[MOAB-dev] r1654 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Thu Mar 13 15:46:43 CDT 2008
Author: tautges
Date: 2008-03-13 15:46:43 -0500 (Thu, 13 Mar 2008)
New Revision: 1654
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/ReadParallel.cpp
Log:
Add code for determining/adding partition and interface sets.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-03-13 20:44:30 UTC (rev 1653)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-03-13 20:46:43 UTC (rev 1654)
@@ -15,9 +15,8 @@
#include "RangeMap.hpp"
#include <iostream>
+#include <algorithm>
-#define MAX_SHARING_PROCS 10
#define MIN(a,b) (a < b ? a : b)
const bool debug = false;
@@ -1249,19 +1248,18 @@
j = 0; i = 0;
// get vertices shared by 1 or n procs
- std::map<std::vector<int>, MBRange> proc_nranges[MAX_SHARING_PROCS];
- std::map<int, MBRange> proc_ranges;
+ std::map<std::vector<int>, MBRange> proc_nranges;
result = tag_shared_verts(shared_verts, skin_ents,
- proc_ranges, proc_nranges);
+ proc_nranges);
RRA(" ");
// get entities shared by 1 or n procs
result = tag_shared_ents(shared_dim, shared_verts, skin_ents,
+ proc_nranges);
RRA(" ");
// create the sets for each interface
- result = create_interface_sets(proc_ranges, proc_nranges);
+ result = create_interface_sets(proc_nranges);
RRA(" ");
if (0 == shared_dim) return MB_SUCCESS;
@@ -1321,69 +1319,112 @@
return result;
-MBErrorCode MBParallelComm::create_interface_sets(std::map<int, MBRange> &proc_ranges,
- std::map<std::vector<int>, MBRange> *proc_nranges)
+MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges)
MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
pstatus_tag);
RRA(" ");
+ MBRange::iterator rit;
- for (int j = 0; j < MAX_SHARING_PROCS; j++) {
- for (std::map<std::vector<int>,MBRange>::iterator mit = proc_nranges[j].begin();
- mit != proc_nranges[j].end(); mit++) {
- // create the set
- MBEntityHandle new_set;
- result = mbImpl->create_meshset(MESHSET_SET, new_set);
- RR("Failed to create interface set.");
- // add entities
- result = mbImpl->add_entities(new_set, (*mit).second);
- RR("Failed to add entities to interface set.");
- // tag it with the proc ranks
- result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1,
- &((*mit).first)[0]);
- RR("Failed to tag interface set with procs.");
+ MBTag tmp_iface_tag;
+ MBEntityHandle tmp_iface_set = 0;
+ result = mbImpl->tag_create("__tmp_iface", sizeof(MBEntityHandle),
+ MB_TAG_DENSE, MB_TYPE_HANDLE,
+ tmp_iface_tag, &tmp_iface_set);
+ RR("Failed to create temporary iface set tag.");
- // get the owning proc, then set the pstatus tag
- int min_proc = procConfig.proc_size();
- for (int i = 0; i < j+1; i++) min_proc = MIN(min_proc, ((*mit).first)[i]);
- unsigned char pstatus = PSTATUS_SHARED;
- if (min_proc == (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
- result = mbImpl->tag_set_data(pstatus_tag, &new_set, 1, &pstatus);
- RR("Failed to tag interface set with pstatus.");
+ // get all partition sets and mark contents with iface set tag
+ MBTag pset_tag;
+ MBRange iface_sets, tmp_ents, tmp_ents2;
+ result = mbImpl->tag_get_handle(PARALLEL_PARTITION_TAG_NAME, pset_tag);
+ RR("Couldn't get PARALLEL_PARTITION tag, needed to create iface sets.");
+ result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &pset_tag, NULL, 1,
+ iface_sets);
+ RR("Couldn't get PARALLEL_PARTITION sets.");
