[MOAB-dev] r1999 - in MOAB/trunk: . mhdf/include
kraftche at mcs.anl.gov
Tue Jul 8 14:04:14 CDT 2008
Author: kraftche
Date: 2008-07-08 14:04:14 -0500 (Tue, 08 Jul 2008)
New Revision: 1999
Modified:
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/mhdf/include/mhdf.h
Log:
Fix "bug" in HDF5 file format as written by MOAB:
- mhdf.h defines constants for tag storage type
(bit, dense, sparse, or mesh).
- ReadHDF5 and WriteHDF5 cast the MBTagType to an
int rather than using the constants provided in
mhdf.h.
- The values for the mhdf.h constants are not the
same as the MBTagType enum values.
Solution:
- Change the values of the mhdf constants to mach
the MOAB ones so as to avoid breaking reading
of existing files.
- Change ReadHFD5 and WriteHDF5 such that they
convert between the mhdf and MOAB constants to
avoid future breakage.
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2008-07-08 17:05:54 UTC (rev 1998)
+++ MOAB/trunk/ReadHDF5.cpp 2008-07-08 19:04:14 UTC (rev 1999)
@@ -1138,7 +1138,7 @@
mhdf_TagDataType mhdf_type; // Enum for tag data type
int tag_size; // Size of tag
- int storage; // TSTT storage type (dense vs. sparse)
+ int mhdf_storage; // TSTT storage type (dense vs. sparse)
int have_default; // File contains default value for tag
int have_global; // File contains global value for tag
int have_sparse; // File contains sparse data table for tag
@@ -1147,15 +1147,25 @@
int array_size; // If tag is not opaque, the number of data per entity
MBTag handle; // The handle for the tag
MBDataType mb_type; // The MOAB data type for the data
+ MBTagType storage;
// Get description of tag
- mhdf_getTagInfo( filePtr, name, &mhdf_type, &tag_size, &storage,
+ mhdf_getTagInfo( filePtr, name, &mhdf_type, &tag_size, &mhdf_storage,
&have_default, &have_global, &have_sparse, &status );
if (mhdf_isError( &status ))
readUtil->report_error( mhdf_message( &status ) );
return MB_FAILURE;
+ switch (mhdf_storage) {
+ case mhdf_DENSE_TYPE : storage = MB_TAG_DENSE ; break;
+ case mhdf_SPARSE_TYPE: storage = MB_TAG_SPARSE; break;
+ case mhdf_BIT_TYPE : storage = MB_TAG_BIT; break;
+ case mhdf_MESH_TYPE : storage = MB_TAG_MESH; break;
+ default:
+ readUtil->report_error( "Invalid storage type for tag '%s': %d\n", name, mhdf_storage );
+ return MB_FAILURE;
// Type-specific stuff
switch (mhdf_type)
@@ -1338,10 +1348,10 @@
else if (MB_TAG_NOT_FOUND == rval)
if (tag_size == MB_VARIABLE_LENGTH)
- rval = iFace->tag_create_variable_length( name, (MBTagType)storage, mb_type,
+ rval = iFace->tag_create_variable_length( name, storage, mb_type,
handle, default_ptr, default_size );
else
- rval = iFace->tag_create( name, tag_size, (MBTagType)storage, mb_type,
+ rval = iFace->tag_create( name, tag_size, storage, mb_type,
handle, default_ptr );
if (MB_SUCCESS != rval)
return rval;
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2008-07-08 17:05:54 UTC (rev 1998)
+++ MOAB/trunk/WriteHDF5.cpp 2008-07-08 19:04:14 UTC (rev 1999)
@@ -2440,10 +2440,10 @@
unsigned long num_sparse_entities,
unsigned long data_table_size )
- MBTagType storage;
+ MBTagType mb_storage;
MBDataType mb_type;
- int tag_size, elem_size, mhdf_size;
+ int tag_size, elem_size, mhdf_size, storage;
hid_t hdf_type = (hid_t)0;
hid_t handles[2];
std::string tag_name;
@@ -2452,7 +2452,14 @@
// get tag properties
- rval = iFace->tag_get_type( tag_id, storage ); CHK_MB_ERR_0(rval);
+ rval = iFace->tag_get_type( tag_id, mb_storage ); CHK_MB_ERR_0(rval);
+ switch (mb_storage) {
+ case MB_TAG_DENSE : storage = mhdf_DENSE_TYPE ; break;
+ case MB_TAG_SPARSE: storage = mhdf_SPARSE_TYPE; break;
+ case MB_TAG_BIT: storage = mhdf_BIT_TYPE; break;
+ case MB_TAG_MESH: storage = mhdf_MESH_TYPE; break;
+ default: return MB_FAILURE;
rval = iFace->tag_get_name( tag_id, tag_name ); CHK_MB_ERR_0(rval);
rval = get_tag_size( tag_id, mb_type, tag_size, elem_size, mhdf_size, mhdf_type, hdf_type );
CHK_MB_ERR_0(rval);
Modified: MOAB/trunk/mhdf/include/mhdf.h
--- MOAB/trunk/mhdf/include/mhdf.h 2008-07-08 17:05:54 UTC (rev 1998)
+++ MOAB/trunk/mhdf/include/mhdf.h 2008-07-08 19:04:14 UTC (rev 1999)
@@ -1492,11 +1492,11 @@
/** \brief Was dense tag data in mesh database */
-#define mhdf_DENSE_TYPE 0
+#define mhdf_DENSE_TYPE 2
/** \brief Was sparse tag data in mesh database */
#define mhdf_SPARSE_TYPE 1
/** \brief Was bit-field tag data in mesh database */
-#define mhdf_BIT_TYPE 2
+#define mhdf_BIT_TYPE 0
/** \brief Unused */
#define mhdf_MESH_TYPE 3
