[MOAB-dev] Re: General iMesh usage
Jason Kraftcheck
kraftche at cae.wisc.edu
Tue Aug 12 14:46:05 CDT 2008
Neil Hodge wrote:
> Jason:
> I tried to subscribe to the mailing list, but I have gotten no response,
I don't think you need to subscribe to the list to be able to send messages
to it.
> and I don't have very long to get the first cut of this implemented, so
> I thought I would ask you a few questions:
> 1) Is there a nice example of _writing out_ a mesh available somewhere?
> Fortran90 would be nice, but C would be ok too.
Not that I know of.
> 2) If not, then, how does one write a mesh? I am guessing the following:
> * iMesh_createEntSet
I'm not sure why you want to do that.
> * iMesh_createVtxArr
> * iMesh_createEntArr
> This is really non-obvious . . .
> Does this need to be called twice (or more), once for POINTs,
createVtxArr will create vertices.
> and once for HEXAHEDRONs, (or more, once for each intermediate
> topology), or can hexes be defined directly in terms of vertices.
hexes can be defined by specifying vertices in canonical (PATRAN/Exodus II)
ordering or by intermediate entities such as edges or quads.
> Also, how are hexes defined, i.e., what does
> "lower_order_entity_handles" look like for hexes?
The concatenation of the lists of lower-order entities (e.g vertices)
defining each hex.
> * iMesh_addEntArrToSet
> Do the vertices need to be added to the entity set as well?
> I would imagine so, since this is the only place that I see
> coordinates being defined.
I don't know. What do you want the entity set for? If it is only to pass
to iMesh_save, then just pass in the result of iMesh_getRootSet (unless you
only want to save a subset of the mesh.)
- jason
