[MOAB-dev] Bug with PSTATUS_NOT_OWNED bit
Tim Tautges tautges at mcs.anl.gov
Wed Jun 18 07:50:29 CDT 2008
mbparallelcomm_test worked as before, 2 proc works, 4 procs doesn't.
- tim
David C Thompson wrote:
> All,
> I've checked in what I believe to be a fix to MBParallelConventions.h,
> but some more eyes on the problem might prevent debugging nightmares
> down the road... The PSTATUS_NOT_OWNED macro was set to 0x0 and I
> changed it to 0x1. Since this value is apparently OR-ed together with
> other macro values, a zero value doesn't make sense. Is this the correct
> fix?
> 	Thanks,
> 	David
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
