[MOAB-dev] r2305 - in MOAB/trunk: . test/h5file
kraftche at mcs.anl.gov
Wed Dec 3 12:17:53 CST 2008
Author: kraftche
Date: 2008-12-03 12:17:52 -0600 (Wed, 03 Dec 2008)
New Revision: 2305
Added:
MOAB/trunk/test/h5file/h5regression.cpp
Modified:
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/test/h5file/Makefile.am
MOAB/trunk/test/h5file/h5sets_test.cpp
Log:
o Make HDF5 writer fail if element connectivity list contains invalid
vertex handles (better to fail when writing than when reading.)
o Add test to verify that writer fails for invalid connectivity.
o Fix bug in existing test (missing return value from 'main')
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2008-12-03 18:16:20 UTC (rev 2304)
+++ MOAB/trunk/WriteHDF5.cpp 2008-12-03 18:17:52 UTC (rev 2305)
@@ -772,7 +772,8 @@
iter = next;
for (long i = 0; i < count*nodes_per_elem; ++i)
- buffer[i] = idMap.find( buffer[i] );
+ if (0 == (buffer[i] = idMap.find( buffer[i] )))
+ return MB_FAILURE;
mhdf_writeConnectivity( elem_table, offset, count,
id_type, buffer, &status );
Modified: MOAB/trunk/test/h5file/Makefile.am
--- MOAB/trunk/test/h5file/Makefile.am 2008-12-03 18:16:20 UTC (rev 2304)
+++ MOAB/trunk/test/h5file/Makefile.am 2008-12-03 18:17:52 UTC (rev 2305)
@@ -1,6 +1,6 @@
DEFS = $(DEFINES)
INCLUDES += -I$(top_srcdir) -I$(top_srcdir)/mhdf/include -I$(top_builddir)
-check_PROGRAMS = h5test h5legacy h5varlen h5sets_test
+check_PROGRAMS = h5test h5legacy h5varlen h5sets_test h5regression
TESTS = $(check_PROGRAMS)
LDADD = $(top_builddir)/libMOAB.la
@@ -9,3 +9,4 @@
h5legacy_SOURCES = h5legacy.cpp
h5varlen_SOURCES = h5varlen.cpp
h5sets_test_SOURCES = h5sets_test.cpp
+h5regression_SOURCES = h5regression.cpp
Added: MOAB/trunk/test/h5file/h5regression.cpp
--- MOAB/trunk/test/h5file/h5regression.cpp (rev 0)
+++ MOAB/trunk/test/h5file/h5regression.cpp 2008-12-03 18:17:52 UTC (rev 2305)
@@ -0,0 +1,65 @@
+#include "MBCore.hpp"
+#include "testdir.h"
+#include "TestUtil.hpp"
+#include "MBRange.hpp"
+#include "MBReadUtilIface.hpp"
+#include "WriteHDF5.hpp"
+#include "FileOptions.hpp"
+#include <algorithm>
+#include <iostream>
+#include <stdlib.h>
+#include <math.h>
+const char filename[] = "bad.h5m";
+void test_write_invalid_elem();
+int main(int argc, char* argv[])
+ int exitval = 0;
+ exitval += RUN_TEST( test_write_invalid_elem );
+ return exitval;
+ MBCore mbcore;
+ MBInterface& moab = mbcore;
+ MBReadUtilIface* readtool = 0;
+ MBErrorCode rval;
+ void* ptr = 0;
+ rval = moab.query_interface( "MBReadUtilIface", &ptr );
+ CHECK_ERR(rval);
+ CHECK( ptr != 0 );
+ readtool = reinterpret_cast<MBReadUtilIface*>(ptr);
+ // create two nodes
+ MBEntityHandle first_node;
+ std::vector<double*> coords;
+ rval = readtool->get_node_arrays( 3, 2, 1, first_node, coords );
+ CHECK_ERR(rval);
+ coords[0][0] = coords[0][1] = 0.0;
+ coords[1][0] = coords[1][1] = 0.0;
+ coords[2][0] = coords[2][1] = 0.0;
+ // create a triangle with an invalid node handle for its
+ // third vertex
+ MBEntityHandle tri;
+ MBEntityHandle* conn = 0;
+ rval = readtool->get_element_array( 1, 3, MBTRI, 1, tri, conn );
+ CHECK_ERR(rval);
+ conn[0] = first_node; // valid
+ conn[1] = first_node+1; // valid
+ conn[2] = first_node+2; // invalid
+ // try to write the file (should fail)
+ WriteHDF5 writer( &moab );
+ FileOptions opts(0);
+ rval = writer.write_file( filename, true, opts, 0, 0, std::vector<std::string>() );
+ CHECK(MB_SUCCESS != rval);
Modified: MOAB/trunk/test/h5file/h5sets_test.cpp
--- MOAB/trunk/test/h5file/h5sets_test.cpp 2008-12-03 18:16:20 UTC (rev 2304)
+++ MOAB/trunk/test/h5file/h5sets_test.cpp 2008-12-03 18:17:52 UTC (rev 2305)
@@ -132,6 +132,7 @@
int exitval = 0;
exitval += RUN_TEST( test_ranged_set_with_holes );
exitval += RUN_TEST( test_file_set );
+ return exitval;
