[MOAB-dev] r1660 - in MOAB/trunk: . mhdf
kraftche at mcs.anl.gov
Fri Mar 14 14:25:45 CDT 2008
Author: kraftche
Date: 2008-03-14 14:25:43 -0500 (Fri, 14 Mar 2008)
New Revision: 1660
Modified:
MOAB/trunk/Makefile.am
MOAB/trunk/acsite.m4
MOAB/trunk/configure.in
MOAB/trunk/mhdf/Makefile.am
Log:
Clean up handling of NetCDF and HDF5 configuration to some degree:
o Use AM_CPPFLAGS and AM_LDFLAGS rather than INCLUDES and LIBS
o Make detection functions export HDF5_CPPFLAGS and such rather
than modifying CPPFLAGS, LDFLAGS, etc directly.
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2008-03-14 14:17:31 UTC (rev 1659)
+++ MOAB/trunk/Makefile.am 2008-03-14 19:25:43 UTC (rev 1660)
@@ -61,7 +61,7 @@
WriteNCDF.cpp WriteNCDF.hpp \
WriteSLAC.cpp WriteSLAC.hpp
endif
-libMOAB_la_LIBADD =
+libMOAB_la_LIBADD = $(NETCDF_LIBS) $(HDF5_LIBS)
if HDF5_FILE
libMOAB_la_LIBADD += $(top_builddir)/mhdf/libmhdf.la
INCLUDES += -I$(srcdir)/mhdf/include
Modified: MOAB/trunk/acsite.m4
--- MOAB/trunk/acsite.m4 2008-03-14 14:17:31 UTC (rev 1659)
+++ MOAB/trunk/acsite.m4 2008-03-14 19:25:43 UTC (rev 1660)
@@ -295,7 +295,10 @@
# Check for HDF5 library and related stuff
# Sets HAVE_HDF5 to 'yes' or 'no'
-# If HAVE_HDF5 == yes, then updates INCLUDES and LIBS accordingly.
+# If HAVE_HDF5 == yes, then sets:
+# HDF5_CPPFLAGS
+# HDF5_LDFLAGS
+# HDF5_LINK
AC_DEFUN([SNL_CHECK_HDF5],[
@@ -312,7 +315,7 @@
if ! test -d ${WITH_ZLIB}/lib; then
AC_MSG_ERROR([Not a directory: ${WITH_ZLIB}/lib])
fi
- LIBS="$LIBS -L${WITH_ZLIB}/lib"
+ HDF5_LDFLAGS="$HDF5_LDFLAGS -L${WITH_ZLIB}/lib"
esac
HAVE_ZLIB=no
@@ -334,7 +337,7 @@
if ! test -d ${WITH_SZIP}/lib; then
AC_MSG_ERROR([Not a directory: ${WITH_SZIP}/lib])
fi
- LIBS="$LIBS -L${WITH_SZIP}/lib"
+ HDF5_LDFLAGS="$HDF5_LDFLAGS -L${WITH_SZIP}/lib"
esac
HAVE_SZIP=no
@@ -346,16 +349,19 @@
# CLI option for extra HDF5 link flags
AC_ARG_WITH([--with-hdf5-ldflags],[AC_HELP_STRING([--with-hdf5-ldflags=...],
[Extra LDFLAGS required for HDF5 library (e.g. parallel IO lib)])],
- [HDF5_LDFLAGS="$withval"
+ [HDF5_LDFLAGS_WITHVAL="$withval";
DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-hdf5-ldflags=\"${withval}\""
-],[HDF5_LDFLAGS=])
-case "x$HDF5_LDFLAGS" in
+],[HDF5_LDFLAGS_WITHVAL=])
+case "x$HDF5_LDFLAGS_WITHVAL" in
xno)
AC_MSG_ERROR("Invalid argument: --without-hdf5-ldflags")
xyes)
AC_MSG_ERROR("Nonsensical argument: --with-hdf5-ldflags without any specified flags")
+ HDF5_LDFLAGS="$HDF5_LDFLAGS $HDF5_LDFLAGS_WITHVAL"
esac
@@ -379,7 +385,7 @@
HAVE_HDF5=yes
# Check for IBM parallel IO library
if test "x$WITH_MPI" != "xno"; then
- AC_CHECK_LIB([gpfs],[gpfs_stat],[LIBS="-lgpfs $LIBS"])
+ AC_CHECK_LIB([gpfs],[gpfs_stat],[HDF5_LIBS="-lgpfs $HDF5_LIBS"])
fi
# if a path is specified, update LIBS and INCLUDES accordingly
@@ -392,41 +398,43 @@
AC_MSG_ERROR("$HDF5_ARG is not a directory.")
