[MOAB-dev] r1527 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jan 15 10:14:09 CST 2008
Author: kraftche
Date: 2008-01-15 10:14:09 -0600 (Tue, 15 Jan 2008)
New Revision: 1527
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
   MOAB/trunk/MBAdaptiveKDTree.hpp
   MOAB/trunk/kd_tree_test.cpp
Log:
Add a few features to MBAdaptiveKDTree:
  o Make MBAdaptiveKDTreeIter bidirectional.
  o Add function to get iterator for leaf containing a point.
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2008-01-14 23:35:35 UTC (rev 1526)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2008-01-15 16:14:09 UTC (rev 1527)
@@ -264,7 +264,7 @@
 MBErrorCode MBAdaptiveKDTree::get_tree_iterator( MBEntityHandle root,
-                                 MBAdaptiveKDTreeIter& iter )
+                                                 MBAdaptiveKDTreeIter& iter )
   double box[6];
   MBErrorCode rval = moab()->tag_get_data( rootTag, &root, 1, box );
@@ -274,12 +274,23 @@
   return get_sub_tree_iterator( root, box, box+3, iter );
+MBErrorCode MBAdaptiveKDTree::get_last_iterator( MBEntityHandle root,
+  double box[6];
+  MBErrorCode rval = moab()->tag_get_data( rootTag, &root, 1, box );
+  if (MB_SUCCESS != rval)
+    return rval;
+  return iter.initialize( this, root, box, box+3, MBAdaptiveKDTreeIter::RIGHT );
 MBErrorCode MBAdaptiveKDTree::get_sub_tree_iterator( MBEntityHandle root,
-                                     const double min[3],
-                                     const double max[3],
-                                     MBAdaptiveKDTreeIter& result )
+                                                     const double min[3],
+                                                     const double max[3],
+                                                     MBAdaptiveKDTreeIter& result )
-  return result.initialize( this, root, min, max );
+  return result.initialize( this, root, min, max, MBAdaptiveKDTreeIter::LEFT );
 MBErrorCode MBAdaptiveKDTree::split_leaf( MBAdaptiveKDTreeIter& leaf,
@@ -302,7 +313,7 @@
   if (MB_SUCCESS != set_split_plane( leaf.handle(), plane ) ||
       MB_SUCCESS != moab()->add_child_meshset( leaf.handle(), left ) ||
       MB_SUCCESS != moab()->add_child_meshset( leaf.handle(), right) ||
-      MB_SUCCESS != leaf.step_to_first_leaf()) {
+      MB_SUCCESS != leaf.step_to_first_leaf(MBAdaptiveKDTreeIter::LEFT)) {
     MBEntityHandle children[] = { left, right };
     moab()->delete_entities( children, 2 );
     return MB_FAILURE;
@@ -427,7 +438,8 @@
 MBErrorCode MBAdaptiveKDTreeIter::initialize( MBAdaptiveKDTree* tool,
                                               const double box_min[3],
-                                              const double box_max[3] )
+                                              const double box_max[3],
+                                              Direction direction )
   mStack.clear();
   treeTool = tool;
@@ -438,13 +450,14 @@
   mBox[BMAX][1] = box_max[1];
   mBox[BMAX][2] = box_max[2];
   mStack.push_back( StackObj(root,0) );
-  return step_to_first_leaf();
+  return step_to_first_leaf( direction );
-MBErrorCode MBAdaptiveKDTreeIter::step_to_first_leaf()
+MBErrorCode MBAdaptiveKDTreeIter::step_to_first_leaf( Direction direction )
   MBErrorCode rval;
   MBAdaptiveKDTree::Plane plane;
+  const Direction opposite = static_cast<Direction>(1-direction);
   for (;;) {
     childVect.clear();
@@ -458,17 +471,18 @@
       return rval;
-    mStack.push_back( StackObj(childVect[0],mBox[BMAX][plane.norm]) );
-    mBox[BMAX][plane.norm] = plane.coord;
+    mStack.push_back( StackObj(childVect[direction],mBox[opposite][plane.norm]) );
+    mBox[opposite][plane.norm] = plane.coord;
   return MB_SUCCESS;
-MBErrorCode MBAdaptiveKDTreeIter::step()
+MBErrorCode MBAdaptiveKDTreeIter::step( Direction direction )
   StackObj node, parent;
   MBErrorCode rval;
     // If stack is empty, then either this iterator is uninitialized
     // or we reached the end of the iteration (and return
@@ -494,23 +508,23 @@
       return rval;
       // If we're at the left child
-    if (childVect[0] == node.entity) {
+    if (childVect[opposite] == node.entity) {
         // change from box of left child to box of parent
-      mBox[BMAX][plane.norm] = node.coord;
+      mBox[direction][plane.norm] = node.coord;
         // push right child on stack
-      node.entity = childVect[1];
-      node.coord = mBox[BMIN][plane.norm];
+      node.entity = childVect[direction];
+      node.coord = mBox[opposite][plane.norm];
       mStack.push_back( node );
         // change from box of parent to box of right child
-      mBox[BMIN][plane.norm] = plane.coord;
         // descend to left-most leaf of the right child
+      return step_to_first_leaf(opposite);
       // The current node is the right child of the parent,
       // continue up the tree.
