[MOAB-dev] r1908 - MOAB/trunk/refiner
dcthomp at mcs.anl.gov
Tue Jun 17 19:52:23 CDT 2008
Author: dcthomp
Date: 2008-06-17 19:52:23 -0500 (Tue, 17 Jun 2008)
New Revision: 1908
Modified:
MOAB/trunk/refiner/test_mesh_refiner.cpp
Log:
ENH: Try out resolve_shared_ents. It does assign some
values properly to the PARALLEL_STATUS tag but
doesn't seem to get ownership right when run on
2 nodes. Specifically, vertices 1, 2, and 4 should
have the PSTATUS_NOT_OWNED bit set but don't...
Modified: MOAB/trunk/refiner/test_mesh_refiner.cpp
--- MOAB/trunk/refiner/test_mesh_refiner.cpp 2008-06-17 21:31:59 UTC (rev 1907)
+++ MOAB/trunk/refiner/test_mesh_refiner.cpp 2008-06-18 00:52:23 UTC (rev 1908)
@@ -233,14 +233,15 @@
#endif // USE_MPI
MBRefinerTagManager* tmgr = new MBRefinerTagManager( imesh, omesh );
MBEdgeSizeSimpleImplicit* eval = new MBEdgeSizeSimpleImplicit( tmgr );
+ MBParallelComm ipcomm( imesh );
double coords[][6] = {
{ 0. , 0.0, 0. , 0. , 0.0, 0. }, // 0
- { -1. , 0.0, 0.5, -1. , 0.0, 0.5 }, // 1
- { -0.5, -1.0, 0.5, -0.5, -1.0, 0.5 }, // 2
- { 0. , 0. , 1. , 0. , 0. , 1. }, // 3
- { 0.5, 0.5, 0.5, 0.5, 0.5, 0.5 }, // 4
- { 0.5, -0.5, 0.5, 0.5, -0.5, 0.5 } // 5
+ { 0. , 0. , 1. , 0. , 0. , 1. }, // 1
+ { -1. , 0.0, 0.5, -1. , 0.0, 0.5 }, // 2
+ { -0.5, -1.0, 0.5, -0.5, -1.0, 0.5 }, // 3
+ { 0.5, -0.5, 0.5, 0.5, -0.5, 0.5 }, // 4
+ { 0.5, 0.5, 0.5, 0.5, 0.5, 0.5 } // 5
double default_floatular[2] = {
@@ -267,16 +268,20 @@
int default_gid[] = { -1 };
int gid_values[] = {
- 0, 1, 2, 3, 4, 5, // vertices
- 6, 7, 8, 9 // tetrahedra
+ 1, 2, 3, 4, 5, 6, // vertices
+ 7, 8, 9, 10, // tetrahedra
+ 11, 12,
+ 13, 14,
+ 15, 16,
+ 17, 18 // triangles
// List of vertices resident on each node.
int proc_nodes[4][4] = {
- { 0, 2, 3, 1 },
+ { 0, 1, 2, 3 },
{ 0, 1, 3, 4 },
- { 0, 4, 3, 5 },
- { 0, 5, 3, 2 },
+ { 0, 1, 4, 5 },
+ { 0, 1, 5, 2 },
// List of nodes with a copy of each vertex (first entry is owner)
@@ -289,10 +294,25 @@
{ 2, 3, -1, -1 } // 5
+ int internal_bdy[4][6] = {
+ { 1, 0, 2, 0, 1, 3 },
+ /* Oops, these refer to offsets into coords array, not node_handles:
+ { 1, 0, 3, 0, 1, 4 },
+ { 1, 0, 4, 0, 1, 5 },
+ { 1, 0, 5, 0, 1, 2 }
eval->set_ratio( 2. );
MBEntityHandle node_handles[4];
MBEntityHandle tet_handle;
+ MBEntityHandle tri_handles[2];
+ MBEntityHandle tri_node_handles[6];
MBTag tag_floatular;
imesh->tag_create( "floatular", 2 * sizeof( double ), MB_TAG_DENSE, MB_TYPE_DOUBLE, tag_floatular, default_floatular );
@@ -303,8 +323,13 @@
MBTag tag_gid;
imesh->tag_create( PARALLEL_GID_TAG_NAME, sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_gid, default_gid );
- MBTag tag_spr;
- imesh->tag_create( PARALLEL_SHARED_PROCS_TAG_NAME, 4 * sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_spr, default_gid );
+ MBTag tag_sproc;
+ MBTag tag_sprocs;
+ MBTag tag_shand;
+ MBTag tag_shands;
+ MBTag tag_pstat;
+ ipcomm.get_shared_proc_tags( tag_sproc, tag_sprocs, tag_shand, tag_shands, tag_pstat );
+ MBTag tag_part = ipcomm.partition_tag();
void const* iptrs[4];
void const* fptrs[4];
@@ -314,10 +339,11 @@
int pnode = proc_nodes[rank][i];
imesh->create_vertex( coords[pnode], node_handles[i] );
+ //std::cout << rank << ": global " << (pnode + 1) << " is handle " << node_handles[i] << "\n";
iptrs[i] = (void const*) intular_values[pnode];
fptrs[i] = (void const*) floatular_values[pnode];
gptrs[i] = (void const*) &gid_values[pnode];
- sptrs[i] = (void const*) &node_procs[pnode];
+ //sptrs[i] = (void const*) &node_procs[pnode];
imesh->tag_set_data( tag_floatular, node_handles, 4, fptrs, 0 );
@@ -327,10 +353,27 @@
tmgr->add_vertex_tag( tag_intular );
imesh->tag_set_data( tag_gid, node_handles, 4, gptrs, 0 );
- imesh->tag_set_data( tag_spr, node_handles, 4, sptrs, 0 );
+ //imesh->tag_set_data( tag_sproc, node_handles, 4, sptrs, 0 );
imesh->create_element( MBTET, node_handles, 4, tet_handle );
imesh->tag_set_data( tag_gid, &tet_handle, 1, gid_values + 6 + rank );
+ for ( int i = 0; i < 6; ++ i )
+ tri_node_handles[i] = node_handles[internal_bdy[rank][i]];
+ imesh->create_element( MBTRI, tri_node_handles, 3, tri_handles[0] );
+ imesh->create_element( MBTRI, tri_node_handles + 3, 3, tri_handles[1] );
+ imesh->tag_set_data( tag_gid, tri_handles, 2, gid_values + 10 + 2 * rank );
+ //imesh->tag_set_data( tag_sprocs, &tet_handle, 1, sptrs, 0 );
+ //MBRange proc_ents( node_handles[0], tet_handle );
+ MBEntityHandle set_handle;
+ imesh->create_meshset( MESHSET_SET, set_handle );
+ imesh->tag_set_data( tag_part, &set_handle, 1, &rank );
+ imesh->add_entities( set_handle, &tet_handle, 1 );
+ ipcomm.resolve_shared_ents( 3, 2 );
+ //ipcomm.resolve_shared_ents( 3, 3 );
#ifdef USE_MPI
for ( int i = 0; i < nprocs; ++ i )
