[MOAB-dev] r1549 - MOAB/trunk
dcthomp at mcs.anl.gov
Mon Jan 21 20:10:10 CST 2008
Author: dcthomp
Date: 2008-01-21 20:10:10 -0600 (Mon, 21 Jan 2008)
New Revision: 1549
Modified:
MOAB/trunk/test_mesh_refiner.cpp
Log:
ENH: Create output vertices and elements (no tags yet) in test harness.
Modified: MOAB/trunk/test_mesh_refiner.cpp
--- MOAB/trunk/test_mesh_refiner.cpp 2008-01-21 22:32:13 UTC (rev 1548)
+++ MOAB/trunk/test_mesh_refiner.cpp 2008-01-22 02:10:10 UTC (rev 1549)
@@ -7,6 +7,18 @@
class MBTestOutputFunctor : public MBEntityRefinerOutputFunctor
+public:
+ typedef std::vector<MBEntityHandle> node_list_t;
+ typedef std::pair<MBEntityHandle,MBEntityHandle> node_pair_t;
+ typedef std::map<MBEntityHandle,MBEntityHandle> node_hash_t;
+ typedef std::map<node_pair_t,MBEntityHandle> edge_hash_t;
+ MBInterface* mesh;
+ bool input_is_output;
+ node_hash_t node_hash;
+ edge_hash_t edge_hash;
+ node_list_t elem_vert;
virtual void operator () ( const double* vcoords, const void* vtags, MBEntityHandle* vhash )
std::cout << "[ " << vcoords[0];
@@ -21,17 +33,80 @@
for ( int i = 0; i < 4; ++i )
std::cout << ", " << m[i];
std::cout << " > { ";
- while ( *vhash )
+ MBEntityHandle* vin = vhash;
+ while ( *vin )
- std::cout << *vhash << " ";
- ++ vhash;
+ std::cout << *vin << " ";
+ ++ vin;
std::cout << "}\n";
+ MBEntityHandle vertex_handle;
+ if ( ! vhash[1] )
+ if ( this->input_is_output )
+ { // Don't copy the original vertex!
+ vertex_handle = vhash[0];
+ else
+ node_hash_t::iterator it = this->node_hash.find( vhash[0] );
+ if ( it == this->node_hash.end() )
+ if ( this->mesh->create_vertex( vcoords + 3, vertex_handle ) != MB_SUCCESS )
+ std::cerr << "Could not insert corner vertex!\n";
+ this->node_hash[vhash[0]] = vertex_handle;
+ else
+ vertex_handle = it->second;
+ else if ( ! vhash[2] )
+ node_pair_t pr;
+ if ( vhash[0] < vhash[1] )
+ pr.first = vhash[0];
+ pr.second = vhash[1];
+ else
+ pr.first = vhash[1];
+ pr.second = vhash[0];
+ edge_hash_t::iterator it = this->edge_hash.find( pr );
+ if ( it == this->edge_hash.end() )
+ std::cerr << "Could not insert mid-edge vertex!\n";
+ this->edge_hash[pr] = vertex_handle;
+ else
+ else
+ std::cerr << "Not handling mid-face vertices yet.\n";
+ // FIXME: Handle face midpoint.
+ std::cout << " -> " << vertex_handle << "\n";
+ this->elem_vert.push_back( vertex_handle );
virtual void operator () ( MBEntityType etyp )
std::cout << "---------- " << etyp << "\n\n";
+ MBEntityHandle elem_handle;
+ this->mesh->create_element( etyp, &this->elem_vert[0], this->elem_vert.size(), elem_handle );
+ this->elem_vert.clear();
@@ -89,10 +164,14 @@
MBSimplexTemplateRefiner eref( iface );
MBTestOutputFunctor* ofunc = new MBTestOutputFunctor;
+ ofunc->input_is_output = ( argc > 1 && ! strcmp( argv[1], "-new-mesh" ) ) ? false : true;
+ ofunc->mesh = ofunc->input_is_output ? iface : new MBCore;
eref.set_edge_size_evaluator( eval );
eref.set_output_functor( ofunc );
eref.refine_entity( tri_handle );
+ if ( ! ofunc->input_is_output )
+ delete ofunc->mesh;
delete iface;
return 0;