-    assert( childVect[1] == node.entity );
-    mBox[BMIN][plane.norm] = node.coord;
+    assert( childVect[direction] == node.entity );
+    mBox[opposite][plane.norm] = node.coord;
     node = parent;
     mStack.pop_back();
@@ -1090,7 +1104,7 @@
     return rval;
   MBAdaptiveKDTreeIter iter;
-  iter.initialize( this, root_set_out, bmin.array(), bmax.array() );
+  iter.initialize( this, root_set_out, bmin.array(), bmax.array(), MBAdaptiveKDTreeIter::LEFT );
   for (;;) {
@@ -1199,6 +1213,55 @@
   return MB_SUCCESS;
+MBErrorCode MBAdaptiveKDTree::leaf_containing_point( MBEntityHandle root,
+                                                     const double point[3],
+    // get bounding box of tree
+  MBErrorCode rval = moab()->tag_get_data( rootTag, &root, 1, result.mBox );
+    return rval;
+    // test that point is inside tree
+  if (point[0] < result.box_min()[0] || point[0] > result.box_max()[0] ||
+      point[1] < result.box_min()[1] || point[1] > result.box_max()[1] ||
+      point[2] < result.box_min()[2] || point[2] > result.box_max()[2])
+    return MB_ENTITY_NOT_FOUND;
+    // initialize iterator at tree root
+  result.treeTool = this;
+  result.mStack.clear();
+  result.mStack.push_back( MBAdaptiveKDTreeIter::StackObj(root,0) );
+    // loop until we reach a leaf
+  MBAdaptiveKDTree::Plane plane;
+  for(;;) {
+      // get children
+    result.childVect.clear();
+    rval = moab()->get_child_meshsets( result.handle(), result.childVect );
+      return rval;
+      // if no children, then at leaf (done)
+    if (result.childVect.empty())
+      break;
+      // get split plane
+    rval = get_split_plane( result.handle(), plane );
+      return rval;
+      // step iterator to appropriate child
+      // idx: 0->left, 1->right
+    const int idx = (point[plane.norm] > plane.coord);
+    result.mStack.push_back( MBAdaptiveKDTreeIter::StackObj( result.childVect[idx],
+                                                             result.mBox[1-idx][plane.norm] ) );
+    result.mBox[1-idx][plane.norm] = plane.coord;
+  return MB_SUCCESS;
 struct NodeDistance {
   MBEntityHandle handle;
   MBCartVect dist; // from_point - closest_point_on_box
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp	2008-01-14 23:35:35 UTC (rev 1526)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp	2008-01-15 16:14:09 UTC (rev 1527)
@@ -85,6 +85,10 @@
   //! Get iterator for tree
   MBErrorCode get_tree_iterator( MBEntityHandle tree_root,
                                  MBAdaptiveKDTreeIter& result );
+  //! Get iterator at right-most ('last') leaf.
+  MBErrorCode get_last_iterator( MBEntityHandle tree_root,
+                                 MBAdaptiveKDTreeIter& result );
   //! Get iterator for tree or subtree
   MBErrorCode get_sub_tree_iterator( MBEntityHandle tree_root,
@@ -183,6 +187,14 @@
                                      MBEntityHandle& leaf_out );
+  //! Get iterator at leaf containing input position.
+  //! Returns MB_ENTITY_NOT_FOUND if point is not within
+  //! bounding box of tree.
+  MBErrorCode leaf_containing_point( MBEntityHandle tree_root,
+                                     const double xyz[3],
   //! Find all leaves within a given distance from point in space.
   MBErrorCode leaves_within_distance( MBEntityHandle tree_root,
                                       const double from_point[3],
@@ -195,6 +207,10 @@
 //! Iterate over leaves of an adapative kD-tree
 class MBAdaptiveKDTreeIter
+public:
+  enum Direction { LEFT = 0, RIGHT = 1 };
 private:
   struct StackObj {
@@ -213,7 +229,7 @@
   //! Descend tree to left most leaf from current position
   //! No-op if at leaf.
-  MBErrorCode step_to_first_leaf();
+  MBErrorCode step_to_first_leaf( Direction direction );
   friend class MBAdaptiveKDTree;
 public:
@@ -223,7 +239,8 @@
   MBErrorCode initialize( MBAdaptiveKDTree* tool,
-                          const double box_max[3] );
+                          Direction direction );
   MBAdaptiveKDTree* tool() const
     { return treeTool; }
@@ -243,11 +260,26 @@
     //! Get depth in tree. root is at depth of 1.
   unsigned depth() const
     { return mStack.size(); }
+  //! Advance the iterator either left or right in the tree
+  //! Note:  stepping past the end of the tree will invalidate
+  //!        the iterator.  It will *not* be work step the
+  //!        other direction.
+  MBErrorCode step( Direction direction );
     //! Advance to next leaf
     //! Returns MB_ENTITY_NOT_FOUND if at end.
