[MOAB-dev] error: The package name "iMesh_SIDL" is illegal because it has an underbar (_)
Tim Tautges tautges at mcs.anl.gov
Tue Jun 10 11:27:58 CDT 2008
MOAB's only compatible right now with SIDL 0.10.12.  There are specific
changes required to go to 1.x that we haven't made yet.  I'll put the
question to the ITAPS group in general (if you're interested in doing
that I'd very much welcome that too).  We've gone to a common
implementation of the SIDL interface on top of our C interface, but
right now that implementation is supposed to be ours.
- tim
de Almeida, Valmor F. wrote:
> This is a more involved config build
> ./configure --prefix=$HOME/projects/scidac/itaps/moab-usr
> --enable-doxygen=/usr/bin  --enable-imesh --with-mpi=/usr/local/ompi_gnu
> --with-zlib=/ --with-szip=/ --with-hdf5=/usr/lib --with-netcdf=/usr/lib
> --with-babel=/usr/local/cca-tools
> The configure went fine I think. Here is where make stopped:
> ...snip...
> make[4]: Leaving directory
> `/home/dealmeida/projects/scidac/itaps/moab-dev/tools/iMesh'
> Making all in SIDL
> make[4]: Entering directory
> `/home/dealmeida/projects/scidac/itaps/moab-dev/tools/iMesh/SIDL'
> test -d mserver || /bin/mkdir -p mserver || exit 1
> /usr/local/cca-tools/bin/babel -sC++ ./iBase.sidl ./iMesh.sidl
> ./iMesh_SIDL.sidl -o mserver
> - #1----------------------------------------
> /home/dealmeida/projects/scidac/itaps/moab-dev/tools/iMesh/SIDL/iMesh_SI
> DL.sidl:4: error: The package name "iMesh_SIDL" is illegal because it
> has an underbar (_).
> package iMesh_SIDL version 0.002 {
> make[4]: *** [mserver/babel.make] Error 88
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> `/home/dealmeida/projects/scidac/itaps/moab-dev/tools'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/home/dealmeida/projects/scidac/itaps/moab-dev'
> make: *** [all] Error 2
> Here is babel's version
> ->babel --version
> Babel version 1.0.8
> Is this a matter of upgrading babel or another issue?
> Thanks,
> Valmor
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
