[MOAB-dev] r1955 - MOAB/trunk
tautges at mcs.anl.gov
Sun Jun 29 16:21:09 CDT 2008
Author: tautges
Date: 2008-06-29 16:21:04 -0500 (Sun, 29 Jun 2008)
New Revision: 1955
Modified:
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/Tqdcfr.hpp
Log:
Couple more fixes for cub reader:
- read in mesh for geom entities in order of increasing dimension; this shouldn't be necessary, since
cubit usually writes them out in order already, but it doesn't cost much, so I'll keep it
- fix a bug in which vertex ids get excluded from vertex id map; was assuming monotonically increasing
vertex handles allocated by MOAB, which isn't the case now
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2008-06-29 18:55:17 UTC (rev 1954)
+++ MOAB/trunk/Tqdcfr.cpp 2008-06-29 21:21:04 UTC (rev 1955)
@@ -150,7 +150,7 @@
Tqdcfr::Tqdcfr(MBInterface *impl)
: cubFile(NULL), globalIdTag(0), geomTag(0), uniqueIdTag(0),
blockTag(0), nsTag(0), ssTag(0), attribVectorTag(0), entityNameTag(0),
- categoryTag(0), hasMidNodesTag(0)
+ categoryTag(0), hasMidNodesTag(0), printedSeqWarning(false), printedElemWarning(false)
assert(NULL != impl);
mdbImpl = impl;
@@ -160,7 +160,6 @@
readUtilIface = reinterpret_cast<MBReadUtilIface*>(ptr);
currVHandleOffset = -1;
- firstVHandle = 0;
for (MBEntityType this_type = MBVERTEX; this_type < MBMAXTYPE; this_type++)
currElementIdOffset[this_type] = -1;
@@ -214,8 +213,8 @@
mFileSet = file_set;
// get "before" entities
- MBRange before_ents;
- result = mdbImpl->get_entities_by_handle(0, before_ents);
+ MBRange beforeEnts;
+ result = mdbImpl->get_entities_by_handle(0, beforeEnts);
if (MB_SUCCESS != result) {
readUtilIface->report_error("Couldn't get \"before\" entities.");
return result;
@@ -255,26 +254,31 @@
return result;
- // now read in mesh for each geometry entity
- for (unsigned int gindex = 0;
- gindex < mesh_model->feModelHeader.geomArray.numEntities;
- gindex++) {
- Tqdcfr::GeomHeader *geom_header = &mesh_model->feGeomH[gindex];
+ // now read in mesh for each geometry entity; read in order of increasing dimension
+ // so we have all the mesh we need
+ for (int dim = 0; dim < 4; dim++) {
+ for (unsigned int gindex = 0;
+ gindex < mesh_model->feModelHeader.geomArray.numEntities;
+ gindex++) {
+ Tqdcfr::GeomHeader *geom_header = &mesh_model->feGeomH[gindex];
- // read nodes
- if (debug) std::cout << "Reading geom index " << gindex << " mesh: nodes... ";
- result = read_nodes(gindex, mesh_model, geom_header);
- if (MB_SUCCESS != result)
- return result;
+ if (geom_header->maxDim != dim) continue;
+ // read nodes
+ if (debug) std::cout << "Reading geom index " << gindex << " mesh: nodes... ";
+ result = read_nodes(gindex, mesh_model, geom_header);
+ if (MB_SUCCESS != result)
+ return result;
- // read elements
- if (debug) std::cout << "elements... ";
- result = read_elements(mesh_model, geom_header);
- return result;
- if (debug) std::cout << std::endl;
+ // read elements
+ if (debug) std::cout << "elements... ";
+ result = read_elements(mesh_model, geom_header);
+ return result;
+ if (debug) std::cout << std::endl;
// read acis records...
@@ -364,7 +368,7 @@
return result;
- after_ents = after_ents.subtract(before_ents);
+ after_ents = after_ents.subtract(beforeEnts);
result = mdbImpl->add_entities(mFileSet, after_ents);
return result;
@@ -975,6 +979,15 @@
// get node ids in uint_buf
FREADI(entity->nodeCt);
+ if (debug) {
+ std::cout << "(";
+ for (unsigned int i = 0; i < entity->nodeCt; i++) {
+ std::cout << uint_buf[i];
+ if (i != entity->nodeCt-1) std::cout << ", ";
+ std::cout << ")...";
// get a space for reading nodal data directly into MB, and read that data
MBEntityHandle vhandle = 0;
std::vector<double*> arrays;
@@ -983,8 +996,6 @@
readUtilIface->parallel_rank(),
vhandle, arrays);
- if (!firstVHandle) firstVHandle = vhandle;
// get node x's in arrays[0]
FREADDA(entity->nodeCt, arrays[0]);
// get node y's in arrays[1]
@@ -1016,7 +1027,7 @@
// get all vertices, removing ones in this batch
MBRange vrange, tmp_range(dum_range);
result = mdbImpl->get_entities_by_type(0, MBVERTEX, vrange); RR;
- if (1 != firstVHandle) tmp_range.insert(1, firstVHandle-1);
+ if (!beforeEnts.empty()) tmp_range.merge(beforeEnts.subset_by_type(MBVERTEX));
vrange = vrange.subtract(tmp_range);
// compute the max cid; map is indexed by cid, so size is max_cid+1
#define MAX(a,b) (a > b ? a : b)
@@ -1150,6 +1161,9 @@
// get MB element type from cub file's
MBEntityType elem_type = mp_type_to_mb_type[int_type];
