[MOAB-dev] r1506 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Thu Jan 3 16:59:36 CST 2008
Author: tautges
Date: 2008-01-03 16:59:36 -0600 (Thu, 03 Jan 2008)
New Revision: 1506
Modified:
MOAB/trunk/parallel/ReadParallel.cpp
Log:
Adding debug output. Also, only do an MPI broadcast if # procs > 1 (running on one proc allows profiling).
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2008-01-03 21:04:34 UTC (rev 1505)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2008-01-03 22:59:36 UTC (rev 1506)
@@ -159,6 +159,9 @@
switch (*vit) {
case PA_READ:
+ if (debug)
+ std::cout << "Reading file " << file_name << std::endl;
reader = impl->reader_writer_set()->
get_file_extension_reader( file_name );
if (reader)
@@ -205,6 +208,9 @@
case PA_GET_FILESET_ENTS:
+ if (debug)
+ std::cout << "Getting fileset entities." << std::endl;
if (0 == file_set_tag) {
tmp_result = mbImpl->tag_get_handle("FILE_SET", file_set_tag);
if (MB_SUCCESS == tmp_result) {
@@ -241,7 +247,12 @@
case PA_BROADCAST:
// do the actual broadcast; if single-processor, ignore error
- tmp_result = pcom.broadcast_entities( reader_rank, entities );
+ if (debug)
+ std::cout << "Broadcasting mesh." << std::endl;
+ if (mbImpl->proc_size() > 1)
+ tmp_result = pcom.broadcast_entities( reader_rank, entities );
if (debug) {
std::cerr << "Bcast done; entities:" << std::endl;
mbImpl->list_entities(0, 0);
@@ -250,6 +261,9 @@
case PA_DELETE_NONLOCAL:
+ if (debug)
+ std::cout << "Deleting nonlocal entities." << std::endl;
tmp_result = delete_nonlocal_entities(partition_tag_name,
partition_tag_vals,
distrib,
@@ -258,6 +272,9 @@
case PA_CHECK_GIDS_SERIAL:
+ if (debug)
+ std::cout << "Checking global ids." << std::endl;
tmp_result = pcom.check_global_ids(file_set, 0, 1, true, false);
break;
@@ -321,8 +338,8 @@
if (distribute) {
MBRange tmp_sets;
// distribute the partition sets
- int num_sets = partition_sets.size() / proc_sz, orig_numsets = num_sets;
- if (proc_rk < partition_sets.size() % proc_sz) num_sets++;
+ int num_sets = partition_sets.size() / proc_sz;
+ if (proc_rk < (int) (partition_sets.size() % proc_sz)) num_sets++;
// cut them in half if we're on one proc
if (proc_sz == 1 && num_partsets == num_sets) num_sets /= 2;
@@ -345,10 +362,7 @@
MBEntityHandle file_set)
- if (debug) std::cerr << "Deleting non-local entities." << std::endl;
MBErrorCode result;
- MBError *merror = ((MBCore*)mbImpl)->get_error_handler();
// get partition entities and ents related to/used by those
// get ents in the partition
@@ -356,6 +370,9 @@
MBReadUtilIface *read_iface;
mbImpl->query_interface(iface_name, reinterpret_cast<void**>(&read_iface));
MBRange partition_ents, all_sets;
+ if (debug) std::cout << "Gathering related entities." << std::endl;
result = read_iface->gather_related_ents(partition_sets, partition_ents,
&all_sets);
RR("Failure gathering related entities.");
@@ -372,6 +389,8 @@
MBRange deletable_sets = all_sets.intersect(deletable_ents);
MBRange keepable_sets = all_sets.subtract(deletable_sets);
+ if (debug) std::cout << "Removing deletable entities from keepable sets." << std::endl;
// remove deletable ents from all keepable sets
for (MBRange::iterator rit = keepable_sets.begin();
rit != keepable_sets.end(); rit++) {
@@ -379,6 +398,8 @@
RR("Failure removing deletable entities.");
+ if (debug) std::cout << "Deleting deletable entities." << std::endl;
// delete sets, then ents
if (!deletable_sets.empty())
result = mbImpl->delete_entities(deletable_sets);
@@ -389,9 +410,6 @@
result = mbImpl->delete_entities(deletable_ents);
RR("Failure deleting entities in delete_nonlocal_entities.");
-// if (debug)
-// result = ((MBCore*)mbImpl)->check_adjacencies();
return result;
