[MOAB-dev] r1937 - in MOAB/trunk: . tools/mbcoupler
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jun 26 20:14:13 CDT 2008
Author: tautges
Date: 2008-06-26 20:14:12 -0500 (Thu, 26 Jun 2008)
New Revision: 1937
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
   MOAB/trunk/MBAdaptiveKDTree.hpp
   MOAB/trunk/MBMatrix3.hpp
   MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
- adding some timing and kdtree data to coupler output
- adding function to get kdtree depth info
- adding include to MBMatrix3.hpp
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2008-06-27 00:09:29 UTC (rev 1936)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2008-06-27 01:14:12 UTC (rev 1937)
@@ -1897,3 +1897,18 @@
   return MB_SUCCESS;
+MBErrorCode MBAdaptiveKDTree::get_info(MBEntityHandle root,
+                                       double min[3], double max[3],
+                                       unsigned int &dep)
+  MBErrorCode result = get_tree_box(root, min, max);
+  if (MB_SUCCESS != result) return result;
+  MBAdaptiveKDTreeIter iter;
+  get_tree_iterator( root, iter );
+  iter.step_to_first_leaf(MBAdaptiveKDTreeIter::LEFT);
+  dep = iter.depth();
+  return MB_SUCCESS;
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp	2008-06-27 00:09:29 UTC (rev 1936)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp	2008-06-27 01:14:12 UTC (rev 1937)
@@ -165,6 +165,11 @@
   MBErrorCode build_tree( const MBRange& entities,
                           MBEntityHandle& root_set_out,
                           const Settings* settings = 0 );
+    //! get some information about the tree
+  MBErrorCode get_info(MBEntityHandle root,
+                       unsigned int &dep);
   //! Find triangle closest to input position.
   //!\param from_coords  The input position to test against
Modified: MOAB/trunk/MBMatrix3.hpp
--- MOAB/trunk/MBMatrix3.hpp	2008-06-27 00:09:29 UTC (rev 1936)
+++ MOAB/trunk/MBMatrix3.hpp	2008-06-27 01:14:12 UTC (rev 1937)
@@ -24,6 +24,7 @@
 #include "MBCartVect.hpp"
 #include "MBTypes.h"
 #include <iosfwd>
+#include <limits>
 class MBMatrix3
Modified: MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
--- MOAB/trunk/tools/mbcoupler/MBCoupler.cpp	2008-06-27 00:09:29 UTC (rev 1936)
+++ MOAB/trunk/tools/mbcoupler/MBCoupler.cpp	2008-06-27 01:14:12 UTC (rev 1937)
@@ -52,6 +52,7 @@
   MBRange local_ents;
   MBAdaptiveKDTree::Settings settings;
+  settings.candidatePlaneSet = MBAdaptiveKDTree::SUBDIVISION;
   allBoxes.resize(6*myPc->proc_config().proc_size());
     //get entities on the local part
@@ -78,6 +79,17 @@
   int mpi_err = MPI_Allgather(&allBoxes[6*my_rank], 6, MPI_DOUBLE,
                               &allBoxes[0], 6, MPI_DOUBLE,
                               myPc->proc_config().proc_comm());
+#ifndef NDEBUG
+  double min[3] = {0,0,0}, max[3] = {0,0,0};
+  unsigned int dep;
+  myTree->get_info(localRoot, min, max, dep);
+  std::cout << "Proc " << my_rank << ": box min/max, tree depth = ("
+            << min[0] << "," << min[1] << "," << min[2] << "), ("
+            << max[0] << "," << max[1] << "," << max[2] << "), "
+            << dep << std::endl;
+#endif
   if (MPI_SUCCESS == mpi_err) return MB_SUCCESS;
   else return MB_FAILURE;
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-27 00:09:29 UTC (rev 1936)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-27 01:14:12 UTC (rev 1937)
@@ -34,7 +34,10 @@
 MBErrorCode test_interpolation(MBInterface *mbImpl,
                                std::string &interp_tag,
                                std::vector<MBParallelComm *> &pcs,
-                               std::vector<ReadParallel *> rps);
+                               std::vector<ReadParallel *> rps,
+                               double &instant_time,
+                               double &pointloc_time,
+                               double &interp_time);
 int main(int argc, char **argv)
@@ -94,16 +97,24 @@
   PRINT_LAST_ERROR;
   if (!interp_tag.empty()) {
+    double instant_time, pointloc_time, interp_time;
       // test interpolation
-    result = test_interpolation(mbImpl, interp_tag, pcs, rps);
+    result = test_interpolation(mbImpl, interp_tag, pcs, rps,
+                                instant_time, pointloc_time, interp_time);
     PRINT_LAST_ERROR;
+    std::cout << "Coupler instantiation/point location/interpolation times = "
+              << instant_time << ", "
+              << pointloc_time << ", "
+              << interp_time << std::endl;
     // output mesh
-  result = mbImpl->write_file("output.h5m", NULL, NULL,
+  const char *outfile = "output.h5m";
+  result = mbImpl->write_file(outfile, NULL, NULL,
                               pcs[1]->partition_sets());
   PRINT_LAST_ERROR;
+  std::cout << "Wrote " << outfile << std::endl;
   std::cout << "Success." << std::endl;
   err = MPI_Finalize();
@@ -206,16 +217,23 @@
     // source is 1st mesh, target is 2nd
   MBRange src_elems, targ_elems;
   MBErrorCode result = pcs[0]->get_part_entities(src_elems, 3);
   PRINT_LAST_ERROR;
+  double start_time = MPI_Wtime();
     // instantiate a coupler, which also initializes the tree
   MBCoupler mbc(mbImpl, pcs[0], src_elems, 0);
+  instant_time = MPI_Wtime();
     // get points from the target mesh to interpolate
   MBRange targ_verts, tmp_verts;
@@ -239,11 +257,19 @@
   result = mbc.locate_points(&vpos[0], targ_verts.size());
   PRINT_LAST_ERROR;
+  pointloc_time = MPI_Wtime();
     // now interpolate tag onto target points
   std::vector<double> field(targ_verts.size());
   result = mbc.interpolate(MBCoupler::LINEAR_FE, interp_tag, &field[0]);
   PRINT_LAST_ERROR;
+  interp_time = MPI_Wtime();
+  interp_time -= pointloc_time;
+  pointloc_time -= instant_time;
+  instant_time -= start_time;
     // set field values as tag on target vertices
   MBTag tag;
   result = mbImpl->tag_get_handle(interp_tag.c_str(), tag); PRINT_LAST_ERROR;
