[MOAB-dev] MOAB distcheck failed.
Nightly Test kraftche at cae.wisc.edu
Fri Jun 6 02:01:31 CDT 2008
../DualTool.cpp: In member function 'MBErrorCode DualTool::split_pair_nonmanifold(MBEntityHandle*, MBEntityHandle*, MBEntityHandle*, std::vector<long unsigned int, std::allocator<long unsigned int> >*, std::vector<long unsigned int, std::allocator<long unsigned int> >*, MBEntityHandle*, MBEntityHandle*, MBEntityHandle*, MBEntityHandle*, MBEntityHandle*)':
../DualTool.cpp:1976: warning: unused variable 'cond1'
../DualTool.cpp:1985: warning: unused variable 'cond2'
../DualTool.cpp: In member function 'MBErrorCode DualTool::foc_get_stars(MBEntityHandle*, MBEntityHandle*, std::vector<long unsigned int, std::allocator<long unsigned int> >*, std::vector<long unsigned int, std::allocator<long unsigned int> >*)':
../DualTool.cpp:2096: warning: 'on_bdy' may be used uninitialized in this function
../MBAdaptiveKDTree.cpp:1581: warning: 'MBErrorCode closest_to_triangles(MBInterface*, MBEntityHandle, double, const MBCartVect&, std::vector<long unsigned int, std::allocator<long unsigned int> >&, std::vector<MBCartVect, std::allocator<MBCartVect> >&)' defined but not used
../ReadIDEAS.cpp: In constructor 'ReadIDEAS::ReadIDEAS(MBInterface*)':
../ReadIDEAS.cpp:20: warning: dereferencing type-punned pointer will break strict-aliasing rules
../WriteGMV.cpp: In constructor 'WriteGMV::WriteGMV(MBInterface*)':
../WriteGMV.cpp:60: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_save_(void*, void*, const char*, const char*, int*, int, int)':
../../../tools/iMesh/iMesh_MOAB.cpp:324: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_destroyentset_(void*, void*, int*)':
../../../tools/iMesh/iMesh_MOAB.cpp:1054: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_addentset_(void*, void*, void**, int*)':
../../../tools/iMesh/iMesh_MOAB.cpp:1194: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_rmventset_(void*, void*, void**, int*)':
../../../tools/iMesh/iMesh_MOAB.cpp:1211: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_setentsetdata_(void*, void*, void*, const char*, int, int*)':
../../../tools/iMesh/iMesh_MOAB.cpp:1788: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_rmventsettag_(void*, void*, void*, int*)':
../../../tools/iMesh/iMesh_MOAB.cpp:1948: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../tools/iMesh/iMesh_MOAB.cpp: In function 'void imesh_getentsbytagsrec_(void*, void*, int, int, void* const*, const char* const*, int, int, void***, int*, int*, int*)':
../../../tools/iMesh/iMesh_MOAB.cpp:2844: warning: 'result' may be used uninitialized in this function
../../../tools/mbcoupler/findpt.c:14:25: error: extrafindpt.h: No such file or directory
../../../tools/mbcoupler/errmem.h:33: warning: 'scalloc' defined but not used
../../../tools/mbcoupler/errmem.h:56: warning: 'buffer_init_' defined but not used
../../../tools/mbcoupler/errmem.h:60: warning: 'buffer_reserve_' defined but not used
../../../tools/mbcoupler/errmem.h:68: warning: 'buffer_free' defined but not used
../../../tools/mbcoupler/poly.c:370: warning: 'lagrange_0' defined but not used
../../../tools/mbcoupler/poly.c:379: warning: 'lagrange_1' defined but not used
../../../tools/mbcoupler/poly.c:412: warning: 'lagrange_2u' defined but not used
../../../tools/mbcoupler/findpt.c:1202: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1231: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1236: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1244: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1256: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1262: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1288: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1302: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1319: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1325: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1345: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1375: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1387: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1401: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1407: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1416: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1439: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1447: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1453: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c:1461: error: expected ')' before '*' token
../../../tools/mbcoupler/findpt.c: In function 'opt_findpt_2':
../../../tools/mbcoupler/findpt.c:1769: error: 'opt_no_constraints_2' undeclared (first use in this function)
../../../tools/mbcoupler/findpt.c:1769: error: (Each undeclared identifier is reported only once
../../../tools/mbcoupler/findpt.c:1769: error: for each function it appears in.)
../../../tools/mbcoupler/findpt.c: At top level:
../../../tools/mbcoupler/findpt.c:1954: error: expected specifier-qualifier-list before 'opt_data_3'
../../../tools/mbcoupler/findpt.c: In function 'findpt_setup_3':
../../../tools/mbcoupler/findpt.c:1996: error: 'findpt_data_3' has no member named 'od'
../../../tools/mbcoupler/findpt.c:1996: error: 'opt_data_3' undeclared (first use in this function)
../../../tools/mbcoupler/findpt.c:1996: error: expected expression before ')' token
../../../tools/mbcoupler/findpt.c:2012: warning: implicit declaration of function 'opt_alloc_3'
../../../tools/mbcoupler/findpt.c:2012: error: 'findpt_data_3' has no member named 'od'
../../../tools/mbcoupler/findpt.c:2013: error: 'findpt_data_3' has no member named 'od_work'
../../../tools/mbcoupler/findpt.c:2013: error: 'findpt_data_3' has no member named 'od'
../../../tools/mbcoupler/findpt.c: In function 'findpt_free_3':
../../../tools/mbcoupler/findpt.c:2032: warning: implicit declaration of function 'opt_free_3'
../../../tools/mbcoupler/findpt.c:2032: error: 'findpt_data_3' has no member named 'od'
../../../tools/mbcoupler/findpt.c: In function 'findpt_guess_2':
../../../tools/mbcoupler/findpt.c:2098: error: 'opt_no_constraints_2' undeclared (first use in this function)
../../../tools/mbcoupler/findpt.c: In function 'findpt_guess_3':
../../../tools/mbcoupler/findpt.c:2111: error: 'opt_no_constraints_3' undeclared (first use in this function)
../../../tools/mbcoupler/findpt.c:2114: warning: implicit declaration of function 'opt_findpt_3'
../../../tools/mbcoupler/findpt.c:2114: error: 'findpt_data_3' has no member named 'od'
../../../tools/mbcoupler/findpt.c: In function 'findpt_pass_2':
../../../tools/mbcoupler/findpt.c:2129: error: 'opt_no_constraints_2' undeclared (first use in this function)
../../../tools/mbcoupler/findpt.c: In function 'findpt_pass_3':
../../../tools/mbcoupler/findpt.c:2151: error: 'opt_no_constraints_3' undeclared (first use in this function)
../../../tools/mbcoupler/findpt.c:2152: error: 'findpt_data_3' has no member named 'od'
../../../tools/mbcoupler/findpt.c: In function 'findpt_eval_3':
../../../tools/mbcoupler/findpt.c:2215: error: 'findpt_data_3' has no member named 'od_work'
make[4]: *** [findpt.lo] Error 1
make[4]: *** Waiting for unfinished jobs....
