[MOAB-dev] r1942 - in MOAB/trunk: . parallel tools/mbcoupler
tautges at mcs.anl.gov
Fri Jun 27 13:18:39 CDT 2008
Author: tautges
Date: 2008-06-27 13:18:39 -0500 (Fri, 27 Jun 2008)
New Revision: 1942
Modified:
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/WriteHDF5.hpp
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/parallel/WriteHDF5Parallel.hpp
MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
- updated parallel HDF5 writer to use latest parallel data
arrangements
- enhanced to look for all set-based tags for shared sets, with the
exception of tags beginning in "__" and known parallel data
representation tags that I don't want written out
- hooked up parallel writing in mbcoupler_test
Passes make check (except for the parallel test that was failing
before), including parallel writing, though I'm not sure that means
it's really working.
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/WriteHDF5.cpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -439,7 +439,10 @@
// Create the file layout, including all tables (zero-ed) and
// all structure and meta information.
parallel = (MB_SUCCESS == opts.match_option( "PARALLEL", "FORMAT" ));
- result = create_file( filename, overwrite, qa_records, user_dimension, parallel );
+ int pcomm_no = 0;
+ opts.get_int_option("PARALLEL_COMM", pcomm_no);
+ result = create_file( filename, overwrite, qa_records, user_dimension,
+ parallel, pcomm_no );
if (MB_SUCCESS != result)
return result;
@@ -1992,7 +1995,8 @@
bool overwrite,
std::vector<std::string>& qa_records,
int dimension,
- bool parallel )
+ bool parallel,
+ int pcomm_no)
long first_id;
mhdf_Status status;
@@ -2004,7 +2008,7 @@
// overridden with an alternate version in WriteHDF5Parallel
// that supports parallel I/O. If we're here and parallel == true,
// then MOAB was not built with support for parallel HDF5 I/O.
- if (parallel)
+ if (parallel || pcomm_no)
return MB_NOT_IMPLEMENTED;
const char* type_names[MBMAXTYPE];
Modified: MOAB/trunk/WriteHDF5.hpp
--- MOAB/trunk/WriteHDF5.hpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/WriteHDF5.hpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -82,7 +82,8 @@
bool overwrite,
int dimension = 3,
- bool parallel = false );
+ bool parallel = false,
+ int pcomm_no = 0);
/** Functions that the parallel version overrides*/
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -3047,7 +3047,8 @@
MBErrorCode MBParallelComm::remove_nonowned_shared(MBRange &ents,
int to_proc,
- bool owned_test)
+ bool owned_test,
+ bool shared_test)
// remove from ents any entities which are not owned locally or
// who are already shared with to_proc
@@ -3063,7 +3064,9 @@
for (rit = ents.begin(), i = 0; rit != ents.end(); rit++, i++) {
// don't save if I don't own this entity
if (owned_test && (PSTATUS_NOT_OWNED & shared_flags[i])) continue;
+ else if (!shared_test) tmp_ents.insert(*rit);
// if entity isn't shared yet, add to list
else if (!(PSTATUS_SHARED & shared_flags[i])) tmp_ents.insert(*rit);
@@ -3441,6 +3444,42 @@
return MB_SUCCESS;
+ /** \brief Return the rank of the entity owner
+MBErrorCode MBParallelComm::get_owner(MBEntityHandle entity,
+ int &owner)
+ // I'm sure there's a much more efficient logic to this,
+ // but I'm tired...
+ unsigned char pstat;
+ MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &entity, 1,
+ &pstat);
+ if (!(pstat & PSTATUS_NOT_OWNED)) {
+ owner = proc_config().proc_rank();
+ return MB_SUCCESS;
+ int sharing_procs[MAX_SHARING_PROCS];
+ result = mbImpl->tag_get_data(sharedp_tag(), &entity, 1,
+ sharing_procs);
+ RRA(" ");
+ if (-1 != sharing_procs[0]) {
+ owner = sharing_procs[0];
+ result = mbImpl->tag_get_data(sharedps_tag(), &entity, 1,
+ sharing_procs);
+ if (MB_SUCCESS == result && -1 != sharing_procs[0]) {
+ owner = -1;
+ return MB_FAILURE;
#ifdef TEST_PARALLELCOMM
#include <iostream>
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -213,6 +213,11 @@
bool lower_dim_ents = false,
bool verts_too = true,
int operation = MBInterface::UNION);
+ MBErrorCode get_owner(MBEntityHandle entity,
+ int &owner);
/** \brief Get entities on an inter-processor interface and of specified dimension
* If other_proc is -1, any interface entities are returned. If dim is -1,
@@ -298,6 +303,13 @@
//! return all the entities in parts owned locally
MBErrorCode get_part_entities(MBRange &ents, int dim = -1);
+ //! remove from the range all ents not owned by this proc or already
