[MOAB-dev] r1508 - MOAB/trunk
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jan 3 19:42:37 CST 2008
Author: tautges
Date: 2008-01-03 19:42:37 -0600 (Thu, 03 Jan 2008)
New Revision: 1508
Modified:
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/Tqdcfr.hpp
Log:
Changing lots of int's to unsigned int's 'cuz that's really what the .cub writer uses.
Fixes problem found trying to read a file > 2 GB in size.
Passes make check.
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2008-01-03 23:02:58 UTC (rev 1507)
+++ MOAB/trunk/Tqdcfr.cpp	2008-01-04 01:42:37 UTC (rev 1508)
@@ -89,7 +89,7 @@
-void Tqdcfr::FSEEK( long offset ) {
+void Tqdcfr::FSEEK( unsigned int offset ) {
   int rval = fseek( cubFile, offset, SEEK_SET );
   IO_ASSERT( !rval );
@@ -109,8 +109,8 @@
   FREADCA( num_ents, &char_buf[0] );
-void Tqdcfr::FREADIA( unsigned num_ents, int* array ) {
-  unsigned rval = fread( array, sizeof(int), num_ents, cubFile );
+void Tqdcfr::FREADIA( unsigned num_ents, unsigned int* array ) {
+  unsigned rval = fread( array, sizeof(unsigned int), num_ents, cubFile );
   IO_ASSERT( rval == num_ents );
@@ -220,7 +220,7 @@
   result = mesh_model->read_metadata_info(this); RR;
     // now read in mesh for each geometry entity
-  for (int gindex = 0;
+  for (unsigned int gindex = 0;
        gindex < mesh_model->feModelHeader.geomArray.numEntities;
        gindex++) {
     Tqdcfr::GeomHeader *geom_header = &mesh_model->feGeomH[gindex];
@@ -247,7 +247,7 @@
     // read groups...
   if (debug) std::cout << "Reading groups... ";
-  for (int grindex = 0;
+  for (unsigned int grindex = 0;
        grindex < mesh_model->feModelHeader.groupArray.numEntities;
        grindex++) {
     GroupHeader *group_header = &mesh_model->feGroupH[grindex];
@@ -260,7 +260,7 @@
     // read blocks...
   if (debug) std::cout << "Reading blocks... ";
-  for (int blindex = 0;
+  for (unsigned int blindex = 0;
        blindex < mesh_model->feModelHeader.blockArray.numEntities;
        blindex++) {
     BlockHeader *block_header = &mesh_model->feBlockH[blindex];
@@ -274,7 +274,7 @@
     // read nodesets...
   if (debug) std::cout << "Reading nodesets... ";
-  for (int nsindex = 0;
+  for (unsigned int nsindex = 0;
        nsindex < mesh_model->feModelHeader.nodesetArray.numEntities;
        nsindex++) {
     NodesetHeader *nodeset_header = &mesh_model->feNodeSetH[nsindex];
@@ -287,7 +287,7 @@
     // read sidesets...
   if (debug) std::cout << "Reading sidesets...";
-  for (int ssindex = 0;
+  for (unsigned int ssindex = 0;
        ssindex < mesh_model->feModelHeader.sidesetArray.numEntities;
        ssindex++) {
     SidesetHeader *sideset_header = &mesh_model->feSideSetH[ssindex];
@@ -327,7 +327,7 @@
     // look first for the nodeset and sideset offset flags; if they're not
     // set, we don't need to convert
-  int nodeset_offset, sideset_offset;
+  unsigned int nodeset_offset, sideset_offset;
   MBTag tmp_tag;
   MBErrorCode result = mdbImpl->tag_get_handle(BLOCK_NODESET_OFFSET_TAG_NAME.c_str(),
                                                tmp_tag);
@@ -359,19 +359,19 @@
   result = mdbImpl->tag_get_data(globalIdTag, blocks, &block_ids[0]);
   if (MB_SUCCESS != result) return result;
-  int i = 0;
+  unsigned int i = 0;
   MBRange::iterator rit = blocks.begin();
   MBRange new_nodesets, new_sidesets;
   std::vector<int> new_nodeset_ids, new_sideset_ids;
   for (; rit != blocks.end(); i++, rit++) {
-    if (0 != nodeset_offset && block_ids[i] >= nodeset_offset &&
-        (nodeset_offset > sideset_offset || block_ids[i] < sideset_offset)) {
+    if (0 != nodeset_offset && block_ids[i] >= (int) nodeset_offset &&
+        (nodeset_offset > sideset_offset || block_ids[i] < (int) sideset_offset)) {
         // this is a nodeset
       new_nodesets.insert(*rit);
       new_nodeset_ids.push_back(block_ids[i]);
-    else if (0 != sideset_offset && block_ids[i] >= sideset_offset &&
-             (sideset_offset > nodeset_offset || block_ids[i] < nodeset_offset)) {
+    else if (0 != sideset_offset && block_ids[i] >= (int) sideset_offset &&
+             (sideset_offset > nodeset_offset || block_ids[i] < (int) nodeset_offset)) {
         // this is a sideset
       new_sidesets.insert(*rit);
