[MOAB-dev] r1963 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Jun 30 10:55:02 CDT 2008
Author: kraftche
Date: 2008-06-30 10:55:02 -0500 (Mon, 30 Jun 2008)
New Revision: 1963
Modified:
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
Log:
Don't reserve file ids for interface entities unless we're going to save those entities
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-06-30 15:26:14 UTC (rev 1962)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-06-30 15:55:02 UTC (rev 1963)
@@ -294,6 +294,53 @@
if (MB_SUCCESS != result) return result;
+ // remoteMesh currently contains interface entities for the
+ // entire mesh. We now need to a) remove from the sets of entities
+ // and handles that this proc doesn't own and b) remove from remoteMesh
+ // any handles for entities that we aren't going to write (on any proc.)
+ // First move handles of non-owned entities from lists of entities
+ // that this processor will write to the 'nonowned' list.
+ MBRange tmpset, nonowned;
+ tmpset.clear();
+ result = myPcomm->get_owned_entities( nodeSet.range, tmpset );
+ if (MB_SUCCESS != result)
+ return result;
+ nodeSet.range.swap( tmpset );
+ nonowned.merge( tmpset.subtract( nodeSet.range ) );
+ for (std::list<ExportSet>::iterator eiter = exportList.begin();
+ eiter != exportList.end(); ++eiter ) {
+ tmpset.clear();
+ result = myPcomm->get_owned_entities( eiter->range, tmpset );
+ return result;
+ eiter->range.swap( tmpset );
+ nonowned.merge( tmpset.subtract( eiter->range ) );
+ // Now remove from remoteMesh any entities that are not
+ // in 'nonowned' because we aren't writing those entities
+ // (on any processor.)
+ for (int i = 0; i < myPcomm->proc_config().proc_size(); ++i)
+ if (i != myPcomm->proc_config().proc_rank())
+ remoteMesh[i] = nonowned.intersect( remoteMesh[i] );
+ // For the 'remoteMesh' list for this processor, just remove
+ // entities we aren't writing.
+ MBRange& my_remote_mesh = remoteMesh[myPcomm->proc_config().proc_size()];
+ tmpset = my_remote_mesh.subtract( nodeSet.range );
+ if (!tmpset.empty())
+ my_remote_mesh = my_remote_mesh.subtract( tmpset );
+ tmpset = my_remote_mesh.subtract( eiter->range );
// print some debug output summarizing what we've accomplished
printdebug("Remote mesh:\n");
for (unsigned int ii = 0; ii < myPcomm->proc_config().proc_size(); ++ii)
@@ -337,15 +384,6 @@
rval = gather_interface_meshes();
if (MB_SUCCESS != rval) return rval;
- rval = myPcomm->remove_nonowned_shared(nodeSet.range, -1, true, false);
- if (MB_SUCCESS != rval) return rval;
- for (std::list<ExportSet>::iterator eiter = exportList.begin();
- eiter != exportList.end(); ++eiter ) {
- rval = myPcomm->remove_nonowned_shared(eiter->range, -1, false, false);
/**************** get tag names for sets likely to be shared ***********/
rval = get_sharedset_tags();
