[MOAB-dev] r1670 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Mar 17 12:43:24 CDT 2008
Author: kraftche
Date: 2008-03-17 12:43:24 -0500 (Mon, 17 Mar 2008)
New Revision: 1670
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
fix possible buffer overflow
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-03-17 17:09:49 UTC (rev 1669)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-03-17 17:43:24 UTC (rev 1670)
@@ -927,7 +927,7 @@
else {
- static std::vector<int> tag_data;
+ std::vector<unsigned char> tag_data;
std::vector<MBRange>::const_iterator tr_it = tagRanges.begin();
PACK_INT(buff_ptr, allTags.size());
@@ -955,7 +955,7 @@
// name
PACK_CHAR_64(buff_ptr, tinfo->get_name().c_str());
- tag_data.resize((tr_it->size()+1) * tinfo->get_size() / sizeof(int));
+ tag_data.resize(tr_it->size() * tinfo->get_size());
result = mbImpl->tag_get_data(*tag_it, *tr_it, &tag_data[0]);
RR("Failed to get tag data in pack_tags.");
PACK_RANGE(buff_ptr, (*tr_it));
@@ -982,7 +982,6 @@
int num_tags;
UNPACK_INT(buff_ptr, num_tags);
- std::vector<int> tag_data;
std::vector<MBEntityHandle> tag_ents;
for (int i = 0; i < num_tags; i++) {