../../../tools/mbcoupler/MBElemUtil.cpp:194:25: error: extrafindpt.h: No such file or directory
../../../tools/mbcoupler/MBElemUtil.cpp: In static member function 'static void MBElemUtil::hex_findpt(real**, int, MBCartVect, MBCartVect&, double&)':
../../../tools/mbcoupler/MBElemUtil.cpp:208: error: 'opt_data_3' was not declared in this scope
../../../tools/mbcoupler/MBElemUtil.cpp:208: error: expected `;' before 'data'
../../../tools/mbcoupler/MBElemUtil.cpp:217: error: 'data' was not declared in this scope
../../../tools/mbcoupler/MBElemUtil.cpp:217: error: 'opt_alloc_3' was not declared in this scope
../../../tools/mbcoupler/MBElemUtil.cpp:224: error: 'opt_no_constraints_3' was not declared in this scope
../../../tools/mbcoupler/MBElemUtil.cpp:225: error: 'opt_findpt_3' was not declared in this scope
../../../tools/mbcoupler/MBElemUtil.cpp:232: error: 'opt_free_3' was not declared in this scope
../../../tools/mbcoupler/poly.h: At global scope:
../../../tools/mbcoupler/poly.h:158: warning: 'void lagrange_1(lagrange_data*, real)' defined but not used
../../../tools/mbcoupler/poly.h:173: warning: 'void lagrange_2(lagrange_data*, real)' defined but not used
../../../tools/mbcoupler/poly.h:191: warning: 'void lagrange_2u(lagrange_data*)' defined but not used
../../../tools/mbcoupler/findpt.h:58: warning: 'void findpt_weights_2(findpt_data_2*, const real*)' defined but not used
../../../tools/mbcoupler/findpt.h:64: warning: 'void findpt_weights_3(findpt_data_3*, const real*)' defined but not used
../../../tools/mbcoupler/findpt.h:71: warning: 'double findpt_eval_2(findpt_data_2*, const real*)' defined but not used
../../../tools/mbcoupler/findpt.h:78: warning: 'double findpt_eval_3(findpt_data_3*, const real*)' defined but not used
../../../tools/mbcoupler/errmem.h:32: warning: 'void* scalloc(size_t, size_t, const char*)' defined but not used
../../../tools/mbcoupler/errmem.h:55: warning: 'void buffer_init_(buffer*, size_t, const char*)' defined but not used
../../../tools/mbcoupler/errmem.h:59: warning: 'void buffer_reserve_(buffer*, size_t, const char*)' defined but not used
../../../tools/mbcoupler/errmem.h:68: warning: 'void buffer_free(buffer*)' defined but not used
make[4]: *** [MBElemUtil.lo] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all] Error 2
make: *** [distcheck] Error 2
home/jason/moab/test/dist/moab-3.99/parallel/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99/parallel && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        top_distdir="$top_distdir" \
	        distdir="$distdir/$subdir" \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[1]: Leaving directory `/home/jason/moab/test/dist/parallel'
make[1]: Entering directory `/home/jason/moab/test/dist/test'
list='dual h5file obb perf'; for subdir in $list; do \
	  if test "$subdir" = .; then :; else \
	    test -d "/home/jason/moab/test/dist/moab-3.99/test/$subdir" \
	    || mkdir -p -- "/home/jason/moab/test/dist/moab-3.99/test/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99/test && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[2]: Entering directory `/home/jason/moab/test/dist/test/dual'
make[2]: Leaving directory `/home/jason/moab/test/dist/test/dual'
make[2]: Entering directory `/home/jason/moab/test/dist/test/h5file'
make[2]: Leaving directory `/home/jason/moab/test/dist/test/h5file'
make[2]: Entering directory `/home/jason/moab/test/dist/test/obb'
make[2]: Leaving directory `/home/jason/moab/test/dist/test/obb'
make[2]: Entering directory `/home/jason/moab/test/dist/test/perf'
make[2]: Leaving directory `/home/jason/moab/test/dist/test/perf'
make[1]: Leaving directory `/home/jason/moab/test/dist/test'
make[1]: Entering directory `/home/jason/moab/test/dist/tools'
mkdir -p -- /home/jason/moab/test/dist/moab-3.99/tools/mbzoltan
list='iMesh converter hexmodops mbchaco mbcoupler mbzoltan mbperf mcnpmit qvdual size skin tagprop spheredecomp surfplot dagmc'; for subdir in $list; do \
	    test -d "/home/jason/moab/test/dist/moab-3.99/tools/$subdir" \
	    || mkdir -p -- "/home/jason/moab/test/dist/moab-3.99/tools/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99/tools && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[2]: Entering directory `/home/jason/moab/test/dist/tools/iMesh'
list='. SIDL'; for subdir in $list; do \
	    test -d "/home/jason/moab/test/dist/moab-3.99/tools/iMesh/$subdir" \
	    || mkdir -p -- "/home/jason/moab/test/dist/moab-3.99/tools/iMesh/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/moab/test/dist/moab-3.99/tools/iMesh && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[3]: Entering directory `/home/jason/moab/test/dist/tools/iMesh/SIDL'
test -d /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL || mkdir -p -- /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL || exit 1
test -d /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver || mkdir -p -- /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver || exit 1
cp -p ../../../../src/tools/iMesh/SIDL/iBase.sidl /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/iBase.sidl
cp -p ../../../../src/tools/iMesh/SIDL/iMesh.sidl /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/iMesh.sidl
cp -p ../../../../src/tools/iMesh/SIDL/iMesh_SIDL.sidl /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/iMesh_SIDL.sidl
cp -p ../../../../src/tools/iMesh/SIDL/mserver/iBase_Error_Impl.cc /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver/iBase_Error_Impl.cc
cp -p ../../../../src/tools/iMesh/SIDL/mserver/iBase_Error_Impl.hh /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver/iBase_Error_Impl.hh
cp -p ../../../../src/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.cc
cp -p ../../../../src/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.hh /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver/iMesh_SIDL_MeshSidl_Impl.hh
cp -p ../../../../src/tools/iMesh/SIDL/iBase_SIDL_defs.h /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/iBase_SIDL_defs.h
cp -p ../../../../src/tools/iMesh/SIDL/testcxx.cpp /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/testcxx.cpp
cp -p ../../../../src/tools/iMesh/SIDL/mserver.make /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/mserver.make
cp -p ../../../../src/tools/iMesh/SIDL/Cclient.make /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/Cclient.make
cp -p ../../../../src/tools/iMesh/SIDL/Fclient.make /home/jason/moab/test/dist/moab-3.99/tools/iMesh/SIDL/Fclient.make