       new_sideset_ids.push_back(block_ids[i]);
@@ -424,7 +424,7 @@
     // read ids for each entity type
   int this_type, num_ents;
   std::vector<MBEntityHandle> ns_entities, excl_entities;
-  for (int i = 0; i < nodeseth->memTypeCt; i++) {
+  for (unsigned int i = 0; i < nodeseth->memTypeCt; i++) {
       // get how many and what type
     FREADI(2);
     this_type = int_buf[0];
@@ -455,12 +455,12 @@
   FSEEK(model->modelOffset+sideseth->memOffset);
-  int this_type, num_ents, sense_size;
+  unsigned int this_type, num_ents, sense_size;
   std::vector<MBEntityHandle> ss_entities, excl_entities;
   std::vector<double> ss_dfs;
   if (data_version <= 1.0) {
-    for (int i = 0; i < sideseth->memTypeCt; i++) {
+    for (unsigned int i = 0; i < sideseth->memTypeCt; i++) {
       FREADI(3);
@@ -476,7 +476,7 @@
       if (sense_size == 1) {
           // byte-size sense flags; make sure read ends aligned...
-        int read_length = (num_ents / 8) * 8;
+        unsigned int read_length = (num_ents / 8) * 8;
         if (read_length < num_ents) read_length += 8;
         FREADC(read_length);
@@ -492,25 +492,25 @@
   else {
       FREADI(1);
       num_ents = int_buf[0];
         // get the types, and ids
-      std::vector<int> mem_types(num_ents), mem_ids(num_ents);
+      std::vector<unsigned int> mem_types(num_ents), mem_ids(num_ents);
       FREADIA(num_ents, &mem_types[0]);
       FREADIA(num_ents, &mem_ids[0]);
         // wrt entities
       FREADI(1);
       int num_wrts = int_buf[0];
-      std::vector<int> wrt_ents(num_wrts);
+      std::vector<unsigned int> wrt_ents(num_wrts);
       FREADIA(num_wrts, &wrt_ents[0]);
       std::vector<MBEntityHandle> ss_entities;
@@ -567,7 +567,7 @@
     for (int i = 0; i < num_ents; i++) {
       if (int_buf[i] == 0) forward.push_back(ss_entities[i]);
       else if (int_buf[i] == 1) reverse.push_back(ss_entities[i]);
-      if (int_buf[i] == -1) { // -1 means "unknown", which means both
+      if (*((int*)&int_buf[i]) == -1) { // -1 means "unknown", which means both
@@ -603,19 +603,19 @@
 MBErrorCode Tqdcfr::process_sideset_11(std::vector<MBEntityHandle> &ss_entities,
-                                       std::vector<int> &wrt_ents,
+                                       std::vector<unsigned int> &wrt_ents,
                                        Tqdcfr::SidesetHeader *sideseth)
   std::vector<MBEntityHandle> forward, reverse;
-  int num_ents = ss_entities.size();
-  std::vector<int>::iterator wrt_it = wrt_ents.begin();
+  unsigned int num_ents = ss_entities.size();
+  std::vector<unsigned int>::iterator wrt_it = wrt_ents.begin();
-  for (int i = 0; i < num_ents; i++) {
+  for (unsigned int i = 0; i < num_ents; i++) {
-    int num_wrt = 0;
+    unsigned int num_wrt = 0;
     if (!wrt_ents.empty()) num_wrt = *wrt_it++;
-    for (int j = 0; j < num_wrt; j++) wrt_it += 2;
+    for (unsigned int j = 0; j < num_wrt; j++) wrt_it += 2;
       // assume here that if it's in the list twice, we get both senses
     if (num_wrt > 1) {
@@ -673,7 +673,7 @@
   std::vector<MBEntityHandle> block_entities, excl_entities;
-  for (int i = 0; i < blockh->memTypeCt; i++) {
+  for (unsigned int i = 0; i < blockh->memTypeCt; i++) {
     FREADI(2);
@@ -709,7 +709,7 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::read_group(const int group_index,
+MBErrorCode Tqdcfr::read_group(const unsigned int group_index,
                                Tqdcfr::ModelEntry *model,
                                Tqdcfr::GroupHeader *grouph)
@@ -719,7 +719,7 @@
   std::vector<MBEntityHandle> grp_entities, excl_entities;
-  for (int i = 0; i < grouph->memTypeCt; i++) {
+  for (unsigned int i = 0; i < grouph->memTypeCt; i++) {
     FREADI(2);
@@ -807,14 +807,14 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::get_entities(const int *mem_types,
-                                 int *id_buf, const int id_buf_size,
+MBErrorCode Tqdcfr::get_entities(const unsigned int *mem_types,
+                                 unsigned int *id_buf, const unsigned int id_buf_size,
                                  const bool is_group,
                                  std::vector<MBEntityHandle> &entities)
   MBErrorCode tmp_result, result = MB_SUCCESS;
