[MOAB-dev] memory leak in ReadParallel class?
Tim Tautges
tautges at mcs.anl.gov
Mon Jul 14 19:50:51 CDT 2008
That is correct, the ReadParallel class doesn't destroy the
MBParallelComm objects it creates. The primary reason I did it this way
is because I store pointers to the MBPC objects as a tag on the
interface instance, so that MBParallelComm::get_pcomm function (which is
static) can get the indexed object. I should probably put something in
the MBCore destructor to check for this tag and delete any objects it finds.
Thanks for your interest, and if you see any other problems/bugs send
'em in. The parallel reader stuff is fairly new, so we're still finding
bugs here and there.
- tim
Ryuta Suzuki wrote:
> Hi,
> I've been playing around MOAB for a while to use it as parallel mesh
> reader/writer.
> I noticed that in RealParallel class, its constructor "new" the
> MBParallelComm object but it doesn't delete the object at any point in
> the class. I suppose it'd be natural that the ReadParallel destructor
> should handle this memory allocation.
> Running valgrind confirmed that MBParallelComm object is not correctly
> freed.
> Please correct me if I'm wrong. Thank you.
> -ryuta
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