+ //! shared with to_proc
+ MBErrorCode remove_nonowned_shared(MBRange &ents,
+ int to_proc,
+ bool owned_test = true,
+ bool shared_test = true);
private:
int num_subranges(const MBRange &this_range);
@@ -447,12 +459,6 @@
MBErrorCode pack_range_map(MBRange &this_range, MBEntityHandle actual_start,
HandleMap &handle_map);
- //! remove from the range all ents not owned by this proc or already
- //! shared with to_proc
- MBErrorCode remove_nonowned_shared(MBRange &ents,
- int to_proc,
- bool owned_test = true);
//! for a given interface set, gets a number of layers of bridge entities
//! of dimension to_dim going through bridge dimension bridge_dim
MBErrorCode get_ghost_layers(MBEntityHandle iface_set,
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -31,6 +31,7 @@
#include "MBInternals.hpp"
#include "MBTagConventions.hpp"
#include "MBParallelConventions.h"
+#include "MBParallelComm.hpp"
#include "MBCN.hpp"
#include "MBWriteUtilIface.hpp"
#include "MBRange.hpp"
@@ -40,9 +41,9 @@
#ifdef DEBUG
# define START_SERIAL \
- for (int _x = 0; _x < numProc; ++_x) {\
+ for (int _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
MPI_Barrier( MPI_COMM_WORLD ); \
- if (_x != myRank) continue
+ if (_x != myPcomm->proc_config().proc_rank()) continue
# define END_SERIAL \
@@ -121,7 +122,7 @@
#ifndef DEBUG
static void print_type_sets( MBInterface* , int , int , MBRange& ) {}
#else
-static void print_type_sets( MBInterface* iFace, int myRank, int numProc, MBRange& sets )
+static void print_type_sets( MBInterface* iFace, int myPcomm->proc_config().proc_rank(), int myPcomm->proc_config().proc_size(), MBRange& sets )
MBTag gid, did, bid, sid, nid, iid;
iFace->tag_get_handle( GLOBAL_ID_TAG_NAME, gid );
@@ -147,8 +148,8 @@
dim += 3;
else if (MB_SUCCESS == iFace->tag_get_data(iid, &*riter, 1, proc)) {
- assert(proc[0] == (unsigned)myRank || proc[1] == (unsigned)myRank);
- id = proc[proc[0] == (unsigned)myRank];
+ assert(proc[0] == (unsigned)myPcomm->proc_config().proc_rank() || proc[1] == (unsigned)myPcomm->proc_config().proc_rank());
+ id = proc[proc[0] == (unsigned)myPcomm->proc_config().proc_rank()];
dim = 8;
else {
@@ -226,8 +227,8 @@
{ list.push_back( Data(filter,data,filterval) ); }
-WriteHDF5Parallel::WriteHDF5Parallel( MBInterface* iface )
- : WriteHDF5(iface)
+WriteHDF5Parallel::WriteHDF5Parallel( MBInterface* iface)
+ : WriteHDF5(iface), myPcomm(NULL), pcommAllocated(false)
multiProcSetTags.add( MATERIAL_SET_TAG_NAME );
multiProcSetTags.add( DIRICHLET_SET_TAG_NAME );
@@ -240,7 +241,7 @@
WriteHDF5Parallel::WriteHDF5Parallel( MBInterface* iface,
const std::vector<std::string>& tag_names )
for(std::vector<std::string>::const_iterator i = tag_names.begin();
i != tag_names.end(); ++i)
@@ -249,9 +250,16 @@
const MultiProcSetTags& set_tags )
- : WriteHDF5(iface), multiProcSetTags(set_tags)
+ : WriteHDF5(iface), multiProcSetTags(set_tags), myPcomm(NULL),
+ pcommAllocated(false)
+WriteHDF5Parallel::~WriteHDF5Parallel()
+ if (pcommAllocated && myPcomm)
+ delete myPcomm;
// The parent WriteHDF5 class has ExportSet structs that are
// populated with the entities to be written, grouped by type
// (and for elements, connectivity length). This function:
@@ -261,10 +269,7 @@
// o sets their file Id to '1'
MBErrorCode WriteHDF5Parallel::gather_interface_meshes()
- MBRange range;
MBErrorCode result;
- MBTag iface_tag, geom_tag;
- int i, proc_pair[2];
//START_SERIAL;
printdebug( "Pre-interface mesh:\n");
@@ -275,132 +280,23 @@
printrange(setSet.range);
// Allocate space for remote mesh data
- remoteMesh.resize( numProc );
+ remoteMesh.resize( myPcomm->proc_config().proc_size() );
- // Get tag handles
- result = iFace->tag_get_handle( PARALLEL_SHARED_PROC_TAG_NAME, iface_tag );
- if (MB_SUCCESS != result) {
- iface_tag = 0;
- return MB_SUCCESS;
- result = iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, geom_tag );
- if (MB_SUCCESS != result) return result;
- // Get interface mesh sets
- result = iFace->get_entities_by_type_and_tag( 0,
- MBENTITYSET,
- &iface_tag,
- 0,
- 1,
- range );
+ MBRange iface_sets = myPcomm->interface_sets();
// Populate lists of interface mesh entities
- for (MBRange::iterator iiter = range.begin(); iiter != range.end(); ++iiter)
- result = iFace->tag_get_data( iface_tag, &*iiter, 1, proc_pair );
- const int remote_proc = proc_pair[0];
- // Get list of all entities in interface and
- // the subset of that list that are meshsets.