make[3]: Leaving directory `/home/jason/moab/test/dist/tools/iMesh/SIDL'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/iMesh'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/converter'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/converter'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/hexmodops'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/hexmodops'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/mbchaco'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/mbchaco'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/mbcoupler'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/mbcoupler'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/mbzoltan'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/mbzoltan'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/mbperf'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/mbperf'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/mcnpmit'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/mcnpmit'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/qvdual'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/qvdual'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/size'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/size'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/skin'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/skin'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/tagprop'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/tagprop'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/spheredecomp'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/spheredecomp'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/surfplot'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/surfplot'
make[2]: Entering directory `/home/jason/moab/test/dist/tools/dagmc'
make[2]: Leaving directory `/home/jason/moab/test/dist/tools/dagmc'
make[1]: Leaving directory `/home/jason/moab/test/dist/tools'
make[1]: Entering directory `/home/jason/moab/test/dist/doc'
make[1]: Leaving directory `/home/jason/moab/test/dist/doc'
make[1]: Entering directory `/home/jason/moab/test/dist/doxygen'
make[1]: Leaving directory `/home/jason/moab/test/dist/doxygen'
find moab-3.99 -type d ! -perm -777 -exec chmod a+rwx {} \; -o \
	  ! -type d ! -perm -444 -links 1 -exec chmod a+r {} \; -o \
	  ! -type d ! -perm -400 -exec chmod a+r {} \; -o \
	  ! -type d ! -perm -444 -exec /bin/sh /home/jason/moab/test/src/install-sh -c -m a+r {} {} \; \
	|| chmod -R a+r moab-3.99
tardir=moab-3.99 && /bin/sh /home/jason/moab/test/src/missing --run tar chof - "$tardir" | GZIP=--best gzip -c >moab-3.99.tar.gz
{ test ! -d moab-3.99 || { find moab-3.99 -type d ! -perm -200 -exec chmod u+w {} ';' && rm -fr moab-3.99; }; }
case 'moab-3.99.tar.gz' in \
	*.tar.gz*) \
	  GZIP=--best gunzip -c moab-3.99.tar.gz | /bin/sh /home/jason/moab/test/src/missing --run tar xf - ;;\
	*.tar.bz2*) \
	  bunzip2 -c moab-3.99.tar.bz2 | /bin/sh /home/jason/moab/test/src/missing --run tar xf - ;;\
	*.tar.Z*) \
	  uncompress -c moab-3.99.tar.Z | /bin/sh /home/jason/moab/test/src/missing --run tar xf - ;;\
	*.shar.gz*) \
	  GZIP=--best gunzip -c moab-3.99.shar.gz | unshar ;;\
	*.zip*) \
	  unzip moab-3.99.zip ;;\
	esac
chmod -R a-w moab-3.99; chmod a+w moab-3.99
mkdir moab-3.99/_build
mkdir moab-3.99/_inst
chmod a-w moab-3.99
dc_install_base=`CDPATH="${ZSH_VERSION+.}:" && cd moab-3.99/_inst && pwd | sed -e 's,^[^:\\/]:[\\/],/,'` \
	  && dc_destdir="${TMPDIR-/tmp}/am-dc-$$/" \
	  && cd moab-3.99/_build \
	  && ../configure --srcdir=.. --prefix="$dc_install_base" \
	  && make  \
	  && make  dvi \
	  && make  check \
	  && make  install \
	  && make  installcheck \
	  && make  uninstall \
	  && make  distuninstallcheck_dir="$dc_install_base" \
	        distuninstallcheck \
	  && chmod -R a-w "$dc_install_base" \
	       (cd ../.. && umask 077 && mkdir "$dc_destdir") \
	       && make  DESTDIR="$dc_destdir" install \
	       && make  DESTDIR="$dc_destdir" uninstall \
	       && make  DESTDIR="$dc_destdir" \
	            distuninstallcheck_dir="$dc_destdir" distuninstallcheck; \
	      } || { rm -rf "$dc_destdir"; exit 1; }) \
	  && rm -rf "$dc_destdir" \
	  && make  dist \
	  && rm -rf moab-3.99.tar.gz \
	  && make  distcleancheck
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking dependency style of cc... gcc3
checking how to run the C preprocessor... cc -E
checking for CC... no
checking for aCC... no
checking for cxx... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking dependency style of c++... gcc3
checking how to run the C++ preprocessor... c++ -E
checking for known C compilers... GNU
checking for known compiler/OS combinations... GNU:x86_64
checking for known c++ compilers... GNU
checking whether ln -s works... yes
checking whether make sets $(MAKE)... (cached) yes
checking for gfortran... gfortran
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognise dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g77... g77
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g77 accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by c++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for c++ option to produce PIC... -fPIC
checking if c++ PIC flag -fPIC works... yes
checking if c++ static flag -static works... yes
checking if c++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for g77 option to produce PIC... -fPIC
checking if g77 PIC flag -fPIC works... yes
checking if g77 static flag -static works... yes
checking if g77 supports -c -o file.o... yes
checking whether the g77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for gunzip... gunzip -c
checking for gzip... (cached) gunzip -c
checking for zcat... (cached) gunzip -c
checking if C++ compiler supports template specialization... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.3.1 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.1/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for sys/types.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for size_t... yes
checking for ptrdiff_t... yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking for deflate in -lz... yes
checking for SZ_Decompress in -lsz... no
checking if HDF5 support is enabled... yes
checking hdf5.h usability... yes
checking hdf5.h presence... yes
checking for hdf5.h... yes
checking for H5Fopen in -lhdf5... yes
checking if NetCDF support is enabled... yes
checking strstream.h usability... no
checking strstream.h presence... no
checking for strstream.h... no
checking sstream.h usability... no
checking sstream.h presence... no
checking for sstream.h... no
checking strstream usability... yes
checking strstream presence... yes
checking for strstream... yes
checking netcdf.h usability... yes
checking netcdf.h presence... yes
checking for netcdf.h... yes
checking for netcdf.hh... yes
checking for netcdf_c++ library... yes
checking if mbconvert is to be built... yes
checking if hexmodops is to be built... yes
checking if mbchaco is to be built... no
checking if mbperf is to be built... yes
checking if qvdual is to be built... no
checking if mbsize is to be built... yes
checking if mbskin is to be built... yes
checking if mbtagprop is to be built... yes
checking if mcnpmit is to be built... yes
checking if mbcoupler is to be built... yes
checking if spheredecomp is to be built... yes
checking if mbsurfplot is to be built... yes
checking if mbzoltan is to be built... no
checking if dagmc is to be built... yes
checking if iMesh support is to be built... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating testdir.h
config.status: creating parallel/Makefile
config.status: creating mhdf/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating tools/Makefile
config.status: creating tools/converter/Makefile
config.status: creating tools/hexmodops/Makefile
config.status: creating tools/iMesh/Makefile
config.status: creating tools/iMesh/iMesh-Defs.inc
config.status: creating tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