max_dim = (max_dim < MBCN::Dimension(elem_type) ? MBCN::Dimension(elem_type) : max_dim);
+ if (debug)
+ std::cout << "type " << MBCN::EntityTypeName(elem_type) << ":";
// get element ids
FREADI(num_elem);
@@ -1158,8 +1172,10 @@
int contig;
unsigned int max_id, min_id;
check_contiguous(num_elem, contig, min_id, max_id);
- if (0 == contig)
+ if (0 == contig && !printedElemWarning) {
std::cout << "Element ids are not contiguous!" << std::endl;
+ printedElemWarning = true;
// get a space for reading connectivity data directly into MB
MBEntityHandle *conn, start_handle;
@@ -1171,7 +1187,7 @@
MBRange dum_range(start_handle, start_handle+num_elem-1);
long elem_offset;
- elem_offset = start_handle - int_buf[0];
+ elem_offset = (1 == contig ? start_handle - int_buf[0] : int_buf[num_elem-1]);
if (-1 == currElementIdOffset[elem_type])
currElementIdOffset[elem_type] = elem_offset;
@@ -1188,13 +1204,13 @@
// post-process connectivity into handles
MBEntityHandle new_handle;
for (unsigned int j = 0; j < total_conn; j++) {
+ if (debug) {
+ if (0 == j) std::cout << "Conn=";
+ std::cout << ", " << uint_buf[j];
if (NULL == cubMOABVertexMap)
new_handle = (MBEntityHandle) currVHandleOffset+uint_buf[j];
else {
- if (debug) {
- if (0 == i) std::cout << "Conn";
- std::cout << ", " << uint_buf[j];
assert(uint_buf[j] < cubMOABVertexMap->size() &&
0 != (*cubMOABVertexMap)[uint_buf[j]]);
new_handle = (*cubMOABVertexMap)[uint_buf[j]];
@@ -1475,6 +1491,25 @@
instance->uidSetMap[geom_headers[i].geomID] = geom_headers[i].setHandle;
+ // now get the dimensions of elements for each geom entity
+ for (unsigned int i = 0; i < info.numEntities; i++) {
+ if (geom_headers[i].elemTypeCt == 0) continue;
+ instance->FSEEK(model_offset+geom_headers[i].elemOffset);
+ for (unsigned int j = 0; j < geom_headers[i].elemTypeCt; j++) {
+ // for this elem type, get the type, nodes per elem, num elems
+ instance->FREADI(3);
+ int int_type = instance->uint_buf[0];
+ int nodes_per_elem = instance->uint_buf[1];
+ int num_elem = instance->uint_buf[2];
+ MBEntityType elem_type = mp_type_to_mb_type[int_type];
+ geom_headers[i].maxDim = std::max(geom_headers[i].maxDim,
+ (int)MBCN::Dimension(elem_type));
+ if (j < geom_headers[i].elemTypeCt-1)
+ instance->FREADI(num_elem + num_elem*nodes_per_elem);
return MB_SUCCESS;
@@ -1717,7 +1752,10 @@
if (!debug) return;
std::cout << prefix << std::endl;
if (NULL != header)
- for (unsigned int i = 0; i < num_headers; i++) header[i].print();
+ for (unsigned int i = 0; i < num_headers; i++) {
+ std::cout << "Index " << i << std::endl;
+ header[i].print();
void Tqdcfr::ModelEntry::print_group_headers(const char *prefix,
@@ -2249,8 +2287,10 @@
if (this_record.rec_type != Tqdcfr::UNKNOWN) {
// print a warning if it looks like there are sequence numbers
- if (type_substr != this_record.att_string.c_str())
+ if (type_substr != this_record.att_string.c_str() && !printedSeqWarning) {
std::cout << "Warning: acis file has sequence numbers!" << std::endl;
+ printedSeqWarning = true;
// scan ahead to the next white space
type_substr = strchr(type_substr, ' ');
@@ -2310,7 +2350,7 @@
Tqdcfr::GeomHeader::GeomHeader()
: geomID(0), nodeCt(0), nodeOffset(0), elemCt(0), elemOffset(0),
- elemTypeCt(0), elemLength(0), setHandle(0)
+ elemTypeCt(0), elemLength(0), maxDim(0), setHandle(0)
void Tqdcfr::GeomHeader::print()
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp 2008-06-29 18:55:17 UTC (rev 1954)
+++ MOAB/trunk/Tqdcfr.hpp 2008-06-29 21:21:04 UTC (rev 1955)
@@ -24,6 +24,7 @@
#include "MBForward.hpp"
#include "MBReaderIface.hpp"
#include "MBTagConventions.hpp"
+#include "MBRange.hpp"
#include <stdio.h>
#include <string>
@@ -121,6 +122,8 @@
unsigned int geomID, nodeCt, nodeOffset, elemCt, elemOffset,
elemTypeCt, elemLength;
+ int maxDim;
MBEntityHandle setHandle;
void print();
@@ -274,7 +277,7 @@
std::vector<ModelEntry> modelEntries;
MetaDataContainer modelMetaData;
long currVHandleOffset;
- MBEntityHandle firstVHandle;
long currElementIdOffset[MBMAXTYPE];
MBTag globalIdTag, cubIdTag, geomTag, uniqueIdTag, blockTag, nsTag, ssTag,
attribVectorTag, entityNameTag, categoryTag, hasMidNodesTag;
@@ -333,6 +336,10 @@
MBEntityHandle mFileSet; // set containing read entities.
+ bool printedSeqWarning; // only print acis sequence #'s warning once
+ bool printedElemWarning; // only print element #'s warning once
MBErrorCode convert_nodesets_sidesets();
MBErrorCode read_acis_records( const char* sat_file_name = 0 );