- MBRange entities, sets;
- result = iFace->get_entities_by_handle( *iiter, entities );
- result = iFace->get_entities_by_type( *iiter, MBENTITYSET, sets );
+ for (MBRange::iterator ifit = iface_sets.begin(); ifit != iface_sets.end(); ifit++) {
+ int owner;
+ result = myPcomm->get_owner(*ifit, owner);
+ if (MB_SUCCESS != result || -1 == owner) return result;
- // Put any non-meshset entities in the list directly.
- //range_remove( entities, sets ); //not necessary, get_entities_by_handle doesn't return sets
- remoteMesh[remote_proc].merge( entities );
- //remoteMesh[remote_proc].insert( *iiter );
- for (MBRange::iterator siter = sets.begin(); siter != sets.end(); ++siter)
- // For current parallel meshing code, root processor owns
- // all curve and geometric vertex meshes.
- int dimension;
- result = iFace->tag_get_data( geom_tag, &*siter, 1, &dimension );
- if (result == MB_SUCCESS && dimension < 2)
- continue;
- // Put entities in list for appropriate processor.
- //remoteMesh[remote_proc].insert( *siter );
- entities.clear();
- result = iFace->get_entities_by_handle( *siter, entities );
+ result = iFace->get_entities_by_handle(*ifit, remoteMesh[owner], true);
+ if (MB_SUCCESS != result) return result;
- // all curve and geometric vertex meshes. Find them and
- // allocate them appropriately.
- MBRange curves_and_verts;
- MBTag tags[] = { geom_tag, geom_tag };
- int value_ints[] = { 0, 1 };
- const void* values[] = {value_ints, value_ints + 1};
- result = iFace->get_entities_by_type_and_tag( 0, MBENTITYSET,
- tags, values, 2,
- curves_and_verts,
- MBInterface::UNION );
- assert(MB_SUCCESS == result);
- MBRange edges, nodes;
- for (MBRange::iterator riter = curves_and_verts.begin();
- riter != curves_and_verts.end(); ++riter)
- result = iFace->get_entities_by_type( *riter, MBVERTEX, nodes ); assert(MB_SUCCESS == result);
- result = iFace->get_entities_by_type( *riter, MBEDGE, edges ); assert(MB_SUCCESS == result);
- std::list<ExportSet>::iterator eiter = exportList.begin();
- for ( ; eiter != exportList.end() && eiter->type != MBEDGE; ++eiter );
- remoteMesh[0].merge( nodes );
- remoteMesh[0].merge( edges );
- //remoteMesh[0].merge( curves_and_verts );
- if (myRank == 0)
- nodeSet.range.merge( nodes );
- //setSet.range.merge(curves_and_verts);
- eiter->range.merge( edges );
- edges.merge(nodes);
- //edges.merge(curves_and_verts);
- for (i = 1; i < numProc; i++)
- MBRange diff = edges.intersect( remoteMesh[i] );
- range_remove(remoteMesh[i], diff);
- // For all remote mesh entities, remove them from the
- // lists of local mesh to be exported and the ID map
- // (they will be put back into the ID map with different
- // IDs later.)
- for (i = 0; i < numProc; i++)
- if (i == myRank) continue;
- const MBRange& range = remoteMesh[i];
- range_remove( nodeSet.range, range );
- //range_remove( setSet.range, range );
- for (std::list<ExportSet>::iterator eiter = exportList.begin();
- eiter != exportList.end(); ++eiter )
- range_remove( eiter->range, range );
- //for (MBRange::const_pair_iterator pi = range.const_pair_begin();
- // pi != range.const_pair_end(); ++pi)
- // idMap.erase( pi->first, pi->second - pi->first + 1 );
// print some debug output summarizing what we've accomplished
printdebug("Remote mesh:\n");
- for (int ii = 0; ii < numProc; ++ii)
+ for (unsigned int ii = 0; ii < myPcomm->proc_config().proc_size(); ++ii)
printdebug(" proc %d : %d\n", ii, remoteMesh[ii].size());
printrange( remoteMesh[ii] );
@@ -418,13 +314,12 @@
return MB_SUCCESS;
MBErrorCode WriteHDF5Parallel::create_file( const char* filename,
bool overwrite,
int dimension,
- bool parallel )
+ bool parallel,
+ int pcomm_no)
if (!parallel)
return WriteHDF5::create_file(filename, overwrite, qa_records, dimension, false );
@@ -432,18 +327,33 @@
MBErrorCode rval;
int result;
mhdf_Status status;
- result = MPI_Comm_rank( MPI_COMM_WORLD, &myRank );
- assert(MPI_SUCCESS == result);
- result = MPI_Comm_size( MPI_COMM_WORLD, &numProc );
+ myPcomm = MBParallelComm::get_pcomm(iFace, pcomm_no);
+ if (0 == myPcomm) {
+ myPcomm = new MBParallelComm(iFace);
+ pcommAllocated = true;
rval = gather_interface_meshes();
if (MB_SUCCESS != rval) return rval;
+ rval = myPcomm->remove_nonowned_shared(nodeSet.range, -1, true, false);
+ if (MB_SUCCESS != rval) return rval;
+ for (std::list<ExportSet>::iterator eiter = exportList.begin();
+ eiter != exportList.end(); ++eiter ) {
+ rval = myPcomm->remove_nonowned_shared(eiter->range, -1, false, false);
+ /**************** get tag names for sets likely to be shared ***********/
+ rval = get_sharedset_tags();
/**************** Create actual file and write meta info ***************/
- if (myRank == 0)
+ if (myPcomm->proc_config().proc_rank() == 0)
// create the file
@@ -545,7 +455,7 @@
// Populate proc_tag_offsets on root processor with the values from
// tag_counts on each processor.