config.status: creating tools/iMesh/SIDL/Makefile
config.status: creating tools/iMesh/SIDL/common.make
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbchaco/Makefile
config.status: creating tools/mbcoupler/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/mcnpmit/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/size/Makefile
config.status: creating tools/skin/Makefile
config.status: creating tools/tagprop/Makefile
config.status: creating tools/spheredecomp/Makefile
config.status: creating tools/surfplot/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating tools/dagmc/dagmc.make
config.status: creating doc/Makefile
config.status: creating doxygen/Makefile
config.status: creating config.h
config.status: creating MBVersion.h
config.status: creating MBEntityHandle.h
config.status: creating MBCN_FCDefs.h
config.status: executing depfiles commands
C:   cc  -Wall -pipe -O2 -DNDEBUG
C++: c++  -Wall -pipe -O2 -DNDEBUG
make[1]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build'
make  all-recursive
make[2]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build'
Making all in mhdf
make[3]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/mhdf'
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT adjacency.lo -MD -MP -MF ".deps/adjacency.Tpo" -c -o adjacency.lo `test -f 'src/adjacency.c' || echo '../../mhdf/'`src/adjacency.c; \
	then mv -f ".deps/adjacency.Tpo" ".deps/adjacency.Plo"; else rm -f ".deps/adjacency.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT connectivity.lo -MD -MP -MF ".deps/connectivity.Tpo" -c -o connectivity.lo `test -f 'src/connectivity.c' || echo '../../mhdf/'`src/connectivity.c; \
	then mv -f ".deps/connectivity.Tpo" ".deps/connectivity.Plo"; else rm -f ".deps/connectivity.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT file-handle.lo -MD -MP -MF ".deps/file-handle.Tpo" -c -o file-handle.lo `test -f 'src/file-handle.c' || echo '../../mhdf/'`src/file-handle.c; \
	then mv -f ".deps/file-handle.Tpo" ".deps/file-handle.Plo"; else rm -f ".deps/file-handle.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT file.lo -MD -MP -MF ".deps/file.Tpo" -c -o file.lo `test -f 'src/file.c' || echo '../../mhdf/'`src/file.c; \
	then mv -f ".deps/file.Tpo" ".deps/file.Plo"; else rm -f ".deps/file.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT nodes.lo -MD -MP -MF ".deps/nodes.Tpo" -c -o nodes.lo `test -f 'src/nodes.c' || echo '../../mhdf/'`src/nodes.c; \
	then mv -f ".deps/nodes.Tpo" ".deps/nodes.Plo"; else rm -f ".deps/nodes.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT sets.lo -MD -MP -MF ".deps/sets.Tpo" -c -o sets.lo `test -f 'src/sets.c' || echo '../../mhdf/'`src/sets.c; \
	then mv -f ".deps/sets.Tpo" ".deps/sets.Plo"; else rm -f ".deps/sets.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT status.lo -MD -MP -MF ".deps/status.Tpo" -c -o status.lo `test -f 'src/status.c' || echo '../../mhdf/'`src/status.c; \
	then mv -f ".deps/status.Tpo" ".deps/status.Plo"; else rm -f ".deps/status.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT tags.lo -MD -MP -MF ".deps/tags.Tpo" -c -o tags.lo `test -f 'src/tags.c' || echo '../../mhdf/'`src/tags.c; \
	then mv -f ".deps/tags.Tpo" ".deps/tags.Plo"; else rm -f ".deps/tags.Tpo"; exit 1; fi
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT connectivity.lo -MD -MP -MF .deps/connectivity.Tpo -c ../../mhdf/src/connectivity.c -o connectivity.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT sets.lo -MD -MP -MF .deps/sets.Tpo -c ../../mhdf/src/sets.c -o sets.o
if /bin/sh ../libtool --tag=CC --mode=compile cc -I../../mhdf/include  -I. -I../../mhdf -I.. -I.. -I.. -I..     -Wall -pipe -O2 -DNDEBUG -MT util.lo -MD -MP -MF ".deps/util.Tpo" -c -o util.lo `test -f 'src/util.c' || echo '../../mhdf/'`src/util.c; \
	then mv -f ".deps/util.Tpo" ".deps/util.Plo"; else rm -f ".deps/util.Tpo"; exit 1; fi
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT status.lo -MD -MP -MF .deps/status.Tpo -c ../../mhdf/src/status.c -o status.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT adjacency.lo -MD -MP -MF .deps/adjacency.Tpo -c ../../mhdf/src/adjacency.c -o adjacency.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT tags.lo -MD -MP -MF .deps/tags.Tpo -c ../../mhdf/src/tags.c -o tags.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT file.lo -MD -MP -MF .deps/file.Tpo -c ../../mhdf/src/file.c -o file.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT nodes.lo -MD -MP -MF .deps/nodes.Tpo -c ../../mhdf/src/nodes.c -o nodes.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT util.lo -MD -MP -MF .deps/util.Tpo -c ../../mhdf/src/util.c -o util.o
 cc -I../../mhdf/include -I. -I../../mhdf -I.. -I.. -I.. -I.. -Wall -pipe -O2 -DNDEBUG -MT file-handle.lo -MD -MP -MF .deps/file-handle.Tpo -c ../../mhdf/src/file-handle.c -o file-handle.o
/bin/sh ../libtool --tag=CC --mode=link cc  -Wall -pipe -O2 -DNDEBUG  -lm -o libmhdf.la   adjacency.lo connectivity.lo file-handle.lo file.lo nodes.lo sets.lo status.lo tags.lo util.lo -lhdf5 -lm
mkdir .libs
ar cru .libs/libmhdf.a  adjacency.o connectivity.o file-handle.o file.o nodes.o sets.o status.o tags.o util.o
ranlib .libs/libmhdf.a
creating libmhdf.la
(cd .libs && rm -f libmhdf.la && ln -s ../libmhdf.la libmhdf.la)
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/mhdf'
Making all in .
make[3]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build'
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT AEntityFactory.lo -MD -MP -MF ".deps/AEntityFactory.Tpo" -c -o AEntityFactory.lo ../AEntityFactory.cpp; \
	then mv -f ".deps/AEntityFactory.Tpo" ".deps/AEntityFactory.Plo"; else rm -f ".deps/AEntityFactory.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT DualTool.lo -MD -MP -MF ".deps/DualTool.Tpo" -c -o DualTool.lo ../DualTool.cpp; \
	then mv -f ".deps/DualTool.Tpo" ".deps/DualTool.Plo"; else rm -f ".deps/DualTool.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT EntitySequence.lo -MD -MP -MF ".deps/EntitySequence.Tpo" -c -o EntitySequence.lo ../EntitySequence.cpp; \
	then mv -f ".deps/EntitySequence.Tpo" ".deps/EntitySequence.Plo"; else rm -f ".deps/EntitySequence.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ExoIIUtil.lo -MD -MP -MF ".deps/ExoIIUtil.Tpo" -c -o ExoIIUtil.lo ../ExoIIUtil.cpp; \
	then mv -f ".deps/ExoIIUtil.Tpo" ".deps/ExoIIUtil.Plo"; else rm -f ".deps/ExoIIUtil.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT FileOptions.lo -MD -MP -MF ".deps/FileOptions.Tpo" -c -o FileOptions.lo ../FileOptions.cpp; \
	then mv -f ".deps/FileOptions.Tpo" ".deps/FileOptions.Plo"; else rm -f ".deps/FileOptions.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT FileTokenizer.lo -MD -MP -MF ".deps/FileTokenizer.Tpo" -c -o FileTokenizer.lo ../FileTokenizer.cpp; \
	then mv -f ".deps/FileTokenizer.Tpo" ".deps/FileTokenizer.Plo"; else rm -f ".deps/FileTokenizer.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT GeomTopoTool.lo -MD -MP -MF ".deps/GeomTopoTool.Tpo" -c -o GeomTopoTool.lo ../GeomTopoTool.cpp; \
	then mv -f ".deps/GeomTopoTool.Tpo" ".deps/GeomTopoTool.Plo"; else rm -f ".deps/GeomTopoTool.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT HigherOrderFactory.lo -MD -MP -MF ".deps/HigherOrderFactory.Tpo" -c -o HigherOrderFactory.lo ../HigherOrderFactory.cpp; \