fi
if test -d "${HDF5_ARG}/include"; then
- INCLUDES="$INCLUDES -I${HDF5_ARG}/include"
+ HDF5_CPPFLAGS="$HDF5_CPPFLAGS -I${HDF5_ARG}/include"
else
- INCLUDES="$INCLUDES -I${HDF5_ARG}"
+ HDF5_CPPFLAGS="$HDF5_CPPFLAGS -I${HDF5_ARG}"
fi
fi
# Add flag to defines
+ old_CPPFLAGS="$CPPFLAGS"
+ old_LDFLAGS="$LDFLAGS"
old_LIBS="$LIBS"
- LIBS="$LIBS $HDF5_LDFLAGS"
+ CPPFLAGS="$HDF5_CPPFLAGS $CPPFLAGS"
+ LDFLAGS="$HDF5_LDFLAGS $LDFLAGS"
+ LIBS="$HDF5_LIBS $LIBS"
# check for libraries and headers
- old_CPPFLAGS="$CPPFLAGS"
- CPPFLAGS="$CPPFLAGS $INCLUDES"
AC_CHECK_HEADERS( [hdf5.h], [], [HAVE_HDF5=no] )
- CPPFLAGS="$old_CPPFLAGSS"
HAVE_LIB_HDF5=no
AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes] )
if test $HAVE_LIB_HDF5 = no; then
if test $HAVE_ZLIB = yes; then
unset ac_cv_lib_hdf5_H5Fopen
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; old_LIBS="-lz $old_LIBS"], [], [-lz] )
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="-lz $HDF5_LIBS"], [], [-lz] )
fi
fi
if test $HAVE_SZIP = yes; then
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; old_LIBS="-lsz $old_LIBS"], [], [-lsz] )
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="-lsz $HDF5_LIBS"], [], [-lsz] )
fi
fi
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; old_LIBS="-lsz -lz $old_LIBS"], [], [-lz -lsz] )
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="-lsz -lz $HDF5_LIBS"], [], [-lz -lsz] )
fi
fi
fi
@@ -435,11 +443,17 @@
HAVE_HDF5=no
fi
- if test "x$HAVE_HDF5" = "xyes"; then
- LIBS="$HDF5_LDFLAGS -lhdf5 $old_LIBS"
+ if test "x$HAVE_HDF5" = "xno"; then
+ HDF5_CPPFLAGS=
+ HDF5_LDFLAGS=
+ HDF5_LIBS=
else
- LIBS="$old_LIBS"
+ HDF5_LIBS="$HDF5_LIBS -lhdf5"
fi
+ CPPFLAGS="$old_CPPFLAGS"
+ LDFLAGS="$old_LDFLAGS"
+ LIBS="$old_LIBS"
fi
@@ -451,7 +465,7 @@
# Check for NetCDF library ((C++)
# Sets HAVE_NETCDF to 'yes' or 'no'
-# If HAVE_NETCDF == yes, then updates INCLUDES and LIBS accordingly.
+# If HAVE_NETCDF == yes, then exports NETCDF_CPPFLAGS and NETCDF_LDFLAGS
AC_DEFUN([SNL_CHECK_NETCDF],[
@@ -485,30 +499,29 @@
AC_CHECK_HEADER( [sstream], [NETCDF_DEF="<sstream>"] )
AC_LANG_RESTORE
if test "xyes" != "x$NETCDF_ARG"; then
if test -d "${NETCDF_ARG}/lib"; then
- LIBS="$LIBS -L${NETCDF_ARG}/lib"
+ NETCDF_LDFLAGS="-L${NETCDF_ARG}/lib"
elif test -d "${NETCDF_ARG}"; then
- LIBS="$LIBS -L${NETCDF_ARG}"
+ NETCDF_LDFLAGS="-L${NETCDF_ARG}"
else
AC_MSG_ERROR("$NETCDF_ARG is not a directory.")
