[MOAB-dev] r1917 - in MOAB/trunk: . tools/iMesh
tautges at mcs.anl.gov
Mon Jun 23 17:38:27 CDT 2008
Author: tautges
Date: 2008-06-23 17:38:27 -0500 (Mon, 23 Jun 2008)
New Revision: 1917
Modified:
MOAB/trunk/MBCN.hpp
MOAB/trunk/MBTest.cpp
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
Changing dimensions of some tables in MBCN, to save memory. Reporting those sizes from MBTest.
Checking for valid entity in iterator-based functions in iMesh.
Passes make check.
Modified: MOAB/trunk/MBCN.hpp
--- MOAB/trunk/MBCN.hpp 2008-06-23 17:01:28 UTC (rev 1916)
+++ MOAB/trunk/MBCN.hpp 2008-06-23 22:38:27 UTC (rev 1917)
@@ -42,10 +42,10 @@
#include "MBEntityType.h"
// the maximum number n-1 dimension adjacencies a element may have
-#define MB_MAX_SUB_ENTITIES 24
+#define MB_MAX_SUB_ENTITIES 12
// the maximum number of nodes an n-1 dimensional element may have
-#define MB_MAX_SUB_ENTITY_VERTICES 16
+#define MB_MAX_SUB_ENTITY_VERTICES 8
typedef std::pair<MBEntityType, MBEntityType> MBDimensionPair;
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2008-06-23 17:01:28 UTC (rev 1916)
+++ MOAB/trunk/MBTest.cpp 2008-06-23 22:38:27 UTC (rev 1917)
@@ -5827,7 +5827,14 @@
// Check command line arg to see if we should avoid doing the stress test
bool stress_test = true;
+ std::cout << "Size of mConnMap = " << sizeof(MBCN::mConnectivityMap)
+ << std::endl;
+ std::cout << "Size of mUpConnMap = " << sizeof(MBCN::mUpConnMap)
+ << std::endl;
+ std::cout << "Size of MBCN = " << sizeof(MBCN)
+ << std::endl;
for (int i = 1; i < argc; ++i) {
if (string(argv[i]) == "-nostress")
stress_test = false;
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-06-23 17:01:28 UTC (rev 1916)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-06-23 22:38:27 UTC (rev 1917)
@@ -881,18 +881,21 @@
CHECK_SIZE(*entity_handles, *entity_handles_allocated, expected_size,
iBase_EntityHandle, false);
- int& i = *entity_handles_size;
+ int j = 0, i;
for (i = 0; i < this_it->requestedSize; ++i, ++this_it->currentPos)
if (this_it->currentPos == this_it->iteratorRange.end()) {
*is_end = false;
+ *entity_handles_size = j;
RETURN(iBase_SUCCESS);
- (*entity_handles)[i] = (iBase_EntityHandle)*this_it->currentPos;
+ if (MBimesh->is_valid(*this_it->currentPos))
+ (*entity_handles)[j++] = (iBase_EntityHandle)*this_it->currentPos;
*is_end = true;