printdebug("Exchanging tag data for %d tags.\n", num_tags);
- std::vector<unsigned long> proc_tag_offsets(2*num_tags*numProc);
+ std::vector<unsigned long> proc_tag_offsets(2*num_tags*myPcomm->proc_config().proc_size());
result = MPI_Gather( &tag_counts[0], 2*num_tags, MPI_UNSIGNED_LONG,
&proc_tag_offsets[0], 2*num_tags, MPI_UNSIGNED_LONG,
0, MPI_COMM_WORLD );
@@ -563,7 +473,7 @@
tag_counts[2*i] = tag_counts[2*i+1] = 0;
unsigned long next_offset = 0;
unsigned long next_var_len_offset = 0;
- for (int j = 0; j < numProc; j++)
+ for (unsigned int j = 0; j < myPcomm->proc_config().proc_size(); j++)
unsigned long count = proc_tag_offsets[2*i + j*2*num_tags];
proc_tag_offsets[2*i + j*2*num_tags] = next_offset;
@@ -576,7 +486,7 @@
tag_counts[2*i + 1] += count;
- if (0 == myRank)
+ if (0 == myPcomm->proc_config().proc_rank())
rval = create_tag(tag_iter->tag_id, next_offset, next_var_len_offset);
assert(MB_SUCCESS == rval);
@@ -622,7 +532,7 @@
/************** Close serial file and reopen parallel *****************/
- if (0 == myRank)
mhdf_closeFile( filePtr, &status );
@@ -648,17 +558,17 @@
mhdf_Status status;
// gather node counts for each processor
- std::vector<long> node_counts(numProc);
+ std::vector<long> node_counts(myPcomm->proc_config().proc_size());
long num_nodes = nodeSet.range.size();
result = MPI_Gather( &num_nodes, 1, MPI_LONG, &node_counts[0], 1, MPI_LONG, 0, MPI_COMM_WORLD );
// create node data in file
long first_id;
- if (myRank == 0)
int total = 0;
- for (int i = 0; i < numProc; i++)
+ for (unsigned int i = 0; i < myPcomm->proc_config().proc_size(); i++)
total += node_counts[i];
hid_t handle = mhdf_createNodeCoords( filePtr, dimension, total, &first_id, &status );
@@ -676,11 +586,11 @@
nodeSet.first_id = (id_t)first_id;
// calculate per-processor offsets
- if (myRank == 0)
int prev_size = node_counts[0];
node_counts[0] = 0;
- for (int i = 1; i < numProc; ++i)
+ for (unsigned int i = 1; i < myPcomm->proc_config().proc_size(); ++i)
int mysize = node_counts[i];
node_counts[i] = node_counts[i-1] + prev_size;
@@ -736,7 +646,7 @@
// Get number of types each processor has
int num_types = 2*exportList.size();
- std::vector<int> counts(numProc);
+ std::vector<int> counts(myPcomm->proc_config().proc_size());
result = MPI_Gather( &num_types, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, MPI_COMM_WORLD );
@@ -764,11 +674,11 @@
#endif
// Get list of types from each processor
- std::vector<int> displs(numProc + 1);
+ std::vector<int> displs(myPcomm->proc_config().proc_size() + 1);
displs[0] = 0;
- for (long i = 1; i <= numProc; ++i)
+ for (unsigned long i = 1; i <= myPcomm->proc_config().proc_size(); ++i)
displs[i] = displs[i-1] + counts[i-1];
- int total = displs[numProc];
+ int total = displs[myPcomm->proc_config().proc_size()];
std::vector<int> alltypes(total);
result = MPI_Gatherv( &my_types[0], my_types.size(), MPI_INT,
&alltypes[0], &counts[0], &displs[0], MPI_INT,
@@ -778,7 +688,7 @@
// Merge type lists
std::list<elemtype> type_list;
std::list<elemtype>::iterator liter;
- for (int i = 0; i < numProc; ++i)
+ for (unsigned int i = 0; i < myPcomm->proc_config().proc_size(); ++i)
int* proc_type_list = &alltypes[displs[i]];
liter = type_list.begin();
@@ -867,7 +777,7 @@
// Get number of each element type from each processor
const int numtypes = exportList.size();
std::vector<long> my_counts(numtypes);
- std::vector<long> counts(numtypes * numProc + numtypes);
+ std::vector<long> counts(numtypes * myPcomm->proc_config().proc_size() + numtypes);
viter = my_counts.begin();
for (ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter)
{ *viter = ex_iter->range.size(); ++viter; }
@@ -880,7 +790,7 @@
for (int i = 0; i < numtypes; i++)
long prev = 0;
- for (int j = 0; j <= numProc; j++)
+ for (unsigned int j = 0; j <= myPcomm->proc_config().proc_size(); j++)
long tmp = counts[j*numtypes + i];
counts[j*numtypes+i] = prev;
@@ -901,10 +811,10 @@