-  for (int i = 0; i < id_buf_size; i++) {
+  for (unsigned int i = 0; i < id_buf_size; i++) {
     if (is_group)
       tmp_result = get_entities(mem_types[i], id_buf+i, 1, entities, entities);
     else
@@ -826,8 +826,8 @@
   return result;
-MBErrorCode Tqdcfr::get_entities(const int this_type,
+MBErrorCode Tqdcfr::get_entities(const unsigned int this_type,
                                  std::vector<MBEntityHandle> &entities,
                                  std::vector<MBEntityHandle> &excl_entities)
@@ -841,18 +841,18 @@
   return result;
-MBErrorCode Tqdcfr::get_ref_entities(const int this_type,
+MBErrorCode Tqdcfr::get_ref_entities(const unsigned int this_type,
     entities.push_back((gidSetMap[5-this_type])[id_buf[i]]);
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::get_mesh_entities(const int this_type,
+MBErrorCode Tqdcfr::get_mesh_entities(const unsigned int this_type,
@@ -872,11 +872,11 @@
   if (MBVERTEX == this_ent_type) {
       // use either vertex offset or cubMOABVertexMap
     if (NULL == cubMOABVertexMap) {
         ent_list->push_back(int_buf[i]+currNodeIdOffset);
     else {
         assert(0 != (*cubMOABVertexMap)[int_buf[i]]);
         ent_list->push_back((*cubMOABVertexMap)[int_buf[i]]);
@@ -893,7 +893,7 @@
     if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result) return result;
       // now go through id list, finding each entity by id
       std::vector<int>::iterator vit = std::find(cub_ids.begin(), cub_ids.end(), id_buf[i]);
       if (vit != cub_ids.end()) {
         MBEntityHandle this_ent = tmp_ents[vit-cub_ids.begin()];
@@ -909,7 +909,7 @@
   return result;
-MBErrorCode Tqdcfr::read_nodes(const int gindex,
+MBErrorCode Tqdcfr::read_nodes(const unsigned int gindex,
                                Tqdcfr::GeomHeader *entity)
@@ -952,8 +952,8 @@
     // might make this offset negative
   long node_offset = mdbImpl->id_from_handle( node_handle);
-  int max_id = -1;
-  int contig;
+  long max_id = -1;
+  long contig;
   check_contiguous(entity->nodeCt, contig, max_id);
@@ -985,16 +985,16 @@
   if (NULL != cubMOABVertexMap) {
       // expand the size if necessary
     if (max_id > (int) cubMOABVertexMap->size()-1) {
-      long old_size = cubMOABVertexMap->size();
+      unsigned int old_size = cubMOABVertexMap->size();
       cubMOABVertexMap->resize(max_id+1);
       std::fill(&(*cubMOABVertexMap)[old_size], &(*cubMOABVertexMap)[0]+cubMOABVertexMap->size(), 0);
       // now set the new values
-    std::vector<int>::iterator vit;
+    std::vector<unsigned int>::iterator vit;
     MBRange::iterator rit;
     for (vit = int_buf.begin(), rit = dum_range.begin(); rit != dum_range.end(); vit++, rit++) {
-      assert(0 < *vit && *vit < (int)cubMOABVertexMap->size());
+      assert(0 < *vit && *vit < cubMOABVertexMap->size());
       (*cubMOABVertexMap)[*vit] = *rit;
@@ -1024,7 +1024,7 @@
   if (md_entry->mdDataType != 3) return MB_FAILURE;
     // if contiguous, we can use the node id as an offset
   if (1 == contig) {
-    for (std::vector<int>::iterator vit = md_entry->mdIntArrayValue.begin();
+    for (std::vector<unsigned int>::iterator vit = md_entry->mdIntArrayValue.begin();
          vit != md_entry->mdIntArrayValue.end(); vit++) {
       if (*vit - int_buf[0] < entity->nodeCt) return MB_FAILURE;
       fixed_flags[*vit - int_buf[0]] = 1;
@@ -1033,10 +1033,10 @@
     // else we have to find the position of each node in the node ids, then set the
     // equivalent position in the fixed flags
   else {
-    int *buf_end = &int_buf[0]+entity->nodeCt;
+    unsigned int *buf_end = &int_buf[0]+entity->nodeCt;
-      int *vit2 = std::find(&int_buf[0], buf_end, *vit);
+      unsigned int *vit2 = std::find(&int_buf[0], buf_end, *vit);
       if (vit2 != buf_end) fixed_flags[vit2 - &int_buf[0]] = 1;
@@ -1068,7 +1068,7 @@
   int int_type, nodes_per_elem, num_elem;
   int max_dim = -1;
   MBErrorCode result;
-  for (int i = 0; i < entity->elemTypeCt; i++) {
+  for (unsigned int i = 0; i < entity->elemTypeCt; i++) {
       // for this elem type, get the type, nodes per elem, num elems
     FREADI(3);
     int_type = int_buf[0];
@@ -1083,7 +1083,7 @@
     FREADI(num_elem);
       // check to see if ids are contiguous...
