[MOAB-dev] r1603 - MOAB/trunk/tools/dagmc
wilsonp at mcs.anl.gov
Wed Feb 20 20:48:22 CST 2008
Author: wilsonp
Date: 2008-02-20 20:48:22 -0600 (Wed, 20 Feb 2008)
New Revision: 1603
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/DagMC.hpp
Log:
Added capabality to set dagmc settings from the calling application.
Faceting tolerance must be determined early and passed to load_and_init().
Other settings can be set later using set_settings.
In MCNP(X), this is done by setting the faceting tolerance on the command line
and the others in the input file (RDUM, IDUM).
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2008-02-20 20:15:29 UTC (rev 1602)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2008-02-21 02:48:22 UTC (rev 1603)
@@ -231,7 +231,41 @@
+void DagMC::set_settings(int source_cell, int use_cad, int use_dist_limit,
+ double distance_tolerance) {
+ moabMCNPSourceCell = source_cell;
+ if (moabMCNPSourceCell < 0) {
+ std::cerr << "Invalid source_cell = " << moabMCNPSourceCell << std::endl;
+ exit(2);
+ std::cout << "Set Source Cell = " << moabMCNPSourceCell << std::endl;
+ distanceTolerance = distance_tolerance;
+ if (distanceTolerance <= 0 || distanceTolerance > 1) {
+ std::cerr << "Invalid distance_tolerance = " << distanceTolerance << std::endl;
+ exit(2);
+ std::cout << "Set distance tolerance = " << distanceTolerance << std::endl;
+ moabMCNPUseDistLimit = !!(use_dist_limit);
+ std::cout << "Turned " << (moabMCNPUseDistLimit?"ON":"OFF") << " distance limit." << std::endl;
+ useCAD = !!(use_cad);
+ std::cout << "Turned " << (useCAD?"ON":"OFF") << " ray firing on full CAD model." << std::endl;
+#ifdef CUBIT_CGM
+ if (useCAD) {
+ std::cout << "Warning: use_cad = 1 not supported with this build of "
+ << "CGM/DagMC;" << std:: endl
+ << "need an ACIS-based install of CGM." << std::endl;
+#endif
void DagMC::read_settings( const char* filename )
int num_opt = sizeof(options) / sizeof(options[0]);
@@ -795,9 +829,10 @@
MBErrorCode DagMC::load_file_and_init(const char* cfile,
- const int clen,
- const char* ffile,
- const int flen)
+ const int clen,
+ const char* ffile,
+ const int flen,
+ const double facet_tolerance)
// Always do this first to make sure we have at least the
// default values if noone ever calls read_settings(). If
@@ -805,6 +840,9 @@
// re-parse the same values.
read_settings(0);
+ if (facet_tolerance > 0 )
+ facetingTolerance = facet_tolerance;
MBErrorCode rval;
std::string scfile = cfile;
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2008-02-20 20:15:29 UTC (rev 1602)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2008-02-21 02:48:22 UTC (rev 1603)
@@ -78,7 +78,8 @@
MBErrorCode load_file_and_init(const char* cfile,
const int clen,
const char* ffile,
- const int flen);
+ const int flen,
+ const double facet_tolerance = 0);
// map between MBEntityHandle, base-1 index, and GLOBAL_ID
MBEntityHandle entity_by_index( int dimension, int index );
@@ -95,6 +96,8 @@
void read_settings( const char* filename );
void write_settings( FILE* filp, bool with_description = true );
void parse_settings();
+ void set_settings(int source_cell, int use_cad, int use_dist_limit,
+ double distance_tolerance);
char *get_spec_reflect();
char *get_white_reflect();
@@ -146,7 +149,7 @@
double discard_dist_tol() {return discardDistTol;}
double faceting_tolerance() {return facetingTolerance;}
int source_cell() {return moabMCNPSourceCell;}
bool use_dist_limit() {return moabMCNPUseDistLimit;}