// Create element tables
std::vector<long> start_ids(numtypes);
- if (myRank == 0)
viter = start_ids.begin();
- long* citer = &counts[numtypes * numProc];
+ long* citer = &counts[numtypes * myPcomm->proc_config().proc_size()];
rval = create_elem_tables( ex_iter->type,
@@ -938,7 +848,9 @@
MBErrorCode rval;
mhdf_Status status;
- int i, j, result;
+ unsigned int j;
+ int i, result;
#ifdef WRITE_NODE_ADJACENCIES
const int numtypes = exportList.size()+1;
#else
@@ -946,7 +858,7 @@
#endif
std::vector<long>::iterator viter;
std::list<ExportSet>::iterator ex_iter;
- std::vector<long> local(numtypes), all(numProc * numtypes + numtypes);
+ std::vector<long> local(numtypes), all(myPcomm->proc_config().proc_size() * numtypes + numtypes);
// Get adjacency counts for local processor
viter = local.begin();
@@ -974,7 +886,7 @@
for (i = 0; i < numtypes; i++)
long prev = 0;
- for (j = 0; j <= numProc; j++)
+ for (unsigned j = 0; j <= myPcomm->proc_config().proc_size(); j++)
long tmp = all[j*numtypes + i];
all[j*numtypes+i] = prev;
@@ -985,8 +897,8 @@
// For each element type for which there is no adjacency data,
// send -1 to all processors as the offset
for (i = 0; i < numtypes; ++i)
- if (all[numtypes*numProc+i] == 0)
- for (j = 0; j < numProc; ++j)
+ if (all[numtypes*myPcomm->proc_config().proc_size()+i] == 0)
+ for (j = 0; j < myPcomm->proc_config().proc_size(); ++j)
all[j*numtypes+i] = -1;
// Send offsets back to each processor
@@ -1004,9 +916,9 @@
{ ex_iter->adj_offset = *viter; ++viter; }
// Create data tables in file
- if (myRank == 0)
- viter = all.begin() + (numtypes * numProc);
+ viter = all.begin() + (numtypes * myPcomm->proc_config().proc_size());
if (*viter) {
hid_t handle = mhdf_createAdjacency( filePtr,
@@ -1105,7 +1017,8 @@
RemoteSetData& data, long& offset )
MBErrorCode rval;
- int i, result;
+ int i;
+ int result;
MBRange::iterator riter;
rval = iFace->tag_get_handle( tags.filterTag.c_str(), data.filter_tag );
@@ -1160,7 +1073,7 @@
printdebug("Found %d meshsets with \"%s\" tag.\n", data.range.size(), tags.filterTag.c_str() );
// Exchange number of sets with tag between all processors
- data.counts.resize(numProc);
+ data.counts.resize(myPcomm->proc_config().proc_size());
int count = data.range.size();
result = MPI_Allgather( &count, 1, MPI_INT,
&data.counts[0], 1, MPI_INT,
@@ -1168,11 +1081,11 @@
// Exchange tag values for sets between all processors
- data.displs.resize(numProc+1);
+ data.displs.resize(myPcomm->proc_config().proc_size()+1);
data.displs[0] = 0;
- for (i = 1; i <= numProc; i++)
- data.displs[i] = data.displs[i-1] + data.counts[i-1];
- int total = data.displs[numProc];
+ for (unsigned int j = 1; j <= myPcomm->proc_config().proc_size(); j++)
+ data.displs[j] = data.displs[j-1] + data.counts[j-1];
+ int total = data.displs[myPcomm->proc_config().proc_size()];
data.all_values.resize(total);
data.local_values.resize(count);
rval = iFace->tag_get_data( data.data_tag, data.range, &data.local_values[0] );
@@ -1187,10 +1100,10 @@
std::vector<int> sorted( data.all_values );
std::sort( sorted.begin(), sorted.end() );
int r = 0, w = 0;
- for (i = 0; i < numProc; ++i)
+ for (unsigned j = 0; j < myPcomm->proc_config().proc_size(); ++j)
const int start = w;
- for (int j = 0; j < data.counts[i]; ++j)
+ for (int i = 0; i < data.counts[j]; ++i)
std::vector<int>::iterator p
= std::lower_bound( sorted.begin(), sorted.end(), data.all_values[r] );
@@ -1202,7 +1115,7 @@
++r;
- data.counts[i] = w - start;
+ data.counts[j] = w - start;
total = w;
data.all_values.resize( total );
@@ -1227,15 +1140,15 @@
++r;
- assert( count == data.counts[myRank] );
+ assert( count == data.counts[myPcomm->proc_config().proc_rank()] );
assert( count == w );
data.local_values.resize( count );
sorted.clear(); // release storage
// recalculate displacements for updated counts
data.displs[0] = 0;
// Find sets that span multple processors and update appropriately.