-    int contig, max_id;
+    long contig, max_id;
     check_contiguous(num_elem, contig, max_id);
     if (0 == contig)
       std::cout << "Element ids are not contiguous!" << std::endl;
@@ -1096,7 +1096,7 @@
                                      readUtilIface->parallel_rank(),
                                      start_handle, conn);
-    long unsigned int elem_offset;
+    long elem_offset;
     elem_offset = mdbImpl->id_from_handle( start_handle) - int_buf[0];
     if (-1 == currElementIdOffset[elem_type])
       currElementIdOffset[elem_type] = elem_offset;
@@ -1106,10 +1106,10 @@
       // get the connectivity array; be careful, the connectivity is stored
       // in the file as ints, while the connect array is handles, which may
       // be long; this will lead to problems on 64-bit machines
-    int total_conn = num_elem * nodes_per_elem;
-    int *tmp_conn = reinterpret_cast<int*>(conn);
-    if (sizeof(MBEntityHandle) != sizeof(int))
-      tmp_conn = new int[total_conn];
+    unsigned int total_conn = num_elem * nodes_per_elem;
+    unsigned int *tmp_conn = reinterpret_cast<unsigned int*>(conn);
+    if (sizeof(MBEntityHandle) != sizeof(unsigned int))
+      tmp_conn = new unsigned int[total_conn];
     FREADIA(total_conn, tmp_conn);
@@ -1158,10 +1158,10 @@
   return MB_SUCCESS;
-void Tqdcfr::check_contiguous(const int num_ents, int &contig, int &max_id)
+void Tqdcfr::check_contiguous(const unsigned int num_ents, long &contig, long &max_id)
-  std::vector<int>::iterator id_it;
-  int curr_id, i;
+  std::vector<unsigned int>::iterator id_it;
+  unsigned int curr_id, i;
   max_id = -1;
     // check in forward-contiguous direction
@@ -1207,7 +1207,7 @@
     // need to loop over i, b/c int_buf is bigger than num_ents
   for (id_it = int_buf.begin(), i = 0; i < num_ents; id_it++, i++) {
-    if (*id_it < min_id || -1 == min_id) min_id = *id_it;
+    if (((int)*id_it) < min_id || -1 == min_id) min_id = *id_it;
     if (*id_it > max_id || -1 == max_id) max_id = *id_it;
   if (max_id - min_id + 1 == num_ents) contig = min_id;
@@ -1216,7 +1216,7 @@
   contig = 0;
-void Tqdcfr::FEModelHeader::init(const int offset, Tqdcfr* instance )
+void Tqdcfr::FEModelHeader::init(const unsigned int offset, Tqdcfr* instance )
   instance->FSEEK(offset);
   instance->FREADI(4);
@@ -1259,8 +1259,8 @@
   FREADI(fileTOC.numModels*6);
   modelEntries = new ModelEntry[fileTOC.numModels];
   if (NULL == modelEntries) return MB_FAILURE;
-  std::vector<int>::iterator int_it = int_buf.begin();
-  for (int i = 0; i < fileTOC.numModels; i++) {
+  std::vector<unsigned int>::iterator int_it = int_buf.begin();
+  for (unsigned int i = 0; i < fileTOC.numModels; i++) {
     modelEntries[i].modelHandle = *int_it++;
     modelEntries[i].modelOffset = *int_it++;
     modelEntries[i].modelLength = *int_it++;
@@ -1274,15 +1274,15 @@
   return MB_SUCCESS;
-int Tqdcfr::find_model(const int model_type)
+int Tqdcfr::find_model(const unsigned int model_type)
     if (modelEntries[i].modelType == model_type) return i;
   return -1;
-MBErrorCode Tqdcfr::read_meta_data(const int metadata_offset,
+MBErrorCode Tqdcfr::read_meta_data(const unsigned int metadata_offset,
                                    Tqdcfr::MetaDataContainer &mc)
     // read the metadata header
@@ -1297,7 +1297,7 @@
     new Tqdcfr::MetaDataContainer::MetaDataEntry[mc.numDatums];
     // now read the metadata values
-  for (int i = 0; i < mc.numDatums; i++) {
+  for (unsigned int i = 0; i < mc.numDatums; i++) {
     FREADI(2);
     mc.metadataEntries[i].mdOwner = int_buf[0];
     mc.metadataEntries[i].mdDataType = int_buf[1];
@@ -1367,7 +1367,7 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::GeomHeader::read_info_header(const int model_offset,
+MBErrorCode Tqdcfr::GeomHeader::read_info_header(const unsigned int model_offset,
                                                  const Tqdcfr::FEModelHeader::ArrayInfo &info,
                                                  Tqdcfr* instance,
                                                  Tqdcfr::GeomHeader *&geom_headers)
@@ -1384,7 +1384,7 @@
     if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
-  for (int i = 0; i < info.numEntities; i++) {
