[MOAB-dev] r2300 - MOAB/trunk/tools/tagprop
kraftche at mcs.anl.gov
Tue Dec 2 23:45:07 CST 2008
Author: kraftche
Date: 2008-12-02 23:45:07 -0600 (Tue, 02 Dec 2008)
New Revision: 2300
Modified:
MOAB/trunk/tools/tagprop/parse.cpp
MOAB/trunk/tools/tagprop/propagate_tags.cpp
Log:
Try to clean up help:
o Re-write and/or reformat much of help text for clarity and to
fix spelling/typing errors.
o Print only a brief description if run with no arguments
(only print full help for '-h' option.)
o For '-h' option, send all help output to std::cout rather than
std::cerr so that it can be easily piped through a pager
(e.g. the 'more' utility.)
o Fix broken parsing of '-h' flag.
Modified: MOAB/trunk/tools/tagprop/parse.cpp
--- MOAB/trunk/tools/tagprop/parse.cpp 2008-12-03 05:42:17 UTC (rev 2299)
+++ MOAB/trunk/tools/tagprop/parse.cpp 2008-12-03 05:45:07 UTC (rev 2300)
@@ -8,26 +8,32 @@
void tag_syntax( std::ostream& s )
- s << "Tags are specified as <name>=[value], where the tag value is "
- "optional."
- "For opaque tags, a numeric value may be specified in hexadecimal "
- "with a '0x' prefix. If the value does not begin with the '0x' "
- "prefix, it will be treated as a string (not a numerical value) "
- "and padded with NULL characters to fit the tag size." << std::endl
- << "For integral types (INTEGER, BIT, and HANDLE), values "
- "are parsed as integers with the standard 0x and 0 prefixes for "
- "hexidecimal and octal bases, respectively." << std::endl
- << "DOUBLE types must be specified in base-10. Exponential "
- "syntax (e) is accepted." << std::endl
- << "If the tag is not opaque and is an array of values, the values "
- "must be specified as a comma-separated list w/out spaces."
+ s << "Tags are specified as <name>=[value], where the tag value " << std::endl
+ << "is optional." << std::endl
+ << std::endl
+ << "Values of integral types (INTEGER, BIT, and HANDLE) are " << std::endl
+ << "specified using standard C integer notation (a 0x prefix " << std::endl
+ << "for hexidecimal, 0 prefix for octal, and no prefix for " << std::endl
+ << "decimal.) The value of an opaque tag is interpreted as " << std::endl
+ << "either a integral value or a character string. If the tag " << std::endl
+ << "value begins with the prefix 0x it will be interpreted as a " << std::endl
+ << "hexidecimal (base-16) number. If the value does not begin " << std::endl
+ << "with the 0x prefix, it is interpreted as a character string." << std::endl
+ << "Characater strings will be padded with null characters as" << std::endl
+ << "necessary to fill the tag." << std::endl
+ << "Floating-point (real) values must be specified in base-10." << std::endl
+ << "C exponential notation (e.g. 1e-10) is accepted." << std::endl
+ << std::endl
+ << "If the tag is an array of integral or floating-point values " << std::endl
+ << "then the tag value must be specified as a comma-separated " << std::endl
+ << "list, with NO spaces." << std::endl
+ << std::endl
+ << "Tags are created with the syntax name=type:size[=default_value]." << std::endl
+ << "where type is one of {int,double,opaque,handle,bit} and size is " << std::endl
+ << "the number of values of the specified type, or the number of " << std::endl
+ << "bytes if the type is 'opaque', A default value for the tag may " << std::endl
+ << "be specified."
<< std::endl;
- s << "Tags are created with the form name=type:size[=default_value] "
- "where type is one of {int,double,opaque,handle,bit} and size is "
- "the number of values of the specified type, or the number of "
- "bytes if the type is 'opaque', A default value for the tag make "
- "be specified."