fi
if test -d "${NETCDF_ARG}/include"; then
- INCLUDES="$INCLUDES -I${NETCDF_ARG}/include"
+ NETCDF_CPPFLAGS="-I${NETCDF_ARG}/include"
elif test -d "${NETCDF_ARG}/inc"; then
- INCLUDES="$INCLUDES -I${NETCDF_ARG}/inc"
+ NETCDF_CPPFLAGS="-I${NETCDF_ARG}/inc"
else
- INCLUDES="$INCLUDES -I${NETCDF_ARG}"
+ NETCDF_CPPFLAGS="-I${NETCDF_ARG}"
fi
fi
- old_CXXFLAGS="$CXXFLAGS"
- CXXFLAGS="$CXXFLAGS $INCLUDES"
- old_LIBS="$LIBS"
+ CPPFLAGS="$NETCDF_CPPFLAGS $CPPFLAGS"
+ LDFLAGS="$NETCDF_LDFLAGS $LDFLAGS"
# Check for C library
AC_CHECK_HEADERS( [netcdf.h], [], [AC_MSG_WARN([[NetCDF header not found.]]); HAVE_NETCDF=no] )
@@ -527,10 +540,11 @@
HAVE_NETCDF=no
fi
if test "x$NETCDF_DEF" != "x"; then
- CPPFLAGS="$CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
- CXXFLAGS="$CXXFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
+ NETCDF_CPPFLAGS="$NETCDF_CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
+ CPPFLAGS="$CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
fi
AC_MSG_CHECKING([[for netcdf_c++ library]])
+ old_LIBS="$LIBS"
LIBS="$LIBS -lnetcdf_c++ -lnetcdf"
AC_TRY_LINK(
[#include <netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
@@ -538,15 +552,14 @@
[AC_MSG_RESULT([no]);
AC_MSG_ERROR([NetCDF C++ API not found])
HAVE_NETCDF=no] )
+ LIBS="$old_LIBS"
AC_LANG_RESTORE
- CXXFLAGS="$old_CXXFLAGS"
- if test "x$NETCDF_DEF" != "x"; then
- DEFINES="$DEFINES '-DSTRSTREAM_H_SPEC=$NETCDF_DEF'"
- fi
if test "x$HAVE_NETCDF" = "xno"; then
AC_MSG_WARN("NetCDF support disabled")
- LIBS="$old_LIBS"
+ NETCDF_CPPFLAGS=
+ NETCDF_LDFLAGS=
fi
fi
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2008-03-14 14:17:31 UTC (rev 1659)
+++ MOAB/trunk/configure.in 2008-03-14 19:25:43 UTC (rev 1660)
@@ -115,6 +115,12 @@
DEFINES="$DEFINES -DHDF5_FILE"
fi
AM_CONDITIONAL(HDF5_FILE, [test "xno" != "x$HAVE_HDF5"])
+AM_CPPFLAGS="$HDF5_CPPFLAGS $AM_CPPFLAGS"
+AM_LDFLAGS="$HDF5_LDFLAGS $AM_LDFLAGS"
+AC_SUBST(HDF5_LIBS)
+echo "HDF5_CPPFLAGS=$HDF5_CPPFLAGS"
+echo "HDF5_LDFLAGS=$HDF5_LDFLAGS"
+echo "HDF5_LIBS=$HDF5_LIBS"
HAVE_HDF5_PARALLEL=no
if test "xno" != "x$HAVE_HDF5"; then
@@ -136,10 +142,15 @@
SNL_CHECK_NETCDF
if test "xno" = "x$HAVE_NETCDF"; then
AC_MSG_WARN([Support for ExodusII file format disabled])
+ NETCDF_LIBS=
else
DEFINES="$DEFINES -DNETCDF_FILE"
+ NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"
fi
AM_CONDITIONAL(NETCDF_FILE, [test "xno" != "x$HAVE_NETCDF"])
+AM_CPPFLAGS="$NETCDF_CPPFLAGS $AM_CPPFLAGS"
+AM_LDFLAGS="$NETCDF_LDFLAGS $AM_CPPFLAGS"
+AC_SUBST(NETCDF_LIBS)
@@ -749,6 +760,8 @@
AC_SUBST([INCLUDES])
AC_SUBST([DEFINES])
+AC_SUBST([AM_CPPFLAGS])
+AC_SUBST([AM_LDFLAGS])
AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
AC_ARG_VAR([FC], [FORTRAN compiler command])
Modified: MOAB/trunk/mhdf/Makefile.am
--- MOAB/trunk/mhdf/Makefile.am 2008-03-14 14:17:31 UTC (rev 1659)
+++ MOAB/trunk/mhdf/Makefile.am 2008-03-14 19:25:43 UTC (rev 1660)
@@ -1,5 +1,6 @@
noinst_LTLIBRARIES = libmhdf.la
+libmhdf_la_LIBADD = $(HDF5_LIBS)
libmhdf_la_SOURCES = include/mhdf.h \
src/adjacency.c \
