[MOAB-dev] r1621 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Feb 27 16:32:48 CST 2008
Author: kraftche
Date: 2008-02-27 16:32:48 -0600 (Wed, 27 Feb 2008)
New Revision: 1621
Modified:
MOAB/trunk/TypeSequenceManager.cpp
Log:
fix possible allocation of handles past end of sequence
Modified: MOAB/trunk/TypeSequenceManager.cpp
--- MOAB/trunk/TypeSequenceManager.cpp 2008-02-27 22:32:28 UTC (rev 1620)
+++ MOAB/trunk/TypeSequenceManager.cpp 2008-02-27 22:32:48 UTC (rev 1621)
@@ -376,6 +376,14 @@
// if we overlap a data object, we must be entirely inside of it
return start + num_entities - 1 <= (*i)->data()->end_handle();
+#ifndef NDEBUG
+ if (i != begin()) {
+ const_iterator j = i;
+ --j;
+ assert( (*j)->end_handle() < start );
+#endif
// check if we fit in the block of free handles
if (start + num_entities > (*i)->start_handle()) // start + num + 1 >= i->start
@@ -387,7 +395,8 @@
if ((*i)->values_per_entity() != values_per_ent)
return false;
// if overlap, must be entirely contained
- return start >= data_out->start_handle();
+ return start >= data_out->start_handle() &&
+ start + num_entities - 1 <= data_out->end_handle();
// check if we overlap the data for the previous sequence
