[MOAB-dev] r2052 - in MOAB/trunk: . tools/mbzoltan
de Almeida, Valmor F. dealmeidav at ornl.gov
Fri Aug 29 14:14:53 CDT 2008
That solves it
configure: WARNING: Expect --with-zoltan-arch with --with-zoltan
configure: WARNING: "Guessing '/usr/local/zoltan/lib'"
checking zoltan_cpp.h usability... yes
checking zoltan_cpp.h presence... yes
checking for zoltan_cpp.h... yes
checking for Zoltan_LB_Partition in -lzoltan... no
checking for Zoltan_LB_Partition in -lzoltan... yes
Valmor
> -----Original Message-----
> From: owner-moab-dev at mcs.anl.gov [mailto:owner-moab-dev at mcs.anl.gov]
On
> Behalf Of kraftche at mcs.anl.gov
> Sent: Friday, August 29, 2008 12:52 PM
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] r2052 - in MOAB/trunk: . tools/mbzoltan
> Author: kraftche
> Date: 2008-08-29 11:51:46 -0500 (Fri, 29 Aug 2008)
> New Revision: 2052
> Modified:
>    MOAB/trunk/configure.in
>    MOAB/trunk/tools/mbzoltan/Makefile.am
> Log:
> Overhaul Zoltan configuration/detection:
>   - require no options if Zoltan and Parmetis are in default search
path
>   - require --with-zoltan-arch only when necessary to disambiguate
between
>      mulitple Obj_$ARCH directories.
>   - detect whether or not Zoltan requires Parmetis (don't require
Parmetis
>      if Zoltan doesn't.)
> This problably needs more work.  Zoltan can also optionally depend on
> other libraries (e.g. PaToH and Nemesis) that we don't handle.
