[MOAB-dev] MOAB question
Suzanne Shontz
shontz at cse.psu.edu
Tue Dec 2 22:38:35 CST 2008
Dear Jason & Tim,
Thanks for your very helpful responses. The solution suggested in the
"short answer" section did the trick. All I needed was the 0's and 1's to
mark vertices as fixed/free for Mesquite. (Although you'd be happy to
know that I read the long answer solution, too.)
-- Suzanne
On Tue, 2 Dec 2008, Jason Kraftcheck wrote:
> Tim Tautges wrote:
>> Only have time for a quick answer just now, but you should use mbtagprop to
>> propagate sets (which are used to represent cubit blocks/nodesets/sidesets)
>> to tags (variables on indiv mesh entities representing same thing).
>> - tim
>> Suzanne Shontz wrote:
>>> Dear Tim:
>>> I've been using MOAB to convert some hex meshes from the Exodus II file
>>> format (they're meshes generated with CUBIT) to the VTK file format.
>>> The outputted VTK files contain information on the vertex coordinates and
>>> the hex elements. However, they do not contain information as to
>>> which vertices are/are not part of the surface (i.e., boundary). Is there
>>> an option within MOAB to write out this additional information? Note
>>> that I'm calling mbconvert as follows: mbconvert file.g file.vtk.
>>> Thanks in advance for your help,
>>> Suzanne
> Short answer:
> If all you want is to mark the boundary vertices as fixed so that they can be
> used as input to Mesquite, use the mbskin utility:
> mbskin -t -w file.g file.vtk
> Long answer:
> ExodusII files do not directly contain any information about which vertices
> are part of a geometric surface or which are on the skin of the mesh. To
> embed this information in an ExodusII file using Cubit you will need to
> create sidesets or nodesets containing the boundary of the mesh. Cubit will
> write those to the ExodusII file.
> Alternately, you could write a 'cub' file from Cubit, which will contain the
> grouping of mesh entities according to which geometric entities they lie on
> (surfaces, curves, etc.)
> VTK files have no mechanism by which to represent groups of entities. The
> best that can be done is to 'tag' (e.g. store an integer value on) each
> entity indicating the group it belongs to. The mbtagprop utility Tim
> mentioned can do such things. E.g. it can be used to write the ID of each
> geometric surface as a tag on each vertex that is constrained to lie on that
> surface.
> If you have an ExodusII file containing nodesets (dirichlet sets) and you
> want to store on each node the ID of the nodeset it is contained in, I think
> the following will work:
> mbtagprop -t DIRCHLET_SET -n file.g file.vtk
> If instead you want to write a '1' to a tag named 'fixed' for every node
> contained in a nodeset, then I think the following syntax will work:
> mbtagprop -t DIRICHLET_SET -c fixed=integer:1=1 -n file.g file.vtk
> - jason