+  for (unsigned int i = 0; i < info.numEntities; i++) {
     instance->FREADI(8);
     geom_headers[i].nodeCt = instance->int_buf[0];
@@ -1422,7 +1422,7 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::GroupHeader::read_info_header(const int model_offset,
+MBErrorCode Tqdcfr::GroupHeader::read_info_header(const unsigned int model_offset,
                                            Tqdcfr* instance,
                                            Tqdcfr::GroupHeader *&group_headers)
@@ -1438,7 +1438,7 @@
       // create an entity set for this entity
     result = instance->create_set(group_headers[i].setHandle);
@@ -1472,7 +1472,7 @@
 MBErrorCode Tqdcfr::BlockHeader::read_info_header(const double data_version,
-                                                  const int model_offset,
+                                                  const unsigned int model_offset,
                                                   Tqdcfr* instance,
                                                   Tqdcfr::BlockHeader *&block_headers)
@@ -1488,7 +1488,7 @@
     result = instance->create_set(block_headers[i].setHandle);
@@ -1552,7 +1552,7 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::NodesetHeader::read_info_header(const int model_offset,
+MBErrorCode Tqdcfr::NodesetHeader::read_info_header(const unsigned int model_offset,
                                              Tqdcfr* instance,
                                              Tqdcfr::NodesetHeader *&nodeset_headers)
@@ -1568,7 +1568,7 @@
     result = instance->create_set(nodeset_headers[i].setHandle);
@@ -1602,7 +1602,7 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::SidesetHeader::read_info_header(const int model_offset,
+MBErrorCode Tqdcfr::SidesetHeader::read_info_header(const unsigned int model_offset,
                                              Tqdcfr* instance,
                                              Tqdcfr::SidesetHeader *&sideset_headers)
@@ -1618,7 +1618,7 @@
     result = instance->create_set(sideset_headers[i].setHandle);
@@ -1654,52 +1654,52 @@
 void Tqdcfr::ModelEntry::print_geom_headers(const char *prefix,
                                            GeomHeader *header,
-                                            const int num_headers)
+                                            const unsigned int num_headers)
   if (!debug) return;
   std::cout << prefix << std::endl;
   if (NULL != header)
-    for (int i = 0; i < num_headers; i++) header[i].print();
+    for (unsigned int i = 0; i < num_headers; i++) header[i].print();
 void Tqdcfr::ModelEntry::print_group_headers(const char *prefix,
                                             GroupHeader *header,
   if (!debug) return;
   if (NULL != header)
 void Tqdcfr::ModelEntry::print_block_headers(const char *prefix,
                                             BlockHeader *header,
   if (!debug) return;
   if (NULL != header)
 void Tqdcfr::ModelEntry::print_nodeset_headers(const char *prefix,
                                               NodesetHeader *header,
   if (!debug) return;
   if (NULL != header)
 void Tqdcfr::ModelEntry::print_sideset_headers(const char *prefix,
                                               SidesetHeader *header,
   if (!debug) return;
   if (NULL != header)
 MBErrorCode Tqdcfr::ModelEntry::read_header_info( Tqdcfr* instance, const double data_version)
@@ -1808,9 +1808,9 @@
     // get the acis model location
-  int acis_model_offset = 0, acis_model_length = 0, acis_model_handle = 1,
+  unsigned int acis_model_offset = 0, acis_model_length = 0, acis_model_handle = 1,
     acis_sat_type = 1;
     if (modelEntries[i].modelHandle == acis_model_handle &&
         modelEntries[i].modelType == acis_sat_type) {
       acis_model_offset = modelEntries[i].modelOffset;
@@ -1834,21 +1834,21 @@
     // position the file at the start of the acis model
   FSEEK(acis_model_offset);
-  int bytes_left = acis_model_length;
+  unsigned int bytes_left = acis_model_length;
   struct AcisRecord this_record;
   reset_record(this_record);
   char *ret;
     // make the char buffer at least buf_size+1 long, to fit null char
-  const int buf_size = 1023;
+  const unsigned int buf_size = 1023;
