[MOAB-dev] r1532 - in MOAB/trunk: . refiner
pebay at mcs.anl.gov
Wed Jan 16 20:44:27 CST 2008
Author: pebay
Date: 2008-01-16 20:44:27 -0600 (Wed, 16 Jan 2008)
New Revision: 1532
Modified:
MOAB/trunk/refiner/MBEntityRefiner.cpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
MOAB/trunk/test_mesh_refiner.cpp
Log:
ENH: checkpoint
Modified: MOAB/trunk/refiner/MBEntityRefiner.cpp
--- MOAB/trunk/refiner/MBEntityRefiner.cpp 2008-01-17 01:43:10 UTC (rev 1531)
+++ MOAB/trunk/refiner/MBEntityRefiner.cpp 2008-01-17 02:44:27 UTC (rev 1532)
@@ -149,7 +149,7 @@
void MBEntityRefiner::update_heap_size()
unsigned long n = this->get_heap_size_bound( this->maximum_number_of_subdivisions );
- this->coord_heap.resize( 6 * n );
+ this->coord_heap.resize( 6 * n + 8 );
if ( this->edge_size_evaluator )
unsigned long m = this->edge_size_evaluator->get_vertex_tag_size();
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2008-01-17 01:43:10 UTC (rev 1531)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2008-01-17 02:44:27 UTC (rev 1532)
@@ -43,42 +43,49 @@
return false;
std::vector<double> entity_coords;
- std::vector<char> entity_tags;
- int ts = this->edge_size_evaluator->get_vertex_tag_size();
+ std::vector<void*> entity_tags;
entity_coords.resize( 6 * num_nodes );
- if ( ts )
- entity_tags.resize( num_nodes * ts );
+ entity_tags.resize( num_nodes );
MBEntityType etyp = this->mesh->type_from_handle( entity );
// Have to make num_nodes calls to get_coords() because we need xyz interleaved with rst coords.
+ MBTag tag_handle;
+ int tag_offset;
for ( int n = 0; n < num_nodes; ++ n )
if ( this->mesh->get_coords( &conn[n], 1, &entity_coords[6 * n + 3] ) != MB_SUCCESS )
return false;
- // Still need to get tags.
+ entity_tags[n] = this->heap_tag_storage();
+ for ( int i = 0; i < this->edge_size_evaluator->get_number_of_vertex_tags(); ++ i )
+ this->edge_size_evaluator->get_vertex_tag( i, tag_handle, tag_offset );
+ if ( this->mesh->tag_get_data( tag_handle, &conn[n], 1, (char*)( entity_tags[n] ) + tag_offset ) != MB_SUCCESS )
+ return false;
switch ( etyp )
case MBVERTEX:
this->assign_parametric_coordinates( 1, MBVertexParametric, &entity_coords[0] );
- this->refine_0_simplex( &entity_coords[0], &entity_tags[0] );
+ this->refine_0_simplex( &entity_coords[0], entity_tags[0] );
rval = false;
break;
case MBEDGE:
this->assign_parametric_coordinates( 2, MBEdgeParametric, &entity_coords[0] );
rval = this->refine_1_simplex( this->maximum_number_of_subdivisions,
- &entity_coords[0], &entity_tags[0], &entity_coords[6], &entity_tags[ts] );
+ &entity_coords[0], entity_tags[0], &entity_coords[6], entity_tags[1] );
break;
case MBTRI:
this->assign_parametric_coordinates( 3, MBTriParametric, &entity_coords[0] );
rval = this->refine_2_simplex( this->maximum_number_of_subdivisions, 7,
- &entity_coords[ 0], &entity_tags[ 0],
- &entity_coords[ 6], &entity_tags[ ts],
- &entity_coords[12], &entity_tags[2 * ts] );
+ &entity_coords[ 0], entity_tags[0],
+ &entity_coords[ 6], entity_tags[1],
+ &entity_coords[12], entity_tags[2] );
break;
case MBQUAD:
std::cerr << "Quadrilaterals not handled yet\n";
Modified: MOAB/trunk/test_mesh_refiner.cpp
--- MOAB/trunk/test_mesh_refiner.cpp 2008-01-17 01:43:10 UTC (rev 1531)
+++ MOAB/trunk/test_mesh_refiner.cpp 2008-01-17 02:44:27 UTC (rev 1532)
@@ -12,7 +12,15 @@
std::cout << "[ " << vcoords[0];
for ( int i = 1; i < 6; ++i )
std::cout << ", " << vcoords[i];
- std::cout << " ]\n";
+ std::cout << " ] ";
+ double* x = (double*)vtags;
+ int* m = (int*)( (char*)vtags + 2 * sizeof( double ) );
+ std::cout << "< " << x[0]
+ << ", " << x[1];
+ for ( int i = 0; i < 4; ++i )
+ std::cout << ", " << m[i];
+ std::cout << " >\n";
virtual void operator () ( MBEntityType etyp )
@@ -31,6 +39,16 @@
double p2[6] = { 1.0, 0.0, 0.0, 1.0, 0.0, 0.0 };
double p3[6] = { 0.6, 2.0, 0.0, 0.6, 2.0, 0.0 };
+ double default_floatular[] = { 38.7, 104. };
+ double floatular_values[] = { 38.7, 104.,
+ 123.456, 789.012,
+ 0., 1. };
+ int default_intular[] = { 7, 11, 24, 7 };
+ int intular_values[] = { 7, 11, 24, 7,
+ 1, 2, 3, 4,
+ 13, 17, 19, 23 };
if ( eval->evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
return 1;
@@ -45,10 +63,22 @@
MBEntityHandle node_handles[3];
MBEntityHandle tri_handle;
+ MBTag tag_floatular;
+ iface->tag_create( "floatular", 2 * sizeof( double ), MB_TAG_DENSE, tag_floatular, default_floatular );
+ MBTag tag_intular;
+ iface->tag_create( "intular", 4 * sizeof( int ), MB_TAG_DENSE, tag_intular, default_intular );
iface->create_vertex( p0, node_handles[0] );
iface->create_vertex( p2, node_handles[1] );
iface->create_vertex( p3, node_handles[2] );
+ iface->tag_set_data( tag_floatular, node_handles, 3, (void*)floatular_values );
+ eval->add_vertex_tag( tag_floatular );
+ iface->tag_set_data( tag_intular, node_handles, 3, (void*)intular_values );
+ eval->add_vertex_tag( tag_intular );
iface->create_element( MBTRI, node_handles, 3, tri_handle );
MBSimplexTemplateRefiner eref( iface );