-  MBErrorCode step();
+    //! Note: steping past the end of the tree will invalidate
+    //!       the iterator. Calling back() will not work.
+  MBErrorCode step() { return step(RIGHT); }
+    //! Move back to previous leaf
+    //! Returns MB_ENTITY_NOT_FOUND if at beginning.
+    //! Note: steping past the start of the tree will invalidate
+    //!       the iterator. Calling step() will not work.
+  MBErrorCode back() { return step(LEFT); }
     //! Return the side of the box bounding this tree node
     //! that is shared with the immediately adjacent sibling
     //! (the tree node that shares a common parent node with
Modified: MOAB/trunk/kd_tree_test.cpp
--- MOAB/trunk/kd_tree_test.cpp	2008-01-14 23:35:35 UTC (rev 1526)
+++ MOAB/trunk/kd_tree_test.cpp	2008-01-15 16:14:09 UTC (rev 1527)
@@ -5,10 +5,15 @@
 #include <assert.h>
 #include <float.h>
+#include "MBCartVect.hpp"
 const unsigned INTERVALS = 4;
 const unsigned DEPTH = 7; // 3*log2(INTERVALS)+1
 const char* TAG_NAME = "TEST_DATA";
+void test_iterator_back( MBAdaptiveKDTree& tool, MBEntityHandle root );
+void test_point_search( MBAdaptiveKDTree& tool, MBEntityHandle root );
 int main()
   // Initialize MOAB & create tree tool
@@ -72,6 +77,9 @@
   const int num_leaves = INTERVALS*INTERVALS*INTERVALS;
   assert( num_leaves == counter );
+  test_iterator_back( tool, root );
+  test_point_search( tool, root );
   // reduce tree depth to DEPTH-1 by merging adjacent leaf pairs,
   // make new "leaf" have smaller of two data values on original pair
   for (err = tool.get_tree_iterator( root, iter ); !err; err = iter.step()) {
@@ -193,3 +201,123 @@
   return 0;
+  MBAdaptiveKDTreeIter iter;
+  MBErrorCode rval = tool.get_tree_iterator( root, iter );
+  assert( MB_SUCCESS == rval );
+  MBCartVect min( iter.box_min() );
+  MBCartVect max( iter.box_max() );
+  MBEntityHandle leaf = iter.handle();
+    // going back from first location should fail.
+  rval = iter.back();
+  assert( MB_ENTITY_NOT_FOUND == rval );
+  rval = tool.get_tree_iterator( root, iter );
+    // make sure iterator is valid
+  assert( iter.box_min()[0] == min[0] && iter.box_min()[1] == min[1] && iter.box_min()[2] == min[2] );
+  assert( iter.box_max()[0] == max[0] && iter.box_max()[1] == max[1] && iter.box_max()[2] == max[2] );
+  assert( iter.handle() == leaf );
+  while (MB_SUCCESS == iter.step()) {
+      // Get values at current iterator location
+    MBCartVect next_min( iter.box_min() );
+    MBCartVect next_max( iter.box_max() );
+    MBEntityHandle next_leaf = iter.handle();
+      // step back to previous location
+      // check expected values for previous location
+      // advance iterator to 'current' location
+    rval = iter.step();
+      // check that iterator values are correct
+    assert( iter.box_min()[0] == next_min[0] && iter.box_min()[1] == next_min[1] && iter.box_min()[2] == next_min[2] );
+    assert( iter.box_max()[0] == next_max[0] && iter.box_max()[1] == next_max[1] && iter.box_max()[2] == next_max[2] );
+    assert( iter.handle() == next_leaf );
+      // store values for next iteration
+    min = next_min;
+    max = next_max;
+    leaf = next_leaf;
+  MBErrorCode rval;
+  MBEntityHandle leaf;
+  MBAdaptiveKDTreeIter iter, iter2;
+    // points to test
+  MBCartVect left( 0.5 );
+  MBCartVect right( MBCartVect(INTERVALS) - left );
+    // compare leaf search to iterator search
+  rval = tool.leaf_containing_point( root, left.array(), leaf );
+  rval = tool.leaf_containing_point( root, left.array(), iter );
+    // iterator should be at 'first' leaf
+  rval = tool.get_tree_iterator( root, iter2 );
+  for (;;) {
+    assert( iter.handle() == iter2.handle() );
+    assert( iter.depth() == iter2.depth() );
+    assert( iter.box_min()[0] == iter2.box_min()[0] );
+    assert( iter.box_min()[1] == iter2.box_min()[1] );
+    assert( iter.box_min()[2] == iter2.box_min()[2] );
+    assert( iter.box_max()[0] == iter2.box_max()[0] );
+    assert( iter.box_max()[1] == iter2.box_max()[1] );
+    assert( iter.box_max()[2] == iter2.box_max()[2] );
+    rval = iter2.step();
+      break;
+  rval = tool.leaf_containing_point( root, right.array(), leaf );
+  rval = tool.leaf_containing_point( root, right.array(), iter );
+    // iterator should be at 'last' leaf
+  rval = tool.get_last_iterator( root, iter2 );
+  for (;;) {
+    rval = iter2.back();
+      break;