+ for (rit = iface_sets.begin(); rit != iface_sets.end(); rit++) {
+ result = mbImpl->get_entities_by_handle(*rit, tmp_ents);
+ RR("Failed to get entities in partition set.");
+ std::vector<MBEntityHandle> tag_vals(tmp_ents.size());
+ std::fill(tag_vals.begin(), tag_vals.end(), *rit);
+ result = mbImpl->tag_set_data(tmp_iface_tag, tmp_ents, &tag_vals[0]);
+ RR("Failed to set iface tag on partition ents.");
+ tmp_ents.clear();
- for (std::map<int,MBRange>::iterator mit = proc_ranges.begin();
- mit != proc_ranges.end(); mit++) {
+ // create interface sets, tag them, and tag their contents with iface set tag
+ std::vector<MBEntityHandle> tag_vals;
+ for (std::map<std::vector<int>,MBRange>::iterator mit = proc_nranges.begin();
+ mit != proc_nranges.end(); mit++) {
// create the set
+ result = mbImpl->create_meshset(MESHSET_SET, new_set);
+ iface_sets.insert(new_set);
// add entities
+ result = mbImpl->add_entities(new_set, (*mit).second);
- int sharing_proc = (*mit).first;
- result = mbImpl->tag_set_data(sharedp_tag, &new_set, 1,
- &sharing_proc);
+ // tag set with the proc ranks
+ result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1,
+ &((*mit).first)[0]);
+ // tag entities with interface set
+ tag_vals.resize((*mit).second.size());
+ std::fill(tag_vals.begin(), tag_vals.end(), new_set);
+ result = mbImpl->tag_set_data(tmp_iface_tag, (*mit).second,
+ &tag_vals[0]);
+ RR("Failed to tag iface entities with interface set.");
+ int min_proc = ((*mit).first)[0];
- if (sharing_proc > (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
+ if (min_proc != (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
+ // now go back through interface sets and add parent/child links
+ for (int d = 2; d >= 0; d--) {
+ for (MBRange::iterator rit = iface_sets.begin(); rit != iface_sets.end();
+ rit++) {
+ tmp_ents.clear();
+ RR("Couldn't get entities by dimension.");
+ if (tmp_ents.empty() ||
+ mbImpl->dimension_from_handle(*tmp_ents.rbegin()) != d) continue;
+ // get higher-dimensional entities and their interface sets
+ result = mbImpl->get_adjacencies(&(*tmp_ents.rbegin()), 1, d+1,
+ false, tmp_ents2);
+ RR("Couldn't get adjacencies for interface sets.");
+ tag_vals.resize(tmp_ents2.size());
+ result = mbImpl->tag_get_data(tmp_iface_tag, tmp_ents2, &tag_vals[0]);
+ RR("Couldn't get iface set tag for interface sets.");
+ // go through and for any on interface make it a parent
+ for (unsigned int i = 0; i < tag_vals.size(); i++) {
+ if (tag_vals[i]) {
+ result = mbImpl->add_parent_child(tag_vals[i], *rit);
+ RR("Couldn't add parent/child link for interface set.");
+ // delete the temporary tag
+ result = mbImpl->tag_delete(tmp_iface_tag);
+ RR("Couldn't delete tmp iface tag.");
return MB_SUCCESS;
MBErrorCode MBParallelComm::tag_shared_ents(int shared_dim,
tuple_list &shared_verts,
MBRange *skin_ents,
- std::map<int, MBRange> &proc_ranges,
+ std::map<std::vector<int>, MBRange> &proc_nranges)
// set sharing procs tags on other skin ents
@@ -1423,24 +1464,18 @@
assert(!sp_range.empty());
MBRange::iterator rit2;
// set tag for this ent
- int j = 0;
- for (rit2 = sp_range.begin(); rit2 != sp_range.end(); rit2++)
- if (*rit2 != procConfig.proc_rank()) {
- sharing_procs[j++] = *rit2;
+ int j;
+ for (j = 0, rit2 = sp_range.begin(); rit2 != sp_range.end();
+ rit2++, j++) sharing_procs[j] = *rit2;
+ proc_nranges[sharing_procs].insert(*rit);
