[MOAB-dev] r1581 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Feb 4 15:08:16 CST 2008
Author: kraftche
Date: 2008-02-04 15:08:15 -0600 (Mon, 04 Feb 2008)
New Revision: 1581
Modified:
MOAB/trunk/MBCore.hpp
Log:
forgot to check in MBCore.hpp changes corresponding to previous MBInterface.hpp and MBCore.cpp changes
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2008-02-04 21:07:27 UTC (rev 1580)
+++ MOAB/trunk/MBCore.hpp 2008-02-04 21:08:15 UTC (rev 1581)
@@ -618,6 +618,29 @@
const void* def_val,
bool use_existing);
+ /**\brief Define a new tag that can store variable-length data.
+ * Define a new tag for storing application-defined data on MB entities.
+ * \param name The name of the tag.
+ * \param storage The tag storage type (MB_TAG_BIT not supported).
+ * \param data_type The tag data type.
+ * \param handle_out The tag handle (output)
+ * \param default_value Optional default value for tag.
+ * \param default_val_len Length of default value. Required if
+ * default value is specified.
+ * \return - MB_ALREADY_ALLOCATED if a tag with name already exists.
+ * - MB_FAILURE if inconsistant arguments
+ * - MB_SUCCESS otherwise.
+ virtual MBErrorCode tag_create_variable_length( const char* name,
+ MBTagType storage,
+ MBDataType data_type,
+ MBTag& handle_out,
+ const void* default_value = 0,
+ int default_val_len = 0
//! Gets the tag name string of the tag_handle.
/** \param tag_handle MBTag you want the name of.
\param tag_name Name string of <em>tag_handle</em>.