	then mv -f ".deps/HigherOrderFactory.Tpo" ".deps/HigherOrderFactory.Plo"; else rm -f ".deps/HigherOrderFactory.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ExoIIUtil.lo -MD -MP -MF .deps/ExoIIUtil.Tpo -c ../ExoIIUtil.cpp -o ExoIIUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT GeomTopoTool.lo -MD -MP -MF .deps/GeomTopoTool.Tpo -c ../GeomTopoTool.cpp -o GeomTopoTool.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT FileTokenizer.lo -MD -MP -MF .deps/FileTokenizer.Tpo -c ../FileTokenizer.cpp -o FileTokenizer.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT HomXform.lo -MD -MP -MF ".deps/HomXform.Tpo" -c -o HomXform.lo ../HomXform.cpp; \
	then mv -f ".deps/HomXform.Tpo" ".deps/HomXform.Plo"; else rm -f ".deps/HomXform.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT DualTool.lo -MD -MP -MF .deps/DualTool.Tpo -c ../DualTool.cpp -o DualTool.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c ../AEntityFactory.cpp -o AEntityFactory.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT EntitySequence.lo -MD -MP -MF .deps/EntitySequence.Tpo -c ../EntitySequence.cpp -o EntitySequence.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBAdaptiveKDTree.lo -MD -MP -MF ".deps/MBAdaptiveKDTree.Tpo" -c -o MBAdaptiveKDTree.lo ../MBAdaptiveKDTree.cpp; \
	then mv -f ".deps/MBAdaptiveKDTree.Tpo" ".deps/MBAdaptiveKDTree.Plo"; else rm -f ".deps/MBAdaptiveKDTree.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT FileOptions.lo -MD -MP -MF .deps/FileOptions.Tpo -c ../FileOptions.cpp -o FileOptions.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBAffineXform.lo -MD -MP -MF ".deps/MBAffineXform.Tpo" -c -o MBAffineXform.lo ../MBAffineXform.cpp; \
	then mv -f ".deps/MBAffineXform.Tpo" ".deps/MBAffineXform.Plo"; else rm -f ".deps/MBAffineXform.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBAlloc.lo -MD -MP -MF ".deps/MBAlloc.Tpo" -c -o MBAlloc.lo ../MBAlloc.cpp; \
	then mv -f ".deps/MBAlloc.Tpo" ".deps/MBAlloc.Plo"; else rm -f ".deps/MBAlloc.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c ../HigherOrderFactory.cpp -o HigherOrderFactory.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBAxisBox.lo -MD -MP -MF ".deps/MBAxisBox.Tpo" -c -o MBAxisBox.lo ../MBAxisBox.cpp; \
	then mv -f ".deps/MBAxisBox.Tpo" ".deps/MBAxisBox.Plo"; else rm -f ".deps/MBAxisBox.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT HomXform.lo -MD -MP -MF .deps/HomXform.Tpo -c ../HomXform.cpp -o HomXform.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBBits.lo -MD -MP -MF ".deps/MBBits.Tpo" -c -o MBBits.lo ../MBBits.cpp; \
	then mv -f ".deps/MBBits.Tpo" ".deps/MBBits.Plo"; else rm -f ".deps/MBBits.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBAxisBox.lo -MD -MP -MF .deps/MBAxisBox.Tpo -c ../MBAxisBox.cpp -o MBAxisBox.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBBSPTree.lo -MD -MP -MF ".deps/MBBSPTree.Tpo" -c -o MBBSPTree.lo ../MBBSPTree.cpp; \
	then mv -f ".deps/MBBSPTree.Tpo" ".deps/MBBSPTree.Plo"; else rm -f ".deps/MBBSPTree.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBCN.lo -MD -MP -MF ".deps/MBCN.Tpo" -c -o MBCN.lo ../MBCN.cpp; \
	then mv -f ".deps/MBCN.Tpo" ".deps/MBCN.Plo"; else rm -f ".deps/MBCN.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBAdaptiveKDTree.lo -MD -MP -MF .deps/MBAdaptiveKDTree.Tpo -c ../MBAdaptiveKDTree.cpp -o MBAdaptiveKDTree.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBAlloc.lo -MD -MP -MF .deps/MBAlloc.Tpo -c ../MBAlloc.cpp -o MBAlloc.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBCartVect.lo -MD -MP -MF ".deps/MBCartVect.Tpo" -c -o MBCartVect.lo ../MBCartVect.cpp; \
	then mv -f ".deps/MBCartVect.Tpo" ".deps/MBCartVect.Plo"; else rm -f ".deps/MBCartVect.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBBits.lo -MD -MP -MF .deps/MBBits.Tpo -c ../MBBits.cpp -o MBBits.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBHandleUtils.lo -MD -MP -MF ".deps/MBHandleUtils.Tpo" -c -o MBHandleUtils.lo ../MBHandleUtils.cpp; \
	then mv -f ".deps/MBHandleUtils.Tpo" ".deps/MBHandleUtils.Plo"; else rm -f ".deps/MBHandleUtils.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBBSPTree.lo -MD -MP -MF .deps/MBBSPTree.Tpo -c ../MBBSPTree.cpp -o MBBSPTree.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBAffineXform.lo -MD -MP -MF .deps/MBAffineXform.Tpo -c ../MBAffineXform.cpp -o MBAffineXform.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBMatrix3.lo -MD -MP -MF ".deps/MBMatrix3.Tpo" -c -o MBMatrix3.lo ../MBMatrix3.cpp; \
	then mv -f ".deps/MBMatrix3.Tpo" ".deps/MBMatrix3.Plo"; else rm -f ".deps/MBMatrix3.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBCore.lo -MD -MP -MF ".deps/MBCore.Tpo" -c -o MBCore.lo ../MBCore.cpp; \
	then mv -f ".deps/MBCore.Tpo" ".deps/MBCore.Plo"; else rm -f ".deps/MBCore.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBMatrix3.lo -MD -MP -MF .deps/MBMatrix3.Tpo -c ../MBMatrix3.cpp -o MBMatrix3.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBHandleUtils.lo -MD -MP -MF .deps/MBHandleUtils.Tpo -c ../MBHandleUtils.cpp -o MBHandleUtils.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBFactory.lo -MD -MP -MF ".deps/MBFactory.Tpo" -c -o MBFactory.lo ../MBFactory.cpp; \
	then mv -f ".deps/MBFactory.Tpo" ".deps/MBFactory.Plo"; else rm -f ".deps/MBFactory.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBCN.lo -MD -MP -MF .deps/MBCN.Tpo -c ../MBCN.cpp -o MBCN.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBGeomUtil.lo -MD -MP -MF ".deps/MBGeomUtil.Tpo" -c -o MBGeomUtil.lo ../MBGeomUtil.cpp; \
	then mv -f ".deps/MBGeomUtil.Tpo" ".deps/MBGeomUtil.Plo"; else rm -f ".deps/MBGeomUtil.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBMeshSet.lo -MD -MP -MF ".deps/MBMeshSet.Tpo" -c -o MBMeshSet.lo ../MBMeshSet.cpp; \
	then mv -f ".deps/MBMeshSet.Tpo" ".deps/MBMeshSet.Plo"; else rm -f ".deps/MBMeshSet.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBCartVect.lo -MD -MP -MF .deps/MBCartVect.Tpo -c ../MBCartVect.cpp -o MBCartVect.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBOrientedBox.lo -MD -MP -MF ".deps/MBOrientedBox.Tpo" -c -o MBOrientedBox.lo ../MBOrientedBox.cpp; \
	then mv -f ".deps/MBOrientedBox.Tpo" ".deps/MBOrientedBox.Plo"; else rm -f ".deps/MBOrientedBox.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBFactory.lo -MD -MP -MF .deps/MBFactory.Tpo -c ../MBFactory.cpp -o MBFactory.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBOrientedBoxTreeTool.lo -MD -MP -MF ".deps/MBOrientedBoxTreeTool.Tpo" -c -o MBOrientedBoxTreeTool.lo ../MBOrientedBoxTreeTool.cpp; \
	then mv -f ".deps/MBOrientedBoxTreeTool.Tpo" ".deps/MBOrientedBoxTreeTool.Plo"; else rm -f ".deps/MBOrientedBoxTreeTool.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBRange.lo -MD -MP -MF ".deps/MBRange.Tpo" -c -o MBRange.lo ../MBRange.cpp; \
	then mv -f ".deps/MBRange.Tpo" ".deps/MBRange.Plo"; else rm -f ".deps/MBRange.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBRangeSeqIntersectIter.lo -MD -MP -MF ".deps/MBRangeSeqIntersectIter.Tpo" -c -o MBRangeSeqIntersectIter.lo ../MBRangeSeqIntersectIter.cpp; \