if (2 > j) {
result = mbImpl->tag_set_data(sharedp_tag, &(*rit), 1,
&sharing_procs[0]);
- proc_ranges[sharing_procs[0]].insert(*rit);
else {
result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1,
&sharing_procs[0]);
- proc_nranges[j-1][sharing_procs].insert(*rit);
RR("Failed to set sharedp(s)_tag on non-vertex skin entity.");
// reset sharing proc(s) tags
@@ -1453,8 +1488,7 @@
MBErrorCode MBParallelComm::tag_shared_verts(tuple_list &shared_verts,
MBRange *skin_ents,
@@ -1464,8 +1498,7 @@
unsigned int j = 0, i = 0;
std::vector<int> sharing_procs(MAX_SHARING_PROCS);
MBEntityHandle sharing_handles[MAX_SHARING_PROCS];
- int maxp = -1;
- std::fill(sharing_procs.begin(), sharing_procs.end(), maxp);
+ std::fill(sharing_procs.begin(), sharing_procs.end(), -1);
std::fill(sharing_handles, sharing_handles+MAX_SHARING_PROCS, 0);
while (j < 2*shared_verts.n) {
@@ -1479,15 +1512,16 @@
sharing_handles[nump++] = shared_verts.vul[i++];
+ std::sort(&sharing_procs[0], &sharing_procs[nump]);
+ proc_nranges[sharing_procs].insert(this_ent);
if (1 == nump) {
- proc_ranges[sharing_procs[0]].insert(this_ent);
result = mbImpl->tag_set_data(sharedp_tag, &this_ent, 1,
&sharing_procs[0]);
result = mbImpl->tag_set_data(sharedh_tag, &this_ent, 1,
sharing_handles);
else {
- proc_nranges[nump-1][sharing_procs].insert(this_ent);
result = mbImpl->tag_set_data(sharedps_tag, &this_ent, 1,
&sharing_procs[0]);
result = mbImpl->tag_set_data(sharedhs_tag, &this_ent, 1,
@@ -1496,7 +1530,7 @@
RR("Failed setting shared_procs tag on skin vertices.");
std::fill(sharing_handles, sharing_handles+nump, 0);
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-03-13 20:44:30 UTC (rev 1653)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-03-13 20:46:43 UTC (rev 1654)
@@ -42,6 +42,8 @@
template <typename KeyType, typename ValType, ValType NullVal> class RangeMap;
typedef RangeMap<MBEntityHandle, MBEntityHandle, 0> HandleMap;
+#define MAX_SHARING_PROCS 10
class MBParallelComm
public:
@@ -204,17 +206,14 @@
MBErrorCode tag_shared_verts(tuple_list &shared_verts,
MBRange *skin_ents,
- std::map<std::vector<int>, MBRange> *proc_nranges);
+ std::map<std::vector<int>, MBRange> &proc_nranges);
MBErrorCode tag_shared_ents(int shared_dim,
MBRange *skin_ents,
- MBErrorCode create_interface_sets(std::map<int, MBRange> &proc_ranges,
+ MBErrorCode create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges);
//! pack a range map with keys in this_range and values a contiguous series
//! of handles starting at actual_start
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2008-03-13 20:44:30 UTC (rev 1653)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2008-03-13 20:46:43 UTC (rev 1654)
@@ -434,105 +434,20 @@
result = mbImpl->delete_entities(deletable_ents);
RR("Failure deleting entities in delete_nonlocal_entities.");
- return result;
- // get entities in this partition
- int my_rank = (int)mbImpl->proc_config().rank();
- if (my_rank == 0 && mbImpl->proc_config().size() == 1) my_rank = 1;
- int *my_rank_ptr = &my_rank;
- MBTag partition_tag;
- result = mbImpl->tag_get_handle(partition_name.c_str(), partition_tag);
- if (MB_TAG_NOT_FOUND == result) {
- merror->set_last_error( "Couldn't find partition tag\n");
- return result;
+ // mark partition sets with partition tag, needed later for
+ // establishing interface sets
+ MBTag partition_set_tag;