   //CHECK_SIZE(char_buf, buf_size+1);
   char_buf.resize(buf_size+1);
   while (0 != bytes_left) {
       // read the next buff characters, or bytes_left if smaller
-    int next_buf = (bytes_left > buf_size ? buf_size : bytes_left);
+    unsigned int next_buf = (bytes_left > buf_size ? buf_size : bytes_left);
     FREADC(next_buf);
     if (NULL != acisDumpFile)
@@ -1856,7 +1856,7 @@
       // put null at end of string to stop searches
     char_buf[next_buf] = '\0';
-    int buf_pos = 0;
+    unsigned int buf_pos = 0;
       // check for first read, and if so, get rid of the header
     if (bytes_left == acis_model_length) {
@@ -1918,11 +1918,11 @@
                         attribVectorTag, &default_val);
-  int current_record = 0;
+  unsigned int current_record = 0;
 #define REC records[current_record]
-  while (current_record != (int) records.size()) {
+  while (current_record != records.size()) {
       // if this record's been processed, or if it's an attribute, continue
     if (REC.processed || REC.rec_type == Tqdcfr::ATTRIB) {
@@ -1947,10 +1947,10 @@
   return MB_SUCCESS;
-MBErrorCode Tqdcfr::parse_acis_attribs(const int entity_rec_num,
+MBErrorCode Tqdcfr::parse_acis_attribs(const unsigned int entity_rec_num,
                                        std::vector<AcisRecord> &records)
-  int num_read;
+  unsigned int num_read;
   std::vector<std::string> *attrib_vec = NULL;
   char temp_name[80], *name_tag = NULL;
   int id = -1;
@@ -1970,7 +1970,7 @@
   while (-1 != current_attrib) {
     if (records[current_attrib].rec_type != Tqdcfr::UNKNOWN &&
            (records[current_attrib].att_next != next_attrib ||
-            records[current_attrib].att_ent_num != entity_rec_num)) return MB_FAILURE;
+            records[current_attrib].att_ent_num != (int)entity_rec_num)) return MB_FAILURE;
       fwrite(records[current_attrib].att_string.c_str(), sizeof(char),
@@ -2230,7 +2230,7 @@
             << numEntities << ", " << tableOffset << ", " << metaDataOffset << std::endl;
-void Tqdcfr::FEModelHeader::ArrayInfo::init(const std::vector<int>& int_buf)
+void Tqdcfr::FEModelHeader::ArrayInfo::init(const std::vector<unsigned int>& int_buf)
   numEntities = int_buf[0]; tableOffset = int_buf[1]; metaDataOffset = int_buf[2];
@@ -2370,7 +2370,7 @@
   std::cout << "MetaDataContainer:mdSchema, compressFlag, numDatums = "
             << mdSchema << ", " << compressFlag << ", " << numDatums << std::endl;
-  for (int i = 0; i < numDatums; i++)
+  for (unsigned int i = 0; i < numDatums; i++)
     metadataEntries[i].print();
@@ -2383,9 +2383,9 @@
   if (NULL != metadataEntries) delete [] metadataEntries;
-int Tqdcfr::MetaDataContainer::get_md_entry(const int owner, const std::string &name)
+int Tqdcfr::MetaDataContainer::get_md_entry(const unsigned int owner, const std::string &name)
     if (owner == metadataEntries[i].mdOwner && name == metadataEntries[i].mdName) return i;
   return -1;
@@ -2412,7 +2412,7 @@
             << std::endl;
-MBErrorCode Tqdcfr::create_set( MBEntityHandle& h, int flags )
+MBErrorCode Tqdcfr::create_set( MBEntityHandle& h, unsigned int flags )
   MBErrorCode rval;
   if (!mFileSet)
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp	2008-01-03 23:02:58 UTC (rev 1507)
+++ MOAB/trunk/Tqdcfr.hpp	2008-01-04 01:42:37 UTC (rev 1508)
@@ -43,11 +43,11 @@
 public:
-  void FSEEK( long offset );        // set cubFile offset to specified value
+  void FSEEK( unsigned offset );        // set cubFile offset to specified value
   void FREADI( unsigned num_ents ); // read integers into int_buf
   void FREADD( unsigned num_ents ); // read doubles into dbl_buf
   void FREADC( unsigned num_ents ); // read characters into char_buf
-  void FREADIA( unsigned num_ents,    int* array ); // read integers
+  void FREADIA( unsigned num_ents,    unsigned int* array ); // read integers
   void FREADDA( unsigned num_ents, double* array ); // read doubles
   void FREADCA( unsigned num_ents,   char* arrat ); // read bytes
@@ -55,7 +55,7 @@
   class FileTOC
   public:
-    int fileEndian, fileSchema, numModels, modelTableOffset,
+    unsigned int fileEndian, fileSchema, numModels, modelTableOffset,
       modelMetaDataOffset, activeFEModel;
