checkin of this file
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-03-24 17:21:57 UTC (rev 1683)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-03-24 20:59:38 UTC (rev 1684)
@@ -33,6 +33,7 @@
#include "MBParallelConventions.h"
#include "MBCN.hpp"
#include "MBWriteUtilIface.hpp"
+#include "MBRange.hpp"
#include "WriteHDF5Parallel.hpp"
@@ -695,7 +696,7 @@
assert(MPI_SUCCESS == result);
nodeSet.offset = offset;
- return assign_ids( nodeSet.range(), nodeSet.first_id + nodeSet.offset );
+ return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
@@ -734,14 +735,14 @@
exportList.sort();
// Get number of types each processor has
- long num_types = 2*exportList.size();
- std::vector<long> counts(numProc);
- result = MPI_Gather( &num_types, 1, MPI_LONG, &counts[0], 1, MPI_LONG, 0, MPI_COMM_WORLD );
+ int num_types = 2*exportList.size();
+ std::vector<int> counts(numProc);
+ result = MPI_Gather( &num_types, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, MPI_COMM_WORLD );
// Get list of types on this processor
- std::vector<long> my_types(num_types);
- std::vector<long>::iterator viter = my_types.begin();
+ std::vector<int> my_types(num_types);
+ std::vector<int>::iterator viter = my_types.begin();
for (std::list<ExportSet>::iterator eiter = exportList.begin();
eiter != exportList.end(); ++eiter)
@@ -755,20 +756,20 @@
while (viter != my_types.end())
- long type = *viter; ++viter;
- long count = *viter; ++viter;
+ int type = *viter; ++viter;
+ int count = *viter; ++viter;
printdebug(" %s : %d\n", MBCN::EntityTypeName((MBEntityType)type), count);
END_SERIAL;
#endif
// Get list of types from each processor
- std::vector<long> displs(numProc + 1);
+ std::vector<int> displs(numProc + 1);
displs[0] = 0;
for (long i = 1; i <= numProc; ++i)
displs[i] = displs[i-1] + counts[i-1];
- long total = displs[numProc];
- std::vector<long> alltypes(total);
+ int total = displs[numProc];
+ std::vector<int> alltypes(total);
result = MPI_Gatherv( &my_types[0], my_types.size(), MPI_LONG,
&alltypes[0], &counts[0], &displs[0], MPI_LONG,
@@ -798,7 +799,7 @@
// Send list of types to each processor
- std::vector<long> intlist(total * 2);
+ std::vector<int> intlist(total * 2);
viter = intlist.begin();
for (liter = type_list.begin(); liter != type_list.end(); ++liter)
@@ -814,8 +815,8 @@
while (viter != intlist.end())
END_SERIAL;
@@ -1151,7 +1152,8 @@
2,
data.range );
if (rval != MB_SUCCESS) return rval;
- data.range.swap( data.range.intersect( setSet.range ) );
+ MBRange tmp = data.range.intersect( setSet.range );
+ data.range.swap( tmp );
range_remove( setSet.range, data.range );
@@ -1280,8 +1282,10 @@
std::map<int,int>::iterator p = val_id_map.find( data.local_values[i] );
assert( p != val_id_map.end() );
int id = p->second;
- rval = idMap.insert( *riter, id, 1 );
- assert(MB_SUCCESS == rval);
+ if (idMap.end() == idMap.insert( *riter, id, 1 )) {
+ assert(false);
+ return MB_FAILURE;
return MB_SUCCESS;
@@ -1556,14 +1560,8 @@
remove_remote_entities( *riter, tmp_range );
assert (MB_SUCCESS == rval);
for (MBRange::iterator iter = tmp_range.begin(); iter != tmp_range.end(); ++iter)
- int id = 0;
- rval = iFace->tag_get_data( idTag, &*iter, 1, &id );
- if (rval != MB_TAG_NOT_FOUND && rval != MB_SUCCESS)
- { assert(0); return MB_FAILURE; }
- if (id > 0)
+ if (0 != idMap.find( *iter ))
++*sizes_iter;
++sizes_iter;
// Count children
@@ -1574,15 +1572,8 @@
for (std::vector<MBEntityHandle>::iterator iter = child_list.begin();
iter != child_list.end(); ++iter)
- int id = 0;
- if (id > 0)
++*sizes_iter;
- ++sizes_iter;
// Count parents
*sizes_iter = 0;
@@ -1592,15 +1583,8 @@
- int id = 0;
- if (id > 0)
++*sizes_iter;
- ++sizes_iter;
// Exchange sizes for sets between all processors.
@@ -1792,7 +1776,7 @@
for (MBRange::const_pair_iterator pi = data.range.const_pair_begin();
pi != data.range.const_pair_end(); ++pi)
- idMap.erase( pi->first, pi->second - pi_first + 1);
+ idMap.erase( pi->first, pi->second - pi->first + 1);
j = ids.begin();
for (i = data.range.begin(); i != data.range.end(); ++i)
