[MOAB-dev] r1925 - MOAB/trunk/tools/mbcoupler
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Jun 25 09:31:10 CDT 2008
Author: tautges
Date: 2008-06-25 09:31:10 -0500 (Wed, 25 Jun 2008)
New Revision: 1925
Modified:
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
Print out diagnostics about shared entities.
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-25 14:18:01 UTC (rev 1924)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-25 14:31:10 UTC (rev 1925)
@@ -17,6 +17,9 @@
                              std::vector<const char *> &filenames,
                              std::string &opts);
+MBErrorCode report_iface_ents(MBInterface *mbImpl,
+                              std::vector<MBParallelComm *> &pcs);
 int main(int argc, char **argv)
     // need to init MPI first, to tell how many procs and rank
@@ -75,7 +78,11 @@
-  std::cout << "Success." << std::endl;
+  result = report_iface_ents(mbImpl, pcs);
+  if (MB_SUCCESS != result)
+    std::cout << "Failure." << std::endl;
+  else
+    std::cout << "Success." << std::endl;
   err = MPI_Finalize();
   for (unsigned int i = 0; i < filenames.size(); i++) {
@@ -88,6 +95,47 @@
   return 0;
+  MBRange iface_ents[6];
+  MBErrorCode result = MB_SUCCESS, tmp_result;
+    // now figure out which vertices are shared
+  for (unsigned int p = 0; p < pcs.size(); p++) {
+    for (int i = 0; i < 4; i++) {
+      tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
+      if (MB_SUCCESS != tmp_result) {
+        std::cerr << "get_iface_entities returned error on proc "
+                  << pcs[p]->proc_config().proc_rank() << "; message: " << std::endl;
+        std::string last_error;
+        result = mbImpl->get_last_error(last_error);
+        if (last_error.empty()) std::cerr << "(none)" << std::endl;
+        else std::cerr << last_error << std::endl;
+        result = tmp_result;
+      if (0 != i) iface_ents[4].merge(iface_ents[i]);
+    // report # iface entities
+  result = mbImpl->get_adjacencies(iface_ents[4], 0, false, iface_ents[5],
+                                   MBInterface::UNION);
+  int rank;
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  std::cerr << "Proc " << rank << " iface entities: " << std::endl;
+    std::cerr << "    " << iface_ents[i].size() << " "
+              << i << "d iface entities." << std::endl;
+  std::cerr << "    (" << iface_ents[5].size()
+            << " verts adj to other iface ents)" << std::endl;
+  return result;
 MBErrorCode get_file_options(int argc, char **argv,
                              std::string &opts)
