[MOAB-dev] r1930 - in MOAB/trunk: . tools/mbcoupler
dcthomp at mcs.anl.gov
Wed Jun 25 19:34:42 CDT 2008
Author: dcthomp
Date: 2008-06-25 19:34:42 -0500 (Wed, 25 Jun 2008)
New Revision: 1930
Modified:
MOAB/trunk/CMakeLists.txt
MOAB/trunk/tools/mbcoupler/CMakeLists.txt
Log:
ENH: Keep up to date with autoconf build.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2008-06-26 00:32:57 UTC (rev 1929)
+++ MOAB/trunk/CMakeLists.txt 2008-06-26 00:34:42 UTC (rev 1930)
@@ -238,7 +238,7 @@
add_subdirectory( refiner )
- include_directories( refiner )
+ include_directories( ${MOAB_SOURCE_DIR}/refiner )
target_link_libraries( MOAB
MOABrefiner
Modified: MOAB/trunk/tools/mbcoupler/CMakeLists.txt
--- MOAB/trunk/tools/mbcoupler/CMakeLists.txt 2008-06-26 00:32:57 UTC (rev 1929)
+++ MOAB/trunk/tools/mbcoupler/CMakeLists.txt 2008-06-26 00:34:42 UTC (rev 1930)
@@ -3,20 +3,40 @@
set( MBCOUPLER_SRCS
+ MBCoupler.cpp
MBElemUtil.cpp
+ errmem.c
+ findpt.c
+ poly.c
tensor.c
- poly.c
- findpt.c
- errmem.c
add_library( mbcoupler
${MBCOUPLER_SRCS}
+target_link_libraries( mbcoupler MOAB )
+if ( MOAB_USE_MPI )
+ target_link_libraries( mbcoupler MOABpar )
+endif ( MOAB_USE_MPI )
+set_source_files_properties( ${MBCOUPLER_SRCS}
+ COMPILE_FLAGS "${MOAB_DEFINES}"
enable_testing()
# A test for the coupler library
add_executable( findpt_test findpt_test.cpp )
target_link_libraries( findpt_test mbcoupler MOAB )
+ target_link_libraries( findpt_test MOABpar )
add_test( TestMBCouplerFindPt ${EXECUTABLE_OUTPUT_PATH}/findpt_test )
+ # Exercise the coupler and not just findpt:
+ add_executable( mbcoupler_test mbcoupler_test.cpp )
+ set_source_files_properties( mbcoupler_test.cpp
+ COMPILE_FLAGS "${MOAB_DEFINES}" )
+ target_link_libraries( mbcoupler_test mbcoupler MOAB MOABpar )
+ add_test( TestMBCoupler ${EXECUTABLE_OUTPUT_PATH}/mbcoupler_test )