- << std::endl;
// Check endian-ness of platform. Used when parsing numerical
Modified: MOAB/trunk/tools/tagprop/propagate_tags.cpp
--- MOAB/trunk/tools/tagprop/propagate_tags.cpp 2008-12-03 05:42:17 UTC (rev 2299)
+++ MOAB/trunk/tools/tagprop/propagate_tags.cpp 2008-12-03 05:45:07 UTC (rev 2300)
@@ -48,48 +48,76 @@
MBInterface* iface = 0;
const char* exe_name = 0;
-void usage( )
+void usage( bool error = true )
- std::cerr << "Usage: " << exe_name << " <options> <input_file> <output_file>" << std::endl
- << "Options: " << std::endl
- << " -t <ident_tag>[=<value>] " << std::endl
- << " -d <data_tag>[=<default>] " << std::endl
- << " -c <data_tag=type:size>[=defult] " << std::endl
- << " -w <write_tag> " << std::endl
- << " -n|-e " << std::endl
- << std::endl
- << "At least one ident_tag must be specified. This tag will be used to "
- "select entity sets to process. If more than one ident_tag is "
- "specified, entity sets that match A\bAN\bNY\bY the specified tags "
- "will be selected (logical OR). A tag value to match may optionally "
- "be specified for each ident_tag. " << std::endl << std::endl
- << "The data_tag is the tag on the selected entity sets for which the "
- "value should be propogated to the contained mesn entities. If no "
- "data_tag is specified, the value of the ident_tag will be used. If "
- "multiple ident_tags are specified, the data_tag must be specified "
- "explicitly. If the data tag is specified with the '-d' option, the "
- "tag must exist and the optional value will be set on any entiites for "
- "which the owning set doesn't have the data_tag defined. If the data_tag "
- "is specified with the '-c' option, the tag will be created." << std::endl << std::endl
- << "If the write_tag is specified, the tag propogated to the mesh "
- "entities contained in the set will be given this name. If no "
- "write_tag is specified, the data_tag will be used." << std::endl << std::endl
- << "If -\b-n\bn is specified, the tag values will be propogated only "
- "to nodes contained in the identified sets. If -\b-e\be is specified, "
- "the tags will be propogated to the contained elements. If neither is "
- "specified, the default is both." << std::endl << std::endl
- << "The syntax for specifying tag values is as follows: " << std::endl;
- tag_syntax(std::cerr);
- std::cerr << std::endl;
- exit(1);
+ std::ostream& s = error ? std::cerr : std::cout;
+ s << "Usage: " << exe_name << " <options> <input_file> <output_file>" << std::endl
+ << " " << exe_name << " -h" << std::endl
+ << "Options: " << std::endl
+ << " -t <ident_tag>[=<value>] " << std::endl
+ << " -d <data_tag>[=<default>] " << std::endl
+ << " -c <data_tag=type:size>[=defult] " << std::endl
+ << " -w <write_tag> " << std::endl
+ << " -n|-e " << std::endl
+ << std::endl;
+ if (error) {
+ s << "Try '-h' for verbose help." << std::endl;
+ exit(1);
+ s << "This utility will write tag data to a subset of the mesh entities " << std::endl
+ << "contained in a file. The behavior is controlled by three main " << std::endl
+ << "properties:" << std::endl
+ << " 1) The ident_tag is used to identify sets of entities for which " << std::endl
+ << " data will be stored on each contained element or node. The -n " << std::endl
+ << " or -e flags can be used to restrict operation to only nodes or " << std::endl
+ << " elements, respectively." << std::endl
+ << " 2) The data_tag is used to identify which value to write on to " << std::endl
+ << " each entity. This is a tag on the set containing the entities." << std::endl
+ << " 3) The write_tag is the name of the tag that the data is stored in " << std::endl
+ << " on each mesh entity." << std::endl
+ << std::endl
+ << " -t : Specify an ident_tag. If a value is specified, only those " << std::endl
+ << " sets with the specified value are processed. At least one " << std::endl
+ << " ident_tag must be specified. Multiple ident_tags may be " << std::endl
+ << " specified, in which case any set that matches any of the " << std::endl
+ << " specified ident_tags will be processed (logical OR)." << std::endl
+ << std::endl
+ << " -d : Specify the data_tag. If multiple ident_tags are specified " << std::endl
+ << " then the data_tag must be specified. If only one ident_tag " << std::endl
+ << " is specified then the data_tag specification is optional." << std::endl
+ << " If no data_tag is specified, the value of the ident_tag " << std::endl
+ << " will be used. If a value is specified for the data_tag, " << std::endl
+ << " then the specified value will be used for any set that " << std::endl
+ << " doesn't have a value for the data_tag." << std::endl
+ << std::endl
+ << " -c : Similar to -d, except that the tag is created if it doesn't" << std::endl
+ << " already exist. If the tag is created, then all entities" << std::endl
+ << " receive the specified default value for the tag. In this " << std::endl
+ << " case it is an error if no default value is specified." << std::endl
+ << std::endl
+ << " -w : Specify the tag to create and store values in on mesh " << std::endl
+ << " entities. If no write_tag is specified, the data_tag " << std::endl
+ << " will be used." << std::endl
+ << std::endl
+ << " -n : Write tag data only on nodes (vertices)." << std::endl
+ << " -e : Write tag data only on elements." << std::endl
+ << std::endl
+ << "The syntax for specifying tag values is as follows: "
+ << std::endl << std::endl;
+ tag_syntax(s);
+ s << std::endl;
+ exit(0);
-void about( )
+void about( bool error = true )
- std::cerr << "A utility to propogate tag values from the entity sets "
- "containing mesh entities to the entities contained in "
- "those sets." << std::endl << std::endl;
- usage();
+ s << "A utility to propogate tag values from the entity sets "
+ "containing mesh entities to the entities contained in "
+ "those sets." << std::endl << std::endl;
+ usage(error);
void parse_error( const char* msg, const char* val = 0 )
@@ -120,11 +148,19 @@
if (argv[i][0] == '-')
- switch (argv[i][1]) { case 't': case 'c': case 'd': case 'w': ++i; }
- continue;
+ switch (argv[i][1]) {
+ case 't': case 'c': case 'd': case 'w':
+ ++i;
+ break;
+ case 'h':
+ usage(false);
+ break;
+ default:
+ parse_error( "Invalid option", argv[i] );
+ break;
- if (!input_name)
+ else if (!input_name)
input_name = argv[i];
else if (!output_name)
output_name = argv[i];
@@ -163,8 +199,6 @@
if (argv[i] == input_name || argv[i] == output_name)
continue;
- else if (!strcmp(argv[i],"-h"))
- usage();
else if (!strcmp(argv[i],"-n"))
nodes_spec = true;
else if (!strcmp(argv[i], "-e"))