     FileTOC();
@@ -66,23 +66,23 @@
   class FEModelHeader
   public:
-    int feEndian, feSchema, feCompressFlag, feLength;
+    unsigned int feEndian, feSchema, feCompressFlag, feLength;
     class ArrayInfo
     public:
-      int numEntities, tableOffset, metaDataOffset;
+      unsigned numEntities, tableOffset, metaDataOffset;
       ArrayInfo();
       void print();
-      void init(const std::vector<int>& int_buf);
+      void init(const std::vector<unsigned int>& int_buf);
     ArrayInfo geomArray, nodeArray, elementArray, groupArray,
       blockArray, nodesetArray, sidesetArray;
-    void init(const int offset, Tqdcfr* instance );
+    void init(const unsigned int offset, Tqdcfr* instance );
     void print();
@@ -90,14 +90,14 @@
   class MetaDataContainer
   public:
-    int mdSchema, compressFlag, numDatums;
+    unsigned int mdSchema, compressFlag, numDatums;
     class MetaDataEntry
     public:
-      int mdOwner, mdDataType, mdIntValue;
+      unsigned int mdOwner, mdDataType, mdIntValue;
       std::string mdName, mdStringValue;
-      std::vector<int> mdIntArrayValue;
+      std::vector<unsigned int> mdIntArrayValue;
       double mdDblValue;
       std::vector<double> mdDblArrayValue;
@@ -108,7 +108,7 @@
     void print();
-    int get_md_entry(const int owner, const std::string &name);
+    int get_md_entry(const unsigned int owner, const std::string &name);
     MetaDataEntry *metadataEntries;
     MetaDataContainer();
@@ -118,14 +118,14 @@
   class GeomHeader
   public:
-    int geomID, nodeCt, nodeOffset, elemCt, elemOffset,
+    unsigned int geomID, nodeCt, nodeOffset, elemCt, elemOffset,
       elemTypeCt, elemLength;
     MBEntityHandle setHandle;
     void print();
-    static MBErrorCode read_info_header(const int model_offset,
+    static MBErrorCode read_info_header(const unsigned int model_offset,
                                         const FEModelHeader::ArrayInfo &info,
                                         Tqdcfr* instance,
                                         GeomHeader *&entity_headers);
@@ -136,13 +136,13 @@
   class GroupHeader
   public:
-    int grpID, grpType, memCt, memOffset, memTypeCt, grpLength;
+    unsigned int grpID, grpType, memCt, memOffset, memTypeCt, grpLength;
     void print();
                                  Tqdcfr* instance,
                                  GroupHeader *&entity_headers);
@@ -153,7 +153,7 @@
   class BlockHeader
   public:
-    int blockID, blockElemType, memCt, memOffset, memTypeCt, attribOrder, blockCol,
+    unsigned int blockID, blockElemType, memCt, memOffset, memTypeCt, attribOrder, blockCol,
       blockMixElemType, blockPyrType, blockMat, blockLength, blockDim;
@@ -163,7 +163,7 @@
     void print();
     static MBErrorCode read_info_header(const double data_version,
                                         Tqdcfr* instance,
                                         BlockHeader *&block_headers);
@@ -174,13 +174,13 @@
   class NodesetHeader
   public:
-    int nsID, memCt, memOffset, memTypeCt, pointSym, nsCol, nsLength;
+    unsigned int nsID, memCt, memOffset, memTypeCt, pointSym, nsCol, nsLength;
     void print();
                                  Tqdcfr* instance,
                                  NodesetHeader *&entity_headers);
@@ -191,13 +191,13 @@
   class SidesetHeader
   public:
-    int ssID, memCt, memOffset, memTypeCt, numDF, ssCol, useShell, ssLength;
+    unsigned int ssID, memCt, memOffset, memTypeCt, numDF, ssCol, useShell, ssLength;
     void print();
                                  Tqdcfr* instance,
                                  SidesetHeader *&entity_headers);
@@ -214,7 +214,7 @@
     ~ModelEntry();
-    int modelHandle, modelOffset, modelLength, modelType, modelOwner, modelPad;
+    unsigned int modelHandle, modelOffset, modelLength, modelType, modelOwner, modelPad;
     FEModelHeader feModelHeader;
     GeomHeader *feGeomH;
@@ -229,23 +229,23 @@
     void print_geom_headers(const char *prefix,
                             GeomHeader *header,
-                            int num_headers);
+                            unsigned int num_headers);
     void print_group_headers(const char *prefix,
