[MOAB-dev] r1899 - MOAB/trunk/tools/mcnpmit
bmsmith at mcs.anl.gov bmsmith at mcs.anl.gov
Mon Jun 16 11:27:03 CDT 2008
Author: bmsmith
Date: 2008-06-16 11:27:02 -0500 (Mon, 16 Jun 2008)
New Revision: 1899
Modified:
   MOAB/trunk/tools/mcnpmit/main.cpp
   MOAB/trunk/tools/mcnpmit/mcnpmit.cpp
Log:
feature: added relative error data
bug: moved cfd_iter++ out of the hex-tagging loop to cover the situation in which the mcnp mesh does not cover the entire cfd mesh.  In this case some cfd coordinates will not find an mcnp hex, and this is ok.
Modified: MOAB/trunk/tools/mcnpmit/main.cpp
--- MOAB/trunk/tools/mcnpmit/main.cpp	2008-06-14 01:47:00 UTC (rev 1898)
+++ MOAB/trunk/tools/mcnpmit/main.cpp	2008-06-16 16:27:02 UTC (rev 1899)
@@ -23,7 +23,7 @@
 MCNPError next_int(std::string, int&, int&);
 MCNPError result;
-MBTag     coord_tag, rotation_tag, cfd_heating_tag;
+MBTag     coord_tag, rotation_tag, cfd_heating_tag, cfd_error_tag;
 std::string h5m_filename;
 std::string CAD_filename;
@@ -160,6 +160,7 @@
     cfd_iter = cfd_verts.begin();
     MBresult = MBI->tag_create("heating_tag", sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE, cfd_heating_tag, 0);
+    MBresult = MBI->tag_create("error_tag", sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE, cfd_error_tag, 0);
     std::cout << std::endl << "Read in mesh with query points." << std::endl << std::endl;
@@ -169,6 +170,8 @@
   double     testpt[3];
   double     transformed_pt[3];
   double     taldata;
+  double     errdata;
   MBCartVect testvc;
   bool found = false;
@@ -249,16 +252,19 @@
       if (MBElemUtil::point_in_trilinear_hex(hexverts, testvc, 1.e-6)) {
-    	  MBresult = MBI -> tag_get_data( MCNP->tally_tag, &(*rit), 1, &taldata);
-	  outfile <<   n         << ","
+    	MBresult = MBI -> tag_get_data( MCNP->tally_tag, &(*rit), 1, &taldata);
+	MBresult = MBI -> tag_get_data( MCNP->relerr_tag, &(*rit), 1, &errdata);
+	outfile <<   n         << ","
 	            << testpt[0] << ","
 	  	    << testpt[1] << ","
 		    << testpt[2] << ","
-		    << taldata   << std::endl;
+		    << taldata   << ","
+		    << errdata   << std::endl;
         if (!read_qnv) {
           MBresult = MBI->tag_set_data(cfd_heating_tag, &(*cfd_iter), 1, &taldata);
-          cfd_iter++;
+	  MBresult = MBI->tag_set_data(cfd_error_tag, &(*cfd_iter), 1, &errdata);
         found = true;
@@ -268,6 +274,8 @@
+    if (!read_qnv) cfd_iter++;
     if (!found) {
       std::cout << n << " " << testvc << std::endl;
Modified: MOAB/trunk/tools/mcnpmit/mcnpmit.cpp
--- MOAB/trunk/tools/mcnpmit/mcnpmit.cpp	2008-06-14 01:47:00 UTC (rev 1898)
+++ MOAB/trunk/tools/mcnpmit/mcnpmit.cpp	2008-06-16 16:27:02 UTC (rev 1899)
@@ -341,8 +341,8 @@
       // Need to read in relative error entry and tag ...
       result = next_number(s, d, fpos);
       if (result == MCNP_FAILURE) return MCNP_FAILURE;
-      // MBresult = MBI -> tag_set_data(relerr_tag, &handle, 1, &d);
-      // if (MBresult != MB_SUCCESS) return MCNP_FAILURE;
+      MBresult = MBI -> tag_set_data(relerr_tag, &handle, 1, &d);
+      if (MBresult != MB_SUCCESS) return MCNP_FAILURE;
       return MCNP_SUCCESS;
