[MOAB-dev] r2008 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Fri Jul 11 16:25:02 CDT 2008
Author: tautges
Date: 2008-07-11 16:25:02 -0500 (Fri, 11 Jul 2008)
New Revision: 2008
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/mbparallelcomm_test.cpp
Log:
Fixing a bug in remote handle initialization for 0 < d entities.
Tweaking mbparallelcomm_test to print usage if # files isn't input.
Passes make check and mbparallelcomm_test.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-07-10 14:59:28 UTC (rev 2007)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-07-11 21:25:02 UTC (rev 2008)
@@ -1606,15 +1606,17 @@
MBEntityHandle remote_handle)
int i = 0;
- bool more = (remote_procs[0] != -1);
+ bool more = (remote_procs[0] != remote_proc);
while (-1 != remote_procs[i] && i < MAX_SHARING_PROCS &&
remote_proc > remote_procs[i]) i++;
- if (remote_procs[i] == remote_proc) return MB_SUCCESS;
+ if (remote_procs[i] == remote_proc &&
+ remote_hs[i] == remote_handle)
+ return MB_SUCCESS;
assert(i < MAX_SHARING_PROCS-1);
- if (-1 != remote_procs[i]) {
+ if (remote_procs[i] != remote_proc) {
for (int j = MAX_SHARING_PROCS-1; j > i; j--) {
remote_procs[j] = remote_procs[j-1];
remote_hs[j] = remote_hs[j-1];
@@ -3011,7 +3013,8 @@
// if 0 layers, put bridge_ents in to_ents, to avoid range copy later
if (0 == num_layers) bridge_ents_ptr = &to_ents;
- if (bridge_dim == -1)
+ if (bridge_dim == -1 ||
+ (to_dim == -1 && !num_layers))
result = mbImpl->get_entities_by_handle(iface_set, *bridge_ents_ptr);
else
result = mbImpl->get_entities_by_dimension(iface_set, bridge_dim, *bridge_ents_ptr);
@@ -3345,6 +3348,11 @@
for (MBRange::iterator rit = interfaceSets.begin(); rit != interfaceSets.end();
rit++) {
if (!is_iface_proc(*rit, *sit)) continue;
+ int owner;
+ result = get_owner(*rit, owner);
+ if (MB_SUCCESS != result || owner != (int)proc_config().proc_rank())
+ continue;
result = get_ghost_layers(*rit, -1, 0, 0, tag_ents);
RRA("Failed to get tag ents for exchange.");
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp 2008-07-10 14:59:28 UTC (rev 2007)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp 2008-07-11 21:25:02 UTC (rev 2008)
@@ -56,6 +56,8 @@
MBErrorCode report_iface_ents(MBInterface *mbImpl,
std::vector<MBParallelComm *> &pcs);
+void print_usage(const char *);
int main(int argc, char **argv)
// need to init MPI first, to tell how many procs and rank
@@ -81,20 +83,7 @@
// get N, M from command line
if (argc < 3) {
- if (0 == rank)
- std::cerr
- << "Usage: " << argv[0]
- << " [readpar_option] <opt> <input> [...] where:" << std::endl
- << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl
- << " -2 (READ_PARALLEL), -3 (BCAST)" << std::endl
- << "opt input" << std::endl
- << "=== =====" << std::endl
- << " 1 <linear_ints> <shared_verts> " << std::endl
- << " 2 <n_ints> " << std::endl
- << " 3* <# files> <file_names...> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=1] [resolve_shared=1] [with_ghosts=1] [use_mpio=0]" << std::endl
- << " 4 <file_name> " << std::endl
- << "*Note: if opt 3 is used, it must be the last one." << std::endl;
+ if (0 == rank) print_usage(argv[0]);
err = MPI_Finalize();
return 1;
@@ -122,6 +111,11 @@
tag_name = "MATERIAL_SET";
tag_val = -1;
num_files = strtol(argv[npos++], NULL, 0);
+ if (0 == num_files) {
+ err = MPI_Finalize();
+ return 1;
while (num_files-- && npos < argc)
filenames.push_back(std::string(argv[npos++]));
if (npos < argc) tag_name = argv[npos++];
@@ -211,6 +205,22 @@
return (MB_SUCCESS == result ? 0 : 1);
+void print_usage(const char *command)
+ std::cerr
+ << "Usage: " << command
+ << " [readpar_option] <opt> <input> [...] where:" << std::endl
+ << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl
+ << " -2 (READ_PARALLEL), -3 (BCAST)" << std::endl
+ << "opt input" << std::endl
+ << "=== =====" << std::endl
+ << " 1 <linear_ints> <shared_verts> " << std::endl
+ << " 2 <n_ints> " << std::endl
+ << " 3* <# files> <file_names...> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=1] [resolve_shared=1] [with_ghosts=1] [use_mpio=0]" << std::endl
+ << " 4 <file_name> " << std::endl
+ << "*Note: if opt 3 is used, it must be the last one." << std::endl;
MBErrorCode report_nsets(MBInterface *mbImpl)
// get and report various numbers...