	then mv -f ".deps/MBRangeSeqIntersectIter.Tpo" ".deps/MBRangeSeqIntersectIter.Plo"; else rm -f ".deps/MBRangeSeqIntersectIter.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c ../MBOrientedBox.cpp -o MBOrientedBox.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBGeomUtil.lo -MD -MP -MF .deps/MBGeomUtil.Tpo -c ../MBGeomUtil.cpp -o MBGeomUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c ../MBRange.cpp -o MBRange.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBReadUtil.lo -MD -MP -MF ".deps/MBReadUtil.Tpo" -c -o MBReadUtil.lo ../MBReadUtil.cpp; \
	then mv -f ".deps/MBReadUtil.Tpo" ".deps/MBReadUtil.Plo"; else rm -f ".deps/MBReadUtil.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c ../MBCore.cpp -o MBCore.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBReaderWriterSet.lo -MD -MP -MF ".deps/MBReaderWriterSet.Tpo" -c -o MBReaderWriterSet.lo ../MBReaderWriterSet.cpp; \
	then mv -f ".deps/MBReaderWriterSet.Tpo" ".deps/MBReaderWriterSet.Plo"; else rm -f ".deps/MBReaderWriterSet.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c ../MBRangeSeqIntersectIter.cpp -o MBRangeSeqIntersectIter.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBSkinner.lo -MD -MP -MF ".deps/MBSkinner.Tpo" -c -o MBSkinner.lo ../MBSkinner.cpp; \
	then mv -f ".deps/MBSkinner.Tpo" ".deps/MBSkinner.Plo"; else rm -f ".deps/MBSkinner.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBSysUtil.lo -MD -MP -MF ".deps/MBSysUtil.Tpo" -c -o MBSysUtil.lo ../MBSysUtil.cpp; \
	then mv -f ".deps/MBSysUtil.Tpo" ".deps/MBSysUtil.Plo"; else rm -f ".deps/MBSysUtil.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c ../MBOrientedBoxTreeTool.cpp -o MBOrientedBoxTreeTool.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBSysUtil.lo -MD -MP -MF .deps/MBSysUtil.Tpo -c ../MBSysUtil.cpp -o MBSysUtil.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBUtil.lo -MD -MP -MF ".deps/MBUtil.Tpo" -c -o MBUtil.lo ../MBUtil.cpp; \
	then mv -f ".deps/MBUtil.Tpo" ".deps/MBUtil.Plo"; else rm -f ".deps/MBUtil.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c ../MBReadUtil.cpp -o MBReadUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c ../MBReaderWriterSet.cpp -o MBReaderWriterSet.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c ../MBMeshSet.cpp -o MBMeshSet.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MBWriteUtil.lo -MD -MP -MF ".deps/MBWriteUtil.Tpo" -c -o MBWriteUtil.lo ../MBWriteUtil.cpp; \
	then mv -f ".deps/MBWriteUtil.Tpo" ".deps/MBWriteUtil.Plo"; else rm -f ".deps/MBWriteUtil.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MeshSetSequence.lo -MD -MP -MF ".deps/MeshSetSequence.Tpo" -c -o MeshSetSequence.lo ../MeshSetSequence.cpp; \
	then mv -f ".deps/MeshSetSequence.Tpo" ".deps/MeshSetSequence.Plo"; else rm -f ".deps/MeshSetSequence.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c ../MBWriteUtil.cpp -o MBWriteUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c ../MBSkinner.cpp -o MBSkinner.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c ../MBUtil.cpp -o MBUtil.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT MeshTopoUtil.lo -MD -MP -MF ".deps/MeshTopoUtil.Tpo" -c -o MeshTopoUtil.lo ../MeshTopoUtil.cpp; \
	then mv -f ".deps/MeshTopoUtil.Tpo" ".deps/MeshTopoUtil.Plo"; else rm -f ".deps/MeshTopoUtil.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT PolyElementSeq.lo -MD -MP -MF ".deps/PolyElementSeq.Tpo" -c -o PolyElementSeq.lo ../PolyElementSeq.cpp; \
	then mv -f ".deps/PolyElementSeq.Tpo" ".deps/PolyElementSeq.Plo"; else rm -f ".deps/PolyElementSeq.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c ../MeshSetSequence.cpp -o MeshSetSequence.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c ../PolyElementSeq.cpp -o PolyElementSeq.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c ../MeshTopoUtil.cpp -o MeshTopoUtil.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ReadGmsh.lo -MD -MP -MF ".deps/ReadGmsh.Tpo" -c -o ReadGmsh.lo ../ReadGmsh.cpp; \
	then mv -f ".deps/ReadGmsh.Tpo" ".deps/ReadGmsh.Plo"; else rm -f ".deps/ReadGmsh.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ReadSTL.lo -MD -MP -MF ".deps/ReadSTL.Tpo" -c -o ReadSTL.lo ../ReadSTL.cpp; \
	then mv -f ".deps/ReadSTL.Tpo" ".deps/ReadSTL.Plo"; else rm -f ".deps/ReadSTL.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c ../ReadGmsh.cpp -o ReadGmsh.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ReadVtk.lo -MD -MP -MF ".deps/ReadVtk.Tpo" -c -o ReadVtk.lo ../ReadVtk.cpp; \
	then mv -f ".deps/ReadVtk.Tpo" ".deps/ReadVtk.Plo"; else rm -f ".deps/ReadVtk.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ReadIDEAS.lo -MD -MP -MF ".deps/ReadIDEAS.Tpo" -c -o ReadIDEAS.lo ../ReadIDEAS.cpp; \
	then mv -f ".deps/ReadIDEAS.Tpo" ".deps/ReadIDEAS.Plo"; else rm -f ".deps/ReadIDEAS.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c ../ReadSTL.cpp -o ReadSTL.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c ../ReadVtk.cpp -o ReadVtk.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c ../ReadIDEAS.cpp -o ReadIDEAS.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ScdElementData.lo -MD -MP -MF ".deps/ScdElementData.Tpo" -c -o ScdElementData.lo ../ScdElementData.cpp; \
	then mv -f ".deps/ScdElementData.Tpo" ".deps/ScdElementData.Plo"; else rm -f ".deps/ScdElementData.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ScdVertexData.lo -MD -MP -MF ".deps/ScdVertexData.Tpo" -c -o ScdVertexData.lo ../ScdVertexData.cpp; \
	then mv -f ".deps/ScdVertexData.Tpo" ".deps/ScdVertexData.Plo"; else rm -f ".deps/ScdVertexData.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT SequenceData.lo -MD -MP -MF ".deps/SequenceData.Tpo" -c -o SequenceData.lo ../SequenceData.cpp; \
	then mv -f ".deps/SequenceData.Tpo" ".deps/SequenceData.Plo"; else rm -f ".deps/SequenceData.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT SequenceManager.lo -MD -MP -MF ".deps/SequenceManager.Tpo" -c -o SequenceManager.lo ../SequenceManager.cpp; \
	then mv -f ".deps/SequenceManager.Tpo" ".deps/SequenceManager.Plo"; else rm -f ".deps/SequenceManager.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c ../ScdElementData.cpp -o ScdElementData.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c ../ScdVertexData.cpp -o ScdVertexData.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT SparseTagSuperCollection.lo -MD -MP -MF ".deps/SparseTagSuperCollection.Tpo" -c -o SparseTagSuperCollection.lo ../SparseTagSuperCollection.cpp; \
	then mv -f ".deps/SparseTagSuperCollection.Tpo" ".deps/SparseTagSuperCollection.Plo"; else rm -f ".deps/SparseTagSuperCollection.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c ../SequenceManager.cpp -o SequenceManager.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c ../SequenceData.cpp -o SequenceData.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT SparseTagCollection.lo -MD -MP -MF ".deps/SparseTagCollection.Tpo" -c -o SparseTagCollection.lo ../SparseTagCollection.cpp; \
	then mv -f ".deps/SparseTagCollection.Tpo" ".deps/SparseTagCollection.Plo"; else rm -f ".deps/SparseTagCollection.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c ../SparseTagSuperCollection.cpp -o SparseTagSuperCollection.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c ../SparseTagCollection.cpp -o SparseTagCollection.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT StructuredElementSeq.lo -MD -MP -MF ".deps/StructuredElementSeq.Tpo" -c -o StructuredElementSeq.lo ../StructuredElementSeq.cpp; \