// The first processor (sorted by MPI rank) that contains a given set
@@ -1259,7 +1172,7 @@
id = (int)++offset;
val_id_map[data.all_values[i]] = id;
- //const unsigned int values_offset = (unsigned)i - (unsigned)data.displs[myRank];
+ //const unsigned int values_offset = (unsigned)i - (unsigned)data.displs[myPcomm->proc_config().proc_rank()];
//if (values_offset < (unsigned)count)
// riter = data.range.begin();
@@ -1300,11 +1213,11 @@
MBRange::const_iterator riter;
START_SERIAL;
- print_type_sets( iFace, myRank, numProc, setSet.range );
+ print_type_sets( iFace, myPcomm->proc_config().proc_rank(), myPcomm->proc_config().proc_size(), setSet.range );
END_SERIAL;
// Gather data about multi-processor meshsets - removes sets from setSet.range
- cpuParallelSets.resize( numProc );
+ cpuParallelSets.resize( myPcomm->proc_config().proc_size() );
std::vector<RemoteSetData> remote_set_data( multiProcSetTags.list.size() );
for (i = 0; i< (int)multiProcSetTags.list.size(); i++)
@@ -1317,21 +1230,21 @@
START_SERIAL;
printdebug("myLocalSets\n");
END_SERIAL;
// Gather counts of non-shared sets from each proc
// to determine total table size.
- std::vector<long> set_offsets(numProc + 1);
+ std::vector<long> set_offsets(myPcomm->proc_config().proc_size() + 1);
long local_count = setSet.range.size();
result = MPI_Gather( &local_count, 1, MPI_LONG,
&set_offsets[0], 1, MPI_LONG,
- for (i = 0; i <= numProc; i++)
- long tmp = set_offsets[i];
- set_offsets[i] = total_offset;
+ long tmp = set_offsets[j];
+ set_offsets[j] = total_offset;
total_offset += tmp;
@@ -1343,8 +1256,8 @@
setSet.offset = (id_t)(sets_offset);
// Create the set description table
- long total_count_and_start_id[2] = { set_offsets[numProc], 0 };
- if (myRank == 0 && total_count_and_start_id[0] > 0)
+ long total_count_and_start_id[2] = { set_offsets[myPcomm->proc_config().proc_size()], 0 };
+ if (myPcomm->proc_config().proc_rank() == 0 && total_count_and_start_id[0] > 0)
rval = create_set_meta( (id_t)total_count_and_start_id[0], total_count_and_start_id[1] );
assert (MB_SUCCESS == rval);
@@ -1360,7 +1273,7 @@
printdebug("Non-shared sets: %ld local, %ld global, offset = %ld, first_id = %ld\n",
local_count, total_count_and_start_id[0], sets_offset, total_count_and_start_id[1] );
printdebug("my Parallel Sets:\n");
- print_type_sets(iFace, myRank, numProc, cpuParallelSets[myRank] );
+ print_type_sets(iFace, myPcomm->proc_config().proc_rank(), myPcomm->proc_config().proc_size(), cpuParallelSets[myPcomm->proc_config().proc_rank()] );
END_SERIAL;
// Not writing any sets??
@@ -1388,16 +1301,16 @@
long data_counts[3];
rval = count_set_size( setSet.range, rangeSets, data_counts[0], data_counts[1], data_counts[2] );
- std::vector<long> set_counts(3*numProc);
+ std::vector<long> set_counts(3*myPcomm->proc_config().proc_size());
result = MPI_Gather( data_counts, 3, MPI_LONG,
&set_counts[0], 3, MPI_LONG,
- for (i = 0; i < 3*numProc; ++i)
+ for (unsigned int j = 0; j < 3*myPcomm->proc_config().proc_size(); ++j)
- long tmp = set_counts[i];
- set_counts[i] = data_offsets[i%3];
- data_offsets[i%3] += tmp;
+ long tmp = set_counts[j];
+ set_counts[j] = data_offsets[j%3];
+ data_offsets[j%3] += tmp;
long all_counts[] = {data_offsets[0], data_offsets[1], data_offsets[2]};
result = MPI_Scatter( &set_counts[0], 3, MPI_LONG,
@@ -1409,7 +1322,7 @@
setParentsOffset = data_offsets[2];
// Create set contents and set children tables
- if (myRank == 0)
rval = create_set_tables( all_counts[0], all_counts[1], all_counts[2] );
@@ -1464,8 +1377,8 @@
for(MBRange::iterator i = remaining.begin(); i != remaining.end(); ++i)
// Look for the first CPU which knows about both sets.
