[MOAB-dev] r2471 - MOAB/trunk/m4
kraftche at mcs.anl.gov
Thu Dec 4 13:47:25 CST 2008
Author: kraftche
Date: 2008-12-04 13:47:25 -0600 (Thu, 04 Dec 2008)
New Revision: 2471
Modified:
MOAB/trunk/m4/hdf5.m4
Log:
second attempt to work around m4 wierdness
Modified: MOAB/trunk/m4/hdf5.m4
--- MOAB/trunk/m4/hdf5.m4 2008-12-04 19:32:30 UTC (rev 2470)
+++ MOAB/trunk/m4/hdf5.m4 2008-12-04 19:47:25 UTC (rev 2471)
@@ -138,23 +138,25 @@
HAVE_LIB_HDF5=no
AC_CHECK_LIB( [$HDF5_LIBNAME], [H5Fopen], [HAVE_LIB_HDF5=yes] )
- cv_name="ac_cv_lib_${HDF5_LIBNAME}_H5Fopen"
if test $HAVE_LIB_HDF5 = no; then
if test $HAVE_ZLIB = yes; then
- unset '$cv_name'
- AC_CHECK_LIB( [$HDF5_LIBNAME], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="$HDF5_LIBS -lz"], [], [-lz] )
+ unset "ac_cv_lib_${HDF5_LIBNAME}_H5Fopen"
+ unset "ac_cv_lib_${HDF5_LIBNAME}___H5Fopen"
+ AC_CHECK_LIB( [${HDF5_LIBNAME}], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="$HDF5_LIBS -lz"], [], [-lz] )
fi
fi
if test $HAVE_SZIP = yes; then
- unset '$cv_name'
AC_CHECK_LIB( [$HDF5_LIBNAME], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="$HDF5_LIBS -lsz"], [], [-lsz] )
fi
fi
- unset '$cv_name'
AC_CHECK_LIB( [$HDF5_LIBNAME], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="$HDF5_LIBS -lsz -lz"], [], [-lz -lsz] )
fi
fi
