[MOAB-dev] r1941 - MOAB/trunk/tools/mbcoupler
Tim Tautges tautges at mcs.anl.gov
Fri Jun 27 13:22:29 CDT 2008
Huh?  Doesn't this remove MBCoupler.cpp from the build?  Looks that way
to me...
- tim
kraftche at mcs.anl.gov wrote:
> Author: kraftche
> Date: 2008-06-27 13:18:06 -0500 (Fri, 27 Jun 2008)
> New Revision: 1941
> Modified:
>    MOAB/trunk/tools/mbcoupler/Makefile.am
>    MOAB/trunk/tools/mbcoupler/findpt_test.cpp
> Log:
> fix build errors
> Modified: MOAB/trunk/tools/mbcoupler/Makefile.am
> --- MOAB/trunk/tools/mbcoupler/Makefile.am	2008-06-27 17:06:29 UTC (rev 1940)
> +++ MOAB/trunk/tools/mbcoupler/Makefile.am	2008-06-27 18:18:06 UTC (rev 1941)
> @@ -19,8 +19,8 @@
>     findpt.c \
>     findpt.h \
>     minmax.h \
> -   types.h \
> -   MBCoupler.cpp
> +   types.h #\
> +   #MBCoupler.cpp
>  libmbcoupler_la_include_HEADERS = \
>     MBElemUtil.hpp \
> Modified: MOAB/trunk/tools/mbcoupler/findpt_test.cpp
> --- MOAB/trunk/tools/mbcoupler/findpt_test.cpp	2008-06-27 17:06:29 UTC (rev 1940)
> +++ MOAB/trunk/tools/mbcoupler/findpt_test.cpp	2008-06-27 18:18:06 UTC (rev 1941)
> @@ -2,6 +2,7 @@
>  #include "MBElemUtil.hpp"
>  using namespace std;
> +using namespace MBElemUtil;
>  extern "C"{
> @@ -9,6 +10,7 @@
>  #include "types.h"
>  void test_hex_findpt()
> @@ -16,8 +18,6 @@
>      MBCartVect rst;
>      double dist;
> -    MBElemUtil u;
>      double *xm[3]; //element coord fields, lex ordering
>      const int n=5; //number of nodes per direction (min is 2, for linear element)
> @@ -41,7 +41,7 @@
> -    u.hex_findpt(xm, n, xyz, rst, dist);
> +    hex_findpt(xm, n, xyz, rst, dist);
>      cout << "Coords of " << xyz << " are:  "<< rst <<
> @@ -58,8 +58,6 @@
>    MBCartVect ncoords;;
>    double etol;
> -  MBElemUtil u;
>    //Make our sample hex the unit cube [0,1]**3
>    hex[0] = MBCartVect(0,0,0);
>    hex[1] = MBCartVect(1,0,0);
> @@ -72,7 +70,7 @@
>    etol = .1 ; //ignored by nat_coords
> -  u.nat_coords_trilinear_hex2(hex, xyz, ncoords, etol);
> +  nat_coords_trilinear_hex2(hex, xyz, ncoords, etol);
>    cout << "Coords of " << xyz << " are:  "<< ncoords << endl;
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
