[MOAB-dev] r1585 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Feb 5 11:41:18 CST 2008
Author: kraftche
Date: 2008-02-05 11:41:18 -0600 (Tue, 05 Feb 2008)
New Revision: 1585
Modified:
MOAB/trunk/TestUtil.hpp
Log:
Remove #include<setjmp.h>: should be withing a #ifdef, and was.
Add comments.
Modified: MOAB/trunk/TestUtil.hpp
--- MOAB/trunk/TestUtil.hpp 2008-02-05 17:17:26 UTC (rev 1584)
+++ MOAB/trunk/TestUtil.hpp 2008-02-05 17:41:18 UTC (rev 1585)
@@ -33,6 +33,10 @@
// Use signal handler and long jumps to return error state to test runner.
// Might be portable to Windows (not sure). Possibly undefined behavior (e.g. continuing
// with next test after catching segfault is technically undefined behavior.)
+// Also, tests can corrupt heap memory management, interferring with later tests.
+// Leaks memory on test failure (no stack unwind). This is actually a feature, as
+// we don't care too much about tests leaking memory and trying to reconver memory
+// might make things worse, depending on why the test failed.
#define LONGJMP_MODE 3
// If test application hasn't set MODE, set to default
@@ -53,17 +57,29 @@
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
-#include <setjmp.h>
+ * Define What to do when a test fails.
+// For EXCEPTION_MODE, throw an exception when a test fails.
+// This will unwind stack, recover memory, etc.
#if MODE == EXCEPTION_MODE
struct ErrorExcept{};
# define FLAG_ERROR throw ErrorExcept()
+// For FORK_MODE, the test is running in its own processs. Just
+// terminate the process with a non-zero exit code when the test
+// fails.
#elif MODE == FORK_MODE
# include <sys/types.h>
# include <sys/wait.h>
# include <unistd.h>
# include <errno.h>
# define FLAG_ERROR exit(1)
+// For LONGJMP_MODE, we do a long jump to just before the test is
+// run, with a return value of -1 to indicate failures (positive
+// return codes are used if the test caused a segfault or other
+// signal.)
#elif MODE == LONGJMP_MODE
# include <signal.h>
# include <setjmp.h>
@@ -72,9 +88,18 @@
# error "MODE not set"
#endif
+ * Setup for LONGJMP_MODE
#if MODE == LONGJMP_MODE
+// Variable to hold stack state for longjmp
sigjmp_buf jmpenv;
+// Define signal handler used to catch errors such as segfaults.
+// Signal handler does longjmp with the signal number as the
+// return value.
extern "C" {
void sighandler( int sig ) {
signal( sig, sighandler );
@@ -84,15 +109,21 @@
typedef void (*sigfunc_t)(int);
} // extern "C"
+// Helper function to register signal handlers.
int sethandler( int sig ) {
sigfunc_t h = signal( sig, &sighandler );
if (h == SIG_ERR)
return 1;
+ // If user-defined signal handler (or signal is ignored),
+ // than unregister our handler.
else if (h != SIG_DFL)
signal( sig, h );
return 0;
+// Register signal handlers for all defined signals that typicall result
+// in process termination.
int init_signal_handlers()
int result = 0;
@@ -147,13 +178,18 @@
return result;
-// initialize global to force call to init_signal_handlers
+// Declare a garbage global variable. Use variable initialization to
+// force call to init_signal_handlers().
int junk_init_var = init_signal_handlers();
#endif // LONGJMP_MODE
+ * The Code to Run Tests
/* Make sure IS_BUILDING_MB is defined so we can include MBInternals.hpp */
#include "MBTypes.h"
#ifndef IS_BUILDING_MB
@@ -225,15 +261,25 @@
+ // Save stack state at this location.
int rval = sigsetjmp( jmpenv, 1 );
+ // If rval is zero, then we haven't run the test yet.
+ // If rval is non-zero then
+ // a) we ran the test
+ // b) the test failed
+ // c) we did a longjmp back to the location where we called setsigjmp.
+ // run test
if (!rval) {
(*test)();
return 0;
+ // some check failed
else if (rval == -1) {
printf( " %s: FAILED\n", func_name );
return 1;
+ // a signal was raised (e.g. segfault)
else {
printf( " %s: TERMINATED (signal %d)\n", func_name, rval );
return 1;
@@ -244,6 +290,12 @@
+ * CHECK_EQUAL implementations
+// Common implementatation for most types
#define EQUAL_TEST_IMPL( TEST, TYPE ) if( !(TEST) ) { \
printf( "Equality Test Failed: %s == %s\n", sA, sB ); \
printf( " at line %d of '%s'\n", line, file ); \
@@ -296,6 +348,8 @@
+// Special case for MBErrorCode, use mb_error_str() to print the
+// string name of the error code.
void check_equal( MBErrorCode A, MBErrorCode B, const char* sA, const char* sB, int line, const char* file )
if (A == B)
