[MOAB-dev] r1897 - MOAB/trunk/tools/iMesh
tautges at mcs.anl.gov tautges at mcs.anl.gov
Fri Jun 13 15:19:20 CDT 2008
Author: tautges
Date: 2008-06-13 15:19:20 -0500 (Fri, 13 Jun 2008)
New Revision: 1897
Modified:
   MOAB/trunk/tools/iMesh/iMesh.h
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
Committing initial implementation of setAdjTable.  This implementation does nothing with the off-diagonal entries, and initializes the adj table so that vert-ent, ent-vert, vert-vert and 3dent-3dent adj entries are one (i.e. the diagonal entries for edges and faces are zero, the others are one).
Passes make check.
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h	2008-06-13 19:16:47 UTC (rev 1896)
+++ MOAB/trunk/tools/iMesh/iMesh.h	2008-06-13 20:19:20 UTC (rev 1897)
@@ -262,6 +262,26 @@
                           /*out*/ int* adjacency_table_size,
                           /*out*/ int *err);
+    /**\brief  Set the adjacency table and interior entity information for this implementation
+     * Set the adjacency table and interior entity information for this
+     * implementation.  This table
+     * is a 4x4 array, with indices 0-based, where A(i,j) (i=row, j=column)
+     * non-zero requests that adjacencies be stored explicitly from type i
+     * to type j.  Non-zero diagonal elements request that interior entities
+     * of that dimension be represented explicitly, and created along with
+     * higher-dimensional entities.
+     * \param instance iMesh instance handle
+     * \param *adjacency_table Array representing adjacency table
+     *        passed to function
+     * \param adjacency_table_size Size of adjacency table (should be 16)
+     * \param *err Pointer to error type returned from function
+  void iMesh_setAdjTable (iMesh_Instance instance,
+                          /*in*/ int* adjacency_table,
+                          /*in*/ int adjacency_table_size,
+                          /*out*/ int *err);
     /**\brief  Get the number of entities with the specified type in the instance or set
      * Get the number of entities with the specified type in the instance
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-06-13 19:16:47 UTC (rev 1896)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-06-13 20:19:20 UTC (rev 1897)
@@ -10,6 +10,7 @@
 #endif
 #include <iostream>
+#include <cassert>
 #define MIN(a,b) (a < b ? a : b)
 class MBiMesh : public MBCore
@@ -17,9 +18,7 @@
 private:
   bool haveDeletedEntities;
 public:
-  MBiMesh(int proc_rank = 0, int proc_size = 1)
-      : MBCore(proc_rank, proc_size), haveDeletedEntities(false)
+  MBiMesh(int proc_rank = 0, int proc_size = 1);
   virtual ~MBiMesh();
   bool have_deleted_ents( bool reset ) {
@@ -32,8 +31,17 @@
   virtual MBErrorCode delete_mesh();
   virtual MBErrorCode delete_entities( const MBEntityHandle*, const int );
   virtual MBErrorCode delete_entities( const MBRange& );
+  int AdjTable[16];
+MBiMesh::MBiMesh(int proc_rank, int proc_size)
+    : MBCore(proc_rank, proc_size), haveDeletedEntities(false)
+  memset(AdjTable, 0, 16*sizeof(int));
+  for (int i = 0; i < 4; i++) AdjTable[4*i] = AdjTable[i] = 1;
+  AdjTable[15] = 1;
 MBiMesh::~MBiMesh() {}
 MBErrorCode MBiMesh::delete_mesh() {
@@ -55,6 +63,10 @@
   return MBCore::delete_entities( r );
+MBErrorCode create_int_ents(MBInterface *instance,
+                            MBRange &from_ents,
+                            MBEntityHandle in_set = 0);
 #define CHECK_SIZE(array, allocated, size, type, retval)  \
   if (0 != allocated && NULL != array && allocated < (size)) {\
     iMesh_processError(iBase_MEMORY_ALLOCATION_FAILED, \
@@ -187,6 +199,7 @@
 #define MBI reinterpret_cast<MBInterface*>(instance)
+#define MBimesh reinterpret_cast<MBiMesh*>(instance)
 #define RETURN(a) {iMesh_LAST_ERROR.error_type = a; *err = a;return;}
 #define iMesh_processError(a, b) {sprintf(iMesh_LAST_ERROR.description, "%s", b); iMesh_LAST_ERROR.error_type = a; *err = a;}
@@ -306,6 +319,15 @@
       iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
+      // create interior edges/faces if requested
+    if (MBimesh->AdjTable[5] || MBimesh->AdjTable[10]) {
+      MBRange set_ents;
+      result = MBI->get_entities_by_handle(file_set, set_ents, true);
+      if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
+      result = create_int_ents(MBI, set_ents, file_set);
@@ -360,12 +382,26 @@
                           /*inout*/ int* adjacency_table_allocated,
                           /*out*/ int* adjacency_table_size, int *err)
-    *adjacency_table_allocated = 0;
-    *adjacency_table_size = 0;
-    *adjacency_table = NULL;
+    *adjacency_table_size = 16;
+    CHECK_SIZE(*adjacency_table, *adjacency_table_allocated,
+               *adjacency_table_size, int, iBase_MEMORY_ALLOCATION_FAILED);
+    memcpy(*adjacency_table, MBimesh->AdjTable, 16*sizeof(int));
     RETURN(iBase_ERROR_MAP[MB_SUCCESS]);
+                          int* adj_table,
+                          /*inout*/ int adj_table_size,
+                          int *err)
+    if (16 != adj_table_size) {
+      RETURN(iBase_INVALID_ARGUMENT);
+    memcpy(MBimesh->AdjTable, adj_table, 16*sizeof(int));
+    RETURN(iBase_SUCCESS);
   void iMesh_getNumOfType(iMesh_Instance instance,
                           /*in*/ const iBase_EntitySetHandle entity_set_handle,
                           /*in*/ const int entity_type,
@@ -1563,6 +1599,14 @@
       *status_size = num_ents;
+      MBRange set_ents;
+      std::copy(HANDLE_ARRAY_PTR(*new_entity_handles),
+                HANDLE_ARRAY_PTR(*new_entity_handles)+*new_entity_handles_size,
+                mb_range_inserter(set_ents));
+      result = create_int_ents(MBI, set_ents);
@@ -2945,6 +2989,42 @@
   return result;
+                            MBEntityHandle in_set)
+  assert(MBimesh->AdjTable[10] || MBimesh->AdjTable[5]);
+  MBRange int_ents;
+  MBErrorCode result;
+  if (MBimesh->AdjTable[10]) {
+    result = MBI->get_adjacencies(from_ents, 2, true, int_ents,
+                                  MBInterface::UNION);
+    if (MB_SUCCESS != result) return result;
+    unsigned int old_size = from_ents.size();
+    from_ents.merge(int_ents);
+    if (old_size != from_ents.size()) {
+      result = MBI->add_entities(in_set, int_ents);
+  if (MBimesh->AdjTable[5]) {
+    int_ents.clear();
+    result = MBI->get_adjacencies(from_ents, 1, true, int_ents,
+  return MB_SUCCESS;
 void eatwhitespace(std::string &this_string)
   std::string::size_type len = this_string.find_last_not_of(" ");