	then mv -f ".deps/StructuredElementSeq.Tpo" ".deps/StructuredElementSeq.Plo"; else rm -f ".deps/StructuredElementSeq.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT TagInfo.lo -MD -MP -MF ".deps/TagInfo.Tpo" -c -o TagInfo.lo ../TagInfo.cpp; \
	then mv -f ".deps/TagInfo.Tpo" ".deps/TagInfo.Plo"; else rm -f ".deps/TagInfo.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT TagServer.lo -MD -MP -MF ".deps/TagServer.Tpo" -c -o TagServer.lo ../TagServer.cpp; \
	then mv -f ".deps/TagServer.Tpo" ".deps/TagServer.Plo"; else rm -f ".deps/TagServer.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT TagInfo.lo -MD -MP -MF .deps/TagInfo.Tpo -c ../TagInfo.cpp -o TagInfo.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT Tqdcfr.lo -MD -MP -MF ".deps/Tqdcfr.Tpo" -c -o Tqdcfr.lo ../Tqdcfr.cpp; \
	then mv -f ".deps/Tqdcfr.Tpo" ".deps/Tqdcfr.Plo"; else rm -f ".deps/Tqdcfr.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT TypeSequenceManager.lo -MD -MP -MF ".deps/TypeSequenceManager.Tpo" -c -o TypeSequenceManager.lo ../TypeSequenceManager.cpp; \
	then mv -f ".deps/TypeSequenceManager.Tpo" ".deps/TypeSequenceManager.Plo"; else rm -f ".deps/TypeSequenceManager.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c ../StructuredElementSeq.cpp -o StructuredElementSeq.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c ../TagServer.cpp -o TagServer.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT UnstructuredElemSeq.lo -MD -MP -MF ".deps/UnstructuredElemSeq.Tpo" -c -o UnstructuredElemSeq.lo ../UnstructuredElemSeq.cpp; \
	then mv -f ".deps/UnstructuredElemSeq.Tpo" ".deps/UnstructuredElemSeq.Plo"; else rm -f ".deps/UnstructuredElemSeq.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c ../TypeSequenceManager.cpp -o TypeSequenceManager.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT VertexSequence.lo -MD -MP -MF ".deps/VertexSequence.Tpo" -c -o VertexSequence.lo ../VertexSequence.cpp; \
	then mv -f ".deps/VertexSequence.Tpo" ".deps/VertexSequence.Plo"; else rm -f ".deps/VertexSequence.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT VtkUtil.lo -MD -MP -MF ".deps/VtkUtil.Tpo" -c -o VtkUtil.lo ../VtkUtil.cpp; \
	then mv -f ".deps/VtkUtil.Tpo" ".deps/VtkUtil.Plo"; else rm -f ".deps/VtkUtil.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c ../Tqdcfr.cpp -o Tqdcfr.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c ../VertexSequence.cpp -o VertexSequence.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c ../UnstructuredElemSeq.cpp -o UnstructuredElemSeq.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT VtkUtil.lo -MD -MP -MF .deps/VtkUtil.Tpo -c ../VtkUtil.cpp -o VtkUtil.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteAns.lo -MD -MP -MF ".deps/WriteAns.Tpo" -c -o WriteAns.lo ../WriteAns.cpp; \
	then mv -f ".deps/WriteAns.Tpo" ".deps/WriteAns.Plo"; else rm -f ".deps/WriteAns.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteGMV.lo -MD -MP -MF ".deps/WriteGMV.Tpo" -c -o WriteGMV.lo ../WriteGMV.cpp; \
	then mv -f ".deps/WriteGMV.Tpo" ".deps/WriteGMV.Plo"; else rm -f ".deps/WriteGMV.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteGmsh.lo -MD -MP -MF ".deps/WriteGmsh.Tpo" -c -o WriteGmsh.lo ../WriteGmsh.cpp; \
	then mv -f ".deps/WriteGmsh.Tpo" ".deps/WriteGmsh.Plo"; else rm -f ".deps/WriteGmsh.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteSTL.lo -MD -MP -MF ".deps/WriteSTL.Tpo" -c -o WriteSTL.lo ../WriteSTL.cpp; \
	then mv -f ".deps/WriteSTL.Tpo" ".deps/WriteSTL.Plo"; else rm -f ".deps/WriteSTL.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteTemplate.lo -MD -MP -MF ".deps/WriteTemplate.Tpo" -c -o WriteTemplate.lo ../WriteTemplate.cpp; \
	then mv -f ".deps/WriteTemplate.Tpo" ".deps/WriteTemplate.Plo"; else rm -f ".deps/WriteTemplate.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c ../WriteAns.cpp -o WriteAns.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c ../WriteGmsh.cpp -o WriteGmsh.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c ../WriteGMV.cpp -o WriteGMV.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteVtk.lo -MD -MP -MF ".deps/WriteVtk.Tpo" -c -o WriteVtk.lo ../WriteVtk.cpp; \
	then mv -f ".deps/WriteVtk.Tpo" ".deps/WriteVtk.Plo"; else rm -f ".deps/WriteVtk.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c ../WriteTemplate.cpp -o WriteTemplate.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ReadNCDF.lo -MD -MP -MF ".deps/ReadNCDF.Tpo" -c -o ReadNCDF.lo ../ReadNCDF.cpp; \
	then mv -f ".deps/ReadNCDF.Tpo" ".deps/ReadNCDF.Plo"; else rm -f ".deps/ReadNCDF.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c ../WriteVtk.cpp -o WriteVtk.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteNCDF.lo -MD -MP -MF ".deps/WriteNCDF.Tpo" -c -o WriteNCDF.lo ../WriteNCDF.cpp; \
	then mv -f ".deps/WriteNCDF.Tpo" ".deps/WriteNCDF.Plo"; else rm -f ".deps/WriteNCDF.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c ../WriteSTL.cpp -o WriteSTL.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c ../ReadNCDF.cpp -o ReadNCDF.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteSLAC.lo -MD -MP -MF ".deps/WriteSLAC.Tpo" -c -o WriteSLAC.lo ../WriteSLAC.cpp; \
	then mv -f ".deps/WriteSLAC.Tpo" ".deps/WriteSLAC.Plo"; else rm -f ".deps/WriteSLAC.Tpo"; exit 1; fi
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT ReadHDF5.lo -MD -MP -MF ".deps/ReadHDF5.Tpo" -c -o ReadHDF5.lo ../ReadHDF5.cpp; \
	then mv -f ".deps/ReadHDF5.Tpo" ".deps/ReadHDF5.Plo"; else rm -f ".deps/ReadHDF5.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c ../WriteNCDF.cpp -o WriteNCDF.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c ../ReadHDF5.cpp -o ReadHDF5.o
if /bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include     -Wall -pipe -O2 -DNDEBUG -MT WriteHDF5.lo -MD -MP -MF ".deps/WriteHDF5.Tpo" -c -o WriteHDF5.lo ../WriteHDF5.cpp; \
	then mv -f ".deps/WriteHDF5.Tpo" ".deps/WriteHDF5.Plo"; else rm -f ".deps/WriteHDF5.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c ../WriteSLAC.cpp -o WriteSLAC.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I. -I. -I. -I. -I../mhdf/include -Wall -pipe -O2 -DNDEBUG -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c ../WriteHDF5.cpp -o WriteHDF5.o
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -O2 -DNDEBUG  -lm -o libMOAB.la -rpath /home/jason/moab/test/dist/moab-3.99/_inst/lib  AEntityFactory.lo DualTool.lo EntitySequence.lo ExoIIUtil.lo FileOptions.lo FileTokenizer.lo GeomTopoTool.lo HigherOrderFactory.lo HomXform.lo MBAdaptiveKDTree.lo MBAffineXform.lo MBAlloc.lo MBAxisBox.lo MBBits.lo MBBSPTree.lo MBCN.lo MBCartVect.lo MBHandleUtils.lo MBMatrix3.lo MBCore.lo MBFactory.lo MBGeomUtil.lo MBMeshSet.lo MBOrientedBox.lo MBOrientedBoxTreeTool.lo MBRange.lo MBRangeSeqIntersectIter.lo MBReadUtil.lo MBReaderWriterSet.lo MBSkinner.lo MBSysUtil.lo MBUtil.lo MBWriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ReadGmsh.lo ReadSTL.lo ReadVtk.lo ReadIDEAS.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo TagInfo.lo TagServer.lo Tqdcfr.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo VtkUtil!