+ result = mbImpl->tag_create(PARALLEL_PARTITION_TAG_NAME, sizeof(int),
+ MB_TAG_SPARSE, MB_TYPE_INTEGER,
+ partition_set_tag, NULL, true);
+ if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) {
+ RR("Couldn't create/get partition set tag.");
- else if (MB_SUCCESS != result) return result;
- MBRange partition_sets;
- result = mbImpl->get_entities_by_type_and_tag(file_set, MBENTITYSET,
- &partition_tag,
- (const void* const *) &my_rank_ptr,
- 1, partition_sets); RR;
- if (MB_SUCCESS != result || partition_sets.empty()) return result;
- MBRange file_ents, partition_ents, exist_ents, all_ents;
+ std::vector<int> pset_vals(partition_sets.size());
+ std::fill(pset_vals.begin(), pset_vals.end(), mbImpl->proc_rank());
+ result = mbImpl->tag_set_data(partition_set_tag, partition_sets,
+ &pset_vals[0]);
+ RR("Couldn't set partition set tag value.");
- for (MBRange::iterator rit = partition_sets.begin();
- rit != partition_sets.end(); rit++) {
- result = mbImpl->get_entities_by_handle(*rit, partition_ents,
- MBInterface::UNION); RR;
- // get pre-existing ents, which are all entities minus file ents
- result = mbImpl->get_entities_by_handle(0, all_ents); RR;
- result = mbImpl->get_entities_by_handle(file_set, file_ents); RR;
- exist_ents = all_ents.subtract(file_ents);
- // merge partition ents into pre-existing entities
- exist_ents.merge(partition_ents);
- // gather adjacent ents of lower dimension and add to existing ents
- MBRange tmp_ents;
- for (int dim = 2; dim >= 0; dim--) {
- MBEntityType lower_type = MBCN::TypeDimensionMap[dim+1].first,
- upper_type = MBCN::TypeDimensionMap[3].second;
- MBRange::const_iterator bit = exist_ents.lower_bound(lower_type),
- eit = exist_ents.upper_bound(upper_type);
- MBRange from_ents;
- from_ents.merge(bit, eit);
- tmp_ents.clear();
- result = mbImpl->get_adjacencies(from_ents, dim, false, tmp_ents,
- exist_ents.merge(tmp_ents);
- // subtract from all ents to get deletable ents
- all_ents = all_ents.subtract(exist_ents);
- // go through the sets to which ones we should keep
- MBRange all_sets, deletable_sets;
- result = mbImpl->get_entities_by_type(0, MBENTITYSET, all_sets);
- for (MBRange::iterator rit = all_sets.begin(); rit != all_sets.end(); rit++) {
- tmp_ents.clear();
- result = mbImpl->get_entities_by_handle(*rit, tmp_ents, true); RR;
- MBRange tmp_ents2 = tmp_ents.intersect(exist_ents);
- // if the intersection is empty, set is deletable
- if (tmp_ents2.empty()) deletable_sets.insert(*rit);
- else if (tmp_ents.size() > tmp_ents2.size()) {
- // more elements in set or contained sets than we're keeping; delete
- // the difference from just this set, to remove entities to be deleted below
- // it's ok if entity isn't contained, doesn't generate an error
- tmp_ents = tmp_ents.subtract(tmp_ents2);
- result = mbImpl->remove_entities(*rit, tmp_ents); RR;
- // take the deletable sets out of other sets so we don't end up
- // with stale set handles
- if (deletable_sets.find(*rit) == deletable_sets.end()) {
- result = mbImpl->remove_entities(*rit, deletable_sets); RR;
- // remove sets from all_ents, since they're dealt with separately
- all_ents = all_ents.subtract(all_sets);
- // now delete sets first, then ents
- result = mbImpl->delete_entities(deletable_sets); RR;
- result = mbImpl->delete_entities(all_ents); RR;
- result = ((MBCore*)mbImpl)->check_adjacencies();
return result;
