[MOAB-dev] r1923 - in MOAB/trunk: . parallel tools/mbcoupler
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Jun 25 02:01:33 CDT 2008
Author: tautges
Date: 2008-06-25 02:01:32 -0500 (Wed, 25 Jun 2008)
New Revision: 1923
Modified:
   MOAB/trunk/ReadGmsh.cpp
   MOAB/trunk/ReadHDF5.cpp
   MOAB/trunk/ReadSTL.cpp
   MOAB/trunk/ReadVtk.cpp
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/WriteNCDF.cpp
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
Modifying lots of readers to call MBReadUtilIface->update_adjacencies
after creating a batch of elements and updating their connectivity.
This ensures that, if AEntityFactory has already created
vertex-element adjacencies, that those adjacencies will get created
for the new elements/vertices.  Without this, some vertices have
upward adjacencies and some do not.
Also updating mbcoupler_test to use new method for accessing
partitions/interfaces and calling parallel reader for multiple files.
Passes make check, except for parallel Tqdcfr test, which fails because of a check I inserted recently on number of partition sets vs. number of procs.
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/ReadGmsh.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -404,6 +404,10 @@
     memcpy( conn_array, &connectivity[0], connectivity.size() * sizeof(MBEntityHandle) );
+    // notify MOAB of the new elements
+  result = readMeshIface->update_adjacencies(handle, num_elem, node_per_elem, conn_array);
+  if (MB_SUCCESS != result) return result;
     // Store element IDs
   result = mdbImpl->tag_set_data( globalId, elements, &elem_ids[0] );
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/ReadHDF5.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -441,7 +441,14 @@
     rval = convert_id_to_handle( array, (size_t)(nodes_per_elem*count) );
   else
     rval = convert_id_to_handle( nodeSet, array, (size_t)(nodes_per_elem*count) );
+  if (MB_SUCCESS != rval) return rval;
+  MBErrorCode result = readUtil->update_adjacencies(handle, count,
+                                                    nodes_per_elem, array);
   return rval;
Modified: MOAB/trunk/ReadSTL.cpp
--- MOAB/trunk/ReadSTL.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/ReadSTL.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -207,6 +207,7 @@
     // Use vertex_map to reconver triangle connectivity from
     // vertex coordinates.
+  MBEntityHandle *conn_sav = connectivity;
   for (std::vector<Triangle>::iterator i = triangles.begin(); i != triangles.end(); ++i)
     *connectivity = vertex_map[i->points[0]]; ++connectivity;
@@ -214,6 +215,11 @@
     *connectivity = vertex_map[i->points[2]]; ++connectivity;
+  result = readMeshIface->update_adjacencies(handle, triangles.size(),
+                                             3, conn_sav);
   return MB_SUCCESS;
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/ReadVtk.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -671,6 +671,8 @@
       return result;
+    MBEntityHandle *conn_sav = conn_array;
       // Store element connectivity
     for ( ; id < end_id; ++id)
@@ -714,6 +716,11 @@
       conn_array += num_vtx;
+    result = readMeshIface->update_adjacencies(start_handle, num_elem,
+                                               num_vtx, conn_sav);
   return MB_SUCCESS;
@@ -761,6 +768,8 @@
     return MB_FAILURE;
     // Offsets of element vertices in grid relative to corner closest to origin
   long k = dims[0]*dims[1];
   const long corners[8] = { 0, 1, 1+dims[0], dims[0], k, k+1, k+1+dims[0], k+dims[0] };
@@ -775,6 +784,11 @@
           *conn_array = index + corners[j] + first_vtx;
+  result = readMeshIface->update_adjacencies(start_handle, num_elems,
+                                             vert_per_elem, conn_sav);
   return MB_SUCCESS;
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/Tqdcfr.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -1212,6 +1212,10 @@
     result = mdbImpl->add_entities(entity->setHandle, dum_range);
+    result = readUtilIface->update_adjacencies(start_handle, num_elem,
+                                               nodes_per_elem, conn);
     // set the dimension on the geom tag
Modified: MOAB/trunk/WriteNCDF.cpp
--- MOAB/trunk/WriteNCDF.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/WriteNCDF.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -1261,7 +1261,8 @@
                                                   &(*begin_iter),
                                                   1, &exodus_id);
       if (MB_FAILURE == result) {
-        mWriteIface->report_error("Problem getting exodus id for sideset element %lu", ID_FROM_HANDLE(*begin_iter));
+        mWriteIface->report_error("Problem getting exodus id for sideset element %lu",
+                                  (long unsigned int) ID_FROM_HANDLE(*begin_iter));
         return result;
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -1870,12 +1870,13 @@
     MBEntityHandle set_handle;
     result = mbImpl->create_meshset(options_vec[i], set_handle);
     RRA("Failed to create set in unpack.");
+    // make sure new sets handles are monotonically increasing
+    assert(set_handle > *new_sets.rbegin());
     new_sets.insert(set_handle);
-    // make sure new sets handles are contiguous
-  assert(*new_sets.rbegin() - *new_sets.begin() + 1 == new_sets.size());
   entities.merge(new_sets);
   for (rit = new_sets.begin(), i = 0; rit != new_sets.end(); rit++, i++) {
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-25 05:20:15 UTC (rev 1922)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-25 07:01:32 UTC (rev 1923)
@@ -57,21 +57,35 @@
     // read in mesh(es)
-  ReadParallel rp(mbImpl);
-  MBEntityHandle file_set = 0;
-  result = rp.load_file(&filenames[0], filenames.size(), file_set,
-                        FileOptions(opts.c_str()), NULL, 0);
-  if (MB_SUCCESS == result) {
-    std::cout << "Success." << std::endl;
-    err = MPI_Finalize();
-    return 0;
+  std::vector<MBParallelComm *> pcs(filenames.size());
+  std::vector<ReadParallel *> rps(filenames.size());
+  std::vector<MBEntityHandle> filesets(filenames.size());
+  for (unsigned int i = 0; i < filenames.size(); i++) {
+    pcs[i] = new MBParallelComm(mbImpl);
+    rps[i] = new ReadParallel(mbImpl, pcs[i]);
+    result = rps[i]->load_file(filenames[i], filesets[i],
+                               FileOptions(opts.c_str()), NULL, 0);
+    if (MB_SUCCESS != result) {
+      std::string tmp_str;
+      std::cout << "Failure; message:" << std::endl;
+      std::cout << mbImpl->get_last_error(tmp_str) << std::endl;
+      return 1;
-  else {
-    std::string tmp_str;
-    std::cout << "Failure; message:" << std::endl;
-    std::cout << mbImpl->get_last_error(tmp_str) << std::endl;
-    return 1;
+  std::cout << "Success." << std::endl;
+  err = MPI_Finalize();
+    delete rps[i];
+    delete pcs[i];
+  delete mbImpl;
+  return 0;
 MBErrorCode get_file_options(int argc, char **argv,