- int cpu;
- for (cpu = 0; cpu < numProc; ++cpu)
+ unsigned int cpu;
+ for (cpu = 0; cpu < myPcomm->proc_config().proc_size(); ++cpu)
if (cpuParallelSets[cpu].find(relative) != cpuParallelSets[cpu].end() &&
cpuParallelSets[cpu].find(*i) != cpuParallelSets[cpu].end())
break;
@@ -1473,9 +1386,9 @@
// it could also indicate that it is a link to some set that
// exists on this processor but is not being written, because
// the caller requested that some subset of the mesh be written.
- //assert(cpu < numProc);
+ //assert(cpu < myPcomm->proc_config().proc_size());
// If I'm the first set that knows about both, I'll handle it.
- if (cpu == myRank)
+ if (cpu == myPcomm->proc_config().proc_rank())
result.insert( *i );
@@ -1589,11 +1502,11 @@
// Exchange sizes for sets between all processors.
std::vector<long> all_sizes(3*total);
- std::vector<int> counts(numProc), displs(numProc);
- for (i = 0; i < (unsigned)numProc; i++)
+ std::vector<int> counts(myPcomm->proc_config().proc_size()), displs(myPcomm->proc_config().proc_size());
+ for (i = 0; i < (unsigned)myPcomm->proc_config().proc_size(); i++)
counts[i] = 3 * data.counts[i];
displs[0] = 0;
- for (i = 1; i < (unsigned)numProc; i++)
+ for (i = 1; i < (unsigned)myPcomm->proc_config().proc_size(); i++)
result = MPI_Allgatherv( &local_sizes[0], 3*count, MPI_LONG,
&all_sizes[0], &counts[0], &displs[0], MPI_LONG,
@@ -1616,7 +1529,7 @@
for (i = 0; i < total; ++i)
const std::map<int,int>::iterator p = tagsort.find( data.all_values[i] );
- const unsigned r = (unsigned)(i - data.displs[myRank]); // offset in "local" array
+ const unsigned r = (unsigned)(i - data.displs[myPcomm->proc_config().proc_rank()]); // offset in "local" array
// If this is the first instance of this tag value,
// then the processor with this instance is responsible
@@ -1715,18 +1628,18 @@
#ifdef DEBUG
-START_SERIAL; if (counts[myRank]) {
+START_SERIAL; if (counts[myPcomm->proc_config().proc_rank()]) {
std::string name1, name2;
iFace->tag_get_name( data.data_tag, name1 );
iFace->tag_get_name( data.filter_tag, name2 );
printdebug("Remote set data\n" );
printdebug(" %13s %13s owner local_offsets total_counts\n", name1.c_str(), name2.c_str());
-for (unsigned d = 0; d < (unsigned)counts[myRank]; ++d) {
+for (unsigned d = 0; d < (unsigned)counts[myPcomm->proc_config().proc_rank()]; ++d) {
switch(d%3) {
case 0: // data/contents
-printdebug(" %13d %13d %5s %13d %12d\n", data.all_values[(d+displs[myRank])/3],
+printdebug(" %13d %13d %5s %13d %12d\n", data.all_values[(d+displs[myPcomm->proc_config().proc_rank()])/3],
data.filter_value,
- all_sizes[d+displs[myRank]] < 0 ? "no" : "yes",
+ all_sizes[d+displs[myPcomm->proc_config().proc_rank()]] < 0 ? "no" : "yes",
local_offsets[d], local_sizes[d] );
break;
case 1: // children
@@ -1744,7 +1657,7 @@
// Store each parallel meshset in the list
sizes_iter = local_sizes.begin();
offset_iter = local_offsets.begin();
- std::vector<long>::iterator all_iter = all_sizes.begin() + displs[myRank];
+ std::vector<long>::iterator all_iter = all_sizes.begin() + displs[myPcomm->proc_config().proc_rank()];
for (riter = data.range.begin(); riter != data.range.end(); ++riter)
ParallelSet info;
@@ -1993,7 +1906,7 @@
// Communicate the number of ranges and the start_id for
// each processor.