 .lo WriteAns.lo WriteGMV.lo WriteGmsh.lo WriteSTL.lo WriteTemplate.lo WriteVtk.lo ReadNCDF.lo WriteNCDF.lo WriteSLAC.lo ReadHDF5.lo WriteHDF5.lo -lnetcdf_c++ -lnetcdf -lhdf5 ./mhdf/libmhdf.la  -lm
mkdir .libs
rm -fr .libs/libMOAB.lax
mkdir .libs/libMOAB.lax
rm -fr .libs/libMOAB.lax/libmhdf.a
mkdir .libs/libMOAB.lax/libmhdf.a
(cd .libs/libMOAB.lax/libmhdf.a && ar x /home/jason/moab/test/dist/moab-3.99/_build/./mhdf/.libs/libmhdf.a)
ar cru .libs/libMOAB.a  AEntityFactory.o DualTool.o EntitySequence.o ExoIIUtil.o FileOptions.o FileTokenizer.o GeomTopoTool.o HigherOrderFactory.o HomXform.o MBAdaptiveKDTree.o MBAffineXform.o MBAlloc.o MBAxisBox.o MBBits.o MBBSPTree.o MBCN.o MBCartVect.o MBHandleUtils.o MBMatrix3.o MBCore.o MBFactory.o MBGeomUtil.o MBMeshSet.o MBOrientedBox.o MBOrientedBoxTreeTool.o MBRange.o MBRangeSeqIntersectIter.o MBReadUtil.o MBReaderWriterSet.o MBSkinner.o MBSysUtil.o MBUtil.o MBWriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ReadGmsh.o ReadSTL.o ReadVtk.o ReadIDEAS.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o TagInfo.o TagServer.o Tqdcfr.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o WriteSTL.o WriteTemplate.o WriteVtk.o ReadNCDF.o WriteNCDF.o WriteSLAC.o ReadHDF5.o WriteHDF5.o  .libs/libMOAB.lax/libmhdf.a/adjacency.o!
  .libs/libMOAB.lax/libmhdf.a/file-handle.o .libs/libMOAB.lax/libmhdf.a/status.o .libs/libMOAB.lax/libmhdf.a/tags.o .libs/libMOAB.lax/libmhdf.a/file.o .libs/libMOAB.lax/libmhdf.a/nodes.o .libs/libMOAB.lax/libmhdf.a/sets.o .libs/libMOAB.lax/libmhdf.a/connectivity.o .libs/libMOAB.lax/libmhdf.a/util.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build'
Making all in test
make[3]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
Making all in dual
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/dual'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/dual'
Making all in h5file
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/h5file'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/h5file'
Making all in obb
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/obb'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/obb'
Making all in perf
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/perf'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/perf'
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
Making all in tools
make[3]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools'
Making all in iMesh
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
Making all in .
make[5]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DHAVE_CONFIG_H -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/iMesh -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -I.    -Wall -pipe -O2 -DNDEBUG -MT iMesh_MOAB.lo -MD -MP -MF ".deps/iMesh_MOAB.Tpo" -c -o iMesh_MOAB.lo ../../../tools/iMesh/iMesh_MOAB.cpp; \
	then mv -f ".deps/iMesh_MOAB.Tpo" ".deps/iMesh_MOAB.Plo"; else rm -f ".deps/iMesh_MOAB.Tpo"; exit 1; fi
 c++ -DHAVE_CONFIG_H -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/iMesh -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -I. -Wall -pipe -O2 -DNDEBUG -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c ../../../tools/iMesh/iMesh_MOAB.cpp -o iMesh_MOAB.o
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -O2 -DNDEBUG  -lm -o libiMesh.la -rpath /home/jason/moab/test/dist/moab-3.99/_inst/lib  iMesh_MOAB.lo ../../libMOAB.la -lm
mkdir .libs
ar cru .libs/libiMesh.a  iMesh_MOAB.o
ranlib .libs/libiMesh.a
creating libiMesh.la
(cd .libs && rm -f libiMesh.la && ln -s ../libiMesh.la libiMesh.la)
make[5]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
Making all in converter
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/converter'
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/converter -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT convert.o -MD -MP -MF ".deps/convert.Tpo" -c -o convert.o ../../../tools/converter/convert.cpp; \
	then mv -f ".deps/convert.Tpo" ".deps/convert.Po"; else rm -f ".deps/convert.Tpo"; exit 1; fi
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -O2 -DNDEBUG  -lm -o mbconvert  convert.o ../../libMOAB.la -lm
mkdir .libs
c++ -Wall -pipe -O2 -DNDEBUG -o mbconvert convert.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/converter'
Making all in hexmodops
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/hexmodops'
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/hexmodops -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT makeops.o -MD -MP -MF ".deps/makeops.Tpo" -c -o makeops.o ../../../tools/hexmodops/makeops.cpp; \
	then mv -f ".deps/makeops.Tpo" ".deps/makeops.Po"; else rm -f ".deps/makeops.Tpo"; exit 1; fi
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -O2 -DNDEBUG  -lm -o hexmodops  makeops.o ../../libMOAB.la -lm
mkdir .libs
c++ -Wall -pipe -O2 -DNDEBUG -o hexmodops makeops.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/hexmodops'
Making all in mbcoupler
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/mbcoupler'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT MBElemUtil.lo -MD -MP -MF ".deps/MBElemUtil.Tpo" -c -o MBElemUtil.lo ../../../tools/mbcoupler/MBElemUtil.cpp; \
	then mv -f ".deps/MBElemUtil.Tpo" ".deps/MBElemUtil.Plo"; else rm -f ".deps/MBElemUtil.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CC --mode=compile cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT poly.lo -MD -MP -MF ".deps/poly.Tpo" -c -o poly.lo ../../../tools/mbcoupler/poly.c; \
	then mv -f ".deps/poly.Tpo" ".deps/poly.Plo"; else rm -f ".deps/poly.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CC --mode=compile cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT tensor.lo -MD -MP -MF ".deps/tensor.Tpo" -c -o tensor.lo ../../../tools/mbcoupler/tensor.c; \
	then mv -f ".deps/tensor.Tpo" ".deps/tensor.Plo"; else rm -f ".deps/tensor.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CC --mode=compile cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT errmem.lo -MD -MP -MF ".deps/errmem.Tpo" -c -o errmem.lo ../../../tools/mbcoupler/errmem.c; \
	then mv -f ".deps/errmem.Tpo" ".deps/errmem.Plo"; else rm -f ".deps/errmem.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CC --mode=compile cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../..    -Wall -pipe -O2 -DNDEBUG -MT findpt.lo -MD -MP -MF ".deps/findpt.Tpo" -c -o findpt.lo ../../../tools/mbcoupler/findpt.c; \
	then mv -f ".deps/findpt.Tpo" ".deps/findpt.Plo"; else rm -f ".deps/findpt.Tpo"; exit 1; fi
 cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -Wall -pipe -O2 -DNDEBUG -MT poly.lo -MD -MP -MF .deps/poly.Tpo -c ../../../tools/mbcoupler/poly.c -o poly.o
 cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -Wall -pipe -O2 -DNDEBUG -MT errmem.lo -MD -MP -MF .deps/errmem.Tpo -c ../../../tools/mbcoupler/errmem.c -o errmem.o
 cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -Wall -pipe -O2 -DNDEBUG -MT findpt.lo -MD -MP -MF .deps/findpt.Tpo -c ../../../tools/mbcoupler/findpt.c -o findpt.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -Wall -pipe -O2 -DNDEBUG -MT MBElemUtil.lo -MD -MP -MF .deps/MBElemUtil.Tpo -c ../../../tools/mbcoupler/MBElemUtil.cpp -o MBElemUtil.o
 cc -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../tools/mbcoupler -I../.. -I../.. -I../.. -I../.. -I../../.. -I../.. -Wall -pipe -O2 -DNDEBUG -MT tensor.lo -MD -MP -MF .deps/tensor.Tpo -c ../../../tools/mbcoupler/tensor.c -o tensor.o
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/mbcoupler'
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools'
make[2]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build'
make[1]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build'
