[MOAB-dev] r2015 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Jul 15 16:22:00 CDT 2008
Author: kraftche
Date: 2008-07-15 16:22:00 -0500 (Tue, 15 Jul 2008)
New Revision: 2015
Modified:
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/ReadHDF5.hpp
Log:
o clean up some loop constructs
o check for invalid set data offsets to avoid writing past end of
array for invalid input files.
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2008-07-15 20:26:12 UTC (rev 2014)
+++ MOAB/trunk/ReadHDF5.cpp 2008-07-15 21:22:00 UTC (rev 2015)
@@ -625,7 +625,8 @@
-MBErrorCode ReadHDF5::read_set_contents( hid_t meta_id, hid_t data_id )
+MBErrorCode ReadHDF5::read_set_contents( hid_t meta_id, hid_t data_id,
+ const unsigned long data_len )
MBErrorCode rval;
mhdf_Status status;
@@ -640,7 +641,6 @@
if (chunk_size % 2)
--chunk_size; // makes reading range data easier.
unsigned long set_offset = 0; /* running offset into description table */
unsigned long sets_remaining = setSet.range.size();
unsigned long file_offset = 0; /* running offset into child table */
@@ -677,6 +677,10 @@
assert( set_iter != setSet.range.end() );
MBEntityHandle h = *set_iter; ++set_iter;
size_t remaining = offsets[r] + 1 - file_offset;
+ if (remaining > data_len - file_offset) {
+ readUtil->report_error( "Invalid set contents offset read from file." );
+ return MB_FAILURE;
while (remaining)
size_t count = remaining > chunk_size ? chunk_size : remaining;
@@ -724,7 +728,13 @@
else {
// read data for sets in [r,i)
size_t count = offsets[i-1] + 1 - file_offset;
+ if (count > data_len - file_offset) {
mhdf_readSetDataWithOpt( data_id, file_offset, count, handleType, buffer, ioProp, &status );
if (mhdf_isError( &status )) {
readUtil->report_error( mhdf_message( &status ) );
@@ -783,7 +793,8 @@
MBErrorCode ReadHDF5::read_parents_children( bool parents,
hid_t meta_id,
- hid_t data_id )
+ hid_t data_id,
MBErrorCode rval;
mhdf_Status status;
@@ -829,6 +840,11 @@
+ readUtil->report_error( "Invalid set %s offset read from file.",
+ parents ? "parent" : "child" );
while (remaining)
@@ -866,6 +882,11 @@
mhdf_readSetParentsChildrenWithOpt( data_id, file_offset, count, handleType,
@@ -1017,7 +1038,7 @@
result = MB_FAILURE;
else {
- rval = read_set_contents( meta_id, data_id );
+ rval = read_set_contents( meta_id, data_id, data_len );
mhdf_closeData( filePtr, data_id, &status );
if (MB_SUCCESS != rval)
result = rval;
@@ -1032,7 +1053,7 @@
else {
- rval = read_parents_children( false, meta_id, data_id );
+ rval = read_parents_children( false, meta_id, data_id, data_len );
result = rval;
@@ -1047,7 +1068,7 @@
else {
- rval = read_parents_children( true, meta_id, data_id );
+ rval = read_parents_children( true, meta_id, data_id, data_len );
result = rval;
@@ -1919,15 +1940,13 @@
MBEntityHandle offset = elems.first_id;
MBEntityHandle last = offset + elems.range.size();
- MBEntityHandle *const end = array + size;
- while (array != end)
+ for (MBEntityHandle *const end = array + size; array != end; ++array)
if (*array >= last || *array < (MBEntityHandle)offset)
return MB_FAILURE;
MBRange:: const_iterator iter = elems.range.begin();
iter += *array - offset;
*array = *iter;
- ++array;
return MB_SUCCESS;
@@ -1936,20 +1955,18 @@
MBErrorCode ReadHDF5::convert_id_to_handle( MBEntityHandle* array,
size_t size )
MBEntityHandle offset = 1;
MBEntityHandle last = 0;
ElemSet* set = 0;
std::list<ElemSet>::iterator iter;
const std::list<ElemSet>::iterator i_end = elemList.end();
// special case for ZERO
- if (!*array) {
- ++array;
+ if (!*array)
continue;
if (nodeSet.first_id && (*array < offset || *array >= last))
offset = nodeSet.first_id;
@@ -1979,7 +1996,6 @@
MBRange:: const_iterator riter = set->range.begin();
riter += *array - offset;
*array = *riter;
- ++array;
return MB_SUCCESS;
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp 2008-07-15 20:26:12 UTC (rev 2014)
+++ MOAB/trunk/ReadHDF5.hpp 2008-07-15 21:22:00 UTC (rev 2015)
@@ -117,12 +117,14 @@
//! Read set contents
MBErrorCode read_set_contents( hid_t set_description_handle,
- hid_t set_contents_handle );
+ hid_t set_contents_handle,
+ const unsigned long data_len );
//! Read set parents/children
MBErrorCode read_parents_children( bool parents,
//! Read element adjacencies
MBErrorCode read_adjacencies( ElemSet& for_this_set );