- std::vector<int> counts(numProc), offsets(numProc), displs(numProc);
+ std::vector<int> counts(myPcomm->proc_config().proc_size()), offsets(myPcomm->proc_config().proc_size()), displs(myPcomm->proc_config().proc_size());
int mycount = myranges.size();
int mystart = export_set->first_id + export_set->offset;
result = MPI_Allgather( &mycount, 1, MPI_INT, &counts[0], 1, MPI_INT, MPI_COMM_WORLD );
@@ -2003,9 +1916,9 @@
// Communicate the ranges
displs[0] = 0;
- std::vector<unsigned long> allranges( displs[numProc-1] + counts[numProc-1] );
+ std::vector<unsigned long> allranges( displs[myPcomm->proc_config().proc_size()-1] + counts[myPcomm->proc_config().proc_size()-1] );
result = MPI_Allgatherv( &myranges[0], myranges.size(), MPI_UNSIGNED_LONG,
&allranges[0], &counts[0], &displs[0],
MPI_UNSIGNED_LONG, MPI_COMM_WORLD );
@@ -2018,9 +1931,9 @@
// Set file IDs for each communicated entity
// For each processor
- for (int proc = 0; proc < numProc; ++proc)
+ for (unsigned int proc = 0; proc < myPcomm->proc_config().proc_size(); ++proc)
- if (proc == myRank)
+ if (proc == myPcomm->proc_config().proc_rank())
continue;
// Get data for corresponding processor
@@ -2063,7 +1976,7 @@
for (int ii = 0; ii < count; ii+=2)
printdebug("*** %u to %u\n", (unsigned)ranges[ii], (unsigned)ranges[ii+1] );
MBRange junk; junk.insert( global );
- print_type_sets( iFace, myRank, numProc, junk );
+ print_type_sets( iFace, myPcomm->proc_config().proc_rank(), myPcomm->proc_config().proc_size(), junk );
assert(j < count);
int fileid = offset + steps + (global - low);
@@ -2074,3 +1987,54 @@
return MB_SUCCESS;
+MBErrorCode WriteHDF5Parallel::get_sharedset_tags()
+ // get all the sets
+ MBRange all_sets;
+ MBErrorCode result = iFace->get_entities_by_type_and_tag(0, MBENTITYSET, NULL, NULL, 0,
+ all_sets);
+ if (MB_SUCCESS != result || all_sets.empty()) return result;
+ // get all the tags on those sets & test against known exceptions
+ std::set<MBTag> all_tags;
+ std::vector<MBTag> all_tagsv;
+ std::string tag_name;
+ for (MBRange::iterator rit = all_sets.begin(); rit != all_sets.end(); rit++) {
+ all_tagsv.clear();
+ result = iFace->tag_get_tags_on_entity(*rit, all_tagsv);
+ for (std::vector<MBTag>::iterator vit = all_tagsv.begin(); vit != all_tagsv.end(); vit++) {
+ // don't look at tags already selected
+ if (std::find(all_tags.begin(), all_tags.end(), *vit) != all_tags.end()) continue;
+ // get name
+ result = iFace->tag_get_name(*vit, tag_name);
+ // look for known exclusions
+ const char *tag_cstr = tag_name.c_str();
+ if (
+ !((tag_cstr[0] == '_' && tag_cstr[1] == '_') ||
+ tag_name == PARALLEL_SHARED_PROC_TAG_NAME ||
+ tag_name == PARALLEL_SHARED_PROCS_TAG_NAME ||
+ tag_name == PARALLEL_SHARED_HANDLE_TAG_NAME ||
+ tag_name == PARALLEL_SHARED_HANDLES_TAG_NAME ||
+ tag_name == PARALLEL_STATUS_TAG_NAME ||
+ tag_name == PARALLEL_COMM_TAG_NAME
+ all_tags.insert(*vit);
+ // now add the tag names to the list
+ for (std::set<MBTag>::iterator sit = all_tags.begin(); sit != all_tags.end(); sit++) {
+ result = iFace->tag_get_name(*sit, tag_name);
+ multiProcSetTags.add( tag_name);
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -12,6 +12,7 @@
#include <mpi.h>
struct RemoteSetData;
+class MBParallelComm;
class MB_DLL_EXPORT WriteHDF5Parallel : public WriteHDF5
@@ -45,7 +46,9 @@
const std::vector<std::string>& multiproc_set_tags );
+ virtual ~WriteHDF5Parallel();
/**\brief Define tags used to identify sets spanning multiple procesors */
class MultiProcSetTags {
friend class WriteHDF5Parallel;
@@ -100,7 +103,8 @@
bool overwrite,
int dimension = 3,
//! Figure out which mesh local mesh is duplicated on
//! remote processors and which processor will write
@@ -194,12 +198,12 @@
void remove_remote_entities( MBEntityHandle relative, std::vector<MBEntityHandle>& vect );
void remove_remote_sets( MBEntityHandle relative, MBRange& range );
void remove_remote_sets( MBEntityHandle relative, std::vector<MBEntityHandle>& vect );
+ //! get any existing tags which aren't excluded and add to shared set tags
+ MBErrorCode get_sharedset_tags();
private:
- //! MPI environment
- int numProc, myRank;
//! An array of interface mesh which is to be written by
//! remote processors. Indexed by MPI rank (processor number).
std::vector<MBRange> remoteMesh;
@@ -228,6 +232,12 @@
//! List of parallel sets "owned" by this processor
//MBRange myParallelSets;
+ //! pcomm controlling parallel nature of mesh
+ MBParallelComm *myPcomm;
+ //! whether this instance allocated (and dtor should delete) the pcomm
+ bool pcommAllocated;
void printrange( MBRange& );
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2008-06-27 18:18:06 UTC (rev 1941)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2008-06-27 18:18:39 UTC (rev 1942)
@@ -110,7 +110,7 @@
// output mesh
const char *outfile = "output.h5m";
- result = mbImpl->write_file(outfile, NULL, NULL,
+ result = mbImpl->write_file(outfile, NULL, "PARALLEL=FORMAT",
pcs[1]->partition_sets());
PRINT_LAST_ERROR;
std::cout << "Wrote " << outfile << std::endl;