-                             const int num_headers);
+                             const unsigned int num_headers);
     void print_block_headers(const char *prefix,
     void print_nodeset_headers(const char *prefix,
     void print_sideset_headers(const char *prefix,
     MBErrorCode read_header_info( Tqdcfr* instance, const double data_version);
     MBErrorCode read_metadata_info(Tqdcfr *tqd);
@@ -253,11 +253,11 @@
   enum {aBODY, LUMP, SHELL, FACE, LOOP, COEDGE, aEDGE, aVERTEX, ATTRIB, UNKNOWN};
-  const int *ACIS_DIMS;
+  const unsigned int *ACIS_DIMS;
   struct AcisRecord
-    int rec_type;
+    unsigned int rec_type;
     std::string att_string;
     bool processed;
     int first_attrib;
@@ -280,7 +280,7 @@
   std::map<int, MBEntityHandle> uidSetMap;
   std::map<int, MBEntityHandle> gidSetMap[6];
-  std::vector<int> int_buf;
+  std::vector<unsigned int> int_buf;
   std::vector<double> dbl_buf;
   std::vector<char> char_buf;
@@ -300,31 +300,31 @@
   MBErrorCode read_block(const double data_version,
                   ModelEntry *model,
                   BlockHeader *blockh);
-  MBErrorCode read_group(const int gr_index,
+  MBErrorCode read_group(const unsigned int gr_index,
                          ModelEntry *model,
                          GroupHeader *grouph);
-  MBErrorCode read_nodes(const int gindex,
+  MBErrorCode read_nodes(const unsigned int gindex,
                   ModelEntry *model,
                   GeomHeader *entity);
   MBErrorCode read_elements(ModelEntry *model,
   MBErrorCode read_file_header();
   MBErrorCode read_model_entries();
-  int find_model(const int model_type);
-  MBErrorCode read_meta_data(const int metadata_offset,
+  int find_model(const unsigned int model_type);
+  MBErrorCode read_meta_data(const unsigned int metadata_offset,
                       MetaDataContainer &mc);
   MBErrorCode read_md_string(std::string &name);
   enum {mesh, acist, acisb, facet, exodusmesh};
-  MBEntityType type_from_cub_type(const int cub_type, const int nodes_per_elem);
-  void check_contiguous(const int num_ents, int &contig, int &max_id);
+  MBEntityType type_from_cub_type(const unsigned int cub_type, const unsigned int nodes_per_elem);
+  void check_contiguous(const unsigned int num_ents, long &contig, long &max_id);
   Tqdcfr(MBInterface *impl);
   static std::string BLOCK_NODESET_OFFSET_TAG_NAME;
   static std::string BLOCK_SIDESET_OFFSET_TAG_NAME;
-  MBErrorCode create_set( MBEntityHandle& h, int flags = MESHSET_SET );
+  MBErrorCode create_set( MBEntityHandle& h, unsigned int flags = MESHSET_SET );
 private:
@@ -334,7 +334,7 @@
   MBErrorCode read_acis_records( const char* sat_file_name = 0 );
-  MBErrorCode parse_acis_attribs(const int entity_rec_num,
+  MBErrorCode parse_acis_attribs(const unsigned int entity_rec_num,
                           std::vector<AcisRecord> &records);
   MBErrorCode interpret_acis_records(std::vector<AcisRecord> &records);
@@ -374,25 +374,25 @@
     //! get entities with individually-specified types; if is_group is false,
     //! increment each mem_type by 2 since they're CSOEntityType's and not group types
-  MBErrorCode get_entities(const int *mem_types,
+  MBErrorCode get_entities(const unsigned int *mem_types,
                            std::vector<MBEntityHandle> &entities);
     //! get entities specified by type and ids, append to entities
-  MBErrorCode get_entities(const int this_type,
+  MBErrorCode get_entities(const unsigned int this_type,
                            std::vector<MBEntityHandle> &excl_entities);
     //! get ref entity sets with specified type and ids
-  MBErrorCode get_ref_entities(const int this_type,
+  MBErrorCode get_ref_entities(const unsigned int this_type,
+                               unsigned int *id_buf, const unsigned id_buf_size,
     //! get mesh entities with specified type and ids
-  MBErrorCode get_mesh_entities(const int this_type,
+  MBErrorCode get_mesh_entities(const unsigned int this_type,
@@ -404,7 +404,7 @@
                                  Tqdcfr::SidesetHeader *sideseth);
   MBErrorCode process_sideset_11(std::vector<MBEntityHandle> &ss_entities,
     // put entities into the specfied set, and excluded entities into a
