[MOAB-dev] r1953 - in MOAB/trunk: parallel tools/mbcoupler
tautges at mcs.anl.gov
Sun Jun 29 13:53:55 CDT 2008
Author: tautges
Date: 2008-06-29 13:53:55 -0500 (Sun, 29 Jun 2008)
New Revision: 1953
Modified:
MOAB/trunk/parallel/ReadParallel.cpp
MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
Updating some debug output.
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2008-06-29 16:19:07 UTC (rev 1952)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2008-06-29 18:53:55 UTC (rev 1953)
@@ -531,7 +531,7 @@
result = mbImpl->get_entities_by_handle(file_set, file_ents);
RR("Couldn't get pre-existing entities.");
- if (myPcomm->proc_config().proc_rank() == 0) {
+ if (debug && myPcomm->proc_config().proc_rank() == 0) {
std::cout << "File entities: " << std::endl;
file_ents.print("ff ");
@@ -552,13 +552,15 @@
RR("Failure removing deletable entities.");
- if (debug) std::cout << "Deleting deletable entities." << std::endl;
+ if (debug) {
+ std::cout << "Deleting deletable entities." << std::endl;
- std::cout << "Deletable sets: " << std::endl;
- deletable_sets.print("ff ");
+ if (myPcomm->proc_config().proc_rank() == 0) {
+ std::cout << "Deletable sets: " << std::endl;
+ deletable_sets.print("ff ");
// delete sets, then ents
if (!deletable_sets.empty())
result = mbImpl->delete_entities(deletable_sets);
@@ -566,7 +568,7 @@
deletable_ents = deletable_ents.subtract(deletable_sets);
std::cout << "Deletable entities: " << std::endl;
deletable_ents.print("ff ");
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2008-06-29 16:19:07 UTC (rev 1952)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2008-06-29 18:53:55 UTC (rev 1953)
@@ -9,6 +9,8 @@
#include <sstream>
#include <assert.h>
+bool debug = false;
#define RRA(a) if (MB_SUCCESS != result) {\
std::string tmp_str; mbImpl->get_last_error(tmp_str);\
tmp_str.append("\n"); tmp_str.append(a);\
@@ -20,6 +22,7 @@
std::string tmp_str;\
std::cout << "Failure; message:" << std::endl;\
std::cout << mbImpl->get_last_error(tmp_str) << std::endl;\
+ MPI_Finalize(); \
return result;\
@@ -29,7 +32,8 @@
std::string &opts);
MBErrorCode report_iface_ents(MBInterface *mbImpl,
- std::vector<MBParallelComm *> &pcs);
+ std::vector<MBParallelComm *> &pcs,
+ bool print_results);
MBErrorCode test_interpolation(MBInterface *mbImpl,
std::string &interp_tag,
@@ -93,7 +97,7 @@
PRINT_LAST_ERROR;
- result = report_iface_ents(mbImpl, pcs);
+ result = report_iface_ents(mbImpl, pcs, debug);
PRINT_LAST_ERROR;
if (!interp_tag.empty()) {
@@ -136,7 +140,8 @@
+ const bool print_results)
MBRange iface_ents[6];
MBErrorCode result = MB_SUCCESS, tmp_result;
@@ -165,14 +170,16 @@
int rank;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ if (print_results || iface_ents[0].size() != iface_ents[5].size()) {
+ std::cerr << "Proc " << rank << " iface entities: " << std::endl;
+ for (int i = 0; i < 4; i++)
+ std::cerr << " " << iface_ents[i].size() << " "
+ << i << "d iface entities." << std::endl;
+ std::cerr << " (" << iface_ents[5].size()
+ << " verts adj to other iface ents)" << std::endl;
- std::cerr << "Proc " << rank << " iface entities: " << std::endl;
- for (int i = 0; i < 4; i++)
- std::cerr << " " << iface_ents[i].size() << " "
- << i << "d iface entities." << std::endl;
- std::cerr << " (" << iface_ents[5].size()
- << " verts adj to other iface ents)" << std::endl;
return result;
